Electrical Countryman-Specific Coding - R60 Guide
Old Feb 23, 2013 | 01:46 AM
  #626
MBj's Avatar
MBj
I already updated to V48
And yes there are different option for US and EU, but coding is the same and you can set the car from EU to US and back.
There is no difference in ECU or car itself.
Old Feb 23, 2013 | 11:19 AM
  #627
Theta's Avatar
Theta
Not to be argumentative, but that statement is incorrect.
While there is an option in the ECU/DME to switch region, that's certainly not the only difference...
The EU models are different chassis codes (ZC31 and ZC32) vs the US ZC33. The bumper and crash systems are different (as I have extensive knowledge of, sadly), as are many of the subsystems and modules, and the ECU is actually a bit different.
I'm not sure what you were basing your info off of, but I was simply trying to help by giving you a quick heads-up that some options, regardless of the inclusion in the modules, will not activate for EU and vice versa.
But assuming you know more about coding, I'll wish you luck and move on.
Old Feb 23, 2013 | 11:36 AM
  #628
MBj's Avatar
MBj
Thnaks for your informations.
I'm realy no profi in coding Mini (or BMW).
I come from the VAG (Audi) side and have done a lot of coding with a professional software there. Audi is using the same ECU in US and EU (execpt some small differences in crash sensoric and Radio).
At Mini I'm just learning (try and error) and appreciate all information you give me.
Old Feb 23, 2013 | 11:43 AM
  #629
Theta's Avatar
Theta
I've done a lot of coding with Audi, as well (and I believe TRIPLE_O has as well). The easy part about their vehicles is that they literally make one type, then just ship them overseas to other markets.
BMW, on the other hand, actually runs different lines for different markets. It ends up causing a lot of confusion, especially for US dealers. The parts get different numbers (even though some of them are the exact same), supply issues crop up, and it's a mess.
My infamous bumper modification thread is an example of the hallmark of stupidity (in my opinion), in that they actually reduced the effectiveness of the crash structure for the US market. In so doing, they also made the EU parts no longer compatible... It's the same story with 30+% of the other modules.
But the moral here is that while the Datens / TRC files are going to show the same text, the actual limitations are coming from the DME and BCM codes. Thus, some neat options that work on EU cars won't work here, and vice versa. Just makes for more of a mess as you can see.
Old Feb 25, 2013 | 03:04 PM
  #630
Zachrytx's Avatar
Zachrytx
I Know Im doing something wrong just not sure what? Here's what I've done so far.
1. Updated cable drivers (com6)
2. Installed software (restart)
3. Copy/paste datens v41 (did not create r56 dir)
4. Copy/paste sgdat
5. copy/replaced ecu
6. ran laden
7. copy/paste revtor
8. repeated 3-6 with v48
9. created FSW_PSW.MAN (saved all files) in work folder
10. Deleted any FSW_PSW.TRC in work folder
11. Went out to car turn on ignition
12. plugged in cable
13. started INPA (I get an error msg usb/serial) click ok on msg INPA screen comes up two solid black cicles (indicating communication) close INPA
14.Start NSC
15. Load profile Revtor
16.F1 VIN\ZCS\FA
17. F3 ZCS/FA
18. Choose R56
19. Choose CAS
20. F6 Back
21. F4 Process ECU
22. Selected Module
23. F4 Read Module (at which point the NETTODAT open in notepad window)
24. open work folder copy/paste FSW_PSW.TRC and NETTODAT.TRC file to named module folder
25. return to work folder open FSW_PSW.TRC file make code changes and save as FSW_PSW.MAN (which replaces empty .MAN)
26. Close FSW_PSW.TRC file return to NCS F3 Execute job
NCS shows coding ended so i turn the ignition off, but when I turn the car back on there are no changes. If I go thru the steps and open the module there are no changes.
Very Frustrated.....My head is getting bruised from beating it against the wall!! LOL!
Old Feb 25, 2013 | 04:04 PM
  #631
cm.d's Avatar
cm.d
After step 23. Try this.
Close NSC.
Do 24 and 25.
Do 14-22.
Then execute job.
Old Feb 25, 2013 | 05:45 PM
  #632
Zachrytx's Avatar
Zachrytx
cm.d
thank you for your advice. with one addition step 3 i reinstalled the software and this time did create r56 folder in datens dir. then i did as you advised and closed ncs then 14-22 executed job AND EUREKA MY FIRST SUCCESSFUL CODING!!!!
I choose "window close when you hold the lock button" for my first. I think though I'll let the dust settle from my robust celebration before I try more!
thx again to everyone on this thread!!!
Old Feb 25, 2013 | 06:18 PM
  #633
mikecalgon's Avatar
mikecalgon
Guys, Here I need a help.
when I pair my iphone 4 with mini visual boost, I only have option with phone call, In USA i believe most has audio via bluetooth. can you help me check what is your vo list. Not sure If I can get this function by change 6nd to 6ne or adding 6ne
mine
R60_#0712&T6E1%0B16*ZC51$1A1$1CB$1CD$205$210$249$2 58$2GU$2XA$302$313$314$325$345$346$383$386$403$423 $428$431$441$450$473$481$493$494$4C1$4C8$4CX$4UF$4 UK$4UL$507$520$521$522$534$548$550$563$5AA$5AH$5DA $5DT$674$6FP$6ND$6NM$736$785$818$825$866$876$892$8 AA$8KE$8S1$8SM$925$993-A070-EWS4
Old Feb 25, 2013 | 10:46 PM
  #634
MBj's Avatar
MBj
What code are you changing?
I have also some lines which switch back after rereading my coding.
Old Feb 26, 2013 | 05:36 AM
  #635
mikecalgon's Avatar
mikecalgon
Originally Posted by TRIPLE_O
Dynamic Brake Lights which I think are referred to as Brake Force Display (BFD) in BMW world, is coding that allows the rear fogs to illuminate when you brake. I've tried coding this line on a mini (with rear fogs), but it didn't work. However, I didn't check the VO to see if $5AH was in there. Try adding that option to your VO and then reset the IHKA and FRM modules.
Also, regarding DRL's, look in the FRM module and see if you can change one of the DRL options from nicht_aktiv to aktiv.
TRIPLE_O, thanks for your comments. maybe my FRM showing some info interested
BFD_1_ALGORITHMUS
nicht_aktiv
BFD_1_MIT_SL_1
wert_00
BFD_1_MIT_FRA_H
wert_00
BFD_1_MIT_BL_M
wert_00
WBLG_WBL_ENABLE
nicht_aktiv
BFD_1_MIT_BL
wert_00
BFD2_AKTIV
nicht_aktiv
BFD2_ESS_ENABLE
nicht_aktiv
BFD2_ESS_ANZEIGE
nicht_aktiv
BFD2_SL_1
blinkend
BFD2_BL_M
blinkend
BFD2_BL
blinkend
This language is strange to me, seems like I may change some nicht_aktiv to aktiv.
Do someone has a car with Dynamic brake lights activated ( flash when emergency stop), if yes, could you please share me your FRM file.
