Drivetrain CAI for R56 (home made)
Old Apr 1, 2008 | 04:58 PM
  #501
Mutley MCS's Avatar
Mutley MCS
Originally Posted by tachicardia
I guess I wasn't crazy...
Very nice looking set up you have there!
Is that a custom made lower section of the box, how are you holding the panel filter down?
Leaves a lot of scope for ducting to the hood scoop.
Fantastic job, well done in carving new ground in the pursuit of unique intakes.
Old Apr 1, 2008 | 07:18 PM
  #502
ghosthound's Avatar
ghosthound
thats M7's MINI. that intake looks interesting but i would probably go for something foam based. Im waiting for more details on that turbo heatshield though.
Old Apr 1, 2008 | 07:34 PM
  #503
Mutley MCS's Avatar
Mutley MCS
Yes I would love to hear more about that turbo heat shield too, looks great and I am sick of the heat warping the hood scoop.
Old Apr 3, 2008 | 11:02 AM
  #504
Ex-Pat Brit's Avatar
Ex-Pat Brit
Hi all. Been reading this thread for a while now, and after Smudge goes in for service am going to do this. Would it be too much trouble for someone to list the parts needed for this. I was trying to do this through the thread, but could not quite figure out sizes etc. Thanks
Old Apr 3, 2008 | 12:18 PM
  #505
pillar's Avatar
pillar
this as in dyi cai?
if thats the case... read on...
you can get your silicone intakes from www.siliconeintakes.com
you are going to have to buy
1x 90 degree reducer from 2.75 inches to 3 inches
1x 3 inch silicone joiner
1x 2.75 inch tbolt clamp
1x 3 inch tbolt clamp
just so you know, all the products that i listed are for filters with a 3 inch opening. if you are considering a different sized filter, you are going to have to adjust the silicone pipe dimension which is really easy once you realize how all this stuff fits together. Just remember the MAF opening is 2.75 inches and whatever you do from there is up to you. in terms of what filter to get... that is totally up to you. check out previous posts, lots of the members already posted their cai setup and so far, they are all different and look really good...
good luck!
btw... siliconeintakes takes forever to restock their inventory... as of now they are out of a lot of things so you have to order some of the pieces mid to late april. if you find an alternative that is similar in price to siliconeintakes, please share!
::edit::
just a question for the general... i know the worm gear clamp isnt as "good" as the tbolt clamps... but the purpose of these things is to simply attach the silicone parts with joiners and what not... does the silicone pipe really require tbolt clamps as oppose to worm gear clamps?
Old Apr 3, 2008 | 05:03 PM
  #506
Ex-Pat Brit
I was looking at Zenaracing, the prices look good but..
I'm just going to go for a 3 inch filter and leaning towards K&N only because of prior history, but I'm open to suggestions
Old Apr 3, 2008 | 05:13 PM
  #507
pillar's Avatar
pillar
yeah zena racing is awesome.. but their price is nearly doubled that of siliconeintakes...
i was highly considering it but because i STILL dont have to car, i guess i can wait.
I dont think zena has a 90 degree reducer that will fit the coopers 2.75inch MAF to your 3 inch Filter but if you find one, tell me! in that case you have to get a regular 2.75 inch 90 degree bend with a 2.75 to 3 inch straight reducer. that also means you have to buy 2 silicone joiners and 4 tbolts.... i think it gets close to 100 bucks... those pesky joiners are only $7.99 at siliconeintakes and a whopping $17.99 at zena...
STILL cheaper than other products however.... yet too expensive for a bunch of pipes imo...
trueflow trueflow trueflow i dont know why i like it so much... i think its because its a red foam filter that looks like a huge barrel as oppose to a cone. most of their products are used for off road vehicles, so good at filtering?
TrueFlowFilter.jpg?t=1207269610
just to show you the size of this thing... doesnt cease to impress me.
Old Apr 3, 2008 | 07:39 PM
  #508
Mutley MCS's Avatar
Mutley MCS
I have just used a 3" silicone elbow and found that it clamps down under a worm drive clamp onto the airbox connection well (we do not have MAF in australia but the airbox connection is the same size).
I do not see the need for t bolt clamps, this area is not under boost (stock clamps for IC, turbo etc are worm drive from factory anyway). The only advantage in this application is that t bolts look better.
Old Apr 3, 2008 | 08:49 PM
  #509
pillar's Avatar
pillar
wait... are you sure its the same size? has anyone with a maf used a 3" end on the MAF side? i know silicone is somewhat fogiving but a 3" in clamped on something that is 2.75" in diameter? anyone else do this?
i just need to make sure.
Old Apr 3, 2008 | 09:16 PM
  #510
Terry @ BMS's Avatar
Terry @ BMS
Just for kicks I built a DIY intake for our mini, and will do some before and after vbox testing this weekend. I did some before and after post intercooler IAT testing with interesting results.
