Drivetrain The Official ALTA AccessPORT Thread
Old Feb 5, 2011 | 08:50 AM
  #1176
evilstitch626's Avatar
evilstitch626
thank you so much for asking this question i was very concerned about this because i wanted to be able to get rid of the CEL ive had for so long because of the Alta down pipe! Thank you!!!!!
Originally Posted by jkool44
For those of us with the Alta downpipe (I have the single cat JCW DP on my 2010 MCSm) dose the AccessPORT clear the CEL code that occurs permanently or just until the light come on again. Currently I clear mine every 150 miles or so with a $50 tool i purchased to read and clear codes).
Old Feb 5, 2011 | 10:29 AM
  #1177
fishbert's Avatar
fishbert
I understand not wanting to dig through a huge thread, but Alta answered the downpipe CEL question on the very first page.
Old Feb 5, 2011 | 12:08 PM
  #1178
evilstitch626
ah thank you
Old Feb 7, 2011 | 06:02 PM
  #1179
kraptor's Avatar
kraptor
Originally Posted by ALTAPerformance
ALTA AccessPORT FAQ Post
Q. Will the ALTA AccessPORT work on the Euro models?
-At this time no. We are working on this at the moment but its going to be a few weeks before we have more info. We would love to hear from you if you have a Euro car and are interested in the AccessPORT so we can better judged the demand.
Originally Posted by kraptor
Hi,
What happened with that, i´m still waiting good news
Hello,
Any news? I hope there is progress on the euro ECUs
Old Feb 7, 2011 | 09:27 PM
  #1180
turtle343's Avatar
turtle343
Hello,
i am very keen!
Old Feb 8, 2011 | 07:27 AM
  #1181
jrettew's Avatar
jrettew
Strategy for getting the dealer to flash the ECU
Just thought I'd thow this out to see if anyone has some tried and true strategies. I have this ECU version for my 2010 Clubman S Auto:
MINI_USA_R56_0089SU0H910B_165_enc.rom
Alta has been fantastic working up a tweaked verson of the Stage I tune that will smooth out the shifting. But it is seeming like a good idea to have the ECU flashed. Problem is, the only issue I can point to in stock mode is the perviously posted tendancy to lag when starting from a rolling stop (lag and lurch or L&L). I don't know if this L&L even qualifies as "broken" let alone if the dealer would flash the ECU for it anyway. So does anyone have some ideas on how to get the dealer to do the flash?
Old Feb 8, 2011 | 07:32 AM
  #1182
unplugged's Avatar
unplugged
Originally Posted by turtle343
i am very keen!
same here
Old Feb 8, 2011 | 08:02 AM
  #1183
fishbert's Avatar
fishbert
Sure; you go tell them to do it, and they charge you an hour's labor.
Old Feb 8, 2011 | 09:26 AM
  #1184
ALTA_Chris's Avatar
ALTA_Chris
Originally Posted by bmwi6
Hey Chris, I am running the stage 1 92 octane map with the stock throttle settings and I have also ran the stage 1 92 oct. TPS map. I am 100% sure that the over-rev was not from a down-shift. I did not get what rpm was recorded from the dealer. Thanks and let me know what you find.
We double checked the over rev counter, and it is set to 7,200, 200 over the redline, which is just like the OEM map.
One way that you could have hit the limit without downshifting was if you wait right till redline, and press the clutch in to shift gears, the revs could have gone over the limit. That has happened to us before the AccessPORT.
Is there a chance that the over rev happened before the AccessPORT was installed? Have you taken the car to the dealer since you've installed the AccessPORT and have the dealer check for codes?
We can raise the over rev counter, but we're curious to find out why you got it, and why it was still there after the AP was unmarried.
Old Feb 8, 2011 | 11:12 AM
  #1185
jrettew's Avatar
jrettew
hey fishbert...definitely an option, but I'd gathered from a couple other posts that they can be reluctant to do it. Did your's comply on request?