Old Feb 26, 2013 | 05:42 AM
  #636
mikecalgon's Avatar
mikecalgon
Not sure if this helps
when I code my car, I found some time the change was not saved. so I close NCS after reading ECU, then edit .man, then open NCS again to write.
Old Feb 26, 2013 | 12:07 PM
  #637
youthanasia's Avatar
youthanasia
Won't work. I spent a lot of time on this. The COM box is different between 6nd and 6ne. It's physical hardware that you are lacking to get bluetooth audio, not just coding.
mine
Old Feb 26, 2013 | 06:04 PM
  #638
mikecalgon's Avatar
mikecalgon
Thanks, Your experience saved my time
Old Feb 26, 2013 | 06:12 PM
  #639
mikecalgon's Avatar
mikecalgon
Old Feb 27, 2013 | 06:20 AM
  #640
MBj's Avatar
MBj
I have dynamic break lights.
here is my FRM:
Code:
CAN_11H
	nicht_aktiv
IBUS_R_GANG
	nicht_aktiv
IK_BUS_TEILNEMER
	nicht_aktiv
ERR_SCHWENK_R_IGNORIEREN
	nicht_aktiv
KLS_BEI_AL_AKTIV
	nicht_aktiv
ALC_EINSCHALTBEDINGUNG
	wert_01
ALC_SCHWENK_LATCH
	aktiv
ERR_LWR_L_IGNORIEREN
	nicht_aktiv
ERR_SCHWENK_L_IGNORIEREN
	nicht_aktiv
ERR_LWR_R_IGNORIEREN
	nicht_aktiv
KEINE_L_R_SYNCHRONISATION
	nicht_aktiv
CHECK_FGN_SMC_ALC_OFF
	aktiv
CHECK_SMC_ERROR
	aktiv
CKM_ALC_DEF
	wert_16
ABSTELLPOS_SMC
	aktiv
BLEND_CHECK_IST_WINKEL
	aktiv
BLEND_CHECK_SOLL_WINKEL
	nicht_aktiv
CKM_ALC
	wert_16
MAX_SW_SCHWENK_W_INNEN
	wert_16
MAX_SW_SCHWENK_V_HORIZ
	wert_16
MAX_SW_SCHWENK_V_VERTI
	wert_16
MIN_SW_SCHWENK_V_VERTI
	wert_16
ABSTELLPOS_CUSTOM
	nicht_aktiv
TAU_ABSCHWAECHUNG
	wert_16
LICHTZ_R_L_FAKTOR
	wert_16
SW_NULL_BEREICH
	wert_16
V_LO_SW_MITLENKEN
	wert_16
V_HI_SW_MITLENKEN
	wert_16
V_LO_SW_NACH_INNEN
	wert_16
V_HI_AENDER_LENK_UEBERS
	wert_16
V_HI_SW_NACH_INNEN
	wert_16
KENNL_MAX_UEBERST
	wert_16
KENNL_REDUZ_MAX_SCHWENK
	wert_16
T_FILTER_V_VEH
	wert_16
T_FILTER_UEBERST
	wert_16
V_LO_AENDER_LENK_UEBERS
	wert_16
V_LO_RED_SCHWENK_W
	wert_16
V_HI_RED_SCHWENK_W
	wert_16
ABSCHW_D_TAU_LO
	wert_16
ABSCHW_D_TAU_HI
	wert_16
KLASSIF_UEBERST_ENA
	aktiv
V_LO_ABSCHW_D_TAU
	wert_16
V_HI_ABSCHW_D_TAU
	wert_16
OHNE_GIERRATE
	nicht_aktiv
REDUZIERUNG_V_SCHWENK_HI
	wert_16
V_REFERENZLAUF_EN
	wert_16
KLASSIF_LENKM_ENA
	aktiv
KLASSIF_DRIFT_ENA
	aktiv
MIN_SW_SCHWENK_V_HORIZ
	wert_16
AEND_V_SCHWENK_N_AUSSEN
	wert_16
REDUZIERUNG_V_SCHWENK_LO
	wert_16
MAX_DELTA_KEINE_VERR
	wert_16
T_FILTER_LENKWINKEL
	wert_16
V_HI_REDUZIER_V_SCHWENK
	wert_16
MAX_VERRINGERUNG_V_SCHW
	wert_16
MIN_DELTA_MAX_VERR
	wert_16
D_TAU_MITTEL_LENKW
	wert_16
T_FILTER_GIERRATE
	wert_16
D_TAU_MITTEL_GIERR
	wert_16
V_LO_TAU_GIERRATE
	wert_16
T_FILTER_TAU_LW
	wert_16
V_HI_TAU_GIERRATE
	wert_16
T_F_GIERRATE_DEF
	wert_16
SCHW_TAU_LW_GR
	wert_16
T_FILTER_DYN_LZ
	wert_16
DRIFT_INKR
	wert_16
DRIFT_DEKR
	wert_16
DRIFT_SCHWELLE
	wert_16
RAUSCH
	wert_16
ZEITK_TRIGGER1
	wert_16
MERKM_1_MAX
	wert_16
MERKM_1_BEGR
	wert_16
ALC_SCHW_GRAD_SCHLECHTWEG
	wert_01
MERKM_1_INKR
	wert_16
MERKM_1_DEKR
	wert_16
ALC_GRADIENT_SCHLECHTWEG
	nicht_aktiv
LWR_ABSTELLPOS
	wert_01
MAX_SCHWENK_V_H_BEGR
	wert_16
VERHALTEN_UEBERWACHUNG
	wert_01
KURZSCHLUSS_ENTPRELL
	wert_01
KURZSCHL_WIERHOL_ZAEHLER
	wert_01
KURZSCHLUSS_CHECK_TIME
	wert_01
LENKWINKEL_UEBERSCHREITEN
	wert_01
LENKWINKEL_UNTERSCHREITEN
	wert_01
WELCOMELIGHT_CKM_3
	aktiv
LENKSTOCK_UMSCHALT_VERZ
	wert_01
U_POTI_DIMM_MIN
	wert_01
U_POTI_DIMM_DELTA
	wert_01
HEIMLEUCHTEN_ENABLE
	aktiv
MELDUNG_AENDERUNG_DIMMER
	wert_01
POTI_DIMM_INVERS
	aktiv
POTI_LWR_INVERS
	nicht_aktiv
HEIMLEUCHTEN_ABBRUCH
	nicht_aktiv
HEIMLEUCHTEN_VERLAENG
	nicht_aktiv
WARNBLK_ENERGY_SAVE_MODE
	aktiv
DEF_HEIMLEUCHTEN_CKM
	wert_02
UNP_HEIMLEUCHTEN_CKM
	wert_02
AUTOM_LICHT_ABSCHALTUNG
	nicht_aktiv
