Electrical NCSExpert DIY(do it yourself)
Old Jun 6, 2015 | 10:02 AM
  #576
cerenkov's Avatar
cerenkov
Originally Posted by synzeus
Yes, cerenkov i tried it and it worked for both cold and warm monitoring.
But i am having another error with these disabled.
On the 2007 model, the owner also added aftermarket xenons. I also had to:
1.) add $522 to the vehicle order
2.) default the FRM module
3.) disable the bulb check
Old Jul 1, 2015 | 06:58 AM
  #577
walk0080's Avatar
walk0080
Old Jul 1, 2015 | 01:32 PM
  #578
walk0080's Avatar
walk0080
Old Jul 8, 2015 | 06:00 AM
  #579
no1jones's Avatar
no1jones
Any NCSExperts in central Iowa want to hook a guy up? Looking at some changes but really not sure I wouldn't mess this up myself. If not I'll be tackling in then next month or so. PM me if there is anyone able to help out. Thanks.
Old Dec 17, 2015 | 07:59 AM
  #580
dez's Avatar
dez
sorry to revive an old thread but what did you code to disable the rear fog bulb warnings?
was it just these?
FRM Module
Rear Fog Lights
KALTUE_NSL_L_M2_51
WARMUE_NSL_L_M2_51
nicht_aktiv
KALTUE_NSL_R_M1_10
WARMUE_NSL_R_M1_10
nicht_akti
Originally Posted by walk0080
Finished most of the NCS Expert changes for now:
-Disabled city lights, license plate, reverse and rear fog bulb out checks (replacing with VLEDs soon that do not have CANBUS or resistors).
-Disabled automatic A/C engagement.
-Removed Canadian region from Vehicle Order (to get DRL settings)
-Enabled city lights for DRL instead of xenons.
-Enabled comfort close windows/sunroon w/ keyfob.
-Disabled stop of window wind down when door opened.
-Double hazzard light flashes.
-Enable allow fogs with high beam flash.
-Enabled factory alarm light (mine doesn't have the wiring in place... may consider the wiring mod found elsewhere on NAM to get this working...)
-Enabled one-touch sunroof open (one-touch close is not working for me...)
Didn't get around to disabling speed over-estimation or the allow fogs on with high beams. Maybe another day.
For the sunroof, I have the entries below in CAS-SHD module. Not sure if anyone has any suggestions to get one-touch close working?
SCHIEBEHEBEDACH_TIPP_HEB
aktiv
SCHIEBEHEBEDACH_TIPP_SENK
aktiv
SCHIEBEHEBEDACH_TIPP_AUF
aktiv
SCHIEBEHEBEDACH_TIPP_ZU
aktiv
Should I default out the SHD module and try again?
Old Dec 22, 2015 | 11:54 AM
  #581
walk0080's Avatar
walk0080
Old Dec 22, 2015 | 11:55 AM
  #582
walk0080's Avatar
walk0080
Old Dec 22, 2015 | 12:27 PM
  #583
Agbullet25's Avatar
Agbullet25
It might be out on some of the BMW Coding forums. I'll keep an eye out. They really should've done it so when you take your car in for service, and a software update is needed or module replaced, they download the settings (including our changed ones via NCS), then simply re-upload them with the new software. Similar to keeping files and settings when upgrading Windows versions.
Old Dec 22, 2015 | 12:43 PM
  #584
walk0080's Avatar
walk0080
Old Dec 27, 2015 | 09:46 AM
  #585
Ive's Mini's Avatar
Ive's Mini
Hello all. I am finally starting to get my NCS Expert programming started. I have updated everything and updated my Daten, sgdat, and ecu to 53.0.5 . My problem is my REVTOR.PFL file came from Datens v38. I get and error that says Profilversion 2.0 Ungutil! I suspect it is because that cam from V38. I have not been able to find a newer profile. I am a novice at this. Can anyone shed some light to my solution? I am trying to code my 2008 Cooper.
Thank you,
Ivan
Old Dec 27, 2015 | 02:03 PM
  #586
cerenkov's Avatar
cerenkov
What version of NCS Expert are you using?
Old Dec 27, 2015 | 03:24 PM
  #587
BXR's Avatar
BXR
What happens if I add the amplifier to the vin and program the mini as it has an amplifier, but do not install it yet?
Old Dec 27, 2015 | 07:16 PM
  #588
Ive's Mini's Avatar
Ive's Mini
Thank you for replying! BMW Standard Tools 2.12
Ivan
Old Dec 27, 2015 | 07:56 PM
  #589
Ive's Mini's Avatar
Ive's Mini
My NCS Expert appears to be 4.0.1
Old Dec 28, 2015 | 04:29 AM
  #590
cerenkov's Avatar
cerenkov
For NCS Expert V4 the Revtor profile was changed to DUMMY4.
Here's a link that you should be able to download it. Let me know if it does not work.
https://drive.google.com/file/d/0B9g...ew?usp=sharing
Old Dec 28, 2015 | 08:45 PM
  #591
Ive's Mini's Avatar
Ive's Mini
Thank you!!! I set things up and all looks good. I'm going to try hooking up the car tomorrow and see what happens. I'll post back.
