F55/F56 Mini coding/programming
Old Aug 12, 2021 | 06:35 PM
  #1001
maaii's Avatar
maaii
Hello sir
Can you check the kafas 7e fsc status again? E-Sys => Comfort Mode => FSC => Check fsc status
find 7e status
Old Aug 16, 2021 | 03:09 AM
  #1002
dertimaushh's Avatar
dertimaushh
Originally Posted by dertimaushh
Dear all,
i am in the process retrofitting Speed Limit Info to my 03/2018 F54.
I've checked that my car has the KAFAS2 camera and just received the offical FSC Code from BMW.
I have E-Sys installed and and E-Net cable at hand.
Now I am looking at E-Sys and complied the below process:
  • E-Sys => Options => Settings => FSC Tab => Certificate Field: Load FSC Code Certificate --> xxxxxxx_007E0001.der)
  • E-Sys => Comfort Mode => FSC => FSC Field: Load FSC Code --> . xxxxxxx_007E0001.fsc.
  • FA Field: Select "Read FA" to use cars current VO.
  • Parameter Fields:
  • Diagnostic Address (hex) = 0x5D ??? --> Is that correct?
  • Application Number (dec) = 0x7E
  • Base Variant = KAFAS2 ??? --> Is that correct?
  • Upgrade Index = 0x01
  • Select "Upgrade FSC" to Import and Activate FSC Code.
Do I have to add the SLI Option to my VO first and what FDL changes are necessary?
  • From an F45 SLI Activation - i found the below required codings:
  • On the KAFAS 2 ECU:
  • <<< CAFD_00001148.caf.000_029_006 (Kafas2) >>>
  • Kafas2 > SLI_CODING 3010 > NPI_ON_OFF = F056
  • Kafas2 > SLI_CODING 3010 > SLI_ON_OFF = F056
  • On the KOMBI ECU:
  • <<< CAFD_000009C8.caf.006_004_021 (KOMBI L7_MID) >>>
  • KOMBI L7_MID > Anzeige_Konfiguration 3000 > SPEED_LIMIT = aktiv
  • KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_APPL = aktiv
  • KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_TIMEOUT = aktiv
  • KOMBI L7_MID > FZG_Ausstattung 3003 > ANZEIGE_NPI = aktiv (Note: I think NPI stands for no passing information)
  • KOMBI L7_MID > FZG_Ausstattung 3003 > TSM_ENABLE = aktiv
  • KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_SPEED_LIMIT = aktiv (Note: This was already aktiv for me)
  • On the Head Unit ECU:
  • <<< CAFD_00000DED.caf.003_015_037 (HU_NBT) >>>HU_NBT > EXBOX 3001 > SPEEDLIMIT_INFO = aktiv
I would have to change instead: HU_ENTRYNAV2 + SLI_NAVI_DISPLAY to aktiv
Many thanks,
Tim
The above works :-)
Old Aug 24, 2021 | 03:57 PM
  #1003
ranger052's Avatar
ranger052
Hi all,
2022 F60, I was able to code the following:
- Handle Lights On with reverse
- Fogs on with HB
- Declaimer removed
- Auto Fold Mirrors when closing and opening
- Removed fake engine sound
Questions:
- Tire temperature wont show, even after coding a few times. Any ideas?
- If I add blinkers to the HUD , would it auto remove anything? I know if I add JCW sport display to the HUD then the GPS wont show during navigation.
Thank you all!
Old Aug 24, 2021 | 07:44 PM
  #1004
maaii's Avatar
maaii
-----> no support temperature in ENTRYNAV2 HU
-----> no support blinkers in HUD
Old Aug 24, 2021 | 09:36 PM
  #1005
bgdrewsif's Avatar
bgdrewsif
I don't think anyone here had been able to get the turn signal green arrows to show up in their head-up displays... I wish we could, it would be one little extra bit of MINI-awesomeness. As for the tire temps, I got it to display on my tire pressure screen on my 2016 F56 base Cooper... I keep a running text file in my cloud storage of all the coding changes I have made to my MINI and for the tire temp I only have this wrote down:
Display Tire Pressure & Temperature in Vehicle Info: 3001 RDC_SAFETY = aktiv
So that must be what worked for me on that.
I also added the JCW sport display option and it only comes on if you are in SPORT mode so if you are in GREEN or MID you will still have the navigation on your HUD and if you go from sport back to mid or green the JCW display goes away and the turn by turn navigation will reappear.
Old Aug 24, 2021 | 10:04 PM
  #1006
maaii's Avatar
maaii
In old NBT or entrynav HU, temperature can show on.
For JCW sport display, you can code to show on any mode and also gear
Old Aug 25, 2021 | 10:35 AM
  #1007
ranger052's Avatar
ranger052
Thank you,
How did you coded the JCW display to only show on Sport Mode?
Can you share the code?
Old Aug 25, 2021 | 11:53 AM
  #1008
bgdrewsif's Avatar
bgdrewsif
Originally Posted by ranger052
Thank you,
The directions I followed and wrote down on my running log of coding changes are as follows:
JCW in Head up display in sport mode:
go in to expert mode in both the HUD and KOMBI ECUs and enable the following: (All to “aktiv”)
HU_NBT > EXPERT MODE >
HUD_SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
Code vehicle then...
KOMBI > EXPERT MODE >
FZG_Aussttang,HUD _SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
----HUD_FAHRSTUFE_ENABLE*
Code vehicle again.
-On center instrument Go to SETTINGS --> HEAD UP DISPLAY --> DISPLAYED INFORMATION: make sure SPORTS DISPLAYS is checked and at least "In SPORT Mode" is checked as well. Sports Displays only work in SPORT.