CODIERINDEX_FRM
	wert_01
MAX_BETAETIGUNG_FOMEHO
	wert_02
CRASH_WARNBLINKEN
	aktiv
SL_SCHALT_UMSCHALT_OPT
	300_ms
CRASH_58G_EIN
	aktiv
ENERGIE_UBATT_LIMIT
	wert_01
WERT_CRASHVERHALTEN
	wert_01
TIPP_BLK_LOESCHT_IMMER
	aktiv
WELCOMELIGHT_CKM_2
	aktiv
COLORTABLE
	wert_01
NOTLAUF_FKT_SCHALTERSTELL
	aktiv
NOTLAUF_FKT_GESCHW
	wert_01
NOTLAUF_FKT_TIMER
	wert_01
COLORSWITCH_LANGDRUCK
	wert_01
ENERGIE_ZEIT_LIMIT
	wert_01
TIME_PER_STEP
	wert_01
ENERGIE_ZEIT_ENTPRELL
	wert_01
LWR_MAX_POS_NORM
	wert_01
LWR_MAX_POS_REF
	wert_01
LOAD_DUMP_MAX_TIME
	wert_01
LOAD_DUMP_PRELL
	wert_03
UMSCHALTOPT_LICHTSCHALTER
	wert_02
U_LWR_POTI_STELLUNG_2
	wert_01
HALB/VOLLSCHRITT
	halbschritt
LWR_TESTBETRIEB
	nicht_aktiv
LWR_SCHRITTE_STELLUNG_0
	wert_03
U_LWR_POTI_STELLUNG_0
	wert_01
U_LWR_POTI_STELLUNG_1
	wert_01
LWR_SCHRITTABSTAND_GRENZE
	wert_01
LWR_TEMPERATUR_GRENZE
	grad_-20
FL_ASSIST_ENABLE
	nicht_aktiv
BFD_1_WERT_AX_RUCK
	wert_01
VORFELD_BEL_GEDIMMT
	aktiv
IB_2MIN_OPTION
	aktiv
IB_SOFTON_OPTION
	aktiv
FL_ASSIST_FUNKTIONS_ANZ
	nicht_aktiv
WARNBLK_ENERGY_SAVE_AHM
	aktiv
SMART_BEAM_CKM_1
	nicht_aktiv
SMART_BEAM_CKM_2
	nicht_aktiv
SMART_BEAM_CKM_3
	nicht_aktiv
ASP_LIN_VERBAUT
	nicht_aktiv
ASP_KEY_MEM_OHNE_MASTER
	nicht_aktiv
U_MIN_TK_SNU
	wert_01
DEF_ABBIEGELICHT_CKM
	nicht_aktiv
HYST_STAND_KRV
	wert_01
FL_ASSIST_ZUST_22_32
	nicht_aktiv
UNP_ABBIEGELICHT_CKM
	nicht_aktiv
HEIMLEUCHTEN_1
	wert_02
HEIMLEUCHTEN_2
	wert_02
HEIMLEUCHTEN_3
	wert_02
ABBIEGELICHT_CKM_0
	nicht_aktiv
ABBIEGELICHT_CKM_1
	nicht_aktiv
ABBIEGELICHT_CKM_2
	nicht_aktiv
ABBIEGELICHT_CKM_3
	nicht_aktiv
DEF_SMART_BEAM_CKM
	nicht_aktiv
UNP_SMART_BEAM_CKM
	nicht_aktiv
SMART_BEAM_CKM_0
	nicht_aktiv
BFD_1_WEGFALL
	nicht_aktiv
BFD_1_ENTPRELL_AX
	wert_01
DEF_AHL_MODE_CKM
	wert_01
UNP_AHL_MODE_CKM
	wert_01
AHL_MODE_CKM_0
	wert_01
AHL_MODE_CKM_1
	wert_01
AHL_MODE_CKM_2
	wert_01
AHL_MODE_CKM_3
	wert_01
FH_LANGHUB
	wert_01
TAU_ABSCHWAECHUNG_SP
	wert_16
SW_NULL_BEREICH_SP
	wert_16
T_FILTER_UEBERST_SP
	wert_16
V_LO_SW_MITLENKEN_SP
	wert_16
V_HI_SW_MITLENKEN_SP
	wert_16
V_LO_SW_NACH_INNEN_SP
	wert_16
H_SENSOREN_UEBER_FCAN
	nicht_aktiv
SCHRITTABSTAND_STARTPHASE
	wert_01
LWR_TREIBER_CODIERUNG_2
	wert_01
NACHLAUF_KLEMME_VA
	wert_01
BFD_1_THERM_TIMEOUT
	wert_02
BFD_1_MIN_GESCHW
	wert_01
BFD_1_STUFE_DELAY
	wert_01
BFD_1_BLINK_FREQ_AUS
	wert_01
BFD_1_BLINK_FREQ_EIN
	wert_01
BFD_1_ENTPRELL_ABS
	wert_01
WELCOMELIGHT_CKM_1
	aktiv
WELCOMELIGHT_CKM_0
	aktiv
KL_VA_EIN_BEI_ENTRIEGELN
	aktiv
V_HI_SW_NACH_INNEN_SP
	wert_16
KENNL_MAX_UEBERST_SP
	wert_16
KENNL_REDUZ_MAX_SCHWEN_SP
	wert_16
V_LO_AENDER_LENK_UEBER_SP
	wert_16
V_HI_AENDER_LENK_UEBER_SP
	wert_16
T_FILTER_V_VEH_SP
	wert_16
V_LO_RED_SCHWENK_W_SP
	wert_16
ABSCHWAECH_D_TAU_SP
	wert_16
V_HI_RED_SCHWENK_W_SP
	wert_16
MAX_SCHWENK_V_H_BEGR_SP
	wert_16
ABSCHW_D_TAU_LO_SP
	wert_16
MIN_SW_SCHWENK_V_HORIZ_SP
	wert_16
ABSCHW_D_TAU_HI_SP
	wert_16
V_LO_ABSCHW_D_TAU_SP
	wert_16
V_HI_ABSCHW_D_TAU_SP
	wert_16
AEND_V_SCHWENK_N_AUSSE_SP
	wert_16
REDUZIERUNG_V_SCHWE_LO_SP
	wert_16
V_LO_REDUZIER_V_SCHWEN_SP
	wert_16
V_M_LO_REDUZIER_V_SCHW_SP
	wert_16
RAMPE_EIN_BLK
	wert_01
REDUZIERUNG_V_SCHWE_HI_SP
	wert_16
V_M_HI_REDUZIER_V_SCHW_SP
	wert_16
V_HI_REDUZIER_V_SCHWEN_SP
	wert_16
RAMPE_AUS_BLK
	wert_01
MAX_VERRINGERUNG_V_SCH_SP
	wert_16
MIN_DELTA_MAX_VERR_SP
	wert_16
MAX_DELTA_KEINE_VERR_SP
	wert_16
RAMPE_EIN_KRV
	wert_01
RAMPE_AUS_KRV
	wert_01
RAMPE_EIN_RUE
	wert_01
RAMPE_AUS_RUE
	wert_01
V_S_LO_BLK
	wert_01
MAX_HEIZZEIT
	wert_01
HEIZ_ANF
	wert_01
HEIZ_KNICK
	wert_01
V_S_HI_BLK
	wert_01
ABK_VERLAENG
	wert_01
ABK_KNICK
	wert_01
ABK_MIN_PROZ
	wert_01
V_E_LO_BLK
