Drivetrain Burger Motorsports (BMS) Tune(s)
Old Nov 1, 2013 | 05:11 AM
  #801
Mcameron's Avatar
Mcameron
Originally Posted by yesti
Originally I let the car go to sleep (~15 min) before installing the JB+. Got used to how the car drove. Low end (off idle to ~1500rpm) was a little boggy, just like stock, when cold so if I had to merge quickly from a stop (parking lot to street, for example) I would use the sport mode to make sure it zipped out of there.
I'm in the process of installing some audio equipment so I unhooked the battery for the first time since installing the JB+ last night. Today I noticed the low end was much smoother. Maybe it's because I'm back in the 50-100 mile adjustment period for the JB+ and/or the engine is relearning how to operate but I can't say I don't like it. Just wondering if anyone else noticed that.
its not uncommon for people to report better performance after unhooking the battery.
apparently the common concensus is the car is better at "re-adapting" to the mods/ driving style if the computer is completely reset.
now im not an automotive/ electrical engineer...so i wont pretend to try and understand how the BMW ecu/ systems work.......but seeing as how the car had to initially adapt to the JB+....its seems reasonable to think it would adapt/ integrate better if it was always there (as far as the ecu is concerned).
im going to be under the hood this weekend, so while im underthere i may disconnect the battery and see if i can report anything similar.
Old Nov 1, 2013 | 05:17 AM
  #802
cerenkov's Avatar
cerenkov
I didn't think that disconnecting the battery would reset the adaptations. You can IIRC reset them using the secret menu on the BC.
Old Nov 1, 2013 | 09:00 AM
  #803
RoyalCooper's Avatar
RoyalCooper
...so I unhooked the battery for the first time since installing the JB+ last night. Today I noticed the low end was much smoother. Maybe it's because I'm back in the 50-100 mile adjustment period for the JB+ and/or the engine is relearning how to operate but I can't say I don't like it. Just wondering if anyone else noticed that.
im going to be under the hood this weekend, so while im under there i may disconnect the battery and see if i can report anything similar.
This feels like the start of an ol’ wives tale...however if empirical data proves otherwise I, along with most readers / JB+ owners will certainly be unhooking batteries in rapid succession.
Would love to hear Terry weigh in on this.
Old Nov 1, 2013 | 11:25 AM
  #804
yesti's Avatar
yesti
Might be a placebo effect, but it was noticeable even though I wasn't looking for it. Don't see much harm in trying it for yourself, seems like all you have to do is reset your clock.
Old Nov 1, 2013 | 11:44 AM
  #805
pepperwhiteknight's Avatar
pepperwhiteknight
In the process of my dyno-less jb+ testing over the past month, the obc reset and battery disconnect procedures do nothing. If you want to feel a difference remove the JB+ and drive.
Yesti the MINI is just giving you some love back for giving it nice things and spending some quality time with it.
This is from the 1st gen forums but it may apply on our MINIs...
https://www.northamericanmotoring.co...9-post284.html
Originally Posted by Bytetronik
The Adaptation Values are stored in EEPROM (similar to how the BIOS info is stored on your computer); so disconnecting your battery will NOT clear the adaptation values.
I can unplug my car battery, then remove the ECU and then connect the ECU on a bench reader and still read out the stored adaptation values inside that ECU. So in short, you need a special tool to "Clear Adaptations"...
And there are multiple adapations to clear:
  #806
nine5raptor's Avatar
nine5raptor
You may have reset your long term fuel trims. If the jb+ relies on the fuel trims to compensate for more air, you are likely running lean and making more power. May want to let it settle back in...
Old Nov 1, 2013 | 01:27 PM
  #807
yesti's Avatar
yesti
Been only 'city' driving it since the battery disconnect, no WOT pulls. That's the main reason I noticed the smoother low end. Even if it changes back to the way it was before, it's still WAY better than stock so I'd be happy either way.
