Drivetrain Burger Motorsports (BMS) Tune(s)
Old Aug 7, 2014 | 11:06 AM
  #2301
cerenkov's Avatar
cerenkov
Originally Posted by Mayfair
Thanks so much. I added that PID and it works now.
What Boost should be seeing. The highest I saw was 10 ( but I only drove the car for 20 mins this morning).
And the engine temperature was 194F. Is that normal
Any other PID's you recommend I get?
When I was inputting the car's info, it didn't automatically find it. I had to manually enter the engine displacement.
Boost is load dependent and can vary due to factors such as temperature. Boost can be limited until the car is fully warmed up.
Engine temperature is typically 220F. For 2013 models, sport mode reduces this to 175F. Also turning the AC to MAX lowers the temperature.
Some other PIDs of interest are:
Air-to-fuel ratio ->CALC.AFR_ACTUAL or SAE.WO2S11_B.LAMBDA
cylinder #1 timing -> SAE.SPARKADV
intake temperature -> SAE.AAT
Check out this thread for information about DashCommand.
https://www.northamericanmotoring.co...og-graphs.html
Old Aug 8, 2014 | 01:20 PM
  #2302
cactusjk's Avatar
cactusjk
Ordered a JB+ from Way.
Shifting to 91 octane. Do I need to fill up from an empty tank or can I initially mix?
Old Aug 8, 2014 | 01:30 PM
  #2303
Mayfair's Avatar
Mayfair
Originally Posted by cerenkov
Boost is load dependent and can vary due to factors such as temperature. Boost can be limited until the car is fully warmed up. Engine temperature is typically 220F. For 2013 models, sport mode reduces this to 175F. Also turning the AC to MAX lowers the temperature. Some other PIDs of interest are: Air-to-fuel ratio ->CALC.AFR_ACTUAL or SAE.WO2S11_B.LAMBDA cylinder #1 timing -> SAE.SPARKADV intake temperature -> SAE.AAT Check out this thread for information about DashCommand. https://www.northamericanmotoring.co...og-graphs.html
Thanks so much!
Old Aug 10, 2014 | 07:52 AM
  #2304
Damon114's Avatar
Damon114
Thanks so much!
So after a week running 96 octane here are some numbers.
96 octane
jb 100%
Boost : 18.5
Timing : 45.0
AFR: 12.2
Not sure where ideal numbers should be for afr. GP is running like a beast!!!
Old Aug 10, 2014 | 08:05 AM
  #2305
cerenkov's Avatar
cerenkov
96 octane
jb 100%
Boost : 18.5
Timing : 45.0
AFR: 12.2
The timing looks a little high, you sure that's right?
Old Aug 10, 2014 | 08:15 AM
  #2306
Damon114's Avatar
Damon114
Sorry I meant 9 to 10.5 at WOT in 3rd
Old Aug 20, 2014 | 07:15 AM
  #2307
ptguy0618's Avatar
ptguy0618
So I finally found an e85 retailer in my area, I just filled up with 3.25 gallons e85 and the rest 93 octane, I have a catless downpipe, cold air intake, what are my options for turning the JB up at this point?
Old Aug 20, 2014 | 07:20 AM
  #2308
cerenkov's Avatar
cerenkov
Do you have a way to monitor AFR, timing, boost, etc?
Old Aug 20, 2014 | 07:31 AM
  #2309
JcarrollWS6's Avatar
JcarrollWS6
As above, I would get a way to monitor things.
With that blend in MY car, I would go to about 2-2.5 o'clock. Make sure the pull feels like it is consistently getting stronger until the highest RPM range (above 5,250) where it should start to wane. As far as seat-of-the-pants goes, that is what you are looking for.
For eduational purposes only, you COULD (read: at your own risk) turn it up to 4 or so and it will likely feel slower as the computer is yanking so much timing to compensate.
JWS6
Old Aug 20, 2014 | 10:25 AM
  #2310
ptguy0618's Avatar
ptguy0618
. Do you have a way to monitor AFR, timing, boost, etc?
Currently no, I have it at 50%...the stock, should I turn it down then?
