Drivetrain The Official ALTA AccessPORT Thread
Old Jan 25, 2011 | 02:54 AM
  #1126
Rodster's Avatar
Rodster
Just wanted to add another endorsement re the Accessport.After a few initial problems installing the new mapping I got it right.The car is a whole different animal now.While all is smooth and very quick through the entire rev band,the biggest kudos must go to the changes in torque.That little 1.6 feels at least three or four times that big! Really could stand a taller final drive ratio now! Very impressive.Thanks Alta for a superb product!
I have a stock exhaust and want to retain it so as to avoid unwanted resonance and general racket.The Accessport works well with same.The FMIC is a big help in enhancing the overall performance level of the motor package that I have.
Cheers all,
Rod
Old Jan 25, 2011 | 08:06 AM
  #1127
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Cheers all,
Rod
Thanks Rod! Appreciate the feedback and as always let us know how we can ever help in the future!
Adam @ ALTA Performance
Old Jan 25, 2011 | 12:57 PM
  #1128
fishbert's Avatar
fishbert
Originally Posted by Raymazing
Don't know why my subscription was removed but I'm posting again to "renew" it.
FYI: There's a 'Thread Tools' button at the top of the thread that'll let you subscribe (or unsubscribe) from a thread without having to post to it.
Old Jan 27, 2011 | 01:41 PM
  #1129
jrettew's Avatar
jrettew
Just got my AP and trying to make sense of some of the data log figures. Anybody know what torque efficiency measures?
Old Jan 27, 2011 | 04:28 PM
  #1130
ALTA_Chris's Avatar
ALTA_Chris
Jrettew,
The Torque Efficiency is really complicated. It's another huge calculation that controls the ignition. The most important thing for you is to see that it's between 1 and 0.9 when you are flooring it. If it is lower than that, there could be a problem with the way your car is running.
Old Jan 27, 2011 | 07:54 PM
  #1131
choochike's Avatar
choochike
Alta what spark plugs do you recommend using with your maps? What is everyone running who've replaced theirs?
Old Jan 28, 2011 | 07:27 AM
  #1132
jrettew's Avatar
jrettew
Thanks Chris. I do drop below .9 under load, but only with the custom map, not with stock. I'll send you a couple more logs with some good graphic comparisons of the two setups.
Old Jan 28, 2011 | 07:29 AM
  #1133
bmwi6's Avatar
bmwi6
Have there been any updates recently to the AP. Everytime I plug mine into the computer it download something but it still says last update 10/2010. Has anything in the maps changed or any new features?
Old Jan 28, 2011 | 10:27 AM
  #1134
ALTA_Chris's Avatar
ALTA_Chris
BMWi6, are you doing beta updates? We're changing those all the time to add new ECUs, but you don't need to do those if the AP is already working on your car.
Old Jan 28, 2011 | 07:38 PM
  #1135
oldcracker's Avatar
oldcracker
hey Chris, were you guys able to find out what cause the bouncy idling?
Old Jan 28, 2011 | 10:01 PM
  #1136
jsyang15's Avatar
jsyang15
2nd that, I have that issue as well
Old Jan 28, 2011 | 10:03 PM
  #1137
bmwi6's Avatar
bmwi6
3rd that!
Old Jan 29, 2011 | 07:20 AM
  #1138
LASRGUY's Avatar
LASRGUY
Originally Posted by bmwi6
3rd that!
4th that...
Old Jan 29, 2011 | 10:05 AM
  #1139
fishbert's Avatar
fishbert
I used to get bouncy idling with the stock ECU. Not sure if it's the same thing, but mine appeared to be due to carbon buildup on the intake valves. You might go back to stock for a few days and see if it's still there.
Old Jan 29, 2011 | 11:38 AM
  #1140
LASRGUY's Avatar
LASRGUY
I'll give it a try. The last time I went back to stock it seemed to go away but that may have been by chance since it's worse some days than others. I'll do a seafoam treatment as well to try to get rid of some buildup.
Old Jan 29, 2011 | 02:13 PM
  #1141
TeddyL's Avatar
TeddyL
Bouncy idle here too...... doubt it's carbon build up as I only have 2500 miles on it...'10 JCW
Old Jan 29, 2011 | 02:58 PM
  #1142
MP1.6T's Avatar
MP1.6T
For the "bouncy idle" posters. Can you...
also include in your posts which map you are using where you see the problem? If I remember the first post on this, it was a Stage 2 or even Stage 3 map. If it is a stage 1 map, as a fellow owner and user of a map at that level I would want to know (and would want Alta working on it). Mine is a low mileage 2010 w/ good gas so I don't expect I would have a carbon issue already.
If it is a stage 2 or 3 map being used with some of the bouncy idle reports, I would also be interested in the underlying mods. And to be honest in plain English, whether the map being used is at a higher stage than the mods recommended by Alta for use w/ that map. Just asking so I have a better sense of what folks are doing, what works (or not) and any obvious side effects.
Confirming too, no obvious irregular idle for me. 2010 MCS. Stage 1 map w/out (enhanced) FMIC. Factory JCW exhaust (center and rear), JCW "kit" intake w/ original JCW conical filter, noisemaker delete, intake muffler delete.
Thanks.
Old Jan 29, 2011 | 03:33 PM
  #1143
///Mflossin's Avatar
///Mflossin
very, very rarely do I get the bouncy idle and it's subtle but it's there. I have noticed that I only get it with the heater fan on. It happens completely and totally at random. This is with a stage I map.
Old Jan 29, 2011 | 08:48 PM
  #1144
Maugre's Avatar
Maugre
Stock w/stage 1 map. I concur with Mflossin, totally random, but I haven't driven much since the first snowfall. I would rather subject my wifes PT Cruiser to old man winter .
Old Jan 29, 2011 | 09:19 PM
  #1145
LASRGUY's Avatar
LASRGUY
Ran the stock map for half a day today and the idle was rock steady. Switched back to a stage 3 map and the bouncy idle was back. It might have gotten slightly better after a dose of seafoam today but it's not gone.
Old Jan 29, 2011 | 09:55 PM
  #1146
dj.papazian's Avatar
dj.papazian
I bought the accessport way back a few weeks after it first came out for my 09 JCW. I was and still am running stage 2 (no mods since then). I had the bouncing idle problem then, and I still have it now. I called Jeff back in the day to report it but nothing was really done about it. Im positive it is from the accessport, when I run my stock map, my car does not have this bouncing idle problem. only when im running the tuned map. hopefully they'll be able to figure it out soon....cheers.
Old Jan 30, 2011 | 06:39 AM
  #1147
bmwi6's Avatar
bmwi6
I have the bouncy idle problem with a stage 1 92 octane map. If I take tune the car back to stock the problem goes away immediately.
Old Jan 30, 2011 | 06:42 AM
  #1148
///Mflossin
Alta?......Any ideas or concerns?
Old Jan 31, 2011 | 08:49 AM
  #1149
ALTA_Chris's Avatar
ALTA_Chris
Sorry for the delay on posting up! Which maps exactly are you guys running? If you are running a tps map, try the other map to see if it goes away. Also is it happening in sport mode and normal mode?
Old Jan 31, 2011 | 08:57 AM
  #1150
jbourne's Avatar
jbourne
Chris - what's a TPS map?
