Drivetrain The Official ALTA AccessPORT Thread
Old Dec 3, 2010 | 12:29 PM
  #926
MCS9211's Avatar
MCS9211
Believe me, this thing screams with what it has now and im pretty sure you will be 100% happy with around 220 HP. I run 215 Yoko S. drives and have a hard time getting all the power to the ground in 1st and 2nd.
Old Dec 3, 2010 | 12:38 PM
  #927
peter314's Avatar
peter314
It's a good thing I just got 215 Yoko's myself then
If your not driving like a nut hows the mileage with all of those mod's treating you? The bigger tires have knocked me down to about 25-30 mpg from 28-33 mpg, At least I think thats what's doing it... Idk maybe I need to get an alignment after all. I've only driven on them for about 800 miles (~2 weeks) I got one not too long before getting the new tires
Old Dec 3, 2010 | 12:53 PM
  #928
MCS9211's Avatar
MCS9211
on the highway (70-75 mph) the computer says I get between 35 and 38. And in town I get between 26 and 30
Old Dec 3, 2010 | 01:06 PM
  #929
peter314's Avatar
peter314
not bad, Thats what I'm doing now just about. As long as I'm not losing anything its all good.
Also ALTA what has been going on with the PnP, Have you been able to make a two stage map where the "POWER MODE" is engaged when you turn the sport button and normal Cooper S power (or Economy mode) when it's off? That is a feature I really REALLY want.
Old Dec 3, 2010 | 01:08 PM
  #930
MCS9211's Avatar
MCS9211
I saw around a 3 mpg increase across the board. And Im also real interested in the sport button being "power mode." That would be awesome!
Old Dec 3, 2010 | 02:52 PM
  #931
ALTA_Chris's Avatar
ALTA_Chris
Peter,
That is something that we can do. It would just require more programming. If that is something that you really would like, send us a PM or call! Also answer the poll in the "what would you like the sport button to do?" thread!
Old Dec 3, 2010 | 02:56 PM
  #932
peter314's Avatar
peter314
Originally Posted by ALTA_Chris
Peter,
Good to know, I believe that I asked this before and I do not think I got a reply.
I believe that I did answer the poll about that. I will definitely be getting a hold of you guys in the new year for an AccessPort.
Old Dec 3, 2010 | 03:27 PM
  #933
MCS9211's Avatar
MCS9211
Peter,
All stock - 158.1 Hp 190.4 ft-lbs torque
FMIC, CAI, boost tubes, 3" turboback exhaust - 179.4 Hp 200.0 Ft-lbs torque
no accessport
The above + accessport - 217.3 Hp 263.6 Ft-lbs torque
Old Dec 3, 2010 | 04:44 PM
  #934
LASRGUY's Avatar
LASRGUY
Upgrade from stage 1 to stage 3
Just before Thanksgiving I installed Alta's dual cat downpipe to make a full turboback exhaust and upgraded from the stage 1+FMIC map to the stage 3 map. The difference is very noticeable. Overall the stage 3 tune is even smoother with the added low end torque. With the standard stage 3 tune I had some instances where the boost would peak over 22 psi then drop to about 4psi and not go any higher until I let off the gas for a second. Jeff thinks it may be due to airflow differences from my DDM works race intake which has a ram air design. After a trying a few customized stage 3 tunes from Jeff we found one that eliminated the boost cutout. It peaks at about 21psi and sustains right about 20psi. That's about 5-6psi higher than the stage 1 tune. Anyone else see this kind of boost cutout around 22psi? Would I be better off with a different intake?
Is water/methanol injection needed for tuning to boost levels higher than I'm seeing now?
Old Dec 5, 2010 | 09:33 PM
  #935
OttomanFD3S's Avatar
OttomanFD3S
Can the access port display knock retard?
if the car is pulling timing, then the answer is yes, if the answer is no, then u don't...
(also depends what kind of pump gas u use)
Old Dec 5, 2010 | 09:58 PM
  #936
zallion's Avatar
zallion
I asked in another post but it was never replied to by Alta so I figured I would ask here. Does Alta ever plan on doing a group buy or giving a discount on the AccessPort similar to the price of $795.00 that the device cost when it first came out?
Old Dec 6, 2010 | 09:04 AM
  #937
clnconcpts's Avatar
clnconcpts
Now that this has been out for awhile,Has anyone had any issues?
