Electrical NCSExpert DIY(do it yourself)
Old Jun 21, 2014 | 07:35 PM
  #526
JeffInDFW's Avatar
JeffInDFW
Never mind.
Old Jun 22, 2014 | 12:41 PM
  #527
Paul's Avatar
Paul
Originally Posted by cerenkov
The CAS and FRM trc files are going to be different. What your doing is reading the vehicle order (FA). The vehicle order is stored in both the CAS and FRM modules.
Thank you
Old Aug 28, 2014 | 08:20 PM
  #528
TVPostSound's Avatar
TVPostSound
Straight from REVTOR!!
To those still contacting me for "Revtor's NCS Expert Profile"... The profile has been renamed to "NCS Dummy profile" many years ago and download links are provided in chapter 6 of the NCS Dummy user manual. Unlike "Revtor's NCS Expert Profile", the "NCS Dummy profile" is available for both NCS Expert 3.* and 4.*. Furthermore the "NCS Dummy profile" defaults to reading trace files (CODIERDATEN_LESEN) instead of coding (SG_CODIEREN) which is more logical and safer.
NCS Dummy profile for NCS Expert 3.* (1 kB) (NCSDUMMY3.PFL)
NCS Dummy profile for NCS Expert 4.* (1 kB) (NCSDUMMY4.PFL)
Old Aug 30, 2014 | 06:59 PM
  #529
Brandon Mabee's Avatar
Brandon Mabee
Thats the first ive seen of the NCS profile change. ive been trying to install and get this software communicating with my 2013 R56 for three days. tried many different "standards tools" packages, many different Datens up to v50 and still nothing. I get the two black dots in INPA but cannot read my cars modules. All i want to do is be able to code stuff but instead I just get the "VIN is Faulty" code and no one has helped. I see a lot of ppl that experience this problem and then they just post "fixed" without an explanation of how.
Old Aug 30, 2014 | 08:42 PM
  #530
TVPostSound
What OS, what version of EDIBIAS?
PM me
VIN faulty is the cable or driver issue.
Old Sep 2, 2014 | 11:45 PM
  #531
bmrguy03's Avatar
bmrguy03
What worked for me in that situation is the following.
1.Uninstall the NCSEXPERT you have right now.
2. Restart computer
3. Reinstall NCSEXPERT BUT DO NOT install the datens from the installation file/folder, instead install only the newest Datens.
4. Proceed with installation as normal.
If that doesn't work then most likely it is the cable. Usually what people do is follow the old instructions on installing NCSEXPERT and the old Daten folders, but then try to update the Daten folder with the newest one. However the folders contain incompatible files when mixed together so it causes the program not to work properly. In other words, usually improper update method is the culprit.
Old Sep 29, 2014 | 07:38 PM
  #532
R3BrotherJr's Avatar
R3BrotherJr
Can't disable OC3 sensor
Hi Guys I'm having issues disabling my OC3 sensor in my 2007 justa via NCSExpert. I have everything running well, no errors while reading the modules, etc. I am well aware that others have succeeded by setting OC3_1 and OC3_2 to nicht_aktiv on ABG, but when I head there I only have the OC3 option. No OC3_1 nor OC3_2. are those options hidden? Any help would be greatly appreciated.
Old Sep 30, 2014 | 04:06 PM
  #533
ctweber's Avatar
ctweber
Anyone been able to disable the auto window down function from the keyfob?
I see that you can enable the close function to compliment the open listed in the spreadsheet.
I found this function value on a BMW forum.
KOMFORTSCHLIESSUNG_PA which referred to opening for those cars
Wonder if this works on Minis?
I'd try but haven't yet been able to get NCSExpert working properly with my mini.
Old Sep 30, 2014 | 06:19 PM
  #534
TVPostSound
What OS?
Old Oct 4, 2014 | 01:34 PM
  #535
KeyPlayaJim's Avatar
KeyPlayaJim
Disabling Speed Overestimation
Using NCS Expert/NCS Dummy, I successfully disabled the speed overestimation via BC_DIGITAL_V_KORREKTUR, but, it affected only the digital speedometer. The analog speedometer and even the speed control still read high, as before, so, for example, to make the car cruise at an actual 50 MPH, I still have to set the speed control to 52 -- the digital speedo reads 50, and the analog one reads 52.
I haven't found any references to this effect in the various threads. Is it normal, or do I also need to change another parameter? If it's normal, that's fine -- I rarely look at the analog speedo -- but if it can be corrected, I'd like to take care of it.
Also, just a heads-up for anyone who does this: disabling the speed overestimation zeroed out the clock, the trip odometer & some related items, and also reset a couple other things, such as the automatic door locking. It scared me for a minute, because I thought I'd done some damage, but it was just a matter of setting the clock & putting a couple other settings back to the way I wanted them.
