Drivetrain CAI for R56 (home made)
Old Jul 11, 2007 | 10:17 AM
  #201
Klasse Act's Avatar
Klasse Act
Originally Posted by dorkboy
k@rtm@n, honestly for the $25 and the 15 minutes it takes to do this mod. You will love it! Everybody here has tried it and it rocks! I personally love the sound, it's great.
And if you don't like it, then return the $25 filter and within an hour you will have your own results!
Good luck.
I agree 100%, this mod sounds/performs great
Old Jul 11, 2007 | 04:54 PM
  #202
dwjj's Avatar
dwjj
Originally Posted by thlaxx
here how you remove the hood scoop incase anyone wants it.
"unscrew the two screws on the left and right that are visible, looking from the engine-->out. Then look up at the hood, dead center, you see that plastic plug? Pull it out, underneath it is another star drive screw, you need to take that out before the hood scoop piece can come out.
once that screw is out, then lift firmly from the top of the hood while grabbing the hood scoop insert. it pops out, careful as there are little plastic
pins all around the scoop that hold it in.
then you can take the other two screws you could not get too and presto
the plastic insert comes out.
I put the screws back in so I wouldnt lose them, pressure fit the hood scoop
insert back into the hood, put that big star screw back in, put the plastic
plug back in and presto all done.
as for temperature of the engine, I dont think its hugely signifcant, but I do notice that the fan does not stay on or not as long as it use to when parking the car and turning the engine off. so its obviously helping.
but as from experience with lots of cars over the years, when driving in 115 degree texas heat, the more air flow you can get through the engine compartment the better off you are. It also reduces the heat build up
under the hood which is also good especially for all those rubber hoses and plastic pieces that are scattered all over the engine compartment.
its like anything else though, you dont have to do it if you dont want to, be skeptical all you want, but it helps, it works, and it doesnt hurt anything."
I was still a little confused. The two screws before the one under the plug can wait. They're much easier to access after.
If you remove the plug, the screw behind it, the scoop will pop up off the hood.
Then there are 4 screws holding the black grill to the scoop.
Then assembly is opposite of disassembly.
Old Jul 16, 2007 | 08:23 PM
  #203
dwjj's Avatar
dwjj
Got my K&N rx4990 today. Really only three screws to remove the airbox-I didn't have to remove the top cover. I used a long zip-tie to hold it to the top-right and keep it from moving around. Really interesting sound! Might even appease some of the "supercharger noise lover" crowd!
Old Jul 22, 2007 | 05:47 PM
  #204
SPDinNY's Avatar
SPDinNY
I wish you could hear it better...maybe I will take another video when its not raining http://www.youtube.com/watch?v=eN-r84co588
Old Jul 23, 2007 | 02:05 PM
  #205
bartbojo's Avatar
bartbojo
Less responsive...??
So I just installed the K&N rx4990...it fits and sounds great. However, my car lost the "pick up" it had with the stock air box!?!? It just feels less responsive after the K&N filter install....and yes, the scoop is open for fresh air, and filter is never very hot...even after driving 1hr+...
Any ideas???
I'm thinking the air/fuel ratio might be too lean...? Since the turbo already compresses extra air into the cylinder, adding even more air might be overkill??
Hmmm.
Old Jul 23, 2007 | 04:36 PM
  #206
SPDinNY's Avatar
SPDinNY
whats the temp outside today there bart?
Old Jul 23, 2007 | 04:41 PM
  #207
bartbojo's Avatar
bartbojo
well...been running it for a couple of days now, and its in the mid 70's here.
FYI...also started a new thread for this topic:
https://www.northamericanmotoring.co...d.php?t=108300
Old Jul 24, 2007 | 05:05 PM
  #208
bartbojo's Avatar
bartbojo
Those of you with this mod...might find the Alta quote I dug up on this thread very informational.
https://www.northamericanmotoring.co...=108300&page=2
Old Jul 24, 2007 | 08:20 PM
  #209
maxmini's Avatar
maxmini
Any ideas???
Hmmm.
It's just a guess but if it was too lean I think you would notice a increase in power not a loss. We did the K&N mod during part of our creative process for our CAI and if anything had a gain in power .The car with just a filter mod was able to out power a stage "2" car ( head , header , CAI etc ) easily . Just a thought , anyone with other theories ?
