Electrical Countryman-Specific Coding - R60 Guide
Old Dec 11, 2012 | 02:05 PM
  #501
Theta's Avatar
Theta
Originally Posted by kerrys914
Thanks. I tried to have my "bulb out" coded off but we kept getting an error. We assumed it was the Daten files too new for that module.
Just an FYI - there is no such thing as too new on the Daten side of things. There's only an issue if your car's Datens are newer than the software Datens.
Old Dec 11, 2012 | 03:38 PM
  #502
JCW ger's Avatar
JCW ger
Anything like this for R56 MCS??
Old Dec 11, 2012 | 03:51 PM
  #503
Koopah's Avatar
Koopah
Yes! Go to the 2nd Generation MINI > Modifications > Electrical thread.
Old Dec 15, 2012 | 08:03 AM
  #504
TRIPLE_O's Avatar
TRIPLE_O
Theta, just tried to use the 46.3 to code a 2013 JCW...still no luck. I know you said that the files would most likely be in 47.1 but thought I'd give it a shot anyways. Any word on when we may see that release?
Old Dec 17, 2012 | 04:26 PM
  #505
TRIPLE_O's Avatar
TRIPLE_O
Mark Gallo, esse.erre and others with cable issues. After a lot of recent confusion around the eBay cables not working, I have recently purchased a handful of the cheap eBay cables with the WHITE BOARDS, STRICTLY FOR TESTING. Here are my results:
-I ordered from different sellers (each ranging from $25-$35)
-They all came with white boards (I did not know this until after they arrived)
-They all came with Pins 7&8 soldered together, which I unsoldered)
-They all were advertised to work on DCAN vehicles (after 2007, etc)
-NONE OF THEM WORK, PERIOD. THEY ONLY WORK ON K-LINE VEHICLES BEFORE 2007!!
Please contact your sellers immediately and return them because no matter what you do, you will not get them to work.
Additionally, I have purchased multiple $99 cables from one stop electronics that all have Green Boards and work very well. They even come with a plug in adaptor to work with K-Line vehicles if you ever need to.
Lastly, I will note that a few months back I purchased a clear color $50 eBay cable that did work out of the box on DCAN vehicles. The seller was from Toronto. I can't remember the color of the board inside as I have since passed that cable along.
Old Dec 17, 2012 | 04:29 PM
  #506
Theta's Avatar
Theta
Very nicely said - the recent changes that brought the prices on these cables down really screwed things up.
When I bought my clear cable, it was still in the $90 range. They have changed the internals now - it seems to make them cheaper, but they no longer work.
Please heed TRIPLE_O's instructions!
Old Dec 17, 2012 | 04:47 PM
  #507
Koopah's Avatar
Koopah
TRIPLE_O, Theta, et. al. --
The "Toronto" cable has a green PC board and works flawlessly!
HTH,
Old Dec 17, 2012 | 05:11 PM
  #508
TRIPLE_O's Avatar
TRIPLE_O
They really did screw things up.
HTH,
Thank you for confirming!!
Old Dec 19, 2012 | 05:53 AM
  #509
esse.erre's Avatar
esse.erre
TRIPLE_O and other people great job! You are a great team!
Following this issue, I propose to everybody owns a good working cable to post which is the supplier. (... of course without any responsibility ...).
This just for having a way to follow in case of the purchasing.
Old Dec 22, 2012 | 01:31 PM
  #510
cm.d's Avatar
cm.d
I have 2 green board cables coming! I hope they work on 2013 models. woot!
Old Dec 23, 2012 | 06:12 PM
  #511
TRIPLE_O's Avatar
TRIPLE_O
Let us know please. Where did you buy them from (links)? Also make sure you're using updated coding files so you can rule out any file issues if you run into connection problems.
Old Dec 23, 2012 | 07:54 PM
  #512
cm.d's Avatar
cm.d
I emailed every seller on eBay. Only one person said they have the green circuit board. The seller is adgogogo.
Still waiting for my mini to be shipped. Maybe a month more before I can test the cables.
Old Dec 24, 2012 | 12:04 PM
  #513
TRIPLE_O's Avatar
TRIPLE_O
Thank you. I contacted the seller and will try to order one or two some time next week when I get back from Chicago to test them as well. I'll probably have them sent via DHL or Fedex because I cannot wait 3 weeks for anything!! haha. We'll see what kind of price they can work out, it's usually not too bad cost wise.
Old Dec 28, 2012 | 10:30 AM
  #514
mikecalgon's Avatar
mikecalgon
Thumbs up Thanks
It is great to be here, here you kind guys provide packaged software, provide newest datens, provide detail instructions and answers. Those are all time consuming.
I appreciated your contributions
Decided to order DCAN cable and try it on my new countryman copper s all4 which is produced in 09/12.
I believe I will ask some questions later, as newbies.
Mike from China.
Old Dec 28, 2012 | 10:36 AM
  #515
Theta's Avatar
Theta
Much appreciated, Mike! Best of luck to you - feel free to ask questions when you get your cable.
Old Dec 28, 2012 | 10:38 AM
  #516
Theta's Avatar
Theta
By the way, forgot to post an update on this, but I'm having Triple_O test the newest datens on the '13 JCWs as we speak.
Should be able to tap into anything out there.
Old Dec 28, 2012 | 10:48 AM
  #517
bmwr606's Avatar
bmwr606
Theta
is it possible to enable the "shift now" light in usa R60s as in euro models?
scott
Old Dec 28, 2012 | 10:51 AM
  #518
Theta's Avatar
Theta
Eww, good question. I'll look at the files, but Triple_O is more familiar with converting the Euro options as evidenced by some of his earlier posts.
It's of course possible that it's a hardware limitation in the USA models, but I'll do some checking in the code side and the wiring diagram if that goes nowhere. I'll let you know what I find.
Old Dec 28, 2012 | 10:53 AM
  #519
Theta's Avatar
Theta
Can you tell me where that light actually pops up? I can't find a picture of it.
  #520
bmwr606's Avatar
bmwr606
thanks
btw, where did you get a wiring diagram? i would love to have one for my 03/2012 build cms all4
scott
Old Dec 28, 2012 | 10:54 AM
  #521
Theta's Avatar
Theta
Originally Posted by bmwr606
thanks
scott
Part of my BMW subscription. They'd get pretty pissy if I put that stuff online. We're barely skating by with the datens.
Old Dec 28, 2012 | 10:55 AM
  #522
bmwr606's Avatar
bmwr606
i saw a picture of it on the mini uk site, it was in the tach, but i don't remember exactly where
i will try to find it again
scott
Old Dec 28, 2012 | 11:12 AM
  #523
bmwr606's Avatar
bmwr606
Theta
i found it again
it is in the "download brochure" pdf file for the countryman s all4 on pages 12/13
the shift indicator appears in the bottom tach display window in the top right corner
it indicates both up and downshifts
scott
Old Dec 28, 2012 | 11:13 AM
  #524
Theta's Avatar
Theta
Ahh, that explains it. I was looking in the manuals. Found a reference to it in a UK manual for the R56 for 2008.
Old Dec 28, 2012 | 11:14 AM
  #525
bmwr606's Avatar
bmwr606
almost afraid to ask, but i am sitting, so ....
how much for the women, ... errrr the subscription?
scott
