Navigation & Audio [eas] Official DICE iPod integration kit Q/A thread
Old Sep 12, 2008 | 07:44 AM
  #801
Volker's Avatar
Volker
Originally Posted by Ferroequine
Is anyone else having weird radio display issues after upgrading their iPod firmware?
I updated my Touch to 2.2 last night, and now my playlists are only scrolling portions of the song information. Sometimes it freezes until the next song comes on.
you might have tried it already:
Try the following steps:
Press CD6/TRACK99 (<< arrow 2x)
Press CD1
Press CD6/TRACK01
Return to CD1
This will toggle the text on/off and should get things back up to speed.
From Tom for one of my issues. Let me know if it works.
Old Sep 12, 2008 | 11:22 AM
  #802
tom @ eas's Avatar
tom @ eas
Not that I'm aware of, we're using a 3G iPhone with 2.1 at the present moment.
Old Sep 12, 2008 | 09:40 PM
  #803
Ferroequine's Avatar
Ferroequine
Press CD1
Press CD6/TRACK01
Return to CD1
Thanks, that did the trick. Everything is back to normal.
I love this forum!
Old Sep 13, 2008 | 12:20 PM
  #804
Volker's Avatar
Volker
Old Sep 15, 2008 | 01:59 PM
  #805
skillet's Avatar
skillet
ok, I've already e-mail Dension about my issue, but have a feeling it can be solved faster here...
I bought the ICELINK+ probably about 2 years ago. It's revision 2.10a. I had it connected to my 4th Gen iPod Classic, and was able to use my clickwheel with the iPod UI setting.
Well, I bought an iPod Touch. Now when it's connected, I get the "Accesory Connected" message, and can't get past it... I have to unplug it, to be able to scroll through artists... When I get to the artist I want, I push play, and then plug it back in. I'm also wanting it to allow my wife to watch videos while connected, but we get the same message. Please help.
Thanks!
Old Sep 15, 2008 | 05:44 PM
  #806
tom @ eas's Avatar
tom @ eas
Thanks!
You'll have to speak with Dension directly as the ILP kits are not sold/supported in the US. We only support DICE.
Last US supported release was 2BB2.
Old Sep 15, 2008 | 06:21 PM
  #807
skillet's Avatar
skillet
Hmmm. Interesting. I bought mine from Dension, and thought many people had it over here... Maybe I don't have the IceLink+ Maybe it's the DICE...
Old Sep 15, 2008 | 06:37 PM
  #808
tom @ eas's Avatar
tom @ eas
Dension hasn't been in the US since 2005. Can you check your module to be sure?
Old Sep 16, 2008 | 09:06 AM
  #809
skillet's Avatar
skillet
Ugh, now you're gonna have me pull my dash appart... As soon as I get time, I'll do that. The box it came in says ICELINK: Plus... hmm....
Old Sep 16, 2008 | 10:14 AM
  #810
tom @ eas's Avatar
tom @ eas
I would recommend contacting Dension directly at support@dension.com for support on your icelink.
Old Sep 17, 2008 | 06:05 AM
  #811
skillet's Avatar
skillet
Just to let you know. I downloaded the 2.07 update (I'll progress up to the 2.18 ASAP), and then connected my sisters iPod with clickwheel. As soon as I hit disk 6, it took me to the user screen where I could select "iPod UI." After I selected it, it told me to disconnect the iPod, then re-connect. Well, I disconnected it, then reconnected my iPod Touch. Now I have full control through my iPod! It's working how I want it too, now. Hopefully this'll help someone else. Thanks!
Old Sep 17, 2008 | 10:44 AM
  #812
skillet's Avatar
skillet
For those freaking annoyed by the "Accesory Attached" screen , here's how I over came it with my 1st gen iPod Touch (latest software version of 2.1).
