Electrical NCSExpert DIY(do it yourself)
Old Apr 25, 2014 | 03:58 AM
  #501
dracon's Avatar
dracon
Originally Posted by u238
Is it possible to have daten files that are too new? I'm trying to code my 2011 MCS FRM module and can't seem to get it working. I updated to EDIABAS 7.2.0 to solve the Faulty Best Version error, so now I can read the TRC file just fine. Once I go to write it back, I always get an error. I've tried v49.4 and v50.2 datens. I also wiped my BMW Standard Tools completely and started over with version 2.10. Same results. I've followed the guide to the letter and successfully coded other modules. Should I be looking for older daten files maybe?
I've never had problems with using the newest data on cars with older software. What is the error you are getting when writing back to the FRM?
Usually, if you can read the module, then the data is good, otherwise you'd get an error from NCSExpert saying it doesn't recognize the coding index on the module.
Old Apr 25, 2014 | 07:01 AM
  #502
u238's Avatar
u238
I made a thread about it in this sub-forum. Here's the error when I try to code to FRM after changing the double hazards option:
ERROR! Modul: CBD_PROC.C, ProcNr: 02, LineNr: 10, ErrorNr: 40.
00340C'01,OFFSET_ADC_SNU (1125d, 465h)
ERROR! Modul: CDH.C, Proc: CDHGetNettoDataFromCbd, LineNr: 01, ErrorNr: 1043
COAPI-1043: error during processing CBD-file
FRM3_R56.C35
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 1043
SG_CODIEREN
Old Apr 25, 2014 | 07:21 AM
  #503
alexs3d2's Avatar
alexs3d2
I recommend you switch to BMW Standard Tools 2.12, which come with EDIABAS 7.3. Then make sure you update the ECU folder in the EDIABAS directory with the ECUs from your DATEN directory. Your car is relatively new so I also recommend to go to v50+ Datens...
Old May 2, 2014 | 04:59 PM
  #504
u238's Avatar
u238
I made an attempt to install 2.12, but I think I screwed it up somehow because I'm back to a best error. Do you happen to have a source for 2.12? I'm not sure mine is working properly.
Old May 2, 2014 | 10:55 PM
  #505
alexs3d2's Avatar
alexs3d2
That is normal. After you install standard tools you need to reinstall INPA, the ECU and the DATEN files.
Old May 12, 2014 | 02:31 AM
  #506
claw's Avatar
claw
i'm trying do activate DRL's on halogen (yes, not turn off, but turn on )
i did some research, try a few options, but no success.
Change FRM like this:
TAGFAHRLICHT_ECE
Aktiv
VERHALTEN_DRL_TFL
DRL_S
DRL_TFL_SML
Aktiv
And when i read back module (after coding), it's reverted to original state :(
Any ideas? Anyone try this before?
Old May 12, 2014 | 07:43 AM
  #507
jbourne's Avatar
jbourne
TAGFAHRLICHT_ECE
Aktiv
VERHALTEN_DRL_TFL
DRL_S
DRL_TFL_SML
Aktiv
if the value resets back to the original after you code it, make sure you loaded the right profile when you started up NCSExpert (I forget what it was called, maybe FSW PSW Man or something?). An incorrect mode will tend to have that result.
Old May 12, 2014 | 07:53 AM
  #508
claw's Avatar
claw
Now that you mention... i use only two profiles, "expertmodus" (or something like that :D ) and "Revtor's NCS Expert Profile ". And i may i've choosed "Expertmodus" instead of Revtor's profile.
I'll try again later.
Thanks!
Old May 12, 2014 | 07:33 PM
  #509
Agbullet25's Avatar
Agbullet25
Thanks!
You'll need to use Revtor's profile to make any changes. The expert mode profile is used for making vehicle order changes if I remember correctly.
Old May 13, 2014 | 02:51 AM
  #510
claw's Avatar
claw
Yes, i know.
i just was distracted Thanks
Anyway, didn't work. The settings are coded, but no result :(
I tried multiple options, still no DRL. :(
Old May 13, 2014 | 11:23 AM
  #511
Agbullet25's Avatar
Agbullet25
If you're in the US, I think it's a setting in the OBC, not a coding problem.
