Drivetrain Burger Motorsports (BMS) Tune(s)
Old Oct 24, 2013 | 12:02 PM
  #726
KilmerPT's Avatar
KilmerPT
Originally Posted by MarioKart
My GP runs perfect, I installed it at with only 62 miles. JB+ was the first thing I did. Get one!!!!
So can the N18 JCW owners start ordering these now too for beta testing? Or is it still just for the MCS?
Old Oct 24, 2013 | 12:41 PM
  #727
Mini-LSE's Avatar
Mini-LSE
I would like to know the same thing. If Terry needs some JCW testers, I am in.
Old Oct 24, 2013 | 02:36 PM
  #728
Terry @ BMS's Avatar
Terry @ BMS
JCW cars seem OK so far but do lower the dial down to 30% IMHO.
Old Oct 24, 2013 | 02:49 PM
  #729
rckrzy1's Avatar
rckrzy1
What position is what percentage on the jb+ ?
I took mine from factory noon to 11:00 to be
A little safer for piece of mind.
Old Oct 24, 2013 | 03:05 PM
  #730
Terry @ BMS
It's roughly setup like a clock from MIN to MAX.
Old Oct 24, 2013 | 03:46 PM
  #731
Fooj GP's Avatar
Fooj GP
Are you at the stock setting? I have 93 here in Ohio i like to set it up to the max i can push out of that thing.
Old Oct 24, 2013 | 04:09 PM
  #732
rckrzy1's Avatar
rckrzy1
and min is about 1.5 and max about 6 psi ? Or did I get that wrong ?
Old Oct 24, 2013 | 06:11 PM
  #733
Terry @ BMS
No it doesn't really work that way. Min is close to stock and max is close to "max effect".
Old Oct 24, 2013 | 06:58 PM
  #734
Rejeme's Avatar
Rejeme
Plugged mine in today. Installed some NGK 5992's a few days back gapped at .022. Set mine back to 4 (11 o'clock). Only have 91 around these parts. Car feels great even with only a few miles under its belt. Nice, smooth power delivery.
Old Oct 25, 2013 | 08:48 AM
  #735
bmx045's Avatar
bmx045
with 18" hankook v12's in the cold weather I'm burning rubber all day and night 1,2,3 gear. no traction anymore, lol.
Old Oct 25, 2013 | 11:29 AM
  #736
kerrys914's Avatar
kerrys914
Do things work this way? Is the 11:00 position safer (less chance of BOOM) then 12:00 or 1:00?
Old Oct 25, 2013 | 11:40 AM
  #737
kerrys914's Avatar
kerrys914
Are most using the CAN tool or other tools (scangauge II or pod mounted gauges)?
Cheers
Old Oct 25, 2013 | 12:19 PM
  #738
pepperwhiteknight's Avatar
pepperwhiteknight
Cheers
I am not but plan to install one of those tools. Flying blind with 93 octane on stock setting. No codes in the on board computer and the car is running great, no weird noises or thumps.
Attached Thumbnails Burger Motorsports (BMS) Tune(s)-2013-10-24-13.34.34.jpg
Old Oct 25, 2013 | 01:24 PM
  #739
yesti's Avatar
yesti
turning down the boost would be safer, yes. If you have 91 octance, 11'oclock is a good idea
Old Oct 25, 2013 | 07:49 PM
  #740
wzabrouski's Avatar
wzabrouski
Originally Posted by NewCooperFanatic
What octane are you running?
He was on 94 when he did that.
Keep tabs on your timing to make sure it's not pulling.
I should know this but I monitor timing advance via an ultra gauge. What would I be looking for to see if the ecu is pulling timing?
Old Oct 25, 2013 | 08:19 PM
  #741
Dustypants's Avatar
Dustypants
Same for the scangauge II please!
I've since turned mine down to "11" as well since mixing race gas gets real expensive... And all we have in the bay is 91...
It's still a kick in the pants set one back from stock, and still pushes around 17 psi at over boost.
Took a coworker in my car at lunch today who's been in the car several times pre-JB+. As I got on 101 he asked what I had done to the car, because "holy *****, it didn't put me back in the seat like that last time".
Old Oct 25, 2013 | 09:39 PM
  #742
sixer's Avatar
sixer
So is it seeming like if we only have access to 91 octane it is the smarter thing to turn it down to 11? I just picked mine up yesterday and live in California so it's 91 for me
Old Oct 26, 2013 | 01:47 PM
  #743
HorizonBLueN18's Avatar
HorizonBLueN18
Terry, I'm running 93 octane with the mods in my signatureAnd the default settings of the jb+. On the highway today with ambient temp around 50 degrees. I did a few 4th gear pulls and with timing set to the gas gauge and the speedo it dropped to 0-1 timing advance on the majority of the the pulls. Could the winterized gas have an effect on this? I didn't get a chance to check a/f while doing the pulls because I just didn't think about it. I'm just worried as I should have zero timing issues because I'm in the he green on all parameters.
Old Oct 26, 2013 | 01:53 PM
  #744
Fooj GP's Avatar
Fooj GP
JP jb+ owners, What is the stock boot and what is it boosting to with the jb+
Old Oct 26, 2013 | 02:36 PM
  #745
Terry @ BMS
Timing will naturally run 0 or even negative at peak torque if the conditions call for it. What you want to see is timing eventually slopping up as you get closer to redline. If it's not then you probably should turn the dial down a bit.
Old Oct 26, 2013 | 02:50 PM
  #746
HorizonBLueN18
thank you for clarifying. timing does advance as redline approaches. I'm just unfamiliar with monitoring timing and wanted to confirm.
Old Oct 26, 2013 | 03:00 PM
  #747
wzabrouski's Avatar
wzabrouski
When you refer to the ECU "pulling timing", how would we identify this?
Old Oct 26, 2013 | 09:16 PM
  #748
MrRaD's Avatar
MrRaD
i received mine today, but i got home really late. so i connected it asap and it is sitting in the driveway until the morning..
So far i am impressed with the speedy responses from Terry, and the speedy delivery time..
Old Oct 27, 2013 | 08:41 AM
  #749
Terry @ BMS
The easiest things to spot are repeated 3 degree drops at higher RPM and boost values. It can be difficult to distinguish between normal mapping patterns and knock sometimes. It takes a careful eye. But there are also a series of "knock codes" and a check engine light that will come on if you get it to knock bad enough to really worry about it. Long story short unless someone is experienced enough to know what to look for I'd not suggest touching the dial. I'd not suggest touching it anyway, except to lower it, in low grade fuel situations.
Old Oct 27, 2013 | 08:45 AM
  #750
Azminispeedin's Avatar
Azminispeedin
To sum up, we do not have a way to data log the JB like a Cobb accessport in excel so we do not know what is going on with knock counts.
