Electrical Countryman-Specific Coding - R60 Guide
Old Sep 22, 2013 | 08:25 PM
  #876
jwardell's Avatar
jwardell
Originally Posted by Koopah
Fancy meeting you here!
I seem to have enjoyed a rock-solid setup using my MacBook Pro (OSX 10.8.5, model 8,2) with VMWare Fusion (v4) supporting a Windows XP (latest SP) VM. We could meet up at an upcoming event and I could also make sure your cable works.
Theo
Yeah I've seen you making your presence known here. I should be able to handle this stuff myself ya know? But I'll take you up on the offer if it gets to that point. I have an XP VM on my imac, but I don't have a USB cable to go down two flights of stairs and to the driveway. My ebay cable does work, the first software verified ignition status etc. Can't someone make an iphone app already?
Old Sep 29, 2013 | 08:08 PM
  #877
ultragamma's Avatar
ultragamma
Auto headlight sensitivity. RLS module
spammed please detele
Old Sep 29, 2013 | 08:14 PM
  #878
ultragamma's Avatar
ultragamma
Spammed please delete.
Old Sep 30, 2013 | 10:18 AM
  #879
rag1998's Avatar
rag1998
Originally Posted by Hodaka
And we're back. The linked ECUtool cable does not appear to be correct for the R60. Says its for up to 2008 - I was lead to beleive that this does not work for the R60?
So what cable is everyone using? Anything from ebay will work? If there is a specific cable that is working for you please share..
Old Sep 30, 2013 | 10:54 AM
  #880
Theta's Avatar
Theta
No, not everything from eBay will work. There are at least a dozen different cables that people are trying to use...
Just buy the ECUTool cable, it works fine.
Old Sep 30, 2013 | 11:17 AM
  #881
rag1998's Avatar
rag1998
Thanks ordered!
Old Sep 30, 2013 | 11:13 PM
  #882
ultragamma's Avatar
ultragamma
Anyone tried the light sensitivity setting in the RLS module?
It would seem that changing :
DEF_FLC_SCHWELLWERT_SATZ - to Wert_03
would reduce the sensitivity.
Also
KONFIG_RLS_REGEN - Switch on headlights when raining
nicht_activ
KONFIG_RLS_GESCHW - Switch on headlights at high speeds
nicht_activ
Please refer to conger's post
https://www.northamericanmotoring.co...d.php?t=249626
*warning, this is for R56, use at your own risk.
Old Oct 2, 2013 | 08:20 AM
  #883
Koopah's Avatar
Koopah
Originally Posted by ultragamma
Anyone tried the light sensitivity setting in the RLS module? ...{snip}
Of course, insert normal disclaimer here regarding the selective adoption of R56 capabilities in the R60 due to differences in circuitry. Whose going to try these out on a R60 to verify?
Need more free time, here!
Old Oct 2, 2013 | 09:55 PM
  #884
ultragamma's Avatar
ultragamma
I thought tempering with the coding already consider as a risk. I tried on my car, the sensitivity does dial down. I drove through street with building shadows/shades will not trigger the auto headlight like it used to.
PS. Original setting is at Wert_01 which is high sensitive.
Old Oct 22, 2013 | 11:08 PM
  #885
manho1dup's Avatar
manho1dup
Originally Posted by AlphaQuad
no one in socal?:(
Haven't been on here in a while, but I'm in Costa Mesa and I've coded what you are looking to get done on my 2013. If you still need help then PM me and I can help you out.
Old Oct 22, 2013 | 11:12 PM
  #886
manho1dup's Avatar
manho1dup
Aaaaannnnddd .... Here are the latest v49.4 Datens:
http://www.mediafire.com/?9x4yhye89sxfb9v
What has been updated on the v49.4 Datens? Last time I coded my car was v49 but haven't taken the car into the dealer yet since I took delivery back in April.
Old Oct 25, 2013 | 07:53 PM
  #887
Rudeman422's Avatar
Rudeman422
Can anyone tell me how to clear fault codes using NCS Expert? I've been looking everywhere and can't find any instructions or help. Any help would be much appreciated.
Old Nov 9, 2013 | 04:21 AM
  #888
Nathanr877's Avatar
Nathanr877
Is it possible to code in so when i push the lock button my power folding mirriors fold in and unlock button they fold out?
