Drivetrain M62 SC on the MINI is reality
Old Jul 19, 2006 | 03:36 PM
  #126
MattMan's Avatar
MattMan
Coordinator :: Minis Under the Arches (Oct 25-28)
Wow, just took a look at this thread. Awesome stuff. A great alternative to the turbo kits and one would imagine this would be much more reliable as well. That's guys for keeping us posted on this!!!
Old Jul 19, 2006 | 03:47 PM
  #127
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Originally Posted by TonyB
IF anything... RWD. I'm cool with staying FWD, keeping it light, with our minimal driveline loss.
Was thinking the same thing when i was looking at this car possible coming to the US next year
http://www.obvio.ind.br/obviona/012.htm
Since it uses our beloved trinitc 1.6L and will come with a 250hp version from the Factory. Doesnt say if it will be a Turbo or SC but something to think about if it is the M42 SC and then Rob gets his hands on it and Adds the M62.
Also there is the 828 version that has the motors as well. and with these cars wieghing in at 1600 lbs for the 012 and 1300 for the 828. i would say they should be rockets in a straight line. I cant wait for a test drive to see handeling
Old Jul 19, 2006 | 03:50 PM
  #128
Rob @ BRP's Avatar
Rob @ BRP
Thanks for the warm welcome guys! So far, I've been super pleased with the caliber of members this board has to offer. You guys really do represent your community well.
Originally Posted by Wesport
I understand that we probably need better pistons to run above 20psi. That said - it is a lot easier to contain boost spkikes with a SC than a turbo - so it may be easier for us to get closer to the max without the risk of dropping a piston than the TC guys.
Can't wait to here more - hope my AGS 3 will still fit - but doubt it.
Wes
Again, it's hard to put a psi limit on something like this. 20psi isn't what kills a motor. You do far more damage with higher revs than you do with cylinder pressure (provided you aren't detonating). In my experience, what kills pistons is temperature or detonation. The few I've seen go were the result of a Nitrous marathon, a fuel pump failure (followed by a 20 min. track session ) , and just general running lean or over heating.
Something else that is important to note is the Eaton blower is exceptionally sensitive to the pressure differential between the inlet and outlet. You'll notice on the charts that it is much happier at lower boost levels because the higher the boost, the more hp it takes to drive the blower, the more the temperature climbs, etc. The more mods you do to your mini to "lower boost" the better the kit will perform. Big exhausts, cams, head work, low restriction intakes (reduce vacuum at inlet), all contribute to a more favorable Delta P at the blower and end up in more power at the wheels.
Old Jul 19, 2006 | 04:00 PM
  #129
MattMan's Avatar
MattMan
hmmm, that's a funky looking car. Impressive targets though as far as fuel mileage and power.
Old Jul 19, 2006 | 04:17 PM
  #130
TonyB's Avatar
TonyB
From the design, that looks like it will be plenty rigid, and fun. Strange-looking, but I see how you are thinking. Time (and money) will tell...
Old Jul 19, 2006 | 04:22 PM
  #131
Dr Obnxs's Avatar
Dr Obnxs
Going further off-topic...
there's a guy in Woodside who is converting Ariel Atoms to all-electric! For the sports car crowd no less. I think I saw one (red highlights) on San Hill Rd......
And this 62 replacement looks very, very interesting!
Matt
Old Jul 19, 2006 | 05:00 PM
  #132
Ryephile's Avatar
Ryephile
Great to see BRP digging into the MINI world! I met Brant a few years back at the Miata's on the Dragon, great guy that knows his stuff. I wish them the best of luck with a big-blower MINI product
Cheers,
Ryan
Old Jul 19, 2006 | 05:17 PM
  #133
day96's Avatar
day96
Originally Posted by Urban_Assault_JCW
A lil late on the subject but at the track a Cobalt SS ran a 13.9, I don't get my mini did a 14.8 but mp trap speed put the mini in the low 14's I just have to learn to launch better. Any way maybe the cobalt make more than the 200 hp or either that torque makes a big diffrence.
Gearing also plays a role in this thought.... 6 spd vs 5 spd...
Old Jul 19, 2006 | 05:40 PM
  #134
saifa's Avatar
saifa
Just a silly question. Will this kit work with all model years or are there any differences that might require modification?
Old Jul 19, 2006 | 06:19 PM
  #135
SpiderX's Avatar
SpiderX
Hi Rob,
Welcome, I spoke with Brant earlier today and I am very excited about the project.....
this is very cool.......