Old Apr 3, 2008 | 09:55 PM
  #511
Mutley MCS's Avatar
Mutley MCS
It has worked on mine and yes they are 2.75" at the airbox connection. Gives the silicone a wierd taper when the clamp compresses it down. I have not had any instances of slipping over the last week with daily use.
I may put a segment of 2.75" hose under the clamp, which should build it up to approx 3" by the time you have taken into account the OD of the hose, hope that makes sense.
Old Apr 4, 2008 | 06:21 AM
  #512
Ex-Pat Brit
does anyone have part numbers for the filter they got?
Old Apr 4, 2008 | 09:10 AM
  #513
pillar's Avatar
pillar
true flow 90206 air filter universal 3" inlet (5.5" by 9")
http://www.amazon.com/True-Flow-9020...665312&sr=1-54
thanks for the info mutley..
oooh... am very interested by the gains/loss of dyi cai's. i think any gain will justify the amount spent on custom intakes and the sound boost.
Old Apr 4, 2008 | 12:11 PM
  #514
Mutley MCS's Avatar
Mutley MCS
I will be interested to, good thing it easy to swap back to the JCW intake, one day I will get it put on the dyno and do power runs with both intakes to see the difference if any.
Old Apr 6, 2008 | 02:56 PM
  #515
papadimitriou's Avatar
papadimitriou
I dynoed my car yesterday, in a MAHA LPS 3200 dyno.
The car did 195hp in the crank and 28,6 nm of torque in 3510 rpms..
153hp at the wheels.
Before that it has 147hp at the wheels and 26,8nm of torque in 3650 rpms...
If I find some time tomorrow, I will post both diagrams, before and after.
Old Apr 6, 2008 | 03:41 PM
  #516
pillar's Avatar
pillar
nice! what kind of filter and you think the type of filter matters? at some point, the air going in is going to be limited by the size of the tube as oppose to the surface area of the filter right?
Old Apr 6, 2008 | 03:49 PM
  #517
papadimitriou
I used a pipercross foam filter because I believe that foam filters are better(at least my opinion...) and a samco 90 degree silicone hose. The tube that goes to the turbine is the original, I think that what changes is how easily it sucks air right now.
I must notice that I have opened the hood scoop.
I am very happy with the modification, no CELs, and not a significant or noticeable change in mpg.
Old Apr 6, 2008 | 08:58 PM
  #518
ghosthound's Avatar
ghosthound
i agree about foam filters being better...
I recently went back to stock because i had to go to the dealership for service and while the filter was off... i was looking for any trace amounts of dust or debris anywhere along the intake tract and i found nothing....
Im sure paper and gauze filters can filter just as well but they definitely have more restriction.
Old Apr 6, 2008 | 09:29 PM
  #519
Terry @ BMS
I did a few before and after pulls from 10-60 (didn't have much space), and the times were identical stock airbox vs. cone filter with elbow. I'll need to do more testing at higher speeds when I get back to the private track! But for now I'm comfortable saying at the stock boost levels its a sound only mod.
Old Apr 6, 2008 | 09:41 PM
  #520
pillar's Avatar
pillar
boo! although, it would have been pretty sweet if it actually cut the 0-60 acceleration time.
only a sound mod? didnt a few people claim they started to get more mpg? if this isnt the case, guess the stock airbox will have to go on on long trips.
are you still going to do dyno runs for the dyi cais?
your mini must have been through a lot, but then again, i guess that is what its meant for!
Old Apr 7, 2008 | 02:04 AM
  #521
papadimitriou
here is my dyno before and after..
before..
Old Apr 7, 2008 | 02:06 AM
  #522
papadimitriou
and after...
Old Apr 7, 2008 | 02:12 AM
  #523
papadimitriou
Since it is all Greek to you let me help:
Διορθωμένη ισχύ= power in crank
Before was 190,4 now is 194hp
Ισχύς τροχού= power in the wheels
Before was 146,6 now is 154,3hp
Μέγιστη ισχύ στα= maximum power in
before was on 6160 rpms and now is on 5120 rpms.
Ροπη= torque
Before was on 268 now is on 286 nm
Μέγιστη ροπή στα= maximum torque on
before was on 3615 rpms, now is on 3585 rpms.
Old Apr 7, 2008 | 02:35 AM
  #524
rippymcs's Avatar
rippymcs
Ροπη= torque
Were these done back to back on the same day? If so, then those numbers are quite impressive for a simple homemade mod.
Edit: Nevermind, I saw the date and time on the charts. Nevertheless, the numbers are still pretty good for a simple homemade mod, considering the post-mod dyno was at a higher ambient temp.
Old Apr 7, 2008 | 07:21 AM
  #525
sailorliz23's Avatar
sailorliz23
By the dates on the dyno's the before one was in June 2007, after dyno on march 2008. If that's the case then it doesn't accurately showcase the power made from the DIY intake mod. If the dates are wrong and the dynos are the same day then good power gains.