Old Nov 1, 2013 | 04:09 PM
  #808
rAte's Avatar
rAte
Finally
Ordered! Bought wheels and tires right before they released...
Can't wait for USPS next week!
Old Nov 2, 2013 | 02:19 PM
  #809
Roxspin72's Avatar
Roxspin72
Is there any way to tell if your Mini is pulling timing. I tried running AFR & Timing on my hijacked gauges, but it gets really confusing to read while driving. Plus the hijack mode only kicks in when 5psi or higher. Wish there was a way to have constant feedback at the push of a button. Anyways, Mini is running great, lots of power, just want to know what knock or pulled timing would sound or feel like I.e any warning signs besides CEL?
Old Nov 2, 2013 | 02:32 PM
  #810
cerenkov's Avatar
cerenkov
I also think it is hard to monitor that stuff real time so I data log it using DashCommand and study it after the fact.
If you're in imminent danger you should throw a code.
Old Nov 2, 2013 | 04:40 PM
  #811
Roxspin72's Avatar
Roxspin72
Good to know,
What's dash command...
Old Nov 2, 2013 | 04:48 PM
  #812
nine5raptor
May also consider Track Recorder for the app Torque on android. I use it to capture video with an overlay of timing, boost, rpm, throttle, water temps, and speed.
Old Nov 2, 2013 | 05:29 PM
  #813
kerrys914's Avatar
kerrys914
Does the "DashCommand" work in real time and fast enough to be used as a gauge?
Old Nov 2, 2013 | 05:57 PM
  #814
cerenkov's Avatar
cerenkov
It does, IIRC is scans about 8-10 times per second. Which is ok if what I want.
So I have gauges displayed on the iPhone and data log at the same time. Then download the data to excel to study it. Or you can you their software, I prefer excel.
Now you can't use the can tool and DashCommand at the same time.
Old Nov 2, 2013 | 07:08 PM
  #815
RoyalCooper
Good to know,
Here's a heads up to all my fellow MINI and iPhone owners about DashCommand™, just in case you're interested.
You may want to jump on this right away...because it'll probably be for a limited time; but right now the app for iPhones: DashCommand™ – OBD-II gauge dashboards, scan tool, and vehicle diagnostics is 'on sale' for just $9.99 vs. $49.99 usually. (They also make an Android version)
iTunes: http://appshopper.com/link/dashcommand
Keep in mind it also needs a way to communicate with the OBD II (wired or via Bluetooth) and they must be iPhone compatible.
Hopefully there are some of you out there that were looking for this type of app but thought the price tag for DashCommand™ was a bit high...now's your chance.
Again like I said; this price may not last long...could only be for days or just until they sell 'X' amount.
Best of luck
Old Nov 2, 2013 | 07:12 PM
  #816
maupassant's Avatar
maupassant
First of all, I do not have the jb+.
My car is almost stock and while driving , at WOT, i can see that timing is 0 and increases to 2 or 3 when nearing redline. I get the info on my scangauge.
Is it safe to consider adding the jb+?
Old Nov 2, 2013 | 08:45 PM
  #817
PenguinOnTheTelly's Avatar
PenguinOnTheTelly
DashCommand / Blue Tooth
Best of luck
Will the standard Bluetooth sync through the radio work as a link for the DashCommand?
Old Nov 2, 2013 | 09:11 PM
  #818
pepperwhiteknight
No. A dongle type device that can plug into the OBD port is required. I think ELM327 based is the most common. Android can use the Bluetooth version of the OBD dongles but iOS must be WiFi because of the way Apple locked it down the Bluetooth.
Old Nov 2, 2013 | 10:42 PM
  #819
yesti's Avatar
yesti
What mods do you have that make you worry? At least it's not yanking timing on you
Old Nov 3, 2013 | 01:40 AM
  #820
maupassant's Avatar
maupassant
I'm not really worried, just curious. I just want to know how to read the Timing info on my scangauge.