Firmware can be found at http://www.dension.com/dension_apple_matrix.html
1. Erase all songs on your iPod/iPhone (you're only going to want the firmware on your iPod/iPhone.
2. You're going to want to download the firmware in steps (2.07, then 2.15, then 2.18 if you choose to go that far) I currently have 2.07. Also, only download one version at a time.
3. After all songs are gone, upload version 2.07 to you iPod.
4. Go out to your car, flip over to your Dension mode (hit the mode button on your head unit till you see CD-1)
5. Open up your music and you'll see your "update" file.
6. Open that up and select the first track.
7. As soon as it starts playing connect your iPod/iPhone to the Dension cable.
8. It'll start scrolling through all the tracks (approx. 750)
9.It'll also start flashing between "Accessory Attached" and you being able to see the files play.
10. Walk away from the car Give it about 10-15 minutes. It'll stop scrolling and if I remember correctly, still display "Accessory Attached"
11. Connect an older scroll wheel iPod to the Dension (I had to use my sister's as my 4th gen Classic just took a crap... )
12. Hit disc 6 on the head unit
13. Now look at the iPod, you should see a list of options.
14. Use your steering wheel controls to (the ones on the left) select up or down. Hold the button (like you're fast forwarding) to select that option. Basically, you're looking for the "iPod UI" option. Again, scroll to it (it should be highlighted, then press and hold your "next track" button (head unit or steering wheel).
15. It'll tell you to disconnect the iPod, then reconnect it. Only disconnect it.
16.Connect your new iPod/iPhone
That should solve your issues.
This only take maybe 30 minutes total. Seems like a lot, but it's not. If you're having any more issues, let me know. I'll try and help you out the best that I can. Good Luck!
Old Oct 7, 2008 | 12:12 AM
  #813
brian.dayton's Avatar
brian.dayton
Am I reading the compatible list correctly and that the R56 model is not supported?
I have an '07 MCS with the Boost radio. I really want the iPod integration, but will never give in to $500 parts/install direct from Mini.
If it's correct and it will not work with my setup are there other options? For the most part I really only care for the charging and the change track function from my steering wheel.
Old Oct 7, 2008 | 10:30 AM
  #814
tom @ eas's Avatar
tom @ eas
DICE will not work with the R56 as they have made the move to fiber optics (MOST). Your only options are the MINI-branded kit or mObridge.
Old Oct 7, 2008 | 10:36 AM
  #815
brian.dayton
That's what I was afraid of. Looks like the best method for the R56 is to just have the iPod mounted on the dash and use the AUX input. Thanks for the quick response
Old Oct 7, 2008 | 11:31 AM
  #816
skillet's Avatar
skillet
Or just get a Belkin adapter that charges and plays your iPod over FM channels. You won't have control over your iPod with the steering wheel controls, but it's better than having to pull your iPod out at night to charge... just a suggestion.
Old Oct 7, 2008 | 11:39 AM
  #817
brian.dayton
Thanks for the input. I really like the AUX connection for it's clarity. I found the Kesington LiquidAUX should suffice. I already have a kuda mount though, so I might check to see how I can connect this mount properly onto it and make a custom setup using them both.
http://us.kensington.com/html/14493.html
Old Oct 12, 2008 | 09:24 AM
  #818
The_iaiN's Avatar
The_iaiN
Ok, so here's my story. Up until yesterday I've been enjoying using my IceLink+ v2.01 (for those who are not sure if they have one, it's about the size of a finger and covered in black heatshrink... the Dice is a box). Suddenly, I get ALOT of problems from my MINI:
• no turn signal indicators
• tail lights wouldn't turn off
• no output from the radio
• no function from automatic system (i.e. i could turn up the fan on the A/C, but pushing auto would shut that off completely)
• Nav Display would not go past the initial MINI logo
I checked all the fuses (hoping to cut the power to something, cause it to reset and fix the entire situation), but replacing the blown fuse I found didn't fix anything. Then I remember the IceLink I had behind my parcel shelf, i had installed it using the HU wiring harness. Once I had removed that everything went back to normal. So it seems I'm in the market for a new iPod solution.
