Electrical NCSExpert DIY(do it yourself)
Old Feb 2, 2014 | 10:56 AM
  #476
cerenkov's Avatar
cerenkov
I believe that this is the proper way to default a module:
Load Profile
F1
F3
Select R56
Select CAS
F6
F4
Select Module
F2
Select SG_CODIEREN
F3
If you have a .MAN file in your work folder make sure that it is empty.
Old Feb 2, 2014 | 12:18 PM
  #477
Italianguy63's Avatar
Italianguy63
BINGO! As soon as I regen-ed the 2RAD it came up.
Thank you!
Old Feb 3, 2014 | 04:31 PM
  #478
dracon's Avatar
dracon
You guys need BMW Standard Tools 2.12 in order to use a 64bit OS.
You can follow a lot of the same tutorials used by the BMW guys, you'll just load the R5x data instead of the E8x data when setting it up. Otherwise, everything else is exactly the same.
If you guys upgrade to BMW Standard Tools 2.12 w/EDIABAS 7.3.0, you can even use the new Rheingold ISTA software from BMW to perform dealership level diagnostics (without screwing around with INPA) using your K+DCAN cables.
Old Feb 3, 2014 | 06:00 PM
  #479
Agbullet25's Avatar
Agbullet25
So everything is available doing a Google search or over at the bmw coding forum?
Old Feb 3, 2014 | 06:33 PM
  #480
dracon's Avatar
dracon
Pretty much, E90post.com has a pretty good coding section along with tutorials on setting up Standard Tools 2.12, loading the NCS data for coding, etc.
BMWCoding.com is another good reference, including a section just for Mini coding.
There's absolutely no difference on coding setups between BMW and Mini, with the exception you load R5x data instead of Exx data into NCSExpert. They are both built on the same electronics platform and share 98% of modules.
You can even load all chassis into NCSExpert without a problem. I do it myself since I code my parents Mini's and my BMW all the time.
A good tool to use is the BMW Coding Tool - makes it easy to load in data for NCSExpert and WinKFP (if you want to try flashing ECUs with updated software). Works for Mini just as well as BMW.
Old Feb 3, 2014 | 06:41 PM
  #481
Agbullet25's Avatar
Agbullet25
Sounds like I've got a project to work on for a couple weeks. Now when you mention 64 bit systems, does that mean Windows 7 and 8?
Old Feb 3, 2014 | 07:05 PM
  #482
dracon's Avatar
dracon
Works under both, I use Windows 7 64bit and everything works just fine.
Before too long you guys will have to start learning E-Sys for the F56 when they start rolling out. Completely different electronics platform and software for coding. Based on the BMW F-series platform (also known as BN2020).
Let me know if you need any help, I can usually setup a coding machine in about an hour now.
Old Feb 3, 2014 | 07:07 PM
  #483
Agbullet25's Avatar
Agbullet25
Awesome man
Old Feb 6, 2014 | 05:40 AM
  #484
whrisk's Avatar
whrisk
is it possble to change the VIN number in the SZL module with ncsexpert?
i am trying to retrofit my car for cruise control. i have purchased the mfsw buttons for the steering wheel, and have purchased a used SZL module. so i am going to need to change the VIN number in the module to get it to work.
if it matters its an 08 MCS.
Thank you in advance
Old Feb 28, 2014 | 05:13 PM
  #485
g35mt's Avatar
g35mt
i was reading on the r60 forum and the OP post in his thread regarding to VIM (video in motion) enable. I updated the daten file to latest version 51.2 and i can see cic model int he r56 folder.
When i go to read and for some reason, i can't get the CIC module. Anyone have a clue on how to read the CIC module?
https://www.northamericanmotoring.co...r60-guide.html
Old Mar 3, 2014 | 09:49 AM
  #486
Minin's Avatar
Minin
Is there any possible way to auto lock the doors after certain speed? How can i achieve this??