	wert_01
V_E_HI_BLK
	wert_01
V_S_LO_KRV
	wert_01
V_S_HI_KRV
	wert_01
NACHL_RKW
	wert_01
BLK_TIMER_STAND
	wert_01
UNP_WELCOMELIGHT_CKM
	aktiv
DEF_WELCOMELIGHT_CKM
	aktiv
CC_MELD_LICHT_AN_WARNUNG
	aktiv
TIMEOUT_SET_DTC
	aktiv
DOPPELBLINKIMPULS_WARNBLK
	nicht_aktiv
DOPPELBLINKIMPULS_CRASH
	nicht_aktiv
FL_AUS_BEI_BIX_IN_S_FLC
	nicht_aktiv
WL_FL
	nicht_aktiv
WL_NSW
	nicht_aktiv
WL_DAUER
	wert_01
WL_MAX_DAUER
	wert_01
WL_ZYKLEN
	wert_01
WL_AL
	nicht_aktiv
WL_KZL
	soft_einschalten
WL_NSL
	nicht_aktiv
PWM_VFB
	wert_01
PWM_IB
	wert_01
PWM_NSL_FKT_SL
	wert_01
BREMSL_FKT_MIT_BFD
	nicht_aktiv
BFD_1_MIT_BFD
	wert_00
BFD_1_MIT_NSL
	wert_00
ALC_ZUSTANDS_AUTOM
	wert_02
ALC_ERR_NSW_ZUSCHALTEN
	aktiv
ALC_SCHWENK_IM_STAND
	aktiv
NEUE_FAHRT_KL_15_NACHL
	wert_01
NEUE_FAHRT_OPTION
	aktiv
MAX_SW_SCHWENK_W_AUSSEN
	wert_18
ALC_ANHEBUNG_175_KM/H
	wert_17
	wert_02
ALC_VMAX_BESCHLEUNIGUNG
	wert_17
ALC_ABSENKUNG_10_KM/H
	wert_17
	wert_02
ALC_VMIN_BESCHLEUNIGUNG
	wert_17
ALC_ABWEICHUNG_TREND
	wert_17
ALC_DAUER_DYN_NACHFUEHR
	wert_17
ALC_MITTELUNGSINTERV_DYN
	wert_17
ALC_VMAX_BREMSEN
	wert_17
ALC_VMIN_BREMSEN
	wert_17
ALC_SCHW_GRAD_BESCHLEUNIG
	wert_17
ALC_ABTASTRATE_DYN
	wert_17
ALC_MIN_STEIGUNG_VZ_WECHS
	wert_17
ALC_MITTELUNGSINT_VZ_WECH
	wert_17
ALC_MINDESTANZAHL_VZ_WECH
	wert_17
ALC_ABTASTRATE_TREND
	wert_17
ALC_MITTELUNGSINTERV_TREN
	wert_17
ZUWACHS_TASTVERH_KL_58G
	wert_03
ALC_DIFFERENZ_MSP_DYN_STA
	wert_17
ALC_NACHLAUF_SCHLECHTWEG
	wert_17
ALC_SAETT_TIMER_SCHLECHTW
	aktiv
TASTVERH_BEL_WBL_MIN
	wert_01
ZUWACHS_TASTVERH_WBL_BEL
	wert_01
ZUWACHS_TASTVERH_FLC_LED
	wert_01
ALC_SCHW_GRAD_BREMSEN
	wert_17
FSP_ISP_SPERREN
	wert_00
BFD2_BFD
	nicht_aktiv
BFD2_NSL
	nicht_aktiv
BEHOERDENFAHRZEUG
	nicht_aktiv
BEHOERDE_FL_ASYNCHRON
	nicht_aktiv
BFD2_BLINKEN
	3_hz
BFD2_V_MIN
	wert_01
BFD2_A_MIN
	wert_01
SPLITDOOR_DAUER
	wert_01
BFD2_T_ABS
	wert_02
WBLG_A_ABS
	wert_01
	wert_02
WBLG_N
	wert_01
WBLG_T_L_MIN
	wert_01
WBLG_F
	wert_01
WBLG_G_MIN
	wert_01
WBLG_V_WBL
	wert_01
PWM_FRA_H_FKT_BFD
	wert_01
CC_MELDUNG_FRA_Z_L
	wert_01
KALTUE_SML_M2_8_M2_32
	nicht_aktiv
KALTUE_TFL_M1_1_M1_33
	nicht_aktiv
WARMUE_SML_M2_8_M2_32
	nicht_aktiv
ABBIEGELI_PL2_MIT_NSW
	nicht_aktiv
LRE_VERBAUT
	nicht_aktiv
NSL_AUS_BEI_FE_MODE
	nicht_aktiv
NSL_AUS_BEI_FE_MODE_HECK
	nicht_aktiv
PWM_FRA_Z_AN_SML
	wert_03
IGR_SL_RELEVANT
	aktiv
IGR_DRL_H_RELEVANT
	nicht_aktiv
IGR_NSW_RELEVANT
	aktiv
IGR_NSL_RELEVANT
	aktiv
IGR_ABIEGELI_RELEVANT
	nicht_aktiv
IGR_RFS_RELEVANT
	aktiv
IGR_BFD_RELEVANT
	nicht_aktiv
CC_MELDUNG_FRA_Z_R
	wert_01
IGR_LH_RELEVANT
	nicht_aktiv
IGR_WBL_RELEVANT
	aktiv
IGR_TIPP_BLK_RELEVANT
	nicht_aktiv
IGR_DAUER_BLK_RELEVANT
	nicht_aktiv
IGR_IL_RELEVANT
	aktiv
LED_LICHTFUNKTION
	nicht_aktiv
PARKL_SL_1_GEDREHT
	nicht_aktiv
FH_HALL_DIAG_ENABLE
	nicht_aktiv
WL_SL_1_MIN_PWM
	wert_01
BFD_1_ALGORITHMUS
	nicht_aktiv
BFD_1_MIT_SL_1
	wert_00
BFD_1_MIT_FRA_H
	wert_00
BFD_1_MIT_BL_M
	wert_00
WBLG_WBL_ENABLE
	aktiv
BFD_1_MIT_BL
	wert_00
BFD2_AKTIV
	aktiv
BFD2_ESS_ENABLE
	aktiv
BFD2_ESS_ANZEIGE
	aktiv
BFD2_SL_1
	blinkend
BFD2_BL_M
	blinkend
BFD2_BL
	blinkend
LWR_HEBEL
	wert_02
LWR_DIAG_PARAM
	wert_02
RECHTS_LENKER
	nicht_aktiv
ALC_EPSILON_DELTA_AV
	wert_18
ALC_EPSILON_DELTA_A
	wert_18
FZG_RADSTAND
	wert_17
NORM_LEUCHTWEITE
	wert_17
C_METER_NACH_INNEN_HI
	wert_17
LENK_UEBERSETZUNG
	wert_23
ABSCHWAECH_D_TAU
	wert_16
	wert_17
	wert_18
	wert_19
V_LO_REDUZIER_V_SCHWENK
	wert_17
	wert_18
	wert_19
V_M_LO_REDUZIER_V_SCHWENK
	wert_17
	wert_18
	wert_19
V_M_HI_REDUZIER_V_SCHWENK
	wert_17
	wert_18
	wert_19
ALC_KENNLIN_LWR_SENSOR_VO
	wert_22
ALC_LWR_VORZEICHEN
	vorn_aktiv
ALC_ERR_BLK_FREQ
