Electrical Countryman-Specific Coding - R60 Guide
Old Apr 28, 2014 | 02:29 PM
  #976
cwileyrrt's Avatar
cwileyrrt
Took my car in for service and they must of updated firmware because all my mods no longer worked. No big deal.
I loaded the new 51.2 Datens.
I can read modules just fine with dates. I perform mods, save to .MAN, write files.
I get the coding ended message but never hear the clicks, and mods don't work.
Any suggestions?
Old Apr 28, 2014 | 03:31 PM
  #977
TheMike's Avatar
TheMike
I've ordered my cable from One Stop. I've read every thread in anticipation of coding my R60 and my wife's R57. One thing I haven't seen and wonder about is:
The garage door buttons. Can this be coded to remain HOT all the time. I've never had a car that had switched power to the garage door buttons.
Old Apr 28, 2014 | 03:34 PM
  #978
bmrguy03's Avatar
bmrguy03
I'm not sure but I like it the way it is . Reason being is if you have 2 cars with homelink and only a one car garage, then if someone breaks into the car they can't push the buttons to get into your garage.
Old Apr 28, 2014 | 04:48 PM
  #979
TheMike's Avatar
TheMike
Having the Homelink is nice. Just a step up from all those out there that use the battery powered buttons that come with their openers. Like I said, this is my first car where the Homelink wasn't always powered and I personally don't like having to start my car before opening or having to close it before I shut it down.
So the question still remains....
Old Apr 28, 2014 | 04:59 PM
  #980
s0ph34k's Avatar
s0ph34k
+1 on exactly what you said. . I have 2 minis and a motorcycle crammed into my garage and a honda pilot with a homelink that is parked outside. The pilot's homelink is able to function without having to be turned on which scares me sometimes.
Old Apr 29, 2014 | 03:20 AM
  #981
claw's Avatar
claw
Hi guys!
Probably this question has already been answered, but the topic is extensive and I have not found the answer... I've been coding R56/R55 with V45 datens. Do i need to upgrade to code R60?
Also the NCSExpert version that im using is not the latest.
Thanks.
Old Apr 29, 2014 | 08:17 AM
  #982
icuc's Avatar
icuc
It is all based on what version of daten files you have. It would be better to get the latest files.
You would still use the R56 to code R60.
Old Apr 29, 2014 | 08:34 AM
  #983
claw's Avatar
claw
Thanks.
I know i'll have to use "R56" option. The thing is i have a 100% working setup for R56/R55 with this datens and with update i may have issues.
Thanks again.
Old May 3, 2014 | 11:35 AM
  #984
cwileyrrt's Avatar
cwileyrrt
Any suggestions?
Anyone able to help me out with this? Still no luck. Really weird, never had problems before.
Old May 3, 2014 | 11:41 AM
  #985
icuc's Avatar
icuc
Did you use the right profile? If you use the expert profile then it won't stick.
Old May 3, 2014 | 11:43 AM
  #986
cwileyrrt's Avatar
cwileyrrt
Is there a new profile then? Any reference on how the correct way? I installed the software via the original guide, then updated the datens except for the 1 file people said was messing it up. Also ran the Laden file after updating the datens.
Old May 3, 2014 | 12:03 PM
  #987
icuc's Avatar
icuc
You would use the same profile and the existing profile will not be changed when you update the daten.
Old May 5, 2014 | 06:08 AM
  #988
claw's Avatar
claw
Does anyone try (and succeed) to code start&stop memory?
Changed:
MSA_TASTER_MEM_FUNKT
nicht_aktiv
to
aktiv
But does not work.
Old May 19, 2014 | 09:38 AM
  #989
TheMike's Avatar
TheMike
I got an error when "reading a trace file". I've followed the directions to the letter but After I select R56 in the chassis list, then CAS, it populates the Chassis, FG, but I get the following error: “FOLLOWING FEATURE IS INVALID FOR FA: #1113" so I can't "process ECU".
Any ideas from the experts?
EDIT: Nevermind. It was a Daten issue. I screwed up where/what I did with them. All is good!!
Old May 20, 2014 | 08:01 AM
  #990
calforhelp's Avatar
calforhelp
Will the 51.2 datens in this thread will work for a 2014 R60 S All4?
As far as I can tell, coding an R60 is the same as an R56. Is that correct?
Old May 20, 2014 | 08:04 AM
  #991
calforhelp's Avatar
calforhelp
Originally Posted by Rywan
Hi guys! We need some help here in Hong Kong.One of my friend tried coding the rain sensor activate
This reply is kind of late but that icon is saying the sunroof needs recalibrated. You need to pull and hold the sunroof switch ONE CLICK, not two, towards you. You hold it for something like 30 seconds until the sunroof opens all the way then closes all the way. That should fix it.
Old May 20, 2014 | 11:27 AM
  #992
claw's Avatar
claw
About the datens, i believe so. I've used those datens to code one 2013 R60 with updated firmware and worked fine.
It's same as R56
Old May 20, 2014 | 04:20 PM
  #993
TheMike's Avatar
TheMike
YES THEY DO! I just coded my first time doing the one touch sunroof. Mine is a '14 JCW R60, one month old!
I feel like it's christmas time!!! Thank you EVERYONE that started this thread and the knowledge posted. THANK YOU THANK YOU THANK YOU!!!!
Old May 22, 2014 | 05:09 AM
  #994
ke3ee's Avatar
ke3ee
HI, Is anyone near Pittsburgh that can code my 12 all4s CM? I'm looking to change 2 items.
1. auto unlock when engine shut off
2. tach display to something other than Speed.
I am expecting and willing to spend some money.
Old May 22, 2014 | 05:54 AM
  #995
cerenkov's Avatar
cerenkov
Originally Posted by ke3ee
HI, Is anyone near Pittsburgh that can code my 12 all4s CM? I'm looking to change 2 items. 1. auto unlock when engine shut off 2. tach display to something other than Speed. I am expecting and willing to spend some money.
Can you do the auto unlock via the BC?
Old May 22, 2014 | 06:15 AM
  #996
ke3ee's Avatar
ke3ee
Not that I have found or been able to do.
Old May 22, 2014 | 08:49 PM
  #997
calforhelp's Avatar
calforhelp
Originally Posted by claw
It's same as R56
YES THEY DO!
Cool, thanks guys. I'll let you know my results
Old Jun 2, 2014 | 05:37 AM
  #998
ALIENLOVE's Avatar
ALIENLOVE
Any idea if this can be also applied to 11 CM ALL4?
http://tinypic.com/player.php?v=1zmk...8#.U4xvwyj4KOW
Old Jun 2, 2014 | 05:50 AM
  #999
heiker's Avatar
heiker
No, mirror folding option is available only from 11/2012 onwards. Other wiring, mirrors and control modules are implemented to cover this feature.
From that date there is no separate module to control mirror folding, now FRM takes care of this via LIN protocol. There other mirrors and other switches in the door's armrest required. Even in 11/2012 model retrofitting electric folding mirrors is much more complicated, as you need to replace:
- mirrors
- FRM to high (if you have low version)
- door's switches to high version
- wiring harness
I gave up this retrofit. Maybe I will consider it in future....
Old Jun 2, 2014 | 12:16 PM
  #1000
Kimsc321's Avatar
Kimsc321
Sure thing Alienlove... I have successfully reprogrammed that feature as well as few others on 2011 S (mine), 2011 justa and 2012 All4.....
steven
