Electrical NCSExpert DIY(do it yourself)
Old Dec 13, 2011 | 09:28 AM
  #226
strobeyprobey's Avatar
strobeyprobey
I agree you probably need the v43 datens to recode the SHD module. As mentioned above, a different trace file is not going to help you.
One other thing you can try is to initialize the sunroof module:
With the engine running and the sunroof fully closed, hold the sunroof close switch at the first detent for approximately 20 seconds. Continue to hold until the sunroof completes one full cycle.
Old Dec 15, 2011 | 07:33 AM
  #227
QuocDung's Avatar
QuocDung
So i tried the v43 datens light for R56 from the link in the bmwcoding.com. But when i ran the laden.bat, a RR1 folder is created. As far as i know i have a Mini, not a Rolls Royce. Anyway i launch NCS, then when i chose R56 from the list, an error message came, something wrong with the VIN code.
Maybe do i have to download the full version of v43 datens ? Or upgrade NCS ?
I tried v40 datens, and i have the same results as with the v38:still have my problem with the message "anti pinching de-activated".
Newbie question, before launching NCS, i have to close the INPA window, right?
The sunroof initilization does work for me, after 20 seconds pushing the switch, both sunroof open vertically and then nothings more.
I think i really need an example of a "healthy" TRC SHD file... Can you?
Old Dec 15, 2011 | 07:40 AM
  #228
strobeyprobey
You need to copy the files from the archive over manually into your install on the C drive.
Once you do that it should work fine.
/SP-daten-R56/cfgdat/*.* -> C:\NCSEXPR\CFGDAT\*.*
/SP-daten-R56/daten/*.* -> C:\NCSEXPR\DATEN\R56\*.*
/SP-daten-R56/ecu/*.* -> C:\EDIABAS\ECU\*.*
/SP-daten-R56/sgdat/*.* -> C:\NCSEXPR\SGDAT\*.*
A different trace file is not going to help!!!!!
You need to get the V43 installed and then "default" (process CPU button) the SHD module with the trace file manipulation turned off in the profile within NCS Expert.
Here is my FSW_PSW.SHD_R56.C03.TRC (1/08) but it won't help. And I highly recommend you do not use it.
Code:
ANTI_WUMMER
    nicht_aktiv
CHECK_IGNITIONA
    nicht_aktiv
CHECK_IGNITIONC
    aktiv
CHECK_IGNITIONK
    aktiv
CONTINUEAFTERKL50
    aktiv
DELTA_SOS_SHD
    wert_01
DOPPELKLICK_AUF
    nicht_aktiv
DOPPELKLICK_HEBEN
    nicht_aktiv
DOPPELKLICK_ZU
    nicht_aktiv
E9X_HIMMEL
    nicht_aktiv
ECU_BLOCK_1
    spoilerdach
HEBEN_AUS_GEOEFFNET
    nicht_aktiv
HIMMEL_AUTO_AUF
    nicht_aktiv
HIMMEL_AUTO_ZU
    nicht_aktiv
KLEMME_15_NOTWENDIG
    aktiv
KOMFORT_HEBEN
    wert_01
KOMFORT_OEFFNEN
    wert_01
KOMFORT_POS_AUF
    nicht_aktiv
KOMFORT_POS_ZU
    nicht_aktiv
KOMFORT_SCHLIESSEN
    wert_01
LOW_BAT_OFF
    wert_01
LOW_BAT_ON
    wert_01
NO_RAIN_INTENSITY
    wert_01
NOTLAUF_IMMER
    nicht_aktiv
OEFFNEN_AUS_GEHOBEN
    nicht_aktiv
PANIC_CLOSE
    aktiv_2p
PANIC_CLOSE_TILT
    aktiv_2p
PANIC_FREIGABE_CAS
    aktiv
PANIC_FREIGABE_KL15
    nicht_aktiv
REGENSCHLIESSEN
    nicht_aktiv
REGENSCHLIESSENTILT
    nicht_aktiv
RR_SCHALTER
    nicht_aktiv
SCHIEBEHEBEDACH_TIPP_AUF
    nicht_aktiv
SCHIEBEHEBEDACH_TIPP_HEB
    aktiv
SCHIEBEHEBEDACH_TIPP_SENK
    nicht_aktiv
SCHIEBEHEBEDACH_TIPP_ZU
    nicht_aktiv
SET_CODE_0
    wert_01
SHD_BLOCK_01
    wert_01
SHD_BLOCK_02
    wert_01
SHD_BLOCK_03
    wert_01
SHD_POS_1
    wert_01
SHD_POS_2
    wert_01
SICHERHEITS_FZG
    nicht_aktiv
SIEMENS_RES_3000_27
    wert_01
SOS_BLOCK_01
    wert_01
SOS_BLOCK_02
    wert_01
SOS_BLOCK_03
    wert_01
SOS_POS_1
    wert_01
SOS_POS_2
    wert_01
T_DOPPELKLICK
    wert_01
T_PANIC1
    wert_01
T_PANIC2
    wert_01
T_SCHOTT_ZU
    wert_01
T_SCHOTT_ZU_HS
    wert_01
TASTE_UEBER_CAN
    nicht_aktiv
TEMPCFLUSEOUTER
    nicht_aktiv
TEMPCFLUSESENSOR
    aktiv
TEMPTMONUSEOUTER
    nicht_aktiv
TEMPTMONUSESENSOR
    aktiv
TSCHOTT_AUF
    wert_01
TSHOTT_AUF_HS
    wert_01
USE_SOS
    nicht_aktiv
VERSIONSINDEX
    wert_01
VSCHOTT_AUF
    wert_01
VSCHOTT_AUF_HS
    wert_01
VSCHOTT_ZU
    wert_01
VSCHOTT_ZU_HS
    wert_01
WASSERSTOFF_FZG
    nicht_aktiv
WE_MODE
    nicht_aktiv
WINDSCHOTT
    nicht_aktiv
WINDSCHOTT_OPT
    nicht_aktiv
SHD_BLOCK_04
    wert_01
Old Dec 15, 2011 | 09:11 AM
  #229
alexs3d2's Avatar
alexs3d2
You have to remove the error codes for anti-pinching, otherwise automatic opening/closing are disabled. Do that in INPA.