	wert_02
SPLITDOOR_LIGHT_ACTIVE
	nicht_aktiv
ALC_FAILSAVE
	nicht_aktiv
LENK_UEBERSETZUNG_LO
	wert_20
LENK_UEBERSETZUNG_LO_SP
	wert_20
ALC_FAHRZEUG
	aktiv
START_ABBL
	wert_02
CC_MELD_SW_CI_NOT_AKTIV
	aktiv
AUTO_LWR_ENABLE
	aktiv
DYNAM_LWR_ENABLE
	aktiv
LOAD_DUMP_DIMM_FL_PL3
	nicht_aktiv
VERBAU_H_SENSOR_VORNE
	rechts
SNU_TK_ABFRAGE_OHNE_PULSE
	aktiv
ALWR_ENABLE
	nicht_aktiv
ABBL_LZ_STAND
	wert_01
ENDE_ABBL
	wert_01
ABBL_LZ_RKW
	wert_01
HYST_RKW
	wert_01
VORH_HEIZZ
	wert_01
C1_VERT_FA
	wert_08
C1_VERT_BF
	wert_01
C1_HORI_FA
	wert_01
C1_HORI_BF
	wert_01
C2_VERT_FA
	wert_08
C2_VERT_BF
	wert_01
C2_HORI_FA
	wert_01
C2_HORI_BF
	wert_01
V__VERT_FA
	wert_01
V__VERT_BF
	wert_01
V__HORI_FA
	wert_01
V__HORI_BF
	wert_01
E__VERT_FA
	wert_08
E__VERT_BF
	wert_01
E__HORI_FA
	wert_01
E__HORI_BF
	wert_01
E3_VERT_FA
	wert_01
E3_VERT_BF
	wert_01
E3_HORI_FA
	wert_01
E3_HORI_BF
	wert_01
V_LO_STADT
	wert_01
V_HI_STADT
	wert_01
V_MID_LANDSTR
	wert_01
V_LO_AUTOB
	wert_01
V_HI_AUTOB
	wert_01
ZEIT_AUTOB
	wert_01
V_NSW
	wert_01
MAX_KRUEMM
	wert_01
WEG_GERADE
	wert_01
V_MIN_KRUEMM
	wert_01
OFFSET_GESCHW
	wert_02
NSW_AUTOBAHN
	wert_02
REF_DEMO
	wert_01
VERZ_REF_DEMO
	wert_01
F_ALWR
	wert_01
AG_M_ALWR
	wert_01
GL_ALWR
	wert_01
T_ALWR_AUS
	wert_01
STRST_MAXDIFF_ALWR
	wert_01
T_ALWR_NST
	wert_01
T_ALWR_SW
	wert_01
T_ALWR_AM
	wert_01
T_ALWR_MKR
	wert_01
W_ALWR_SW
	wert_01
W_ALWR_EKR
	wert_01
W_ALWR_MKR
	wert_01
Z_ALWR_NST
	wert_01
Z_ALWR_SW
	wert_01
F_A_ALWR
	wert_01
V_ALWR_AM
	wert_01
V_ALWR_AUS
	wert_01
V_ALWR_AN
	wert_01
V_ALWR_BAB1
	wert_01
V_ALWR_BAB2
	wert_01
F_SWEG_ALWR
	wert_01
R_SWEG_ALWR
	wert_01
KALTUE_IB_M1_35
	nicht_aktiv
KALTUE_BFD_M1_5_M1_37
	nicht_aktiv
KALTUE_BLM_M1_40
	nicht_aktiv
WARMUE_BFD_M1_5_M1_37
	nicht_aktiv
WARMUE_TFL_M2_1_M2_33
	nicht_aktiv
WARMUE_BLM_M1_40
	nicht_aktiv
WARMUE_IB_M1_35
	nicht_aktiv
WARMUE_KL_58G_M2_48
	nicht_aktiv
VERBAU_ABBIEGEL_PL2_3R
	nicht_aktiv
ABBIEGELI_AUS_BEI_FL_LH
	nicht_aktiv
SIDEMARKER_US_MIT_FRA_V
	nicht_aktiv
TIPP_BLK_ABBR_GEGENRICHT
	aktiv
TIPP_BLK_ABBR_GLEICHRICHT
	aktiv
DWA_UEBERFALL_ALARM_3R
	mit_fl
HECKDECK_REVERS_ANZ_ZYKL
	wert_01
HECKDECK_REVERS_DOPPELB
	aktiv
STROMSPAR_WARNBLINKEN
	aktiv
NSL_EIN_BEI_NSL_AHM_DEF
	aktiv
LEUCHTDICHTE_EXPONENTIEL
	nicht_aktiv
SM_FKT_ZUSATZBLINKER
	nicht_aktiv
LED_BLINKER_HINTEN
	nicht_aktiv
LED_BLINKER_VORNE
	nicht_aktiv
MIN_TASTVERH_KL_58G
	wert_01
MIN_TASTVERH_BEL_FLC_LED
	wert_01
OPEN_LOAD_LED_BLINKER_H
	wert_01
OPEN_LOAD_LED_BLINKER_V
	wert_01
HEIMLEUCHTEN_FUNKSCHL
	nicht_aktiv
LOAD_DUMP_SCHUTZ
	aktiv
LOAD_DUMP_ABSCHALT_KL58G
	aktiv
LOAD_DUMP_ABSCHALT_FL
	nicht_aktiv
LOAD_DUMP_ABSCHALT_SL_1
	nicht_aktiv
LOAD_DUMP_DIMM_WERT_FRA
	wert_01
LOAD_DUMP_DIMM_WERT_KL58G
	wert_01
LOAD_DUMP_DIMM_AL
	aktiv
LOAD_DUMP_DIMM_BL
	aktiv
LOAD_DUMP_DIMM_FRA_V
	aktiv
LOAD_DUMP_DIMM_FRA_H
	aktiv
IGR_BREMSLICHT_RELEVANT
	nicht_aktiv
PWM_FL_FKT_DRL_3R
	wert_01
PWM_NSW_FKT_PARKL
	wert_03
PWM_FRA_V
	wert_01
PWM_FL_NSW_FKT_ABBLIEGEL
	wert_01
PWM_POL
	wert_01
PWM_POL_BEI_AKTIVEN_FL
	wert_01
PWM_NSW_FKT_TFL
	wert_01
PWM_FRA_V_FKT_SIDEMARKER
	wert_03
PWM_FRA_H
	wert_01
PWM_BL_FKT_SL
	wert_01
PWM_SL_2_FKT_BL
	wert_03
PWM_BFD_3R
	wert_01
PWM_BFD_ERSETZT_SL_1
	wert_01
PWM_BL_M
	wert_01
BFD_ERSETZT_SL_1
	nicht_aktiv
BFD_ERSETZT_BL
	nicht_aktiv
NSL_ERSETZT_SL_1
	nicht_aktiv
NSL_ERSETZT_BL
	nicht_aktiv
BL_ERSETZT_SL_1
	nicht_aktiv
BL_ERSETZT_SL_2
	nicht_aktiv
PARKL_FKT_MIT_POL
	aktiv
PARKL_FKT_MIT_BL
	nicht_aktiv
BL_SCHALTLOGIK_E92_93
	nicht_aktiv
PARKL_FKT_MIT_SL_2
	nicht_aktiv
PARKL_FKT_MIT_NSW
	nicht_aktiv
SL_FKT_MIT_POL
	aktiv
HECKKL_SL_LOGIK
	nicht_aktiv
