Electrical Countryman-Specific Coding - R60 Guide
Old Apr 13, 2013 | 12:41 PM
  #676
Theta's Avatar
Theta
Should have them by this evening. Remind me if I forget tonight.
Old Apr 13, 2013 | 07:32 PM
  #677
Theta's Avatar
Theta
As promised: Here are the v49.0 Datens --
Download v49.0 Datens
Password: v49nam
Old Apr 14, 2013 | 12:27 AM
  #678
hyde76's Avatar
hyde76
Originally Posted by Shoe Coupe
yeah i think im on the bleeding edge. Im friends with the tech at the dealer and he sent me a pic showing it is 2.49.0 and the work papers the dealer gave me says the same thing. 2.49.0.
I had them reflash from 2.48.0 to 2.49.0 because the older version took out my bluetooth voice activation. 2.49.0 fixes this (and other stuff I presume)
What did your dealer show you to tell you that you were on 2.49.0? I just had my car reflashed for the brake software update and re-coded with the v48 datens afterwards, with no issues.
Old Apr 14, 2013 | 12:29 AM
  #679
Theta's Avatar
Theta
Sounds like he has it on the service order. It's not that far-fetched -- ISIS confirms loads beginning April 8th (last Monday).
Anyway, I have you guys covered as always.
Old Apr 14, 2013 | 01:22 AM
  #680
Shoe Coupe's Avatar
Shoe Coupe
Thank so much!!! I'm going to install this tomorrow and try it out.
Thanks again!
Old Apr 14, 2013 | 01:23 AM
  #681
Shoe Coupe's Avatar
Shoe Coupe
it says right on my paperwork that they updated to 2.49.0 to fix brake issue and also bluetooth issue.
  #682
Theta's Avatar
Theta
You're welcome - let me know how it turns out!
Old Apr 14, 2013 | 12:11 PM
  #683
Shoe Coupe's Avatar
Shoe Coupe
Password: v49nam
Theta, just downloaded, I see some extra folders in the zip, are the install instructions the same?
Old Apr 14, 2013 | 12:12 PM
  #684
Theta's Avatar
Theta
Yes - I just stripped the data folder and zipped the rest. Only use what you need.
Old Apr 14, 2013 | 12:45 PM
  #685
Shoe Coupe's Avatar
Shoe Coupe
worked like a charm! got my trip odo back where it belongs! thanks!
Old Apr 14, 2013 | 12:46 PM
  #686
Theta's Avatar
Theta
Wonderful - glad to hear it!
Old Apr 15, 2013 | 01:54 PM
  #687
falaly's Avatar
falaly
Anyone in Houston has experience with coding? I am lost and would like to get some help! Thanks in advance.
Old Apr 17, 2013 | 09:57 PM
  #688
jjangbuy's Avatar
jjangbuy
i have r60 countryman
Folding mirrios not remote key??
frm module ASP_KOMFORT_EINKLAPP aktiv yet
help me T.T
Old Apr 17, 2013 | 10:12 PM
  #689
Theta's Avatar
Theta
I'm not sure we understand you or what you're asking for...
Could you try to ask another way?
Old Apr 17, 2013 | 10:14 PM
  #690
Theta's Avatar
Theta
If you're asking about the ability to fold/unfold the mirrors with the fob, then no - that's not possible.
Another member and I were working on auto-fold on key out, but it was just over-complicated.
Old Apr 19, 2013 | 03:09 PM
  #691
creep's Avatar
creep
It's been a while since I recoded my 2011 Countryman to have 1 touch sunroof open/close. My car is currently at the dealer and they stated they need to keep it over night to reprogram.
If the sunroof option gets overwritten I'll have to recode. It's been a while since I recoded and I'm trying re-educate myself on how to do this using your handy guide and I have a couple of questions.
1) Do I need to use the new datens?
2) I'm a little bit confused by the daten files provided. I know those files are to be placed in the proper directories on the computer, but how do they interact with the data read in from my car? Does the daten version need to match what is read from my car and if so, how do I know which version my car has?
Thanks!
Old Apr 19, 2013 | 03:22 PM
  #692
Shoe Coupe's Avatar
Shoe Coupe
Thanks!
they updated my car, none of my 1 touches went away
Old Apr 19, 2013 | 03:46 PM
  #693
SFWD 1934's Avatar
SFWD 1934
I was reading through the thread. Has anyone been successful in coding a 2013 Countryman yet? I saw that the 2012 was untested in the original post.
Jason
Old Apr 20, 2013 | 01:47 AM
  #694
librayiu's Avatar
librayiu
Hi, I got 9/2012 Countryman S and tried to code by following the instructions in this post. INPA shows both Battery and Ignition are On but NCS Expert seems failed to even read VIN from my car. I tried Daten v41, 48 and even 49, all same failure result...
Anyone can help for my case.. Thanks!
Old Apr 20, 2013 | 12:05 PM
  #695
creep's Avatar
creep
Picked up my car today after the programming was done. You're right, none of the one touch went away.
Old Apr 20, 2013 | 01:03 PM
  #696
Theta's Avatar
Theta
Jason / SFWD - Yes, several 2013s have been programmed (including my JCW).
Old Apr 20, 2013 | 01:04 PM
  #697
Theta's Avatar
Theta
creep, it doesn't matter if you know the Daten version on your car. ALWAYS use the latest Datens posted here.
Old Apr 20, 2013 | 01:37 PM
  #698
manho1dup's Avatar
manho1dup
Thanks Theta for confirming on the 2013 countryman's. Looks like I'm coding my 2013 JCW CM today. Crossing fingers that it all goes well.
Old Apr 22, 2013 | 11:02 AM
  #699
hyde76's Avatar
hyde76
Check your cable. willing to bet there are two soldered pins that need to be unsoldered in order to work properly. Just open the cable, you'll see the soldered pins, heat up your soldering iron and touch it to the solder until it melts away. Once separated, close up your cable and try again.
I was very nervous about doing this myself but then I remembered that I'm a nerd with a cool car and I had an old soldering iron from an old computer kit. found it, plugged it in and I was in business in 5 minutes, coding 10 minutes later. Good luck!
One more thing, my cable worked on my 2011 R60 out of the box (soldered) but had to be unsoldered to work on my wife's 2012 R57. Now it works on both cars flawlessly.
Old Apr 22, 2013 | 11:32 AM
  #700
Theta's Avatar
Theta
You beat me to it - that's a cable issue. Pin 8 needs to be corrected - it's pretty common in this thread.
