Drivetrain CAI for R56 (home made)
Old Apr 10, 2008 | 08:06 AM
  #551
lxjose9xl's Avatar
lxjose9xl
Since I saw on a previous post Siliconeintakes.com did not have in stock for the bending reducers to make the DIY intake, here are some additional sites that provide the same product:
http://www.turbohoses.com
http://www.siliconeintakes.com
http://www.stylinmotors.com/reducing_elbows.html
http://www.roadraceengineering.com/hoseandclamps.htm
http://www.extremepsi.com/store/customer/home.php?
Old Apr 13, 2008 | 02:04 AM
  #552
Mutley MCS's Avatar
Mutley MCS
Here is what the intake looks like now with the bracket that I have made. The bracket is made by bending and polishing a piece of 30mm aluminium. The pipe is 3" aluminium pipe that has been polished and attached to 3"silicone elbow. The filter is a 3" K@N dual cone.
And this is the way it sounds like in the car, initially I am driving at normal everyday spend and acceleration levels. Then I have opened it up a bit in an area of sufficient speed limit so you can hear the bypass valve and the turbo gulping the air in. During this video the drivers window was open and it was filmed from the passenger seat.
Old Apr 13, 2008 | 08:42 AM
  #553
investigator's Avatar
investigator
Originally Posted by sailorliz23
By the dates on the dyno's the before one was in June 2007, after dyno on march 2008. If that's the case then it doesn't accurately showcase the power made from the DIY intake mod. If the dates are wrong and the dynos are the same day then good power gains.
Just a note from someone who has in the past lived in Europe for a good number of years, Europeans, and the rest of the world for that matter, write their dates as day/month/year. Today would be 13/04/2008.
Old Apr 13, 2008 | 02:54 PM
  #554
pillar's Avatar
pillar
oh man... mutely... nice setup!
i can hear the stock bov and damn does it sound nice! i cant wait... this is killing me.
Old Apr 19, 2008 | 11:11 AM
  #555
pillar's Avatar
pillar
you think a lot of these dyi cais with 90 degree bends will fit with those typical strut bars? anyone with pics?
i ask because i know the jcw doesnt fit their intake unless you get the special jcw strut bar...
Old Apr 19, 2008 | 11:31 AM
  #556
papadimitriou's Avatar
papadimitriou
With my home made CAI, the JCW strut brace fits just fine..
Old Apr 22, 2008 | 03:55 AM
  #557
Mutley MCS's Avatar
Mutley MCS
I heard a rumor that exposed filters may mess with the air/fuel ratios on turbo cars. Has anyone running this type found that it threw out their AFR without ECU remapping?
Old Apr 22, 2008 | 06:15 AM
  #558
ukaussi's Avatar
ukaussi
If you attach a filter directly to the MAF without a 90 degree bend I believe it may throw a codes.
Back in this thread it is mentioned a few times.
Also, check the R&D thread/website on ALTA's intake and I beleive you may also find some similar info.
Old Apr 22, 2008 | 06:19 AM
  #559
rippymcs's Avatar
rippymcs
I think one of the vendors here on NAM is selling a kit without the bend. It uses a custom K&N filter, though.
Old Apr 22, 2008 | 09:06 AM
  #560
Motodude's Avatar
Motodude
I have been running an exposed K&N filter directly connected to the MAF with good results. It is a more direct method and have even shortened the intake hose. No CEL's, the turbo spools up quicker and got 38 mpg last tankful. Tried posting a picture, but my digital camera has too many megapixels and exceeds the attachment limit. Very clean installation though.
Old Apr 22, 2008 | 11:38 AM
  #561
pillar's Avatar
pillar
anyone know where i can get some aliminum piping, 2x 3 inch OD, 2 inch in length? or would this be easier going to a local lowes. siliconeintakes is taking forever to restock their stuff and keep pusshing back their dates. i need to find two joiners for this thing...
Old Apr 22, 2008 | 11:48 AM
  #562
Terry @ BMS's Avatar
Terry @ BMS
We are considering it if there is interest. Here are the details:
https://www.northamericanmotoring.co...d.php?t=136905
So far no codes or issues with the air/fuel ratios. The key is making sure you don't have too much oil on the filter.