SL_FKT_MIT_NSW
	nicht_aktiv
BREMSL_FKT_MIT_SL_1
	aktiv
BREMSL_FKT_MIT_SL_2
	nicht_aktiv
BREMSL_FKT_MIT_NSL
	nicht_aktiv
DRL_TFL_MIT_SL_2
	aktiv
DRL_TFL_MIT_KZL
	aktiv
DRL_TFL_MIT_SML_3R
	nicht_aktiv
DRL_TFL_MIT_BLK_V_GED
	nicht_aktiv
DRL_TFL_MIT_NSW
	nicht_aktiv
FH_LIN_BEDIENBLOCK
	nicht_aktiv
FH_MAUT_AUF_FAT_ENABLE
	aktiv
FH_MAUT_AUF_BFT_ENABLE
	aktiv
FH_KURZHUB_DISABLE_FEMOD
	nicht_aktiv
FH_WAIT_ST_WRG_ENB
	aktiv
FH_TASTER_EINSTUFIG_L3
	nicht_aktiv
FH_KURZHUBDELAY_ZU
	wert_01
FH_TIME_WAIT_ST_WRG_ENB
	wert_01
KURZSCHLUSS_CHECK_DISABLE
	wert_01
	wert_02
LWR_OFFSET_PLATTLAUF_L
	wert_01
LWR_OFFSET_PLATTLAUF_R
	wert_01
LWR_DIAG_COOL_TIME
	wert_01
LWR_DIAG_HEAT_TIME
	wert_01
ENABLE_GURTBRINGER_FA
	nicht_aktiv
ENABLE_GURTBRINGER_BF
	nicht_aktiv
LWR_DIAG_PARAM_A
	wert_01
GB_TRIGGER_KL_R
	aktiv
GB_TRIGGER_KL_15
	aktiv
GB_QUICKSTART
	aktiv
GB_USE_SBE
	nicht_aktiv
GB_POS_AUS
	wert_01
GB_T_NOTLAUF
	wert_01
GB_T_EINFAHREN
	wert_01
GB_FAILSAFE
	wert_01
GB_ENTPRELL_TRIGGER
	wert_01
GB_ENTPRELL_CAN
	wert_01
GB_NAD
	wert_01
GB_DELTA_POS
	wert_01
GB_ANZ_REVERSIEREN
	wert_01
GB_T_REVERSIEREN
	wert_01
ASP_EINKLAPPEN
	nicht_aktiv
ASP_KOMFORT_EINKLAPP
	nicht_aktiv
ASP_ELEKTROCHROM
	nicht_aktiv
ASP_NO_SPIEGEL_LIN_START
	nicht_aktiv
ASP_WEG_BORDSTEIN_AUTOM
	wert_01
ASP_GESCHW_AUTO_AUSKLAPP
	wert_01
BFD_1_MIT_SL_2
	wert_00
BFD_GESPERRT_BEI_NSL
	nicht_aktiv
BFD2_SL_2
	nicht_aktiv
WL_FRA_V
	nicht_aktiv
WL_FRA_H
	nicht_aktiv
WL_FL_MIN_PWM
	wert_01
ASP_MAX_GESCHW_EINKLAPPEN
	wert_01
WL_BLK_H_MIN_PWM
	wert_01
WL_AL_MIN_PWM
	wert_01
WL_POL_MIN_PWM
	wert_01
WL_NSW_MIN_PWM
	wert_01
WL_BLK_V_MIN_PWM
	wert_01
WL_SL_2_MIN_PWM
	wert_01
WL_KZL_MIN_PWM
	wert_01
WL_NSL_MIN_PWM
	wert_01
WL_BL_MIN_PWM
	wert_01
WL_BFD_MIN_PWM
	wert_01
PWM_POL_BEI_AKTIVEN_AL
	wert_01
ALC_PARAMETER_FAILSAVE_1
	wert_01
ALC_NSW_NEU_ANF
	aktiv
ALC_PARAMETER_FAILSAVE_2
	wert_01
DUAL_SP_LAMPEN_ARRAY_1
	wert_01
DUAL_SP_PARAMETER_2
	wert_01
DUAL_SP_PARAMETER_3
	wert_01
FSP_LAMPEN_MASK_FRM3
	wert_01
ISP_MASKIERUNG_FRM3
	wert_01
CC_MELDUNG_NSW_L
	wert_01
CC_MELDUNG_NSW_R
	wert_01
CC_MELDUNG_FRA_V_L
	wert_01
CC_MELDUNG_FRA_V_R
	wert_01
CC_MELDUNG_FRA_H_L
	wert_01
CC_MELDUNG_FRA_H_R
	wert_01
CC_MELDUNG_SML_L
	wert_01
CC_MELDUNG_SML_R
	wert_01
V_E_HI_KRV
	wert_01
ENTGEGENGES_RKW
	nicht_aktiv
CC_MELDUNG_SL_2_L
	wert_01
CC_MELDUNG_SL_2_R
	wert_01
V_E_LO_KRV
	wert_01
FSP_MASKIERUNG_FRM3
	wert_01
CC_MELDUNG_BFD_L
	wert_01
CC_MELDUNG_BFD_R
	wert_01
CC_MELDUNG_TFL_L
	wert_01
CC_MELDUNG_TFL_R
	wert_01
CC_MELDUNG_KZL_3R
	wert_01
CC_MELDUNG_BL_M_1
	wert_01
CC_MELDUNG_IB_3R
	wert_01
CC_MELDUNG_KL_58G
	wert_01
CC_MELD_PARKLICHT_EIN
	wert_01
PWM_NSL_FKT_BFD
	wert_01
WL_POL
	soft_einschalten
WELCOME_LIGHT_ACTIVE
	aktiv
ASP_HEIZUNG
	nicht_aktiv
ASP_MEMORY
	nicht_aktiv
ASP_BORDSTEIN_AUTOM
	nicht_aktiv
EINLENKEN_RKW
	nicht_aktiv
CS_GELB_ROT
	wert_01
CS_ZW_WERTE
	wert_01
CS_ZEIT_UML
	wert_01
CS_MIN_PWM
	wert_01
CS_RED_HELL
	wert_01
CS_AUT_RED_HK
	wert_01
FH_TUERAUF_STOP_MAUT_3R
	aktiv
TYP_COLORSWITCH
	dreifarbig
CS_QUITTIERUNGS_BLINK
	aktiv
PARKL_FKT_MIT_SL_1
	aktiv
PARKL_FKT_MIT_BFD
	nicht_aktiv
SL_FKT_MIT_BFD
	nicht_aktiv
PWM_BFD_FKT_SL
	wert_01
WL_SL_1
	soft_einschalten
PWM_SL_1_FKT_SL_TFL
	wert_01
PWM_SL_1_FKT_PARKL
	wert_01
WL_BFD
	nicht_aktiv
DRL_TFL_MIT_BL
	aktiv
DRL_TFL_MIT_SL_1
	aktiv
DRL_TFL_MIT_BFD
	nicht_aktiv
SL_FKT_MIT_SL_1
	aktiv
WL_BL
	soft_einschalten
BL_SCHALTLOGIK_R60
	aktiv
PWM_KZL_3R
	wert_01
PWM_NSL
	wert_02
PWM_RFS
	wert_01
SNU_TYP
	aktiv
PWM_BL_FKT_BL
	wert_02
PWM_SL_1_FKT_BL_TFL
	wert_02
ADAPTION_CAN_LWR_LWS
	pt_can
ALC_KLS_ENABLE
	aktiv
AHL2_ENABLE
	aktiv