Mods on car are basic: Akrapovic complete line including DP, Okada coils, Evolve FMIC waiting to be installed
Old Nov 3, 2013 | 01:50 AM
  #821
yesti's Avatar
yesti
Here's a couple posts from further up this thread from Terry on timing:
https://www.northamericanmotoring.co...5-post746.html
https://www.northamericanmotoring.co...5-post750.html
Old Nov 3, 2013 | 01:42 AM
  #822
cerenkov's Avatar
cerenkov
Here's a screen shot of the newest version of the DashCommand app (you can have multiple screens - from an iPhone 5):
You can easily add gauges to your hearts desire. Also there is a really good 0-60 and 1/4 mile timer in the app. I paid $50 three months ago so the sale price of $10 is a great deal.
You can also totally get crazy and use the free downloadable software (Windows only) to write more custom gauges but I feel that with the new version is this not really needed.
I just added the charting on Saturday to see if I can better monitor AFR and Timing and I need to fix the scaling today (really easy to do - but I was driving at the time) - so kind of ignore that weirdness.
It also has a play back mode which is kind of cool.
The wifi adapter I bought is:
http://www.newegg.com/Product/Produc...9SIA1EF0SN5964
The nice thing about this adapter is that it flashes a blue and red light so you can tell if it is ON and transmitting. And it has a ON/OFF pushbutton so you don't have to unplug it (I generally leave mine on and it hasn't drained the battery yet).
With the iPhone you CANNOT use bluetooth - MUST use wifi. For android you can use bluetooth but I never tried it with an android phone. The nice thing about android is that you can pickup a used phone for cheap and have it as a dedicated display (iPhones are more expensive on the used market).
Their direct website for more info is http://www.palmerperformance.com
Someone asked about sampling rate - on the data log I'm getting about 10 data points per second (10 Hz)
Old Nov 3, 2013 | 02:24 AM
  #823
maupassant's Avatar
maupassant
So nothing to worry about as it seems thats it's normal that timing pulls up from 0 to 2,3.
We supposedly have RON95 fuel here (i'm from Mauritius on the other side of the globe) and hopefully the JB+ will be a nice upgrade when I do go for it.
Old Nov 3, 2013 | 06:15 AM
  #824
PenguinOnTheTelly
iPhone
Thanks I didn't think so. I have an iPhone. Appreciate any feedback on a WiFi dongle that works well (and is a good value) with iPhone in an R56 N18 application. Particularly any feedback on the WiFi version of the ELM327.
Thanks in advance for any help mates.
Old Nov 3, 2013 | 06:47 AM
  #825
wzabrouski's Avatar
wzabrouski
Here's a screen shot of the newest version of the DashCommand app (you can have multiple screens - from an iPhone 5): You can easily add gauges to your hearts desire. Also there is a really good 0-60 and 1/4 mile timer in the app. I paid $50 three months ago so the sale price of $10 is a great deal. You can also totally get crazy and use the free downloadable software (Windows only) to write more custom gauges but I feel that with the new version is this not really needed. I just added the charting on Saturday to see if I can better monitor AFR and Timing and I need to fix the scaling today (really easy to do - but I was driving at the time) - so kind of ignore that weirdness. It also has a play back mode which is kind of cool. The wifi adapter I bought is: http://www.newegg.com/Product/Produc...9SIA1EF0SN5964 The nice thing about this adapter is that it flashes a blue and red light so you can tell if it is ON and transmitting. And it has a ON/OFF pushbutton so you don't have to unplug it (I generally leave mine on and it hasn't drained the battery yet). With the iPhone you CANNOT use bluetooth - MUST use wifi. For android you can use bluetooth but I never tried it with an android phone. The nice thing about android is that you can pickup a used phone for cheap and have it as a dedicated display (iPhones are more expensive on the used market). Their direct website for more info is http://www.palmerperformance.com Someone asked about sampling rate - on the data log I'm getting about 10 data points per second (10 Hz)
Do you have the details about the wifi adapter? The link is not pulling it up. I have used the Palmer products before and they are great.
