Drivetrain The Official ALTA AccessPORT Thread
Old Dec 12, 2010 | 11:38 AM
  #976
ThumperMCS's Avatar
ThumperMCS
Originally Posted by dunphyj
i have some upgraded internals on their way (JCW pistons with custom connecting rods and a lighterweight custom crank shaft, and no displacement was not changed i'm staying at 1.6L
Why did you decide to go with lower compression JCW pistons?
Old Dec 12, 2010 | 12:37 PM
  #977
Smigetsmall's Avatar
Smigetsmall
I believe that the JCW pistons are forged- far greater strength. So although it has lower compression, it can handle far greater pressures in the combustion chamber from mods, resulting in the capability of making much more power!
Old Dec 12, 2010 | 12:47 PM
  #978
ThumperMCS's Avatar
ThumperMCS
I don't know why people think the MCS pistons aren't forged....
The MCS pistons are forged as well...only the shape of the piston crown differs, resulting in the lowered compression.
Old Dec 12, 2010 | 01:15 PM
  #979
Smigetsmall
Standard "S" pistons are forged??
If that's the case- every piece of information I've ever read since 2007 is incorrect.
I have only ever been aware that standard pistons are cast, whereas the JCW pistons are forged.
But anyway- I wouldn't use JCW pistons for upgrading anyway...
Old Dec 12, 2010 | 01:38 PM
  #980
dunphyj's Avatar
dunphyj
I only went jcw cuz a friend of mine crashed her jcw and I got them from her for free... Can't complain with a no cost piece... Also it'll give me something to compare with my stock mcs pistons, if it wasn't for damage to the front brakes I'd be running jcw bbk too :p
Old Dec 12, 2010 | 02:43 PM
  #981
stinkytofu's Avatar
stinkytofu
can your friend part out her turbo? lol
Old Dec 12, 2010 | 03:02 PM
  #982
Eddie07S's Avatar
Eddie07S
ok i forgot i didn't mention numbers and how i got them or what they were for 16 psi map... i had 221whp and 223 wtq with 16 psi extremely broad toruqe too from 2300 -6300 for the torque hp was practically as broad itself... the 252whp was the 19psi map. all that was done on Helix13's Heartbreaker Mustang Dyno... for reference, we had stage 3 JCWs coming in for an RMW tune day in March of 2010, they were only putting out 230wtq and 215whp on that dyno with similar temperature and weather conditions. so the bump in whp and torque at 19 psi (where the JCWs were getting 21-22psi) really shows the power increase from hybrid... seems that my personal setup doesn't like torque as much as other setups, but i made mine to be more of a linear setup rather than torque monster. so it spools a little later (about 300 rpms) than stock but makes it so there is no torque steer issue, just globs of power :P
as for the brakes, i was completely stock brakes ( i know not a good idea, but i had warrantee to spare :P ) post upgrade was Ferodo DS2500 pads with stock rotors in the rear and same pads for front as well as trying out Hawk HP+ pads for the last day and drive home... HP+ pads were decent as a double duty pad, takes a little bit to heat up on the street normal drivng though so HPS might be better for daily driving or those carbos pads... i don't think i spelled that right..
as for the 02 sensor going bad... i had my high pressure fuel pump go bad a few months back which was covered under warrantee, my turbo wasn't exactly put together perfectly which was the wastegate issue, and after waste gate was fixed i found my stock BPV had failed miserably, quickly replaced with WMW replacement, and now with the upgraded Forge one Way's selling, and the O2 sensor, well my car has 83,599 miles on that O2 sensor (and my car for that matter), i think it's about time it went bad :P i have some upgraded internals on their way (JCW pistons with custom connecting rods and a lighterweight custom crank shaft, and no displacement was not changed i'm staying at 1.6L, i have a friend with a 2.0L stroked R53, and that thing just destroys most cars, but is completely undrivable on the street :P
Not familiar with "hybrid turbo" However, sounds like you have quite the engine in that car and your friends 2L sounds insane. Alta's sample dyno charts say I might get in the 210 - 215 Hp range for the mods I have. Modest by your standards but probably plenty for me .