ALC_IMMER_BEI_S_FLC
	nicht_aktiv
SNU_NICHT_VERBAUT
	nicht_aktiv
PWM_SL_2_FKT_SL
	wert_01
SL_FKT_MIT_SL_2
	nicht_aktiv
VERHALTEN_DRL_TFL_3R
	drl_tfl_off
FH_US_REVERSE
	nicht_aktiv
WL_SL_2
	nicht_aktiv
SIGNALBILD_SL
	sl_1
FH_PANIKMODUS
	aktiv
FH_PANIKMODUS_MIT_EKS
	aktiv
FH_MAUT_ZU_FAT_ENABLE
	aktiv
FH_EKS_AKTIV_L3
	aktiv
FH_PANIKMODUS_MAN_L3
	aktiv
FH_MAN_MIT_EKS
	aktiv
FH_MAUT_ZU_BFT_ENABLE
	aktiv
GB_CA_FAHRZEUG
	aktiv
GB_V_MAX_KMH
	wert_02
BFD_1_WERT_AX_EIN
	wert_01
NO_BLK_RKW
	nicht_aktiv
TIPP_BLK
	nicht_aktiv
FL_ASSIST_CC_NOT_AKTIV
	nicht_aktiv
BFD2_A_LOE
	wert_02
WBLG_A_ANF
	wert_02
ALC_ERR_BLK_AL_EIN
	aktiv
LOAD_DUMP_ABSCHALT_KZL
	aktiv
LOAD_DUMP_ABSCHALT_RFS
	aktiv
LOAD_DUMP_ABSCHALT_NSW
	aktiv
LOAD_DUMP_ABSCHALT_NSL
	aktiv
LOAD_DUMP_ABSCHALT_SL_2
	nicht_aktiv
FH_PARAMETER_2
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_3
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_4
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_5
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_6
	r60
FH_PARAMETER_7
	r60
FH_PARAMETER_8
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_9
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_10
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_11
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_12
	r56
	r55
	r57
	r60
	r58
	r59
FH_PARAMETER_13
	r60
FH_PARAMETER_14
	r60
FH_PARAMETER_1
	r60
OFFSET_ADC_SNU
	wert_03
OFFSET_ADC_TK
	wert_03
UNP_ZYKL_TIPP_BLK_CKM
	wert_01
MIND_ANZ_ZYKL_TIPP_BLK
	wert_02
MIND_ANZ_ZYKL_TIPP_BLK_1
	wert_02
MIND_ANZ_ZYKL_TIPP_BLK_2
	wert_01
MIND_ANZ_ZYKL_TIPP_BLK_3
	wert_01
DEF_ZYKL_TIPP_BLK_CKM
	wert_01
FH_CC_MELDUNGEN
	nicht_aktiv
ALC_DEF_LWR_SENSOR_HI
	wert_21
INVERT_COLORS
	wert_01
ALC_KENNLIN_LWR_SENSOR_HI
	wert_22
ALC_OFFSET_LWR
	wert_26
ALC_SCHW_PROP_ABWEICHUNG
	wert_19
ALC_LWR_NEIGUNG_KONSTANTE
	wert_21
ALC_HOEHENWEG
	wert_18
	wert_19
ALC_SCHW_TREND
	wert_18
	wert_19
LWR_SCHRITTE_STELLUNG_1
	wert_03
SICHERHEITS_FZG
	nicht_aktiv
RECHTSVERKEHR
	aktiv
LINKSVERKEHR
	nicht_aktiv
WINKEL_BLENDUNG
	wert_02
GETRIEBE_HANDSCHALTER
	nicht_aktiv
SCHALTER_R_GANG
	nicht_aktiv
LWR_HYSTERESE_START
	wert_02
LWR_VORBESTROMUNG
	wert_02
XENON_LI
	wert_02
ALC_DISABLE_AUSGL_NICK_GW
	aktiv
ALC_AUSWERT_PROP_ABWEICH
	aktiv
ALC_AUSWERT_GRADIENT
	aktiv
AL_AUS_BEI_FL
	nicht_aktiv
CC_MELDUNG_AL_L
	wert_02
CC_MELDUNG_AL_R
	wert_02
PWM_NSW_3R
	wert_01
KALTUE_NSW_M2_37_M1_3_C33
	aktiv
WARMUE_NSW_M2_37_M1_3_C33
	aktiv
QUITT_BLK_ENTSICHERN
	aktiv
QUITT_BLK_SICHERN
	aktiv
DEF_QUITT_BLK_ENTSI_CKM
	aktiv
DEF_QUITT_BLK_SICH_CKM
	aktiv
UNP_QUITT_BLK_ENTSI_CKM
	aktiv
UNP_QUITT_BLK_SICH_CKM
	aktiv
QUITT_BLK_ZU_CHECK
	aktiv
QUITT_BLK_ENTSICHERN_1
	aktiv
QUITT_BLK_ENTSICHERN_2
	aktiv
QUITT_BLK_ENTSICHERN_3
	aktiv
QUITT_BLK_SICHERN_1
	aktiv
QUITT_BLK_SICHERN_2
	aktiv
QUITT_BLK_SICHERN_3
	aktiv
QUITT_BLK_IGNORE_MOTORH
	aktiv
TAGFAHRLICHT_ECE_0
	nicht_aktiv
TAGFAHRLICHT_ECE_1
	nicht_aktiv
TAGFAHRLICHT_ECE_2
	nicht_aktiv
TAGFAHRLICHT_ECE_3
	nicht_aktiv
DEF_TAGFAHRLICHT_ECE_CKM1
	nicht_aktiv
UNP_TAGFAHRLICHT_ECE_CKM1
	nicht_aktiv
AUTOM_LICHT_KONTROLLE
	aktiv
SZL_LOW_VERBAUT
	nicht_aktiv
COLORSWITCH_VERBAUT
	aktiv
VIER_TUERER
	aktiv
SL_FKT_MIT_BL
	aktiv
LH_UND_NSW_NICHT_GLEICHZ
	nicht_aktiv
FL_UND_NSW_NICHT_GLEICHZ
	nicht_aktiv
PWM_FL_BEI_BIXENON
	wert_02
NSL_EINSEITIG_VERBAUT_C34
	linke_seite
LWR_ANSTEUERN
	nicht_aktiv
LWR_FEHLER_BEWERTUNG
	wert_02
ABSCHALTUNG_RFS
	nicht_aktiv
LWR_ABS_MIN_STELLUNG_2
	wert_02
LWR_SCHRITTE_STELLUNG_2
	wert_02
AL_KL50_SCHUTZ
	nicht_aktiv
SL_ABSCH_OHNE_ECE
	aktiv
OPTIONEN_SL_ABSCH_TFL_FL
	aktiv
FH_CONT_MAUT_NACH_KL50
	aktiv
