Must be summer, busy here
Old Jul 13, 2009 | 11:10 AM
  #4451
kenchan's Avatar
kenchan
makes sense to use a large tank...but then it would take more time to fill the tank initially, no?
Old Jul 13, 2009 | 12:08 PM
  #4452
CR&PW&JB's Avatar
CR&PW&JB
Well... I suppose you can use a smaller tank and then stop in the middle of a job, re-fill the tank and then start again.
P.I.T.A.
BTW, considering this one:
http://www.northerntool.com/webapp/w...&cm_ite=123008
Old Jul 13, 2009 | 12:16 PM
  #4453
kenchan's Avatar
kenchan
yah, i like that dual can setup.
was kinda cracking up about the "93–95dB noise level" thing they have there. 93-95dB @ 1mile distance.
Old Jul 13, 2009 | 03:35 PM
  #4454
CR&PW&JB's Avatar
CR&PW&JB
You think it will be that loud ?
Am I going to want to put that in my neighbor's garage and get a 200 foot hose ?
Old Jul 13, 2009 | 05:48 PM
  #4455
kenchan's Avatar
kenchan
no idea but compressors are pretty noisy in general. It's refreshing when it stops.
since you have a large garage you're probably ok though.
Old Jul 13, 2009 | 05:54 PM
  #4456
CR&PW&JB's Avatar
CR&PW&JB
I don't have a large garage... two car, yes, but not large. My tiled area is 15' x 17'. Not big. And the untiled area is only 17 x 3 feet. So... add the two, divide by.... just a little over 300 sf.
Maybe I'll drill a hole through the outside wall of the garage, put the compressor outside, and then......
Old Jul 13, 2009 | 07:21 PM
  #4457
BlimeyCabrio's Avatar
BlimeyCabrio
Yeah, those small compressors are LOUD.
I have one kinda like this:
It's actually much quieter than the small ones. But still loud...
Old Jul 14, 2009 | 09:35 AM
  #4458
kenchan's Avatar
kenchan
wow, that's a studly can you got there blimey.
i suppose you can put the compressor in an enclosure with some sound proofing but that enclosure will become smaller and smaller as the compressor sucks in the air.
how about one of these? isolation wall... only $599.
Old Jul 14, 2009 | 09:38 AM
  #4459
OctaneGuy's Avatar
OctaneGuy
Initially yes, but who says you have to be in the garage when it's filling? lol.
Besides, once you've set the pressure to the desired level, it'll maintain it..instead of thinking that you fill the tank 100% and wait until it's empty to refill.
Old Jul 14, 2009 | 09:43 AM
  #4460
CR&PW&JB's Avatar
CR&PW&JB
Richard, In doing my research, I read some reviews that said the tanks rusted out from moisture build up and recommended you empty the tank if it's going to be some time between uses.
I'll probably use mine once a week to blow the water from the nooks and crannies of the MINIs.
So... do I need to empty it out occassionally, or just keep using it and wait until it's empty to refill ?
Old Jul 14, 2009 | 09:47 AM
  #4461
kenchan's Avatar
kenchan
CR&PW&JB- i just use my shopvac in blower mode to dry my car.... $0.
no drying or emptying needed either.
Old Jul 14, 2009 | 09:48 AM
  #4462
kenchan's Avatar
kenchan
if it's that smart why can't they make a quieter one?
Old Jul 14, 2009 | 09:51 AM
  #4463
OctaneGuy's Avatar
OctaneGuy
I really don't know. It's not like I can open the tank and look inside to check the rust. My tank is used several times a week. Once you have air, you'll find other uses, like blowing dust from the interior and the engine bay and topping the air of your tires and once you start zipping the lug bolts off with an air tool...it just keeps going, lol.
There is a moisture drain valve on my tank, and I do run moisture filters on the lines to prevent moisture from getting into the air supply.
Old Jul 14, 2009 | 10:57 AM
  #4464
CR&PW&JB's Avatar
CR&PW&JB
What's that have, 8 PSI ?
Old Jul 14, 2009 | 10:58 AM
  #4465
CR&PW&JB's Avatar
CR&PW&JB
I should have just asked if you have any problems with your tank rusting.
I thought Ken was the only smart *** around here.
Old Jul 14, 2009 | 11:08 AM
  #4466
OctaneGuy's Avatar
OctaneGuy
Hahah, what do you expect, it's a Detailing Forum.
It's been 2+ years, and no issues with rust. I don't expect the compressor to last forever, but on the otherhand, a replacement tank is a lot less than replacing the whole compressor.
Old Jul 14, 2009 | 11:09 AM
  #4467
kenchan's Avatar
kenchan
not sure about the PSI, but with the conal shaped blower nozzle things can get pretty strong.
Old Jul 14, 2009 | 11:10 AM
  #4468
kenchan's Avatar
kenchan
hey, i sold my old legacy's floor mats today.
ive had them for like 2yrs doing nothing.
i still have a set of 06 civic sedan factory floor mats
that i want to sell for like $20.
Old Jul 14, 2009 | 11:38 AM
  #4469
BlimeyCabrio
My big tank stays pressurized ALL THE TIME, just like most do at most shops. It DOES collect water over time, and I drain it periodically. Yes, it's brown water from the rust. This will drive someone like ChiliPepJet crazy most likely... but rusting from the inside out is what air tanks do... they are an expendable item... though I expect mine will last for MANY years before it finally yields. The one on our farm is at least 40 years old and it hasn't failed yet.
It's REALLY nice to have 100+ PSI available in UNLIMITED quantities whenever desired. With my sculpture studio, I use lots of air tools that suck massive amounts of air. Also air brushes and spray guns and impact wrenches and plasma cutter and and and and....
Mine is in the corner of my garage, and I DID build a sound deadening enclosure for it. It's not sealed (nor is it intended to be - it would overheat the motor and pump), but I enclosed it in a heavy 3/4" MDF box lined with carpet padding foam. It absorb A LOT of the noise, especially the annoying frequencies, but you still hear that big pump pumping when it's on. Lots of room for air to circulate around it and in and out of the enclosure.
Old Jul 14, 2009 | 11:50 AM
  #4470
CR&PW&JB's Avatar
CR&PW&JB
Thanks for the straight-forward, non smart-*** reply, Paul.
And thanks also for the backhanded compliment on my OCD illness.
Old Jul 14, 2009 | 12:06 PM
  #4471
kenchan's Avatar
kenchan
CR&PW&JB- my shopvac in blower mode was not a smart-*** reply.
oh wait, the $0 part.... ok.
Old Jul 14, 2009 | 12:07 PM
  #4472
kenchan's Avatar
kenchan
blimey- you make sculptures? i think we need to see some picts.
Old Jul 14, 2009 | 12:50 PM
  #4473
BlimeyCabrio
www.aerokinetic.com
Old Jul 14, 2009 | 02:17 PM
  #4474
kenchan's Avatar
kenchan
wow, beatiful work.
so this is your primary occupation?
Old Jul 14, 2009 | 02:48 PM
  #4475
lotsie's Avatar
lotsie
A good way to build a soundproofing enclosure, is to build a frame out of 2x4s, use sound insulation batts to fill the voids, this will knock down high frequencies, then skin both inside, and outside with 5/8"drywall, or similar dense panel, to knock down the low frequencies. You can use cheap furnace filters to let air in through an opening.
Mark