Old Mar 3, 2014 | 10:14 AM
  #487
Italianguy63
That's an easier one I think. It is in the Owner's Manual under personal settings... I just turned mine on the other day. You program it with the settings stalk. MC
Old Mar 5, 2014 | 09:35 AM
  #488
fallen002a's Avatar
fallen002a
Hi, can you tell me where I can download the updates for everything? I've never been able to get ncsexpert to work because i had the VIN is faulty error which I could solve but now I'm getting the Chassis is faulty error
Old Mar 5, 2014 | 12:11 PM
  #489
g35mt's Avatar
g35mt
i used the guide on this thread and on the r60 thread for the update file. Also google and you will find some BMW forum that has intensive information on the update.
Old Mar 5, 2014 | 05:59 PM
  #490
Agbullet25's Avatar
Agbullet25
Has anyone coded the rear foglight on a Clubman before? Provided the switch is installed, which VO code is needed to be added to the string and then default the CAS and FRM modules based on the new VO string?
Old Mar 12, 2014 | 11:35 AM
  #491
packruler's Avatar
packruler
Fun fact: Found out making komfort_eject aktiv makes a clicking noise but since I don't have a comfort equipped mini it won't pop the key out for me :( Comfort equipped cars don't even need the key in do they?
Old Mar 12, 2014 | 12:03 PM
  #492
TRIPLE_O's Avatar
TRIPLE_O
Unlike BMW's, the key does not pop out on the Mini's. You are correct in setting the code does work but the functionality does not.
Old Mar 12, 2014 | 12:05 PM
  #493
packruler's Avatar
packruler
It makes a clicking noise though so would it work in a comfort equipped mini?
Old Apr 10, 2014 | 06:45 PM
  #494
moto_mini's Avatar
moto_mini
Well I think I succeeded in wiping the Kombi module :-(
I backed up the trc file, saved it with a modification and flashed it as the man file. It accepted the coding, but I've got no center display (strange icon) and no gas guage.
I think I'm hosed, is this something the dealer can reflash?
Old Apr 11, 2014 | 01:09 PM
  #495
Discovery's Avatar
Discovery
Hi! Today I managed to do my first programming with NCS Expert! What a day!
Now to the problem, when trying chanfe the 2Rad module with R55_hifi to shut off the 100hz cut off.
When Im trying to read the module i get Error: COAPI-2020 no response from controlunit RAD2.
What should i do?
Tried google but couldnt find something for the mini.
Help please?
Old Apr 11, 2014 | 03:00 PM
  #496
cerenkov's Avatar
cerenkov
What should i do?
Help please?
You can't communicate with the 2RAD. IIRC you need something else like ICOM.
Old Apr 12, 2014 | 06:11 AM
  #497
Ive's Mini's Avatar
Ive's Mini
I have a quick easy question. For Daten 50.2, I downloaded the files from Megashare. There are 23 .rar zipped files. Do I need to extract the R56 files from all 23 or just the last one? Thank you in advance. I can't wait to start playing!
Ivan
Old Apr 16, 2014 | 06:02 AM
  #498
Discovery's Avatar
Discovery
Why Is that? It works on 2010 models right? Whats the problem with 2011 and on?
Old Apr 16, 2014 | 06:08 AM
  #499
dracon's Avatar
dracon
Depending on the type of radio, most of the 2RAD units don't have a connection or gateway to the CAN-bus for communication over the OBDII port.
You have to connect to it via the MOST bus, which is the fibre optic bus in the vehicle. You need an ICOM or OPS for that.
Same way on the BMW models that use the 2RAD module as well.
Old Apr 24, 2014 | 04:04 PM
  #500
u238's Avatar
u238
Is it possible to have daten files that are too new? I'm trying to code my 2011 MCS FRM module and can't seem to get it working. I updated to EDIABAS 7.2.0 to solve the Faulty Best Version error, so now I can read the TRC file just fine. Once I go to write it back, I always get an error. I've tried v49.4 and v50.2 datens. I also wiped my BMW Standard Tools completely and started over with version 2.10. Same results. I've followed the guide to the letter and successfully coded other modules. Should I be looking for older daten files maybe?
