Drivetrain CAI for R56 (home made)
Old Jul 29, 2007 | 10:16 PM
  #226
geeza-r56s's Avatar
geeza-r56s
Xray'dit_Mini - that looks like the ticket champ! I love it
Old Jul 30, 2007 | 12:49 AM
  #227
aus's Avatar
aus
Originally Posted by Xray'dit_Mini
I used the bottom of the stock air box, built the top part of the box out of Lexan, and used a silicone elbow. I chose the Long oval K&N and angled it so that the greatest portion of surface area faced the incoming air from the free flowing scoop.
https://www.northamericanmotoring.co...intake_004.jpg
https://www.northamericanmotoring.co...intake_005.jpg
https://www.northamericanmotoring.co...intake_008.jpg
Looks good. Now you can sell a kit.
Also looks like you can get a much longer filter on too. Where did you get the silicon elbow and how did you attach the lexan plates?
Old Jul 30, 2007 | 10:10 AM
  #228
familiarstranger's Avatar
familiarstranger
where is the headlight cowl air hose in relation to the filter?
Old Jul 30, 2007 | 10:17 AM
  #229
Xray'dit_Mini's Avatar
Xray'dit_Mini
You do have room for a longer filter....the problem comes with finding someone that sells the correct dimensions. (as a side note to everyone putting their own filters on.....the MAF is 70mm or 2-3/4" NOT 3" like a lot of people having been saying in this forum)
I bought the silicone elbow on Ebay. There is only one guy on there that I could find that didn't sell the typical 90deg elbow with 2.5" long legs. The elbow I bought had 10" legs that I cut down to a perfect fit.
The Lexan I also bought on Ebay (its VERY hard to find non translucent black, and a lot more exspensive). The Lexan is 1/8" thick. I bought this because it's easier to mold at this thickness. I used a heat gun to mold the Lexan. I doubled up the sides and used aluminum pop-rivets to join them. I molded the corners of the sides an back piece so that they would fit into oneanother, and then used the rivets to join them. The whole piece fits perfectly into the grove of the original airbox where I then placed a few strategic zip-ties to hold it in place.
Old Jul 30, 2007 | 10:34 AM
  #230
bartbojo's Avatar
bartbojo
Originally Posted by familiarstranger
bart- do you notice any increase in noise with the new pipe?
no...if anything there is less "vacuume" noise when I step on the gas. Turbo noise seems the same.
as for the hose I used:
http://www.siliconeintakes.com/produ...53f50af10652f7
...its a reducing hose (3" to 2.75"). I took the time to measure the filter and MAF openings with my calipers befor ordering, and the hose is perfect The smaller end fits nice and snug over the MAF, while the 3" end is attached to the filter using one of the joiners:
...with steel worm gear clamps, of course.
Old Jul 30, 2007 | 11:23 AM
  #231
Xray'dit_Mini
I used the bottom half of the stock airbox so the hose is in the original spot.
The filter is directly above the outlet of the hose into the box.
Old Jul 30, 2007 | 08:59 PM
  #232
58driver's Avatar
58driver
I wish I had the time an tools on hand to build one from lexan. I made something similar using sheet aluminum and a cone filter. I am trying to make a tray for the under side of the hood to funnel air from the scoop to the air box. So far I have a thin sheet of aluminum that channels air back behind the head and about a 4" flap hanging down behind the head and in front of the filter that serves two purposes. It channels the air to the filter and it blocks some heat from the front of the engine. Now I need to stiffen it up and clean it up as well. I'll post picks when I can. I'm trying to find ways to improve the setup with unfortunately very little time after work and before putting the kids to bed.
Cody
Old Jul 30, 2007 | 10:15 PM
  #233
Xray'dit_Mini
Cody,
I had to buy most of the tools I needed to do the job. You have to love Harbor Frieght Tools for inexspensive tools! We have like three local stores here in this area, but you can buy everything online too.
I purchased the heat gun (on sale $9.99), jig saw ($19.99), and hole saw set (12.99).....all for less than $50 at Harborfrieght.
Old Jul 30, 2007 | 10:31 PM
  #234
scott48's Avatar
scott48
Any of you guys know where you can buy an elbow to add on to a k&n filter, like the red elbow Alta uses?
Old Jul 31, 2007 | 05:37 AM
  #235
SPDinNY's Avatar
SPDinNY
I bought mine at Pepboys (I know I know....)
Old Jul 31, 2007 | 07:01 AM
  #236
chili_red07's Avatar
chili_red07
does this mod void the warrenty?