Old Aug 20, 2014 | 12:38 PM
  #2311
cerenkov's Avatar
cerenkov
If you keep it at default (50%) and use premium gasoline (ideally 93) then I don't see any reason to monitor anything. But if you start mixing in ethanol and/or turning up the dial then it would be a good idea to monitor things, at least at first.
Old Aug 20, 2014 | 12:41 PM
  #2312
ptguy0618's Avatar
ptguy0618
Noted! 👍
Old Aug 21, 2014 | 07:50 PM
  #2313
ptguy0618's Avatar
ptguy0618
So I turned it down to 4.5, after trying it on 5, and 6. And I have to say the car feels much stronger and smoother under full throttle!
Old Aug 30, 2014 | 01:44 PM
  #2314
SchnellFowVay's Avatar
SchnellFowVay
My mint-condition JB+ is for sale (I traded-in my Mini). It only has 4,000 miles on it. Feel free to take a look: https://www.northamericanmotoring.co...ml#post3982339
Old Aug 30, 2014 | 03:06 PM
  #2315
NewCooperFanatic's Avatar
NewCooperFanatic
Your timing is probably better in that setting.
Old Aug 30, 2014 | 05:52 PM
  #2316
ptguy0618's Avatar
ptguy0618
Ok so I was just on my way home from dinner, and I was behind a guy in a jcw r56, talked to him at a light, said he had the jb+ as well. Said he was at 2 o clock setting. We got one good rolling pull in together, and he was definitely quicker than me, with my jb at 4.5 an intake and catless downpipe. I thought we'd be closer matched than that, needless to say I have a much greater desire to make my car faster now lol!
Also I think he had an automatic because he was shifting really quick
Old Aug 30, 2014 | 07:03 PM
  #2317
cactusjk's Avatar
cactusjk
Good info! Stock '13 JCW auto.
Old Sep 5, 2014 | 01:19 AM
  #2318
jayely1's Avatar
jayely1
If I get the JB+, will a decent intake help with power as well??
Old Sep 5, 2014 | 06:24 AM
  #2319
RobMuntean's Avatar
RobMuntean
Don't get an intake IMO. Waste of "power" money. Get a DP.
Old Sep 5, 2014 | 09:01 AM
  #2320
jayely1's Avatar
jayely1
Only problem is I don't want the car any louder.
Old Sep 5, 2014 | 09:43 AM
  #2321
RobMuntean's Avatar
RobMuntean
In these little cars you don't gain anything power wise from an intake, so I would look at other mods even a FMIC so heat soaking won't be an issue.
Old Sep 5, 2014 | 03:23 PM
  #2322
Systemlord's Avatar
Systemlord
The only thing that will make a MCS louder is deleting the primary and secondary cats in favor of just a downpipe, then again by removing both cats is what allows these MCS's to reach the hp and torque numbers. Turbos don't like restriction in the exhaust, adding a DP is probably the cheapest upgrade for gaining more hp and torque.
Old Sep 5, 2014 | 05:01 PM
  #2323
Roxspin72's Avatar
Roxspin72
So there's your predicament... On one hand you want power, on the other you want silence...
You can create a sleeper, however the only way to yield more power is to do as previously stated, reduce restriction. However, that will increase noise decibels... Wow, what to do, what to do?
I love the sound of my DOS Intake, M3 DP, & CNT TBE. Sound is amazing.😄
Old Sep 5, 2014 | 05:57 PM
  #2324
KilmerPT's Avatar
KilmerPT
I am crious if this is timing on initial WOT at 2k rpms or at 5-6k rpms
Old Sep 7, 2014 | 03:45 AM
  #2325
preme123's Avatar
preme123
Originally Posted by wzabrouski
Why has everyone been so quiet?? Dumb question but how do you release the clips on the JB? I have to go in for a P1339 code I get off and on and I need to remove the JB. Also have been running a 30% mix of e85. When I remove the JB is there anything wrong with still having this mix in the tank? I did not think so but figured I would ask.
My car also threw this code this morning, What was wrong with your car? how did u fix it? (But I dont have the tune tho.)