Old Apr 22, 2008 | 12:57 PM
  #563
Mutley MCS's Avatar
Mutley MCS
I forgot to add that Australian Minis do not run a MAF, just two MAP sensors. i am a bit worried about AFR's and I think I need to arrange some dyno time soon. What do you all think about exposed pods on MAFless systems in regards to AFR's?
Old Apr 22, 2008 | 02:06 PM
  #564
Terry @ BMS
If the fueling is run by the wideband o2 sensor you should be better off than your MAF counterparts.
Old Apr 23, 2008 | 06:04 AM
  #565
tachicardia's Avatar
tachicardia
I picked up a 3" ID to 3" ID SS pipe section at AutoZone. It will work for now. It was a little long, so I hack sawed (then smoothed) about 1" off of it. The whole thing was like $2. Do not get a 3" OD to 3" ID pipe, the 3" OD section of pipe would be about 3.25" in diameter. I know because I made that mistake.
Old Apr 23, 2008 | 07:02 AM
  #566
pillar's Avatar
pillar
a 3" OD to 3" ID? wait, how is that even possible.... am i incorrect to say that OD - Wall thickness = ID? i ordered mine online and went with aluminum. the outer diameter of the pipe is 3" and the wall is 0.065" thick, making the ID less than 3". i guess i wont know until i get it but it will be alright i hope. it was only 12 bucks which is a lot cheaper than most places online that sells the joiners for 18+ dollars...
when it gets here and i am wrong... i guess you can be the first person to say, "i told you so!"
Old Apr 23, 2008 | 11:17 AM
  #567
tedbone72P's Avatar
tedbone72P
Just out of curiosity. . .does anyone here feel that in the lower rpms it seems like there is more turbo lag and does not get up and go as much and that there is more power arond 4K rpms? I decided to clean my filter a couple of weeks prior, put on the stock system and noticed and increase in power at low rpms. I put my DIY intake back on the other day and it confirmed it for me that I feel a lag in the lower rpm range.
I wanted to post this as I wanted to see if any other DIYers had noticed the same thing.
I did notice a significant difference with gas mileage 4-5 mpg difference (better with DIY intake)
Old Apr 23, 2008 | 12:01 PM
  #568
tachicardia
It sounds like you ordered the right pipe, as the measured outer diameter is stated as being 3". The pipes I looked at were technically 'couplings' for exhausts so i think the labels refered to how the pipe would fit, not the actual measurements.
Old Apr 23, 2008 | 01:53 PM
  #569
pillar's Avatar
pillar
dont have one yet... but i will when i pick up my car this weeekend
but... hey, you win some you lose some. is the lag that bad that its not worth the up in mpg and sound? all personal opinion i guess
Old Apr 23, 2008 | 02:49 PM
  #570
tedbone72P's Avatar
tedbone72P
it def feels like there is an increase in power at around 4K rpm but off the line feels not sluggish but not as responsive.
Old Apr 27, 2008 | 07:25 AM
  #571
Mutley MCS's Avatar
Mutley MCS
Probably because it is sucking in hot under hood air until vehicle movement allows air from the scoop to flush out hot air with cool air. My theory anyway as I have noticed the same thing.
Old Apr 27, 2008 | 10:04 AM
  #572
tachicardia
I've had my intake done for a few weeks now, and finally took a few minutes this weekend to think of a 'mounting' spot for it. I used one of the air boxes gromets with a bolt and a VERY home made bracket. I will test it out this way for a few weeks to see how she drives.
Old Apr 28, 2008 | 02:12 PM
  #573
Murathan's Avatar
Murathan
I expended the hood scoop by carving it ( cut the bended lower side and carved the edges). Letting more air in definitely change the temperature under the hood and filter..
Old Apr 29, 2008 | 06:04 AM
  #574
tachicardia
Did you cut the actual sheet metal?
Old Apr 29, 2008 | 09:31 AM
  #575
Murathan's Avatar
Murathan
Yes, i cut the soft pitched metal. When you look through the hood scoop, there is a metal which blocks the view thats exactly what i removed..