JCW Led light ring
NBT_HU_EVO > 3000 > John Cooper Works HMI > Aktiv then enable in settings under standard view
Hope that helps.
Old Aug 25, 2021 | 03:22 PM
  #1009
ranger052's Avatar
ranger052
Code vehicle again.
JCW Led light ring
Hope that helps.
Thank you so much!
Will try tonight
Old Aug 25, 2021 | 05:52 PM
  #1010
bgdrewsif's Avatar
bgdrewsif
Thank you so much!
Will try tonight
Let us know if that works out for you
Old Aug 25, 2021 | 07:07 PM
  #1011
ranger052's Avatar
ranger052
Hi,
I was able to code almost everything but the below part:
I cannot find that anywhere on the app, I am using Bimmercode's latest app.
Any ideas?
Old Aug 25, 2021 | 10:05 PM
  #1012
bgdrewsif's Avatar
bgdrewsif
Hi,
Any ideas?
Not that it would be the most helpful advice but all I could suggest is what I would do if it were me doing the coding which is 'look again' . I know on some of the menus on Bimmercode in expert mode there are like 300+ different things that all look very similar in weird German-speak in an endless list... I would just start over and carefully and slowly scroll through everything under the KOMBI menu... or maybe the JCW sport display works without it (doubtful but possible?). I know sometimes I have had to sit in my car with my iPad for 20+minutes scrolling and scrolling to find one single option buried in there somewhere...
Old Aug 26, 2021 | 06:45 AM
  #1013
ranger052's Avatar
ranger052
So, I emailed Bimmercode support and they told me those settings are not available or supported right now.
here is their reply:
Hi,
this would be available in the instrument cluster, but the one in your car is not supported unfortuantely.”
Old Aug 26, 2021 | 01:37 PM
  #1014
S_Banks's Avatar
S_Banks
If "HEAD_UNIT" doesn't show up in your list of settings in the Bimmercode app, it could be because you have a "Basic Infotainment System" (BIS). This is what my MINI has and I don't even see Head_Unit in BC.
Old Aug 26, 2021 | 02:07 PM
  #1015
ranger052's Avatar
ranger052
Hi,
Thank you.
No, I have a fully loaded F60 with all extras.
Bimmercode just does not offer that coding for the new Mini Head units.
I contacted another company who can do the codding remotely but I need to buy a cable. I will try to get the cable and get that code in unless you guys have any other idea?
Old Aug 27, 2021 | 12:31 PM
  #1016
bgdrewsif's Avatar
bgdrewsif
Hi,
Thank you.
So if one buys a new model MINI Bimmercode becomes useless? :-(
Old Aug 27, 2021 | 03:41 PM
  #1017
ranger052's Avatar
ranger052
Not unless as most of the coding works, but anything under instrument cluster is gone till they release an update that regain access to that section.
Old Aug 27, 2021 | 03:42 PM
  #1018
ranger052's Avatar
ranger052
Another question guys.
On my F56 I had a code that would allow the fogs to turn on with the Auto Light Sensor, does anyone know the code so I can do it on the F60? I honestly forgot :(.
Old Nov 13, 2021 | 02:52 PM
  #1019
aquila0651's Avatar
aquila0651
Hi guys,
I want to install new 6WB digital cluster in Cooper S F56. I'm french and I have tried everything...
Uninstall and install multiple times ... Esys 3.27.1 and Prolauncher 2.8.2 BFU_XODE edition
when I open prolauncher, "date incorrect or date manipulation detected" error
when i change the date it works, but the token expires in 04/2020 error
when I change the date to 04/2020 "ONLY v2 EST files accepted" error
I will try tomorrow to clean all my disk ... Have you got any idea? I have the correct version of esys? Do you also use these versions?
I already have the obd cable and everything I need for the retrofit, I'm losing hope lol
Thank you for being so kind to answer me
Old Feb 18, 2022 | 01:28 PM
  #1020
Moycmika's Avatar
Moycmika
Hello everyone, I need your help, I'm new to coding. I am looking for a code to let the daytime running lights ring light up in position lights mode. because when I put the position lights, the ring goes out and instead I have a small LED light up in the anti fog lamp. on the jcw model it works like this. thanks in advance friends.
Old Feb 20, 2022 | 04:18 PM
  #1021
TVPostSound's Avatar
TVPostSound
The DRL option should be checked on in your instrument panel settings.
Thas how mine works, if DRL option is off, then the ring goes off in position (parking in the US) mode.
Old Mar 12, 2022 | 01:31 PM
  #1022
R3dl4b3l's Avatar
R3dl4b3l
Does anyone know if BimmerCode allows you to turn on parking lines, contract and brightness in the rear camera mode options?
My 2022 F56 SE had the options but are non selectable. I turned on the trailer hitch zoom option with BimmerCode and it shows the option but also grayed out along with the other 3 options.
Old May 5, 2022 | 07:44 PM
  #1023
TechTurbo's Avatar
TechTurbo
I am trying to find a list of FA Codes (VO Coding) for our cars but with no luck - so I decided to start one. Please add ones you have done.
Digital Cluster Retrofit
Add 6WB to FA, update Zeitkriterium to 0320
VO Code KOMBI
Enable Sport Transmission
Replace 205 with 2TB
VO Code EGS
Old May 6, 2022 | 04:00 PM
  #1024
Giantsfan107's Avatar
Giantsfan107
What is VO Coding?
Old May 6, 2022 | 04:06 PM
  #1025
TechTurbo's Avatar
TechTurbo
Originally Posted by Giantsfan107
What is VO Coding?
Vehicle option coding... to add/remove/change options equip with your car. Pls do a search there are many guides out there!