After reading this entire forum (yeah... wow...) I think I've narrowed down my options. I have a 2005 (04/05 build) MCS with the HK radio system (SN A0464450) and Navigation, so I'm looking at either the DICE RDS Universal Kit or the DICE Silverline and I have a few questions:
1. Does this seem like the wiring harness is ok?
2. I know the Silverline is officially not compatible with the OEM navigation system, but I've grown accustomed to using the iPod's interface (disabling the IceLink's override), so I would probably use the simple iPod interface (disabling the Silverline's Features... like it's ability to disable the Nav). Is it compatible with the installed wiring harness or would I need to replace that?
3. Someone had reported a problem with Navigation Audio, but I've never had this problem. Do the DICE harnesses not pass all of the pins though to the MINI harness? What's the deal here?
4. I know the RDS isn't an FM transmitter, but does it still require tuning into a specific radio station?
Old Oct 13, 2008 | 12:54 PM
  #819
tom @ eas's Avatar
tom @ eas
The ILP module has failed and is grounding out ibus - it needs to be removed immediately.
Since you have the Plus, there's no reason to repurchase the wiring. Simply get the DICE module upgrade and plug it in - you're back in business:
DICE - SILVERLINE iPod Integration Module Upgrade
http://www.europeanautosource.com/pr...oducts_id=1638
In the position you're in - you'll end up spending more for the RDS kit and end up with less features.
Old Oct 13, 2008 | 01:39 PM
  #820
The_iaiN's Avatar
The_iaiN
So you're fairly certain that the ILP failure won't have damaged the harness? I also just wanted make sure that these two were compatible... you can look forward to my business as soon as I can scrape together the coin.
Old Oct 13, 2008 | 01:44 PM
  #821
tom @ eas's Avatar
tom @ eas
A continuity test will verify if the harness is damaged or not.
Old Oct 25, 2008 | 08:44 PM
  #822
ttechatl's Avatar
ttechatl
Silverline seems to be failing
I purchased and installed a Dice Silverline in dash model back around May for my '05 Cabrio S. I updated the radio to an '06 in order to get the Ipod text to display. Everything worked perfectly for about a month then the text stopped displaying. I read through this thread and decided I'd try undoing the battery for a night. This fixed the problem for a week until the issue came back. Tried some other reset suggestions in here but I could only get the display back for a week or so. I finally just resigned myself to not having the radio display as I am happy with the ability to use my Ipod intergrated into the controls. Now this week a new problem has started. My ipods are no longer being charged by the Silverline. One thought I had was the summer heat was causing the problem with the display but it's been cool lately so I can't think this has caused the charging failure. The unit is velcroed behind the A/C controls and toggles in the area under the head unit. I now have to charge them in the house in order to use them in the car. I have this same issue with my older Ipod and both my Ipod minis.
I am out of ideas. Anyone else have any or do I just have a bum unit?
Thanks in advance!
Old Oct 27, 2008 | 12:07 PM
  #823
tom @ eas's Avatar
tom @ eas
Thanks in advance!
Are there any other devices installed (electrical) in the MINI?
Old Oct 28, 2008 | 04:31 AM
  #824
ttechatl's Avatar
ttechatl
Hi Tom,
The only thing that's not factory is a Sirius receiver line out connected to the aux port on the Silverline. I'm able to select it and use it as the instructions indicate. This was added mid-summer after the display issues surfaced so I can't attribute it to the display failure.
Thanks for the reply!
Old Oct 28, 2008 | 08:36 AM
  #825
The_iaiN's Avatar
The_iaiN
Ok, so I've received my silverline and I have two problems:
1. A few times if I leave the iPod in the car long enough for it to turn off the display then start the car I get nothing but static. If I cycle through the modes back to CDC it works fine.
2. The dip switches are difficult to move from off to on... what am I supposed to use to manipulate these?
