F55/F56 Mini coding/programming
Old Jan 22, 2019 | 02:15 PM
  #926
orangedrink888's Avatar
orangedrink888
Disable Front Parking Lights?
Anyone know the coding to disable the front parking lights?
Old Mar 9, 2019 | 02:11 PM
  #927
ghstrdr's Avatar
ghstrdr
Originally Posted by JosephM635
I can confirm that this coding works for the:
JCW Tach and Gear Selection in HUD
HU_NBT > EXPERT MODE > HUD_SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
Code
Then
KOMBI > EXPERT MODE > FZG_Aussttang,HUD _SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
Code
So Cool!
I had to cycle the ignition twice to get rid of the error message.
What driving mode were you in when you took this picture? I believe that this is factory for sport mode on JCW's with the HUD but am interested if this activates it for all driving modes.
Old Mar 9, 2019 | 02:30 PM
  #928
JosephM635's Avatar
JosephM635
Once Coded, this works in every driving mode on my 2015 Cooper S F56.
Old Mar 13, 2019 | 05:41 AM
  #929
sgscomps's Avatar
sgscomps
I coded the JCW tach in my HUD, it’s in the same location as my NAV directions so now my NAV doesn’t display. Is there a way to move the tach to the other side of the HUD so both are present?
Old Mar 13, 2019 | 06:04 AM
  #930
emulajavi's Avatar
emulajavi
Sadly it seems that’s the default behavior is that: if you enable the JCW tach on the HUD settings, the NAV directions do not display at all. You have to have the JCW tach disabled, and so, only the speed shown with a ‘blank space’ to the right to get the NAV directions to show on that ‘blank space’.
The logical behavior would be to always show NAV directions (if NAV directions are activated on HUD settings) no matter if the Sports displays - JCW tacho is activated or not in that settings.
Old Mar 13, 2019 | 06:45 PM
  #931
sgscomps's Avatar
sgscomps
I was hoping to be able to have both at the same time. I'll try turning off the JCW tach in settings and see if the nav comes back. I can always turn the tach off when I want to use nav for trips.
Old Mar 24, 2019 | 02:07 PM
  #932
callumensor's Avatar
callumensor
Indicators as DRLS
Hi does anyone know how to code the indicators as the drls, so I have a amber light constantly on when drls are on.
cheers
Old Mar 29, 2019 | 09:33 AM
  #933
Banner28's Avatar
Banner28
Hopefully this is the proper place for posting this. Does anyone know the codes to keep the "Angel Eye Halo's" on with the fog lights when placed in the Parking Lights toggle position. I can code the fog lights on with DRL's so that the full fog light is lit up in parking light position. However, after my ECU got reset by the factory, I cannot seem to get the Halo to stay on with the fog lights. Example of how my car used to be below
Old Apr 4, 2019 | 02:41 PM
  #934
DunkM's Avatar
DunkM
Just an update for everyone, I have updated the first post in the "Union Jack" thread to cover physical install, coding removal of the errors, and changes to both the US lights for correctly working the turn signal during braking and the EU lights for correctly working brake force display.
Old Apr 13, 2019 | 10:02 AM
  #935
Asssuuu!!!'s Avatar
Asssuuu!!!
Looking for some coding guidance to turn off the welcome gongs/chime, what would be the code? I just hate that bee-bop bee-bop sound every time the car started. What is it under?
Also, I tried to do the accoustic confirmation upon locking/unlocking the car. The checkbox succesfully appeared on the idrive system but it does not do anything. What gives? The 2015MCS simply does not have the small beep speaker?
Succesfully added the JCW tach, roll up all windows by holding the lock button.
Old Apr 13, 2019 | 12:15 PM
  #936
vetsvette's Avatar
vetsvette
Moderator
You won't get the confirmation beep unless you have the factory alarm system. The gong/chime should be in the shortcut menu. It's been a long time since I coded mine out.
Old Apr 13, 2019 | 09:27 PM
  #937
Asssuuu!!!'s Avatar
Asssuuu!!!
thanks, i was able to remove the welcome gongs. It was under seat belt reminder...
Too bad, it seems i do not have an alarm system.
Old Apr 13, 2019 | 10:13 PM
  #938
vetsvette's Avatar
vetsvette
Moderator
I was disappointed when I couldn't get the confirmation beep too. Old ears don't always hear the locks click in a busy area.
Old Apr 18, 2019 | 04:45 PM
  #939
curlywurly's Avatar
curlywurly
Coding LCI analog clock to the central screen display?
Image below to illustrate. I recently noticed the 'home' or dormant screen on LCI's has a sweet analog clock display, with date below.
Anyone stumbled on coding options for this?
Old Apr 19, 2019 | 11:29 AM
  #940
N0B0DY's Avatar
N0B0DY
That's just the screen saver. Not sure if it's in the older system;
Old Apr 23, 2019 | 06:23 AM
  #941
xentar's Avatar
xentar
Same here.. Although you can code the car to sound the horn when you lock the doors while the engine is running. I hope there is a way to code the same when the engine is off.
Old Apr 23, 2019 | 02:24 PM
  #942
Warren2185's Avatar
Warren2185
Bimmercode could not access my head unit to turn off the legal disclaimers that come up every start-up. I'm bummed.
I have a 2019 JCW 3 dr without the navigation. So it's a 6.5 display with no touchscreen. But it has Mini Connect and everything else Anyone had any luck with another coder, Esys?
Old Apr 23, 2019 | 04:38 PM
  #943
Sansho's Avatar
Sansho
Have you contacted the BiimmerCode author about this? It worked on my 2018 MCS.
Old Apr 23, 2019 | 04:53 PM
  #944
Warren2185's Avatar
Warren2185
Yes, Bimmercode replied to my email...."that head unit is not supported at this time"
Sansho, was your 2018 the non-touch screen 6.5" display? It does appear the 8.8 Navigation/Touchscreen in the 2019 definitely is supported.
Old Apr 23, 2019 | 10:05 PM
  #945
N0B0DY's Avatar
N0B0DY
He told me the same thing too. We need more people to request this for the 6.5” display.
Old Apr 25, 2019 | 06:34 AM
  #946
Sansho's Avatar
Sansho
Mine has the 8.8" display.
Old Apr 26, 2019 | 03:56 PM
  #947
Sansho's Avatar
Sansho
Hmm, thought I replied to this, but don't see it ... I have the 8.8" navigation display on my 2018.
Old May 17, 2019 | 12:52 AM
  #948
axman207's Avatar
axman207
Hello I have a 2015 cooper s with the factory jcw package on it but want to remove fog lights to convert it to jcw look. After I do this I would get error codes with the removal of the fog lights and also the sidelights would need to be changed from the fog lights to the headlights. Thank you very much guys and hope someone can help
Old May 17, 2019 | 07:44 PM
  #949
artmem's Avatar
artmem
I recently used Bimmercode to enable the rear fog lights in my 2019 F56 S. They work fine, but since then, I regularly get warnings that my rear brake lights and rear turn signals are malfunctioning (they aren’t). Sometimes it goes away if I restart the car, and sometimes ithe warning stays for a few days and then goes away. Any ideas wha might be causing this?
Old May 17, 2019 | 07:46 PM
  #950
TVPostSound's Avatar
TVPostSound
Did you get the right headlamp switch?
