Old Jun 15, 2018 | 02:58 PM
  #19651
mario23's Avatar
mario23
Thanks! Trying to device what's next! The list is long!
Old Jun 15, 2018 | 04:55 PM
  #19652
cristo's Avatar
cristo
H Sport 25.5 mm hollow rear sway bar, Powerflex front
control arm bushings, new spark plugs, sunroof mechanism
lubrication, and yearly inspection.
Old Jun 15, 2018 | 07:22 PM
  #19653
ssean72's Avatar
ssean72
I refinished my wheel arches, front and rear black trim to body color
Attached Thumbnails What did you do to your mini today?-7ea427af-380e-4baa-9e04-1d191efd5108.jpeg   What did you do to your mini today?-d0c8bc60-ecf7-4fa7-b392-526cd8c56d3e.jpeg   What did you do to your mini today?-07389f79-d90d-4a3c-b119-aa77a3c03504.jpeg   What did you do to your mini today?-5ee802f0-fa10-472a-962f-ec35d38e4a0a.jpeg
Old Jun 16, 2018 | 05:04 AM
  #19654
bratling's Avatar
bratling
Super Moderator
Originally Posted by Shotgun_banjo
Replaced my 11 year old key fob rechargeable battery and saved $350 in the process. Cost of the battery $2.50 + 10 min. of my time.
I don’t suppose you have a link to a tutorial for that? My spouse’s Countryman key fob has lost most of its range in the past year or so.
Old Jun 16, 2018 | 06:10 AM
  #19655
Struns's Avatar
Struns
Walgreens charge me $5.95 and it took me 30 seconds on an '09
Old Jun 16, 2018 | 06:54 AM
  #19656
Ace1287's Avatar
Ace1287
Mirror caps for my BRG
Old Jun 16, 2018 | 07:38 AM
  #19657
Snaps's Avatar
Snaps
Got my results from Blackstone Labs, and the results are quite good I have to say.
And now with all the new seals and gaskets, plus the other added parts, I would say Egan is more than ready for many more miles ahead of it.
I will send another one in once I'm ready to change the oil again just to be sure this wasn't a fluke though.
Old Jun 17, 2018 | 02:48 PM
  #19658
scotty_r56s's Avatar
scotty_r56s
Ran her hard on Road Atlanta and cooked some tires
Old Jun 17, 2018 | 05:43 PM
  #19659
squawSkiBum's Avatar
squawSkiBum
That's just rubber picked up from the track, aka "track snot", that will all peel off and you'll hear it hitting the inside of the wheel wells and wonder what the noise is. Post some videos!
Old Jun 17, 2018 | 07:10 PM
  #19660
ssean72's Avatar
ssean72
I did this today....
Attached Thumbnails What did you do to your mini today?-fd6d03fb-4f26-4226-b9b3-a36db48dbae0.jpeg
Old Jun 17, 2018 | 07:23 PM
  #19661
mini coop's Avatar
mini coop
Ran the track at Watkins Glen International with 300 other MINI's.
Old Jun 18, 2018 | 11:41 AM
  #19662
JABowders's Avatar
JABowders
Veteran: Army
We didn't make the Glen this year, had other commitments. <sad face>
Saturday we did a Dramamine run though some the best twisty roller-coaster hills in our area. Started in Shippensburg, PA ended in Chambersburg, PA straight line distance 12.9 miles ... our route was closer to 90 miles.
Great day.
Motor On!
Old Jun 23, 2018 | 11:20 AM
  #19663
made mini work for a living
My Desire has been turning into a track diva, at least it thinks and acts. Today I give it a dose of reality - made it go grocery shopping. When arrived at the shop, it picked and chose the most out of the way parking spot.
And it has been eating like a hog, consuming 1.5 tank of petrol at 7.7 MPG .
Old Jun 23, 2018 | 07:49 PM
  #19664
Baltoman's Avatar
Baltoman
Did the spark plugs and an oil change. I took a look at the old plugs and realized the previous owner put the wrong kind of plugs in the car >:(
Old Jun 23, 2018 | 10:49 PM
  #19665
one2three_us's Avatar
one2three_us
Retro fit US UNION JACK Brake Lights. Installation was easy, however, coding it to make it to work properly takes awhile.
Old Jun 24, 2018 | 06:08 AM
  #19666
Bnourai's Avatar
Bnourai
Wow that looks great.
Ben
Old Jun 24, 2018 | 07:24 PM
  #19667
cristo's Avatar
cristo
Curbside alignment from hell today.
I had a rear sway bar install and inspection done the week before last while I was on vacation as well as front control arm bushings.
They said they did an alignment, but ...
I noticed the rear toe-in on the right rear wheel was off (too much toe in) when I got it back and got around to fixing it today.
