Drivetrain Burger Motorsports (BMS) Tune(s)
Hey all. Been reading about people turning up the jb+. Just curious what I can turn it up to on the safe side. I always put 93 in and have only a boost tube and an intake on. Can I turn it up a little or should I just leave it where it is at? Thanks!
speaking of turning it up a notch.....
has anyone tried Torco?
its a 'race gas concentrate'....and is supposed to actually boost the octane rating of 93 up to 100 octane.
ive been reading and it seems that this stuff actually does increase octane levels a significant degree( or at least provide knock protection).......just wondering if anyone has any experience.
unfortunatelly race gas and E85 are not too common in my area.
people have dialed it up with no issues. most of them are running 93+ octane, a mix of e85, and/or water/meth injection. even then, one may be toeing the line of engine failure. i am no austin power, so i don't choose to live dangerously.
our JB+ is adapted from the n55 application. there are similarities, but i highly doubt they're interchangeable, if that's what you're asking. and i think it's a bit more than just different settings, altho i'm not sure what qualifies as settings in your mind.
Amazon.com: Torco Accelerator 32oz The Best Fuel Additive: Automotive
May cause engine knock, actually decrease performance, etc, if the fuel isn't there to support it.
Nope.
Terry,
so assuming i add a full 32 oz can of Torco to a tank of 93 octane (Which should bring me to ~97-100 octane)
do you think i would be reasonably safe bumping the JB+ up to 6 or 7 assuming i keep an eye on my timing?
oh wow, thats great to hear....
i think ill take things slow and gradually start to ramp things up over the course of a few weeks. ill be sure to let you know how everything is going along the way.
also, do you think it would be beneficial to swap for colder plugs if im running the JB + on its max setting
yeah, it is a bit pricey.....however,at $25/ can + $50/ full tank of 93, thats works out to ~$5.75/ gal....which is a lot cheaper than what race fuel is going for.
So what's the safest setting on the jb with 93 octane? The base setting? Anyone on here in fort myers fl? Where can you buy higher than 93 octane has around here?
yea i have an S, i just found a sunoco before the bridge to fort myers beach that sells higher octane gas. which is great because i work on the beach. With a completely stock cooper S, running a higher octane fuel, and turning it up, are there any concerns to have? sorry for the questions, i dont currently have a JB+ but im very close to purchasing one. i keep hearing about a jb4 thats in the works, and i dont know if i wanna spend money now only to spend more on the new system later...
Terry has said BMS has an upgrade path where you don't lose by starting with the JB+ then going to the JB4 when it comes out. So have fun now, then have more fun later ;-)
If I put high octane gas (97+) in my mini which is currently running the jb+ stock and I turn it up to 100% I assume there's another break in period just like when u first install it? Just wanna know if I should wait before taking it on a dyno
so essentially any HP gains are going to come from tuning for the higher octane fuel
the race gas/ octane boost will likely not net any HP gains by its self.......what higher octane fuel allows you to do is push more boost safely, because it is more resistant to detonation....
On a side note, I finally located an E85 station near-ish to me. How much E85 should/could I mix into my 91 to safely turn up the JB+ on an MCS?