Old Feb 8, 2011 | 11:40 AM
  #1186
Reebus's Avatar
Reebus
Were they (Alta) able to remedy the L&L by using their tune? Or are you still trying to find a remedy after the tune?
Old Feb 8, 2011 | 11:49 AM
  #1187
ALTA_Chris's Avatar
ALTA_Chris
Reebus,
We are still working on it. We got a new map made that helps, but we are working on making one that is better!
Old Feb 8, 2011 | 12:31 PM
  #1188
Reebus's Avatar
Reebus
Originally Posted by ALTA_Chris
Reebus,
GREAT!!! I'm putting my pennies together now and it should be sometime later next month when I'll be ready to order.......
Old Feb 8, 2011 | 12:57 PM
  #1189
jrettew's Avatar
jrettew
I think it's a lot better. To tell the truth, I've gotten kinda hooked on the extra power and torque, so I can live with a little L&L.
Old Feb 8, 2011 | 01:00 PM
  #1190
///Mflossin's Avatar
///Mflossin
Please excuse my ignorance but what is L&L?
Old Feb 8, 2011 | 01:10 PM
  #1191
fishbert's Avatar
fishbert
I was at the dealer a week or two ago and had them update the firmware in all electronic modules in the car that had updates available.
Been trying to retrofit the Harman Kardon amplifier into my 2009 MCS with the HiFi option, and thought having the most current firmware might help get me past my present hurdle (it didn't).
Old Feb 8, 2011 | 01:38 PM
  #1192
phantasms's Avatar
phantasms
Does this work with a 2011 JCW yet? I thought maybe it would since no major engine updates to the JCW for 2011. I'm picking my car up next week and I'm looking forward to testing the AP with this newer beast.
Old Feb 8, 2011 | 01:50 PM
  #1193
ALTA_Chris's Avatar
ALTA_Chris
L&L is John's (jrettew) term for his automatic transmission hesitation. It stands for lag and lurch. Maybe John can chime in here? (John, I knew this would come up again!!)
The AccessPORT has been working on the 2011 JCW for quite some time now, so you are set!
Hello,
We are still working on the Euro compatibility. We aren't 100% sure yet if we are going to be able to get it to work. Thanks for your interest!
Old Feb 8, 2011 | 02:11 PM
  #1194
jrettew's Avatar
jrettew
fishbert..sorry to hear it wasn't a fix for you, but evidently they had no problem flashing at your request?
Old Feb 8, 2011 | 02:20 PM
  #1195
jrettew's Avatar
jrettew
Mflossin...just to add to Chris's explanation...my 2010 Clubman S Auto has had this tendency all along. When you come to a rolling stop, and re-accelerate, there is a delay before the transmission engages. By the time it decides to engage, the pedal is depressed enough that it causes the car to lurch ahead. Not to the point that it is dangerous, just annoying. For some reason, it is most reproducible on a downhill stop. I've searched around message boards enough to know that I'm not alone, but neither is it a universal issue. Hope that helps.
Old Feb 8, 2011 | 03:14 PM
  #1196
fishbert's Avatar
fishbert
right
Old Feb 8, 2011 | 05:56 PM
  #1197
///Mflossin
Gotcha and thanks. I have a manual box so I am not affectd by this condition. I do see, however, how that might be annoying! Ah computers...sometimes you wonder if they complicate more than aid.
Old Feb 9, 2011 | 04:48 PM
  #1198
tw1112's Avatar
tw1112
People that are running the stage 1 with just FMIC 91oct map, can you guys post up some boost numbers? I'm running that map and seem to avg a peak of just under 14...something like 13.6psi and 15 if I overboost. My gf's mini is stock and she seems to get 17psi with ease. My mini is a 2009 and here is a 2010. Thanks!
Old Feb 9, 2011 | 05:04 PM
  #1199
Raymazing's Avatar
Raymazing
Bigger intercoolers create pressure drop. Basics.
Old Feb 9, 2011 | 10:29 PM
  #1200
com3tojo3's Avatar
com3tojo3
You check for boost leaks? The connectors on the intercooler are usually the culprit