Old Jul 31, 2007 | 09:06 AM
  #237
familiarstranger
it voids the warranty for any problem they can link to this modification. which is vague wording left up to interpretation by your dealer. it is however very easy to switch back to stock.
Old Jul 31, 2007 | 10:13 AM
  #238
FLOWsource's Avatar
FLOWsource
aFe filters available
Hello,
we sell aFe airfilters. aFe has filters available with the following dimensions:
2-3/4" , 2-7/8", or 3" flange opening in 5" or 6" height.
Available in oiled or non-oiled version.
We sell them in a package:
2 filters of your choice (oiled -non oiled)
Cleaning kit if at least 1 filter is oiled
aFe ballcap
Free shipping in the Continental US
$95.00
Old Aug 1, 2007 | 05:34 PM
  #239
snkbte's Avatar
snkbte
Old Aug 2, 2007 | 10:30 PM
  #240
scott48's Avatar
scott48
So guys, correct me if I'm wrong, as long as the filter has an elbow attached that connects to the MAF, there will not be any issues with the car running weird(rich or lean, etc)?? Plus wont a home made one get similar gains to Alta's intake?? Oh yeah, engine doesn't care if you switch back and forth between stock air box and home made CAI??
Old Aug 2, 2007 | 10:46 PM
  #241
Xray'dit_Mini
I don't have a dyno chart, but I know I can chirp the tires shifting from 2nd to 3rd going 55mph since I installed the intake and exhaust!! Nothing but smiles here with the way the intake has been functioning. I'm even average 42mpg since the upgrades!
Old Aug 2, 2007 | 10:53 PM
  #242
scott48's Avatar
scott48
Sweet! I think I'm gonna do the same thing, I just wanted to make sure I wouldn't get any problems from the MAF. What exhaust do you have? I'm getting the Alta turbo back on next week, can't wait
Old Aug 2, 2007 | 11:15 PM
  #243
Xray'dit_Mini
I have the Alta cat-back (actually mine says Perrin on the tips Mine was one of the first shipped, and I think someone goofed when they had my tips etched)
Old Aug 2, 2007 | 11:24 PM
  #244
scott48's Avatar
scott48
by the way, do you need to reset the ecu like someone was sayin?? that seems kinda weird. oh yeah, how much louder is it especially when you shift?
Old Aug 3, 2007 | 09:12 AM
  #245
dwjj's Avatar
dwjj
You know, I'm going to have to stick with my opinion that the elbow idea needs to be proven. Air doesn't like to turn corners, and that causes turbulence too. Unless it's tested on a MINI, how would anyone know which way works, and which way causes problems? Experiences with other cars can make one look more carefully at the MINI, but where the filters sit, the airflow paths, everything, would have to be the same to be directly applicable.
You really need to test 1)stock 2)filter alone 3)filter+elbow before you can prove any positive or ill effects on the MAF sensor between any of them. Otherwise it's speculation.
What the elbow DOES allow you to do is have a little more freedom with filter size.
Old Aug 3, 2007 | 09:20 AM
  #246
wrxdriver's Avatar
wrxdriver
In my opinion, anytime that you change the way a car breathes or takes in or spits out anything (i.e. fuel, air, exhaust, etc.) you should reset the ecu. Doing this allows for your ecu to recalibrate to the modification that you just installed. When an ecu is reset it "learns" from your driving and the variables at which it is given. I have always done this to my cars with no regrets.
Old Aug 3, 2007 | 10:17 AM
  #247
familiarstranger
I put on my filter, then about a month later reset my ECU and butt dyno says it accelerates a little bit smoother
Old Aug 3, 2007 | 11:35 AM
  #248
Xray'dit_Mini
I had the filter setup two different ways:
1. filter straight onto the MAF = really loud "blow-off" noise between shifts
2. Filter in the current setup with box and elbow = at least 60% quieter (at least inside the cabin) ....also seems at bit smoother acceleration
the filter deffinately is much cooler after driving with the current setup. So the cold air it's receiving could play a part in the engine responding differently
Old Aug 3, 2007 | 08:59 PM
  #249
scott48's Avatar
scott48
Well, Alta said you need the elbow and proper size tubing to get the proper air flow over the MAF.
Old Aug 4, 2007 | 05:58 PM
  #250
minipete07's Avatar
minipete07
Hello...does any one know if a 9 inch filter with a 3 inch inlet work with the 90 degree elbow??