Old Oct 6, 2014 | 09:00 PM
  #536
R3BrotherJr
OC3 Sensor
Anyone?
Old Oct 11, 2014 | 01:22 AM
  #537
Robert_NL's Avatar
Robert_NL
First get NCS Expert working properly before making changes to the car.
And to disable the comfort opening windows with keyfob, set KOMFORTOEFFNUNG_FB to nicht_aktiv. This setting can be found in CAS-module.
Old Nov 17, 2014 | 10:54 PM
  #538
TISGOD's Avatar
TISGOD
Thanks guys,
T
Old Nov 24, 2014 | 08:01 AM
  #539
stephanreckie's Avatar
stephanreckie
Hi,
I am finally all set to get NCS running on my WIndows 7 laptop. I bought the cable and it works with INPA. The problem is that NCS doesn't work on Win 7. I tried to install the XP VM, but that took up a lot of space and also I couldn't get the files to share between operating systems.
Does anyone have an easy fix for this?
Cheers!
Old Nov 24, 2014 | 09:36 AM
  #540
KeyPlayaJim
Originally Posted by stephanreckie
Hi,
Cheers!
Check out this post regarding an updated version of NCS: https://www.northamericanmotoring.co...ml#post3983452
It worked for me!
Old Nov 24, 2014 | 09:42 AM
  #541
claw's Avatar
claw
Hi,
Cheers!
BMW Coding Tools 2.12 work on windows 7. Use compatibility mode for XP.
Old Nov 24, 2014 | 01:53 PM
  #542
stephanreckie
BMW Coding 2.12
Is there a simple narrative on how to use the BMW Coding tools with the Countryman?
Old Nov 25, 2014 | 04:04 AM
  #543
claw's Avatar
claw
There's a dedicated section for Countryman here in NAM.
But the procedure is the same as for R56.
https://www.northamericanmotoring.co...r60-guide.html
Old Dec 14, 2014 | 06:02 PM
  #544
miniwpbear's Avatar
miniwpbear
Snowflake / Road Ice Warning Disable?
Anyone know the Module and function title to disable Snowflake / Road Ice Warning?
I found this in the spreadsheet "Road Freeze Temperature Warning Change to nicht_aktiv to eliminate the Check Control message when the temp falls past 37°F KOMBI CC_TEMPERATURWARNUNG" but this was already set to nicht_aktiv when I read my KOMBI module from ECU and I still get the snowflake.
Old Dec 17, 2014 | 12:16 PM
  #545
u238's Avatar
u238
Can NCS Expert or the associated software be used to register a replacement battery?
Old Dec 17, 2014 | 12:51 PM
  #546
miniwpbear's Avatar
miniwpbear
https://www.northamericanmotoring.co...ml#post4017906
https://www.northamericanmotoring.co...nt-help-3.html
Old Dec 19, 2014 | 07:50 AM
  #547
u238's Avatar
u238
I somehow have disabled the 3x momentary turn signal by trying to code the FRM in my 2011 MCS. It still shows as an option on the car, but when selected it immediately reverts to single blink. I have no idea how to fix it. How can I restore the car to defaults?
Edit: I think I fixed the problem by disabling trace file manipulation on the revtor profile and coding the vehicle order back. I'm pretty sure at least some of the original coding problem is due to an incorrect profile I used. The revtor profile produced an error when I tried to code FRM. Instead I used expertmodus and it did something (the lights in the car turned off momentarily) but it obviously didn't code properly. Is there an appropriate profile to use for coding our cars?
Old Jan 7, 2015 | 02:38 PM
  #548
bratling's Avatar
bratling
Super Moderator
Originally Posted by GTECKO
Thanks to jbourne , I have allocated on a spreadsheet the mods that I have tried and know they work - ppl who have tried other new mods are adding them on the sheet.
Here is the spreadsheet , you need to request to view it (please do not edit randomly afterwards) and I will allow you view/edit it.[/I]
Hey there,
I'd like to suggest an update to the spreadsheet, from Brad Bedell's OEM Nav retrofit thread, for pre-LCI Navigation systems.
Retrofit Navigation - Add $609 (navigation) and $6UH (RTTI) to the VO (both CAS & FRM). Remove $6FC (boost radio).
Years: 2007, 2008, 2009, 2010
Definitely does not apply to 2011 or later models.
Old Jan 13, 2015 | 03:38 PM
  #549
justawatcher's Avatar
justawatcher
here ya go, this is what I found and used...
https://www.northamericanmotoring.co...ml#post4032401
Old Jan 14, 2015 | 01:35 AM
  #550
claw's Avatar
claw
(wrong thread, sorry. Please delete)