Old Dec 6, 2010 | 09:08 AM
  #938
dez's Avatar
dez
any idea if or when this will be available for the R60?
Old Dec 6, 2010 | 09:10 AM
  #939
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Hey Guys and Gals,
Chris and Jeff will be in to answer some of the new questions, in the meantime:
CLICK HERE
for a fresh review of the ALTA AccessPORT
Thanks again!
Adam @ ALTA Performance
Old Dec 6, 2010 | 10:12 AM
  #940
MotorMouth's Avatar
MotorMouth
you are reading the same forum we are =) If someone had a major issue i'm sure they would have posted it in this thread. The worst thing I've seen so far is that it didn't recognize someones ECU and they couldn't get it to load.
Old Dec 6, 2010 | 10:20 AM
  #941
ALTAPerformance's Avatar
ALTAPerformance
MotoringFile Reviews The ALTA AccessPORT
MotoringFile is a MINI weblog dedicated to bringing you news, views, and every other little bit of interesting information from the new MINI world.
Quotes From The Review
"Without question, the ultimate second generation MINI performance item is finally here."
"One of the many great features of the (ALTA) AccessPort is its ability to adapt to your MINI upgrades"
"At $895, the “bang for the buck” of this product is nearly unmatched ... "
"Again, the difference was staggering."
"... I realized this tune was going to actually increase my gas mileage."
"As you’d expect I’d highly recommend this item to anyone who drives a turbocharged MINI."
Click HERE To Read The Complete Review.
Click HERE To Check Out The ALTA AccessPORT On The ALTA Performance Web Site.
Old Dec 6, 2010 | 11:06 AM
  #942
MotorMouth's Avatar
MotorMouth
great writeup/review!
I like this:
When the box arrived from UPS I stared in amazement of what potential lay in such a tiny package.
Momma always did say the best gifts come in small packages.
Old Dec 6, 2010 | 02:59 PM
  #943
ALTA_Chris's Avatar
ALTA_Chris
Meth can help you get more power. I won't let you be able to turn up boost more, but help give you more power through tuning. Also remember boost will vary, since the Minis don't try to hit a specific PSI level. You can also get more power if you got a custom protune on a dyno.
We aren't planning on doing another into pricing currently, sorry! If you're looking to purchase the AccessPORT with other ALTA parts, we can get you a deal, thanks!
As soon as we can get our hands on one, we will try it! We haven't even seen those ECUs yet, so we're not sure how much different it's going to be from the S.
Old Dec 6, 2010 | 04:42 PM
  #944
fishbert's Avatar
fishbert
Funny, that's what my girlfriend says, too...
Old Dec 7, 2010 | 07:26 AM
  #945
Mini Coupe's Avatar
Mini Coupe
Has anyone ha any issues with the keyless entry after marrying the accessport to the car? I didn't even load a tune on because I couldn't find a 93 octane stage 3, but after about 10 mins my keyless entry won't open the door. I have to use the key.
Old Dec 7, 2010 | 07:32 AM
  #946
dunphyj's Avatar
dunphyj
battery dead?
Old Dec 7, 2010 | 07:33 AM
  #947
SMOG's Avatar
SMOG
Alliance Member
Interesting connection or coincident?
Very curious.
Stephen
Old Dec 7, 2010 | 07:36 AM
  #948
Mini Coupe's Avatar
Mini Coupe
My car starts up fine... Is it possible for my keyless entry to not work due to a battery problem if my car starts? I'm not sure how the wireing works. Actually now that I think about it I was sitting in my car last night with one of the reading lights on for about 5 mins, then it shut off. I had to press the start button on the car to get it back on (even tho the car was already in on mode)
Edits: just to clarify when I say I need to use the key to open the door, I mean the button on the key. And when I said the light shut off, the engine was not on, the car was in the on position.
Old Dec 7, 2010 | 09:38 AM
  #949
MotorMouth's Avatar
MotorMouth
no. the AP did not affect my comfort access. If you did not load a tune the AP did not change anything on your ECU.
Try starting your engine with the key in the slot - if it'a a prgramming issue with the key this should reset it.
otherwise, change the battery in the key. it's a big button cell that you can buy just about anywhere.
Old Dec 7, 2010 | 05:58 PM
  #950
tacostrk's Avatar
tacostrk
Comfort Access does not have a rechargable battery in the key fob but the car can still be started by placing the fob in the dash if the fob battery is dead.
edit: Sorry i misread. Thought you said charge the battery not change.