Old May 13, 2014 | 11:31 AM
  #512
daddyandmadi's Avatar
daddyandmadi
i'm trying do activate DRL's on halogen (yes, not turn off, but turn on ) i did some research, try a few options, but no success. Change FRM like this: TAGFAHRLICHT_ECE Aktiv VERHALTEN_DRL_TFL DRL_S DRL_TFL_SML Aktiv And when i read back module (after coding), it's reverted to original state :( Any ideas? Anyone try this before? Thanks
Try adding the "Canadian" line in. Search which line, I recall a fellow from Halifax removing his drl by removing the Canadian text
Old May 13, 2014 | 01:47 PM
  #513
claw's Avatar
claw
No, i'm in Europe. I check OBC after every coding and didn't find any option to turn on/off DRL.
You mean add the canada region code to VO?
That idea crossed my mind, but i'm not sure what else will be changed.
Thank you.
Old May 17, 2014 | 04:40 AM
  #514
BXR's Avatar
BXR
Adding the bluetooth and CD changer options
How do I add the bluetooth and CD changer options to the R56 (boost radio)?
I've went through the NCS instructions but didn't figure it out (it isn't written anywhere).
Old May 26, 2014 | 06:11 PM
  #515
pathartl's Avatar
pathartl
Just got my cable in the mail, though my Daten is v38 which is obviously too old for my 2013 MCS. Anybody know what version I should be looking for?
Old May 26, 2014 | 07:16 PM
  #516
cerenkov's Avatar
cerenkov
51.2.
You can download it in the first post in the countryman coding thread.
Old May 26, 2014 | 08:31 PM
  #517
pathartl's Avatar
pathartl
Originally Posted by cerenkov
51.2.
Killer, thanks so much. Got the speedo compensation disabled and window close by remote enabled tonight! Had an error trying to switch to FRM but I'm pretty sure my software is just a little too old. I'll try a newer version tomorrow.
Old Jun 3, 2014 | 12:35 PM
  #518
mscalissi's Avatar
mscalissi
Coding
I'm trying to code my R56 2013 with SP-DATEN v51.2 but some modules can be accessed and some not as FRM...I received na error 0009 about Best Version.
Someone can help me to fix it?
Thanks.
Old Jun 5, 2014 | 07:25 PM
  #519
cerenkov's Avatar
cerenkov
Thanks.
Have you seen this thread?
https://www.northamericanmotoring.co...-2011-r56.html
Old Jun 6, 2014 | 03:36 AM
  #520
mscalissi's Avatar
mscalissi
Problem in Daten/Ediabas version
Yes, but all links to download Ediabas and Daten doesn't work anymore...
Do you have the V32 and Ediabas 7.2.0 to change in my computer? After changed it do you believe if it will be necessary update the Daten to 50>?
Thanks.
Old Jun 6, 2014 | 04:34 AM
  #521
cerenkov's Avatar
cerenkov
Thanks.
I would un-install then reinstall everything. You should be able to use one of these:
http://nutsofamily.com/?page_id=2
or
https://www.northamericanmotoring.co...beginners.html
or maybe even the R60 package (and DATENS):
https://www.northamericanmotoring.co...r60-guide.html
Old Jun 6, 2014 | 06:01 AM
  #522
mscalissi's Avatar
mscalissi
Preference
What do you prefer?
In the same computer I have installed the Esys for my F30, any problem to uninstall only the BMW TOOL?
Thanks.
Old Jun 6, 2014 | 06:05 AM
  #523
mscalissi's Avatar
mscalissi
Information
The second link I tried but still with error...When I tried to code the car with it I got fault chassi...so I update the Daten for 51.2 (I think) and fix this error but continue with error of BEST VERSION, so with 51.2 I just can code some modules as KOMBI and not FRM...
Old Jun 14, 2014 | 11:36 PM
  #524
Paul's Avatar
Paul
I have a quick favor to ask. I'm trying to figure out the differences between the FSW_PSW.TRC after choosing CAS or FRM from the choose ECU dialog box.
In NCS Expert:
F2 CHASSIS -> R56 -> F1 VIN/ZCS/FA -> F3 ZCS/FA f. ECU
then first choose either CAS. At this point, I think a FSW_PSW.TRC file is generated in the in the C:\ncsexper\work directory. Save this somewhere else, this is what I want to compare with the file that's created when you choose FRM.
Some of the differences I'm seeing are:
CAS version:
FZG_RADSTAND
wert_16
FRM version:
FZG_RADSTAND
wert_18
Could someone take a look at their FSW_PSW.TRCs and let me know if you see similar differences?
Thanks!!
Old Jun 15, 2014 | 04:23 AM
  #525
cerenkov's Avatar
cerenkov
The CAS and FRM trc files are going to be different. What your doing is reading the vehicle order (FA). The vehicle order is stored in both the CAS and FRM modules.