Bob
Old Jul 19, 2006 | 06:45 PM
  #136
KevinBaker's Avatar
KevinBaker
Looks great, I have been waiting for someone with much more money than I to experiment with a M62 .
Can't wait to see the results.
Old Jul 19, 2006 | 08:29 PM
  #137
jachristner's Avatar
jachristner
Along the lines of forced induction...
I've seen a turbo kits mentioned more than once in here. Personally, I'd prefer a turbo to a super mainly for the efficiency reason.
Are the turbo kits specifically for the naturally aspirated or supercharged engines?
I'd love to build a turbo Mini, but would prefer the 6-speed Getrag transaxle. Would the better path be to start with a base Mini and swap the 5-speed for the Getrag? Or is the better path to replace the SC with a TC on the S Mini?
Can a supercharger be safely/reliably clutched to provide an on/off switch essentially giving you the choice between economy and performance modes? I can understand it probably wouldn't be good to switch it on and off under load, but that wouldn't be a problem for me.
I think I've seen turbochargers with intercoolers before. If the supercharger was swapped for a turbo, could the intercooler be reused?
Just a few thoughts.
Old Jul 19, 2006 | 08:34 PM
  #138
lcubed's Avatar
lcubed
mercedes uses a clutch on some of their kompressor equipped vehicles.
it's not a particularly good idea on the current mini since the
water pump is driven on a common shaft as the super charger.
Old Jul 19, 2006 | 09:31 PM
  #139
TonyB's Avatar
TonyB
Rob, we're glad the you've dedicated the time and resources to make this happen for us! Curious, what made you get involved with the MINI?
We are a very passionate bunch here, with home-grown tuners, and wannabes like myself doing all that we can to contribute to make this car even more fun.
Looking forward to when you are officially a vendor so you can elaborate further. Thanks much.
Old Jul 19, 2006 | 09:35 PM
  #140
Partsman's Avatar
Partsman
Legion_of_Doom
Tony, you hit it right on the head with this statement.
Old Jul 20, 2006 | 01:54 AM
  #141
SpiderX's Avatar
SpiderX
Tony is batting 2 for 2.....
Old Jul 20, 2006 | 06:22 AM
  #142
obehave's Avatar
obehave
Stick with the MCS short block/internals. Much more robust. Plus you get the Getrag with the MCS.
Intercooler is an intercooler. Change the plumbing and you're good. But I'm betting getting one properly sized with nice round inlet/outlet flanges would be cheaper than paying someone to mod the stock unit.
Old Jul 20, 2006 | 07:32 AM
  #143
RallyMINI2005's Avatar
RallyMINI2005
Is it dynoed yet? Is it dynoed yet? Is it dynoed yet? Is it dynoed yet? Is it dynoed yet? Is it dynoed yet? Is it dynoed yet?
<rocking back and forth in the corner drooling>
RM2k5
Old Jul 20, 2006 | 07:55 AM
  #144
SpiderX's Avatar
SpiderX
RM2k5
your like a puppy peeing all over himself....oh wait,...that's me
Old Jul 20, 2006 | 08:37 AM
  #145
RallyMINI2005
eeeeewwwwwww... you smell like peeeeee.
<off to chase tail >
RM2k5
Old Jul 20, 2006 | 08:58 AM
  #146
SpiderX's Avatar
SpiderX
back OT... I am going to visit DDM on Saturday....
Old Jul 20, 2006 | 09:44 AM
  #147
Major Mini's Avatar
Major Mini
I just spoke with Dave, and he's doing final checks on everything before firing it up and going out for a drive. He'll be checking and making adjustments to the A/F ratio...AND THEN OFF TO THE DYNO! (hopefully) I'll hear from him again later tonight and have some more pics to post.
Everyone stay excited, this project is very near completion ; )
Old Jul 20, 2006 | 09:45 AM
  #148
SpiderX's Avatar
SpiderX
any chance you'll be around on Saturday.... I should get there around noon.
Old Jul 20, 2006 | 10:12 AM
  #149
Major Mini's Avatar
Major Mini
Yeah I could make a trip down (just a little over an hour for me). I'd like to meet you and see your car. You need to follow me back up the mountain to the twisties tho!
Old Jul 20, 2006 | 10:20 AM
  #150
RallyMINI2005
Waaaaaaaaaahooooooooooooooooooo!
If you get a chance, videos are always great! I'd love HEAR the beast, as well as SEE the beast!
RM2k5
