Drivetrain Burger Motorsports (BMS) Tune(s)
Better be ready to have your fake "happy face" on if it isn't the JB+.
Right?! Fingers crosses it is it. She knows I have not ordered it because I keep talking about it so, fingers crossed.
100% 13 hours after I bought the GP and it runs perfect and safe
When you say 100% what do you mean? 0600??? If so is this because fuel mixture or have you ran it on basic 93 octane w/10% ethanol???
Do you do that mixture at every fillup? Curious what the long term effects will be.
I'm also at 100% and have an S. I have the basic bolt on modifications, Aquamist HFS-3 and I run 100 octane race gas. I just bumped the dial up to 100% so it is still adapting but everything so far is in the green.
Wanted to try some e85 even made a spreadsheet to calculate how much E85 to add. After seeing some news reports on E15 and phase separation I chickened out. The news might just be exaggerating but now just going to wait and see.
The meth alone will put you close to 100octane.
.....just trying to save you some money.
I was just being on the safe side since I live in Cali and there's only 91 octane.
If you can run safely with 91 and meth, you can save some money on that 100 race gas.
You can checking timing while in stock form with 91 and straight methanol. If timing is maxed out then the JB+ at 50% should be good.
Just keep making incremental change to observe your timing. If all is still well at 100% then you're good to go.
Is your nozzle before or after the intake temp sensor?
Yea I hear you on that. I'm in Cali myself.
It's before the intake temp sensor.
I'm running the .8 nozzle with 100% meth.
Hey guys. Was thinking about using this intercooler with the jb+ I know its not an Alta or Forge intercooler but looks very similar. I would think it would still be much better than the factory one. Anyone else running this intercooler with the JB+ ?
http://www.ebay.com/itm/221324661002?redirect=mobile
Intercooler
BMW Mini Cooper s R56 R57 2007 2012 Front Mount Intercooler 2008 09 10 11 2012 | eBay
I can speak to the Forge product. I was impressed with its build quality and it fit right in. On my '13 I had to remove the crash bumper to install it but it reinstalled with no clearance issues. So far my highest IAT has been about 23 deg F over ambient on 17.5 psi. Return to ambient takes about 20 seconds or so at highway speeds. I'm sure ALTA and Helix probably perform similarly.
Methanol
Where do you purchase the methanol?
What does it cost/gallon?
How long does a gallon last?
How difficult was the installation of the Aquamist?
What do you do when you bring it in for service (i.e. to protect your warranty?)
BTW thanks again for recommendation on the FMIC.
It does "look" similar and may perform fine. Most likely it's a Chinese made product. The only thing i would say is installation is a full day job and this is an unknown entity. You could save a few hundred bucks but if it doesn't fit right or hold up well this savings could be eliminated very quickly with the labor required to reinstall another unit. There is no top tab mount like on the Forge but I don't think that's really essential. Also unknown would be the gauge (thickness) of aluminum sheeting used in the construction. 6061-T6 is a good alloy for the application that is highly corrosion resistant. It's used frequently for bicycle frames and boat hulls etc. I know this as I was in the metals industry for many years.
After looking around it looks like these guys are selling that exact intercooler. It seems like they actually have some data on the intake temps for it also. Not really a fan of the way they added the fans to the front though.
http://www.ironhorsecoopersports.com/intercooler01.htm
It does "look" similar and may perform fine. Most likely it's a Chinese made product. The only thing i would say is installation is a full day job and this is an unknown entity. You could save a few hundred bucks but if it doesn't fit right or hold up well this savings could be eliminated very quickly with the labor required to reinstall another unit. There is no top tab mount like on the Forge but I don't think that's really essential. Also unknown would be the gauge (thickness) of aluminum sheeting used in the construction. 6061-T6 is a good alloy for the application that is highly corrosion resistant. It's used frequently for bicycle frames and boat hulls etc. I know this as I was in the metals industry for many years. I can speak to the Forge product. I was impressed with its build quality and it fit right in. On my '13 I had to remove the crash bumper to install it but it reinstalled with no clearance issues. So far my highest IAT has been about 23 deg F over ambient on 17.5 psi. Return to ambient takes about 20 seconds or so at highway speeds. I'm sure ALTA and Helix probably perform similarly.