First, it took me about an hour to find my eccentric socket tool for adjusting the rear toe.
Then, I kept shifting the trailing arm with the MINI tool and kept getting either not enough or too much correction over and over.
I tried to make sure the road was level and that I was always parked in the same spot and took a little drive around the block to
settle the suspension after each trial, but still kept getting wonky readings. Checked the rear trailing arm bushings and control arms
for slop, etc, but they were all ok. Front alignment was fine after the control arm bushings install, same as before.
After about 4-5 hours, I finally spun that wheel and noticed quite a bit of wobble (other 3 wheels were fine).
Took the wheel off and noticed that the circlip for the hubcentric ring was not seated properly, and the ring was sticking out on one side,
giving the wheel about a 1 degree angle, hence the wobble and inconsistent alignment readings for camber and toe on that wheel.
Probably happened when the pulled the wheel for inspection.
Pulled the centering ring out (with some difficulty), got the wire ring in its groove, and tapped the centering ring it in flush and correct - no more wobble.
After that, it only took an hour or so to get things pretty close to goal.
Plus, I was on call today and had to stop to answer a couple pages, and had to stop another time for a half an hour for brief rain.
I'm glad that ordeal is over.
Old Jun 24, 2018 | 07:49 PM
  #19668
bratling's Avatar
bratling
Super Moderator
Installed Earthquake SWS-8i speakers into my spouse’s R60 Countryman S.
I discovered that all the online “howto” guides assume you are replacing the nicer Harmon Kardon speakers, which are screwed in and easy to remove. The base audio speaker drivers are GLUED in.
I ended up buying a whole speaker unit from eBay just so I could figure out how to open it without risk of damaging her car. A heat gun on high, several trim panel pry tools, two screwdrivers, one utility knife, a lot of cursing and one blood offering later I was able to remove the POS 6” driver.
At at which point I was ready to disconnect the battery, remove the seats, extract the speaker enclosures, replace the drivers and put it all back together.
I used Technic PNP’s wiring harness and brackets, which on one hand are expensive for laser cut plastic and wires, but on the other hand are TOTALLY worth it for reducing hassle splicing wires and adding potential points of failure. The R60 shares its audio components with the E9x BMW, so these all work:
https://technicpnp.com/product-categ...-3-series-e9x/
The bottom end is filled out nicely and midrange sounds better as well. They work well enough with the Infinity 4” drivers already in the doors. I’d like to put in a proper amp and set high and low pass filters and adjust the levels on each pair… eventually. But for now, my spouse is very happy, so I’m happy!
Also, I put in an arm rest I had removed from my old R55. Again she was thrilled.
Old Jun 25, 2018 | 09:46 AM
  #19669
Snaps's Avatar
Snaps
Got the alignment done yesterday, so now Egan drives straight and true with his new parts.
Now to decide what to do next...
Old Jun 26, 2018 | 05:29 PM
  #19670
Docsigns's Avatar
Docsigns
I want to convert my base 2006 mini R50 W10 Engine to a turbo. So my question is, has anyone done this and will a 2007 turbo manifold fit the W10 engine?
Old Jun 27, 2018 | 07:03 AM
  #19671
DneprDave's Avatar
DneprDave
No, They are completely different engines.
Old Jun 27, 2018 | 10:00 AM
  #19672
Eddie07S's Avatar
Eddie07S
I have seen R53 conversions to turbo. You would have to do some searching to find some posts about that.
However, there is a reason yours is a R50 and the supercharged S and JCW are a R53. That is the R53 is a different body that is stronger to take the added HP. The R50 also has a weaker engine than the later R53s, lower performance cam, different head, different transmission and different ECU. The R50 wouldn’t be my first choice to hop-up.
Old Jun 27, 2018 | 10:12 AM
  #19673
daviday's Avatar
daviday
Everything I’ve read advises not to FI the R50 motor. Unfortunately I’m in the same boat as you. It’s only a matter of time before I blow up my midlands again. Trying to find a mostly intact R53 salvage car for cheap to do something along the lines of what you’re trying to do.
Old Jun 27, 2018 | 12:38 PM
  #19674
Docsigns's Avatar
Docsigns
Turbo Update
I did some research and it was suggested that a remote turbo install would be the best due to the exhaust space created by the OEM muffler removal.
Old Jun 27, 2018 | 01:40 PM
  #19675
edgy's Avatar
edgy
Received my Fumoto drain valve today to replace the rounded off-not really 13mm drain plug on my R53. If it wasn't 104 degrees out, I'd be looking forward to getting this job done but it's just hot. AND, I see that my functional hood scoop must have a broken clip (they're all breaking, it seems) and is trying to chase the wheel arch molding that blasted off my car a week ago. Still ... I love my L'il Red!