Thank you again,
Ivan
Old Dec 29, 2015 | 02:24 PM
  #592
Ive's Mini's Avatar
Ive's Mini
Hello Cerencov.
1st thing I'd like to say is thank you. I am 99% successful and coded a ton of stuff.
I ran into a snag on the last one...as the last one is always the one that burns you...
I attempted to reprogram the SHD to change to 1 touch sunroof operation.
I changed SHIEBEHEBEDACH_TIPP_AUF to aktiv
SHIEBEHEBEDACH_TIPP_SENK to aktiv
SHIEBEHEBEDACH_TIPP_ZU to activ
and SHIEBEHEBEDACH_TIPP_HEB was left on activ
After the program, I have a sunroof warning light and no sunroof operation.
Can you shed a little light on what I must do to restore operation or reinitialize the sunroof?
Thank you for your help.
Ivan
Old Dec 29, 2015 | 06:22 PM
  #593
Ive's Mini's Avatar
Ive's Mini
I am updated my status: 100% successful. I turned on the alarm light, stopped the shut down of the windows when the doors are opened, fixed my speedometer to the tach, shut off the seatbelt alarms, made the sunroof 1 touch, and now can close up all windows and the roof using the remote. I was going to fix my overestimation of the speedometer, but I decided to keep it. It has saved me more times than I can count. Thank you for the help! It feels great to have been able to make everything work!
Ivan
Old Feb 8, 2016 | 07:15 PM
  #594
justawatcher's Avatar
justawatcher
cranky.. '13 R56 :)
Hello, I just purchased a new project car and I'm interested in making a few changes to the VO.
I'm familiar with NCS Expert but was wondering if there are other ways to make these changes.
I've recently upgraded to a 64bit laptop and the version I have only works on 32bit OS's.
On the new system I have Ediabas 7.3.0, BMW Coding Tool, Rheingold 3.51 Standalone and ISTA-P 3.56 but I'm not familiar with all of its capabilities yet.
Are there some links that I missed on VO updates or do I need to dust off the old 32bit trusty system.
thanks all, and Great posts
Old Feb 9, 2016 | 02:36 AM
  #595
cerenkov's Avatar
cerenkov
I sent you a PM.
Old Jul 22, 2016 | 08:53 AM
  #596
JohnnyZenith's Avatar
JohnnyZenith
How do I code for getting my head unit to activate the USB (or speak to) and Aux Ports, and the Bluetooth 6NF in my Mini Clubman 2008?
What are the steps I need to take?
I have never done this before but I am learning from scratch and will not attempt it until I understand it well.
Or Perhaps someone can direct me.
http://nutsofamily.com/wp-content/up...2011.04.23.pdf
I understand the very basics from this
Old Sep 12, 2016 | 01:34 PM
  #597
HCGray12's Avatar
HCGray12
Error Message While Writing to Module - Why?
I made my first coding 'write' effort today (double-blink hazard lights) as a test. I read the module, changed the value of the Doppel... location using NCS Dummy and then went to write the changed MAN file back into the FRM module.
A quick aside...
NCS Dummy can help to figure out which variation of a module is actually in the car. For my 2012 MCS, it's not "FRM", but "FRM3_R56_C35". (I kept trying different version choices in turn in NCS Dummy while trying to read the TRC file from the "FRM" module until one of them was read with no errors.)
Back to the point...
While attempting the "SD_CODIEREN" job in NCSEXPERT, I got a message that said:
"Error in CADB! Look at CABI.ERR and ERROR>LOG!"
"COAPI-2000: EDIABAS or SGBD error"
"IFH-0003: DATATRANSMISSION TO INTERFACE DISTURBED"
The ERROR.LOG file contains:
ERROR! Modul: LFCDHDIA.CPP (A_PL2FRX.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000
SG_CODIEREN
I clicked the OK button and decided to try again by again clicking on "Execute Job". No other changes.
The second time it worked and I got double-blink hazard lights.
Can anyone help with what causes this kind of error message?
Old Sep 12, 2016 | 08:00 PM
  #598
HCGray12's Avatar
HCGray12
So, I went back and tried again. I coded 4 modules without another error - musta been a transient communication issue or something...
Cheers.
Old Sep 20, 2016 | 06:53 PM
  #599
HCGray12's Avatar
HCGray12
"Standing Lights"?
Looking through the sections of FRM(03-C35) related to bulb checks, I found entries for "Standing Lights 1" and "Standing Lights 2".
Does anyone here know what lights those entries refer to?
Cheers!
Old Sep 20, 2016 | 06:59 PM
  #600
HCGray12's Avatar
HCGray12
DCAN Cable Source Suggestion
I bought a DCAN cable through Amazon. As long as the cable is either sold directly by Amazon, or fulfilled by Amazon, you can return a cable that doesn't work - with no questions asked.
This might remove some of the risk for those buying a cable to start coding.
Cheers!