As for the DATEN Installation... You also need to update the ECU files used by EDIABAS\ECU.
The automatic installation option "LADEN.BAT" only works if you have previously installed "BMW Standard Tools" as it searches for the folders (even if some are empty).
Old Dec 15, 2011 | 10:09 AM
  #230
QuocDung's Avatar
QuocDung
Following Strobeyprobey, i did reset the SHD module, and now the "anti piching default" is gone. Thank you very much! (i used datens v38)
Now i will try to code better =)
So now, i don't know, should i use v38, or v43. Knowing that i did what Strobeyprobey wrote earlier (but in the v43 archive i don't have a DATA folder), but in NCS still the same error "Chassis wrong". And in the NCSEXPER/DATEN a RR1 is created when i use the laden.bat.
Did not test adding ECU files in the EDIABAS\ECU yet.
Old Dec 25, 2011 | 09:14 AM
  #231
cmcveay's Avatar
cmcveay
R56 "CIC" module?
I'm watching some of the work that's going on over at BMWCoding.com and I'm interested in some of the features that they are tweaking in the BMW "CIC" module. Anyone have a guess as to which module that might be in the MINI? Specifically, I'm looking at the Video In Motion changes. My car has been at the body shop for the past week so I'm just getting to the point that I can connect it up and start poking around.
Originally Posted by Chernobyl
Here's a mostly complete list of possible modules. You may or may not have everything listed (depending on your car's options).
2MULF - Bluetooth/USB module
2RAD - Radio Module
4BMOT - Digital Motor Electronics (DME)
ABG - Airbag Module
AHM - Trailer Module
AMPH - Hi-Fi Amplifier
CAPPL - Navigation Module
CAS - Car Access System
CCC - Car Communication Computer
CID - Central Information Display
DDE - Digital Diesel Electronics
DSC - Dynamic Stability Control
EGS - Electronic Transmission Control
EPS - Electromechanical Power Steering
FRM - Footwell Module (lighting / window controls)
IHKA - Integrated Automatic Heating/Cooling System
IHKS - Integrated Heating/Cooling System
IHS - Integrated Heater Control
KOMBI - Instrument Cluster
MJOY - MINI joystick
PDC - Park Distance Control
PGS - Passive Go System
RLS - Rain-Light Sensor
SHD - Sunroof Module
SPEG - System Power Electronics Gateway (fuse box "brains")
SZL - Steering Column Switch Cluster
Old Dec 26, 2011 | 11:56 AM
  #232
alexs3d2's Avatar
alexs3d2
Yes... CIC is the new navigation system on 2011+ MINIs. It replaces the CCC and related sub-modules (CAPPL, CTUNE, CHOST etc.). It is a single mechanical unit, but it lists as several ECUs on the CAN bus. Both the CCC and the CIC serve as host units for the optical MOST bus (i.e. they are connected to both the CAN and MOST buses, whereas the rest of the devices are part of either but not both).
Old Dec 27, 2011 | 01:24 PM
  #233
richone's Avatar
richone
Access requested.
thanks
Old Dec 30, 2011 | 06:42 AM
  #234
Antoine524's Avatar
Antoine524
Originally Posted by wai_jai268
Hi Juppers,
I have the same problem with my Kombi module and my car thinks its a coupe with a faulthy spoiler.
How did you find the solution from the other forum? Was it by updating datens? please share if possible.
Thanks!
Hi
Have you resolve your problem ?
I tried to code my car to have 2011 facelift tachymetre, but when the KOMBI restart, I see a coupe with a faulty spoiler ...
My local dealer don't know the solution ...
I lost my fuel gauge, and my tachymetre doesn't work ...
thanks
Old Dec 30, 2011 | 06:44 AM
  #235
Juppers's Avatar
Juppers
You need to update to the v43 datens. Starting to sound like a broken record around here.