Old Nov 9, 2013 | 05:11 AM
  #889
Koopah's Avatar
Koopah
That was covered earlier. IIRC, the folding mirrors are not actuated by any of the control modules so settings changes do not exist for this.
Old Nov 13, 2013 | 02:55 AM
  #890
tm3codefire's Avatar
tm3codefire
Hi,
at the moment i´m converting my Countryman JCW into a Rallyecar (not for road use).
1. I now have replaced the Steeringwheel for a better one.
Problem: I now got a error (on the rev counter display) for the missing Cruise Control and Audio/Phone Control Switches from the Original Steeringwheel.
Question: How can i disable/decode the Cruise Control and/or the Multimedia-Steeringwheel ??
2. After reconnecting the Battery i got a warning (on the rev counter display) to set the actuall time/date onto the system.
Problem: Multimedia System completley removed from the car (Display, CD-Unit, i-drive switches), so i cannot set on the normal way
Question: How can i set the time or disable the warning ??
Old Nov 19, 2013 | 12:36 PM
  #891
fnsnoop's Avatar
fnsnoop
A few questions
  1. How similar are these commands to the R61 paceman?
  2. Where can I get more technical information about the file formats, coding, about this process? I am an EE, so if any body wants hit me with the most technical resource, please do.
  3. Is it possible to enable the PDC (parking distance control) on the navigation screen with coding? There is a retrofit kit but requires a dealer software modifcation.
Old Nov 27, 2013 | 11:01 PM
  #892
madmax88's Avatar
madmax88
Thanks for maintaining this thread, went out and got a little used Samsung Netbook for $100 that runs XP, and the cable on ebay. and went thru the first try, works flawlessly. The instruction were specific and down to the point.
went thru the CAS setting, gonna work on the rest tomorrow.
Now I love mine Mini even more, it's all those little things that count!!!
but it's so stupid that why the manufacture does not code them like that to begin with?? Just want to say thank you!!
Old Nov 30, 2013 | 03:03 PM
  #893
madmax88's Avatar
madmax88
I was able to code thru CAS, SHD, SPEG, and when I got to KOMBI module, for some reason after I coded, the Tacho display is not working any more? and trunk open sign came on in the MpH display in tach, and above the mileage, 2 seats looking thing came on? and the tach is not working as well? not sure what I had done wrong? I only change the
CC_ZUENDSCHLUESSEL
nicht_aktiv
that's it?
I have a 2011 CM s ALL4, and using the V41 update to code, I'm wondering if it actually have a higher than V41, so it actually turn off a few things instead? I've attached the KOMBI FSW_PSW.MAN file, so y'all can see if something was turn off causing the tach not working??
File Type: txt
Old Nov 30, 2013 | 03:23 PM
  #894
madmax88's Avatar
madmax88
NVM, trace back to what I did, and decide to update all the Daten, sgdat, and ecu files to V46, and code it the KOMBI again, and everything is restore back to normal. so turn out i have a later version than V41, just need to do a little updating.
Old Dec 4, 2013 | 08:15 AM
  #895
AlphaQuad's Avatar
AlphaQuad
Hi guys I was wondering if anyone has trying adding option code 8KL to their MINI?
It's the option code for making sure the computer calculates a shortal interval between oil changes? And if so can anybody help guide me on how to do that? Is the process the same using ncsexpert?
Thanks for the help.
Old Dec 10, 2013 | 06:45 PM
  #896
PiXEL8's Avatar
PiXEL8
v50.2 SP-Daten R56/R60 https://www.mediafire.com/?nn4iekqlownd5p6
-PiXEL8
Old Dec 10, 2013 | 07:34 PM
  #897
Theta's Avatar
Theta
Wow, beat me to it. Was sifting through the 51s today to see if there were any Rxx updates.
Nicely done.
Old Dec 10, 2013 | 08:29 PM
  #898
PiXEL8's Avatar
PiXEL8
I have up to v51.1 but v50.2 seems to be the latest for R56/R60.
-PiXEL8
Old Dec 10, 2013 | 08:39 PM
  #899
Theta's Avatar
Theta
Yep, nothing in 51.1 for us.
Old Jan 5, 2014 | 07:48 AM
  #900
Chattmanlan's Avatar
Chattmanlan
can mini manufactured in Aug. 2013 be programmed with this v49.4 datens?
