Electrical The [Complete] NCS Expert DIY
Old Dec 4, 2013 | 05:20 AM
  #101
minimechusa's Avatar
minimechusa
Key fob code to close and open the sunroof and convert able top is the same code. I haven't messed with Win program yet but will today and I'll let you know how it goes!
Old Dec 4, 2013 | 06:27 AM
  #102
RYOAK5150's Avatar
RYOAK5150
Originally Posted by RYOAK5150
No one?? Theres got to be someone who successfully used/uses WinKFP...
UPDATE: I just need v41 DATEN :/ solved my own problem.
Old Dec 4, 2013 | 07:30 AM
  #103
minimechusa
Pm me your email I have 45&49 or do you need 41 specifically. If you really need 41 check the R60 tcs expert thread it has a download link to 41 I believe
Old Jan 31, 2014 | 12:33 PM
  #104
zrickety's Avatar
zrickety
Great thread, thanks for the links.
Old Mar 23, 2014 | 01:37 PM
  #105
bainjs's Avatar
bainjs
Thanks for the instructions! I was able to delete the airbag passenger sensor codes and turn off the airbag light.
Thanks again!
Old May 22, 2014 | 07:40 AM
  #106
MC1973's Avatar
MC1973
Want to set code on 2011 Mini Cooper Convertible
Hi All,
I would like to set following codes on my 2011 Mini cooper convertible
1. Auto un-lock when in Park mode.
2. Disable all light checks on start of the car
3. Able to close soft top from remote key.
I have the cable which I can attach to Mini . I tried to work with NCS Expert software. But it is not working on my laptop which has Windows 7 64 bit version.
I would be very much thankful if some one can help me out with this.
Appreciate!
MC1973
Old Jul 29, 2014 | 09:33 AM
  #107
erider's Avatar
erider
57 sunroof
has anyone been successful with the one touch option for the r57 sunroof? I couldnt figure out what to change in the CVM module.
Thx
Glen
Old Aug 3, 2014 | 08:33 PM
  #108
thenosyt's Avatar
thenosyt
Windows not detecting driver
When I direct Windows to the folder that the cable driver is in, it can't find it.
I am using Windows 7.
Please help!
Old Aug 29, 2014 | 09:26 PM
  #109
Brandon Mabee's Avatar
Brandon Mabee
For those using windows 7, make sure your not running the 64bit system. IF you ARE then you will need to upgrade from windows 7 home to windows 7 pro or ultimate so that you can download the windows XP mode software. This allows you to basically use windows XP and do all your coding. As long as your running a 64bit system, most of these programs will not function.
Old Sep 2, 2014 | 11:14 AM
  #110
SkyJumpr16's Avatar
SkyJumpr16
The latest version of the toolset - .12, does support x64 Windows 7, thanks to Chernobyl. I've used it myself. I just posted it to my Google Drive account so you should be able to download it
https://drive.google.com/folderview?...2s&usp=sharing
Old Sep 2, 2014 | 12:41 PM
  #111
Brandon Mabee
Yeas Sky Jumper is correct and Chernobyl, made an amazing package for us R56erz. It makes the install a breeze too. But for those using the older tools package, you must use XP Mode in a VM
Old Sep 2, 2014 | 12:54 PM
  #112
TVPostSound's Avatar
TVPostSound
For those running Windows 8, Oracle VBox is free, and works!
http://lifehacker.com/5965889/how-to...e-in-windows-8
Old Sep 2, 2014 | 02:02 PM
  #113
KeyPlayaJim's Avatar
KeyPlayaJim
Thanks so much for posting this! I was going to buy the upgrade to Win 7 Professional today, so that I could run NCSE in XP mode, and you saved me the trouble and expense -- just in time.
Old Sep 2, 2014 | 07:03 PM
  #114
Chernobyl's Avatar
Chernobyl
Old Sep 4, 2014 | 09:03 PM
  #115
Brandon Mabee
ALL issues solved! Thanks to Chernobyl and TVPostSound! It was my cable. If your cable comes in and has a white, blue, red, or whatever other color that is NOT green.... Just send it back! Order from ecutools.com and ask for green. After experiencing problems and with the help of these two, we all determined the cable was at fault. Go GREEN!!! Theres numerous cases online where on the green ones work. Woot, successfully coded my wimdow up via key fob, more to come!
Old Sep 5, 2014 | 08:36 AM
  #116
TVPostSound
Coding addiction!!!
Old Oct 2, 2014 | 12:16 PM
  #117
KeyPlayaJim
I just had to say thanks again for posting this: I just did my first mod -- in Windows 7 64-bit -- enabling the closing of the windows & sunroof via the key fob! I nearly jumped up & down in my driveway, until I remembered that I'm 60 years old and might hurt something.
Next up, fix that ridiculously optimistic speedometer!
Old Nov 9, 2014 | 11:59 AM
  #118
mepalm's Avatar
mepalm
I have installed the software per your .pdf. The INPA software works but there is a compatibility issue with NCS Expert. Is this common? I am on Windows 7 SP1.
Thanks,
Mepalm
Old Mar 14, 2015 | 09:33 AM
  #119
seamonkey420's Avatar
seamonkey420
CONFIRMED WORKING ON WINDOWS 8.1 Pro 64bit and 2013 Cooper S Coupe (R58)
Thank you for doing this! I had my 2013 Cooper S Coupe into the dealership and in turn they had updated the software on the car and believe I am on a newer datens than what is in this post. If the datens files i have work, i'll post a link to them and how to copy them into this installation.
Btw, very nice little batch script for the upgrade. i work in IT and do app deployment so totally appreciate things like that
Last edited by seamonkey420; Mar 18, 2015 at 05:40 PM. Reason: added os ran on; Win8.1 Pro
Old Mar 21, 2015 | 09:18 AM
  #120
KeyPlayaJim
Originally Posted by mepalm
I have installed the software per your .pdf. The INPA software works but there is a compatibility issue with NCS Expert. Is this common? I am on Windows 7 SP1. Thanks, Mepalm
mepalm: See my post above. I also have Win 7 SP1 and had no problems running the updated NCSE & NCS Dummy (maybe that was the key to my success). I now have an accurate digital speedometer, remote window & sunroof closing, European hazard flashers, etc.
From iPad / 2013 MCS Hardtop
Old Apr 12, 2015 | 12:23 PM
  #121
Tem862013's Avatar
Tem862013
2014 Roadster
Has anyone had any success with a 2014 S Roadster? From all my research on NCS Expert and the OBD2 cable I have not found anything that mentions the R59.
Old Apr 12, 2015 | 12:31 PM
  #122
siriuszero's Avatar
siriuszero
It will be like any other 2nd gen MINI. Some coding may not work for equipment your Roadster doesn't have (like sunroof tweaks), but most everything should work.
Old Apr 12, 2015 | 12:37 PM
  #123
Tem862013's Avatar
Tem862013
Sweet! Now to see if I can get it installed. Gave it a go last night and about had a panic attack trying to figure out how to get the correct daten files.
Old Apr 12, 2015 | 02:26 PM
  #124
siriuszero's Avatar
siriuszero
Visit this thread for current datens:
https://www.northamericanmotoring.co...r60-guide.html
The thread is an R60 thread, but again, all the 2nd gen MINIs are the same when it comes to coding and the datens listed there will work with any 2nd gen MINI
Old Apr 20, 2015 | 01:54 PM
  #125
Tem862013's Avatar
Tem862013
Installed v53 datens and programmed the auto unlock with key removal and window close with lock on key fob. The auto unlock only unlocks the driver door (would like both doors) and the window close does not function. Thoughts? Should I go with older datens?