Old Dec 30, 2011 | 06:48 AM
  #236
Antoine524's Avatar
Antoine524
Ok then I update my datens, I re-upload my original .trc ?
Or i Reset the KOMBI module ?
Sorry for bad english
Old Dec 30, 2011 | 06:49 AM
  #237
cmcveay's Avatar
cmcveay
Originally Posted by Antoine524
Hi
thanks
The dealer can correct this by reprogramming the KOMBI module but if you do a couple of searches on NAM (v34 or something similar), you'll find that updating your software and using the v34 daten files will fix this issue. PM me if you can't get it sorted out with a little effort and I'll see if I can help.
Old Dec 30, 2011 | 06:52 AM
  #238
Antoine524's Avatar
Antoine524
They told me they can't reprogramming only the KOMBI module, they told me that they need to reprog ALL the module of the car ...
Yes, I have replaced my datens, and now I have v43, but after the update, and I know what to do with NCS ... ?
Sorry for no searching, but a friend who live far (50kms from me), give me their computer for to fix it, and I have only 30% of battery and no charger !!.
Thanks ,
Antoine
Old Dec 30, 2011 | 06:59 AM
  #239
cmcveay's Avatar
cmcveay
To fix mine, I had to have the dealer do the reprogramming and then I was able to do the coding that I wanted.
Old Dec 30, 2011 | 07:19 AM
  #240
Antoine524's Avatar
Antoine524
Ok but your dealer reprog all the car or just the kombi ?
Now i have version 43 of datens . I will reupload the original file into the car, and let we see what it happen (it's english?) lol
Old Dec 30, 2011 | 07:38 AM
  #241
Antoine524's Avatar
Antoine524
When i search ZCS/FA F.ECU, i have : "CHASSIS is faulty" error message ...
Old Jan 1, 2012 | 12:47 PM
  #242
felipe1988puk's Avatar
felipe1988puk
I can make the program work with the NCS daten V43 only if I no copy the files in the folder CFGDAT.
even if I copy the files in this folder is usually a mistake to frame! Is this normal?
that is, if I copy only the folders:
Daten
ECU
SGDAT
The program works perfectly.
and I think I even managed to update daten because in the top right, has changed the number (Nrcl-NO)
How can I be sure that datens relamente is installed correctly?
Old Jan 2, 2012 | 10:31 AM
  #243
GeoffreyM's Avatar
GeoffreyM
I need some help. My wife's clubby was running rough and went to the shop to get fixed. They updated the computer and wiped out all of my coding changes. I went to put them back and used V41 Daten and after coding the KOMBI it thinks its a Coupe with stuck spoiler. I can't for the life of me figure out how to default it. I have updated to V45 datens. Any help is appreciated.
Old Jan 2, 2012 | 12:01 PM
  #244
Antoine524's Avatar
Antoine524
You use Expertmode profile instead of the FSW PSW profile.
Read the module and then change the job (f2) to Sg_Coderin (sp?) and then code the module. All functions in that module return to default.
Don't need to do anything with the. man files etc in this profile mode.
Old Jan 2, 2012 | 12:10 PM
  #245
GeoffreyM's Avatar
GeoffreyM
Ok, so move those three files in to the BIN folder of NCSExpert and run Laden.bat?
Old Jan 2, 2012 | 12:12 PM
  #246
GeoffreyM's Avatar
GeoffreyM
Sorry, not in the BIN, just into NCSExpert
right?
Old Jan 2, 2012 | 12:17 PM
  #247
GeoffreyM's Avatar
GeoffreyM
Got it! Thanks for the help!!!
Edit: For the record. Use V45 datens! If your car has been to the dealer recently they have likely updated to V45 and if you use anything lower your car will think it is a Coupe with a stuck spoiler.
Old Jan 2, 2012 | 12:22 PM
  #248
Antoine524's Avatar
Antoine524
It's ok ??
Old Jan 3, 2012 | 11:41 AM
  #249
Brad Bedell's Avatar
Brad Bedell
Do you have MJOY on your navigation car? It's not on mine.
Old Jan 12, 2012 | 07:37 PM
  #250
mysticturner's Avatar
mysticturner
Help! My MINI's dead
OK. Here's the deal. Looks like I've dorked my MINI. There I said it. Now to the details. I got ahold of the cable, followed the instructions given by Comasysthesis in the Complete NCS Expert DIY thread to get it installed. I plugged up my MINI, got a connection. Was able to see her VIN connect. Opened up some of the applications. Thought everything is good, now I can start researching the next phase. Shut it all down. Got into the car and she has what looks like an airbag warning light. She won't start. Just gives me a click. Tried a couple of times. Now all I get is a Key symbol. Now here's a note that might be important. I have Comfort access. When I was doing the computer stuff, I was sitting outside the car on the garage floor with the key fob in my pocket.
At this point I'm thinking (hoping) that what has happened is that she has lost my key info. But that's a guess. Any ideas?