SL_PARKL_ABSCH_12H
	aktiv
XENON_AL_VERBAUT
	aktiv
BI_XENON_BEI_LH_3R
	aktiv
HALOGEN_AL_VERBAUT
	nicht_aktiv
KALTUE_BL_M2_43_M2_9
	aktiv
WARMUE_BL_M2_43_M2_9
	aktiv
BREMSL_FKT_MIT_BL
	aktiv
CC_MELDUNG_BL_L
	wert_01
CC_MELDUNG_BL_R
	wert_01
KALTUE_POL_M2_50_M1_8
	aktiv
KALTUE_FRA_V_M1_13_M2_40
	aktiv
KALTUE_FRA_H_M2_45_M1_12
	aktiv
KALTUE_SL_1_M1_14_M2_41
	aktiv
KALTUE_KZL_M2_49
	aktiv
WARMUE_AL_M1_6_M2_38
	aktiv
WARMUE_POL_M2_50_M1_8
	aktiv
WARMUE_FRA_V_M1_13_M2_40
	aktiv
WARMUE_FRA_H_M2_45_M1_12
	aktiv
WARMUE_SL_1_M1_14_M2_41
	aktiv
WARMUE_KZL_M2_49
	aktiv
CC_MELDUNG_POL_L
	wert_01
CC_MELDUNG_POL_R
	wert_01
CC_MELDUNG_SL_1_L
	wert_02
CC_MELDUNG_SL_1_R
	wert_02
FH_COUPETUER
	nicht_aktiv
KALTUE_FL_M2_6_M1_04
	nicht_aktiv
KALTUE_AL_M1_6_M2_38
	nicht_aktiv
PWM_AL
	wert_01
CC_MELDUNG_FL_L
	wert_01
CC_MELDUNG_FL_R
	wert_01
KALTUE_NSL_L_M2_51
	aktiv
WARMUE_NSL_L_M2_51
	aktiv
CC_MELDUNG_NSL_L_3R
	wert_01
KALTUE_NSL_R_M1_10
	nicht_aktiv
WARMUE_NSL_R_M1_10
	nicht_aktiv
CC_MELDUNG_NSL_R_3R
	wert_02
KALTUE_RFS_L_M2_47
	nicht_aktiv
WARMUE_RFS_L_M2_47
	nicht_aktiv
CC_MELDUNG_RFS_L
	wert_02
KALTUE_RFS_R_M1_9
	aktiv
WARMUE_RFS_R_M1_9
	aktiv
CC_MELDUNG_RFS_R
	wert_01
KALTUE_SL_2_M1_16_M1_18
	nicht_aktiv
WARMUE_SL_2_M1_16_M1_18
	nicht_aktiv
KALTUE_FRA_Z_M1_11_M2_44
	nicht_aktiv
WARMUE_FRA_Z_M1_11_M2_44
	nicht_aktiv
WARMUE_FL_M2_6_M1_4
	nicht_aktiv
PWM_FL_N
	wert_03
IGR_FAHR_AL_RELVANT
	aktiv
IGR_TFL_RELEVANT
	aktiv
IGR_FL_RELEVANT
	aktiv
CS_FREQ
	160hz_bei_hk300
DELAY_IL_WELC_SC
	0sec
INNENLICHT_ABSENKEN
	wert_06
TIME_COLOR_CIRCLE
	3sec
WELCOME_SCENARIO_ACTIVE
	nicht_aktiv
Old Feb 27, 2013 | 07:26 AM
  #641
mikecalgon's Avatar
mikecalgon
Thanks, MBj. I am comparing them, will post findings soon.
Could you please let me know your VO information, my VO has 5AH which is about decoding Dynamic brake lights.
Old Feb 27, 2013 | 08:57 AM
  #642
MBj's Avatar
MBj
If you tell me what VO is and where to find , I'm sure I can give you the information
Old Feb 27, 2013 | 03:08 PM
  #643
mikecalgon's Avatar
mikecalgon
Thanks, Vehicle Order, recorded in fa.trc in NCS work folder. Someone call it as FA.
Thanks again.
Old Feb 28, 2013 | 12:06 AM
  #644
MBj's Avatar
MBj
This is inside fa.trc:
Code:
R60_#0712&FSGY%0B11*ZD71$1CB$1CD$205$210$226$230$249$258$2GU$2PA$2XA$313$314$322$325$359$381$386$3A2$3AB$403$420$428$431$473$481$493$494$4AA$4C5$4C8$4CU$4U4$4UF$507$520$521$522$524$534$548$550$563$5AA$5DA$5DT$620$674$6FP$6NE$6NF$6NM$6UM$6VC$785$7L7$801$851$879$8KA$8V1$9BD-A070-EWS4
Old Feb 28, 2013 | 12:23 AM
  #645
mikecalgon's Avatar
mikecalgon
Smile
Code:
Appreciated your help.
Old Mar 2, 2013 | 05:07 PM
  #646
falaly's Avatar
falaly
License plate led light blinking
Is there a code to prevent my aftermarket license plate led light from blinking?
Old Mar 2, 2013 | 05:22 PM
  #647
cm.d's Avatar
cm.d
blink all the time or flicker during start up?
flicker during start is normal.
Old Mar 2, 2013 | 05:32 PM
  #648
kerrys914's Avatar
kerrys914
Would coding out the bulb check solve this?
License Plate
KALTUE_KZL_M2_49
WARMUE_KZL_M2_49
I thought the flicker is the car checking and rechecking for a bad bulb.
Old Mar 6, 2013 | 12:37 PM
  #649
falaly's Avatar
falaly
It blinks and flickers the entire time the car is on! It stays normal for approximately 2 mins when I initially turn on the car; before it starts blinking again! :(
Do you think coding would resolve this problem?
Old Mar 6, 2013 | 12:58 PM
  #650
cm.d's Avatar
cm.d
I think you should try different bulbs. I have had that happen to me with my old car. I changed the bulbs and it cleared up.