As for brakes, I had thought about using the HP+ on the track, but concluded that their temp range was too low. I had problems with the HPS on the track (over heated them) and they are both rated for 900 degF. My track buddies talked me into a set of Carbotech XP10s for the front (XP-8 rear). These are rated 1600 degF. The temp sensing paint I put on the rotors said I was hitting a little above 1100 degF. I guess I am hard of brakes. These carbos are a true race pad that I drove on both the track and the street. They made more noise than an old bus, but the have a broad temp band with very constent friction so they are really nice on the track. I am currently using the HP+ on the street and find that they are not as friendly. They warm up quickly but they get grabby, so they are kind-of like a light switch in that regard. They might be good in the autoX I do where that stickyness might come in handy.
I think with the amount of power increase the AP makes, a brakes upgrade is a must for me.
Old Dec 12, 2010 | 03:10 PM
  #983
'11eclipsegrey's Avatar
'11eclipsegrey
when will there be an update for the performance specs for the accessport on the '11 mini cooper s's?
Old Dec 12, 2010 | 03:31 PM
  #984
ThumperMCS's Avatar
ThumperMCS
Nice
Old Dec 12, 2010 | 03:38 PM
  #985
bmwi6's Avatar
bmwi6
Question, I got my accessport and this thing is sweet!!!!! However I noticed two things that changed and I wanted to know if they were normal or pure coincidence. First, I noticed that when I shift now the rpms jump a tiny bit as if the car had a throttle blip system (I have a manual and no i'm not giving it gas). And second, I gave the car a run for it's money yesterday and without the AP I know my fan would've been going crazy like a turbine but it didn't even go off yesterday and my car got pretty hot. Any input on this? Thanks guys
Old Dec 13, 2010 | 11:31 PM
  #986
dunphyj's Avatar
dunphyj
i can attest to the occasional throttle blip happening, never seemed terrible in my mind, but i never had an issue with my cooler fan...
Old Dec 14, 2010 | 09:25 AM
  #987
ALTA_Chris's Avatar
ALTA_Chris
Originally Posted by ///Mflossin
Chris,
What is the difference between stage I and stage I plus? The reason that I ask is because when I got my AP, Jeff had to email me files and I had to manually place them into the AP. How do I know if I have stage I or stage 1+ maps? I sent Jeff an email but didn't hear back. Thanks!
The stage 1 maps for the FMIC should be labeled "stage 1 + FMIC". I remember telling Jeff which map you needed, and he should have sent you the correct map. When you look in the map description either on the AP or while using the AP Manager, it should say what the map was made for.
ALTA- in one of your previous replies you gave this response, "That is part of the body module and at this point the AccessPORT only talks to the ECU".
Does this mean than some time in the future we could see the AccessPORT interacting with body modules?
Like interaction with the DSC, and possibily having some control over the ALL4 system in the new Countryman????
The AccessPORT won't talk to the body module. We aren't planning on making the AccessPORT change the body module at this time.
Originally Posted by Eddie07S
So a question to Alta on this subject - you seem to be willing to customize the tunes to an individual's needs/wants. Can you give us an intial tune that won't throw codes on the track but still make reasonable Hp? It seems that we can always record data, send it to you and you can fine tune it from there. BTY, for me I would like it to be streetable too, like these other tunes seem to be.
I think your answers pretty much have been answered, but we are willing to help customers out if they need a special map! We want our maps to work like the OEM maps, where they can be daily driven, and driven to the track and back home without any problems. If anyone has any problems at all, we want to know about it, so we can fix it.
Old Dec 14, 2010 | 10:39 AM
  #988
ALTA_Chris's Avatar
ALTA_Chris
We will make an update on the front page of this thread and on the AccessPORT page on our website as soon as the AccessPORT is compatible. It's coming soon!