Old Jul 25, 2007 | 08:29 PM
  #210
prb44t's Avatar
prb44t
CAI just installed
Old Jul 26, 2007 | 06:20 AM
  #211
dwjj's Avatar
dwjj
I just pulled the o-ring off and keep it with my airbox. That gives you more flange to catch, and less chance of pulling it off.
Old Jul 26, 2007 | 10:48 AM
  #212
prb44t's Avatar
prb44t
Old Jul 26, 2007 | 11:43 AM
  #213
Klasse Act's Avatar
Klasse Act
My O-ring is green
Old Jul 26, 2007 | 12:01 PM
  #214
Scoobywrx's Avatar
Scoobywrx
After you guys reset the ECU did the car still run funky?
Old Jul 26, 2007 | 12:25 PM
  #215
bartbojo's Avatar
bartbojo
Well...I installed an elbow between the filter and MAF...and it seemed to help.
I really do think if u get a funky flow over the MAF, it affects the measurements.
As for resetting the ECU...I'm kinda sketch, but I guess it makes sense. Any vendors have their 2 cents about this?
Old Jul 26, 2007 | 12:28 PM
  #216
dwjj's Avatar
dwjj
I didn't reset my ECU, never experienced any funkiness. No lags or anything. Just a little more noise. Maybe a little extra mileage.
I removed my hood scoop grill and just left it open. (and I had a green o-ring too)
Old Jul 26, 2007 | 12:30 PM
  #217
mikeg4572's Avatar
mikeg4572
I left my scoop completely open too. I dont think that the little bit of water that could come in when it rains is anything to worry about.
Cant be any worse than when I wash my engine with the hose and some simple green.
Old Jul 27, 2007 | 02:00 PM
  #218
prb44t's Avatar
prb44t
Old Jul 27, 2007 | 09:59 PM
  #219
58driver's Avatar
58driver
After reading this thread, I decided to give this a try. I bought a cone filter and a 90 degree 3" rubber elbow all for about $35. I put the elbow on to help smooth the air prior to the MAF and locate the filter behind the head and centered where the airbox was. I'm going to build a box for the filter and a tunnel for under the hood out of fiberglass to make it draw cold air from the scoop. Right now the filter stays warm but definitely not hot where it is. I hope to have the complete, true cold air kit built for under $50.
Old Jul 28, 2007 | 08:51 AM
  #220
geeza-r56s's Avatar
geeza-r56s
I removed the hood scoop. Then i used a band saw and cut the back blocked side off. Then i fitted the insert again.
It matches the front grills again. Looks oem.
Also talking about cheap mods i read the forum on changing the intercooler silencer section. Got pumped up and drove to an exhaust place got them to cut me 8 inch stainless pipe and they put the car up on a hoist and fitted it in about 10 minutes. Cost me $20.
Old Jul 28, 2007 | 10:44 AM
  #221
familiarstranger's Avatar
familiarstranger
bart- do you notice any increase in noise with the new pipe?
Old Jul 28, 2007 | 07:06 PM
  #222
geeza-r56s's Avatar
geeza-r56s
I dont think so. I changed the cat in mine when i bought the car and that has definitely made it noisier.
Old Jul 29, 2007 | 12:40 AM
  #223
aus's Avatar
aus
What are you guys making the "elbow" out of and how are you attaching it to the MAF? What size elbow is it? Thanks.
Maybe this would actually help smooth the flow to the MAF? The E46 M3 guys will know about this "Gizmo"
Old Jul 29, 2007 | 10:51 AM
  #224
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
E36's came with something like this, right before the MAF
Old Jul 29, 2007 | 01:33 PM
  #225
Xray'dit_Mini's Avatar
Xray'dit_Mini
I used the bottom of the stock air box, built the top part of the box out of Lexan, and used a silicone elbow. I chose the Long oval K&N and angled it so that the greatest portion of surface area faced the incoming air from the free flowing scoop.
https://www.northamericanmotoring.co...intake_004.jpg
https://www.northamericanmotoring.co...intake_005.jpg
https://www.northamericanmotoring.co...intake_008.jpg