Our map wouldn't have caused the RPMs to blip a little, it could have came from the delay of when you lift your foot off the throttle and the ECU tells the engine to release the throttle.
We don't change the operation of the fans, so it must have been just colder out that day, or you were getting more airflow over the radiator.
Old Dec 14, 2010 | 05:52 PM
  #989
Douglas H's Avatar
Douglas H
I drove a Countryman S All4 today. Wow I was impressed!!!!
Tell me that Alta will be able to map the Countryman's ECU once the 2011 maps are done as they use the same engine.
Old Dec 15, 2010 | 09:30 AM
  #990
ALTA_Chris's Avatar
ALTA_Chris
Douglas,
We will, as soon as we can get our hands on one!
Old Dec 15, 2010 | 01:23 PM
  #991
fjork_duf's Avatar
fjork_duf
...First, I noticed that when I shift now the rpms jump a tiny bit as if the car had a throttle blip system (I have a manual and no i'm not giving it gas)...
I noticed the same thing. However I just think that it's because the throttle mapping is different. So I'm used to having to compensate for a laggy (stock) throttle by giving more gas between shifts. The TPS map from Alta is more linear which does away with that issue.
Old Dec 15, 2010 | 04:25 PM
  #992
Eddie07S's Avatar
Eddie07S
Chris, thanks. Also glad to hear from dunphyj about using it on the track. I appreciate hearing the positives about this because it sounds llike a must-have Mod for a Mini, especially for on the track. Well thought out and versatile. It would do some good to hear from some other track users about this. So far it sounds like 2 for 2 for taking this to the track.
Old Dec 16, 2010 | 04:11 AM
  #993
kfmuller's Avatar
kfmuller
still deciding if I need this
Old Dec 16, 2010 | 04:59 AM
  #994
elmmx5's Avatar
elmmx5
Originally Posted by kfmuller
I've got a 2009 factory JCW. Will I lose my pop and burble if I use the AccessPort to update my ECU map?
Also, what map options do I have for a strictly stock JCW?
Nope, you won't lose the pop and burble. I've been using an Alta tune for a stock 2009 factory JCW since early September, and nothing has changed in that regard.
When I purchased the AccessPORT, I was sent two maps (technically 4 maps since different ECU versions apparently need different maps). One map was an Alta tune with the sport button's throttle response left as it was originally, the other was a tune with more linear throttle mappings (regardless of the sport button's setting). Since then, I requested map with the linear throttle mapping when the sport button isn't engaged and the twitchier stock mapping for when the sport button is engaged. Jeff promptly made me a custom map, sent it to me, and I've been running that map for the last few weeks.
Old Dec 16, 2010 | 08:32 AM
  #995
ALTA_Chris's Avatar
ALTA_Chris
Kfmuller, for a totally stock JCW, we also have 91 and 92+ octane options too. These maps are all available by doing an update on the AccessPORT, thanks!
Old Dec 16, 2010 | 08:51 AM
  #996
drewstermalloy's Avatar
drewstermalloy
By 92+ do you mean you also have 93 octane maps? I've never seen 92 around here, just 91 and 93. I only get 93 though.
Old Dec 16, 2010 | 10:50 AM
  #997
kfmuller's Avatar
kfmuller
Thanks for the info - getting ready to pull the trigger on this.
Old Dec 16, 2010 | 07:50 PM
  #998
bmwi6's Avatar
bmwi6
We wants Pop and Burble for MCS.
Old Dec 17, 2010 | 03:33 PM
  #999
Smigetsmall
Can the AccessPORT make the exhaust pop at the rev limit/ "launch control"? Sort of giving the impression of anti-lag?
Old Dec 19, 2010 | 03:38 PM
  #1000
Greg Davis's Avatar
Greg Davis
I'm picking up an '11 Clubman S with an auto trans and am trying to get them to throw in the JCW tuning kit.
If I were to then run your tune, would it be too much for the trans to handle? Down the road, I may also add the JCW turbo - Again, would this be too much for the auto with your tune?
Thanks for your time.
