Drivetrain Invidia Q300 R56 exhaust
Old Apr 18, 2011 | 11:07 AM
  #251
Bigprfed22's Avatar
Bigprfed22
I would solve this problem by fully seating them and clamping down super hard, it would still pull apart from the engine movement. Then i ran 1cm spacers on the brace... worked but i was still unsatisfied. I then welded it all together and now no drone and no spacers.
Originally Posted by krim
Hey guys, are your pipes fulled seated into each other? I have about 1/2" slack on the resonator side and fully seated on the rear section and it bangs against the cross-plate when i lift off the throttle and when going thru dips in the road. I had it all fully seated but it banged all the time, even during idle.
Old Apr 18, 2011 | 11:11 AM
  #252
minimal70700's Avatar
minimal70700
agree...weld it, problem solved...
Old Apr 18, 2011 | 05:21 PM
  #253
Eddie07S's Avatar
Eddie07S
In earlier posts (#'s 183 and 188) I detailed how to position the rear section elbow that is next to the center section and how to jack up on the joint so it lifts off the plate and the crank the clamp up really tight. Been running the last 8 months or so that way with no banging. I would not full seat the pipes. This leave plenty of adjustment for how far the pipes stick out the back and alignment of the pipe sections. With the clamps really tight, it will seal up nicely and stay in place.
Old Apr 19, 2011 | 10:46 PM
  #254
krim's Avatar
krim
I don't want to full seat because that's what I did in the beginning and the tips rub up against the bottom of the rear bumper. I really wanted to see if it was a variable in production (invidia or mini). Cause if everyone is fully seating and I can't, ill have to do something different.
Yeah, i'm saving that for last resort.
I rotated the clamps so that the hourglass is at the bottom, it hasn't come loose since I did that. I'm going to try jacking it up next chance I get, probably in a week or two.
Thanks all.
Old Apr 20, 2011 | 07:01 AM
  #255
Bigprfed22's Avatar
Bigprfed22
Once it's sealed how ever which way you do it, it will kill drone and sound great!
Thanks all.
Old May 14, 2011 | 05:51 PM
  #256
ThumperMCS's Avatar
ThumperMCS
Finally installed my Riss catless DP to go with my Invidia....
Far exceeded expectations....sounds absolutely wicked, its already turned a few heads this afternoon since I've installed it. It's LOUD.
Power wise its a huge difference too...more than I was expecting to be honest.
I'll make some videos tonight hopefully...
Old May 14, 2011 | 05:59 PM
  #257
Eddie07S's Avatar
Eddie07S
No sneaking home with that car now
Old May 14, 2011 | 06:03 PM
  #258
ThumperMCS's Avatar
ThumperMCS
Well I couldn't really before...but now its just out of the question entirely lol
Old May 14, 2011 | 11:11 PM
  #259
J_'09s's Avatar
J_'09s
I've been wanting to hear this combo for so long! Can't wait to hear the clip! Thanks Thumper.
Old May 21, 2011 | 05:34 PM
  #260
J_'09s's Avatar
J_'09s
Old May 23, 2011 | 06:23 AM
  #261
cgaubuchon's Avatar
cgaubuchon
After reading this thread and nearly every other exhaust thread on NAM and M|U its near time to bite the bullet and go for it. Looks like I will have an Invidia via Way in the very near future.
Old May 25, 2011 | 08:49 PM
  #262
ThumperMCS's Avatar
ThumperMCS
here we go...finally threw together some crappy sound clips of the riss w/ invidia.
If you have good speakers, turn them up and turn up the bass
Old May 25, 2011 | 09:41 PM
  #263
silhouette88's Avatar
silhouette88
I really like how the Invidia fills out the entire exhaust valance. I wish my JCW "tips" had more girth.
Old May 26, 2011 | 08:50 AM
  #264
ThumperMCS's Avatar
ThumperMCS
That's what she said...
Old Jun 1, 2011 | 08:55 PM
  #265
SpeedRacer0212's Avatar
SpeedRacer0212
that absolutely sounds awesome. It is really the best sounding system, and it sounds great when you are rocking JBL Pro speakers. Cannot wait to put my entire order in on Monday of next week.
As soon as I get it and install it I will post sound clips; somewhere, where there's no pigs.
Old Jun 1, 2011 | 10:11 PM
  #266
krim's Avatar
krim
*sigh*
looking for a place to get it welded. i'm tired of adjusting it. I tried it using the jack and it worked for 2 days. If any of you are in SoCal and can recommend a place, i'd love a pm. I'm finding prices ranging from $130 minimum to $30 shady "i can do it in 10 minutes"...
Old Jun 2, 2011 | 05:49 PM
  #267
Gryz's Avatar
Gryz
I currently have this exhaust waiting to get put on. I have sat here and read all 11 pages and have one question...
Are any of you still successfully keeping this exhaust in place with just the bolts and clamps? Or is welding the general concensus?
Old Jun 2, 2011 | 06:23 PM
  #268
Eddie07S's Avatar
Eddie07S
I've been almost a year with no problem. Plenty of pot holes and other shakers around here that would "adjust" it if it was going to. Give it a shot with the clamps. Just remember that the clamp should be placed at the end where the slots are. and tighten them tight. Also, that will give you the option to adjust it before welding it if that is needed. Once weld, forever stuck.
Old Jun 2, 2011 | 06:34 PM
  #269
Gryz's Avatar
Gryz
Thank you. If I do decide to get it welded, where are the weld spots? Midpipe to exhaust? I would think you wouldn't weld to the downpipe as then it's permanent...
Do you keep the clamps on when welded? In other words, clamp up as I want it positioned, take it down and then what? Weld around the clamp?
Also: do you mind explaining a little more what you mean by the clamps and slots?
Sorry, I'm not even in the same state as my car right now so can't look at it for reference.
Old Jun 2, 2011 | 07:38 PM
  #270
krim's Avatar
krim
Hmm, you'd leave the vband at the end of the downpipe alone, that one's fine.
Here's how they're put together, one pipe is expanded and a slot is cut. the other tube slips into the expanded pipe and the clamp goes around the end. When you tighten the clamp, it squeezes the the slotted portion tightening it around the inside pipe.
It'll make sense when you see it.
Old Jun 3, 2011 | 10:04 AM
  #271
Bigprfed22's Avatar
Bigprfed22
I ended up welding mine, it would come apart by a few mm's every 1 - 2 months.
Old Jun 7, 2011 | 05:01 PM
  #272
srlinehan's Avatar
srlinehan
Ok so I have been looking through this thread and my head is spinning. I am trying to decide on an exhaust and well.... I can't haha. I have been watching videos on Borla, Supersprint, Alta, Invidia and so on. Was wondering if anyone had input on which of these would be best. The videos i have seen on the Borla and Supersprint seem to sound a little weak but idk if it the video quality or people not knowing how to record a good video IMOP. Would love some of your guys help/ input
Old Jun 7, 2011 | 05:24 PM
  #273
srlinehan's Avatar
srlinehan
SICK SET UP!!! I think this is the set up I am leaning towards as of know. It sounds MEAN!!!
Old Jun 7, 2011 | 08:25 PM
  #274
ThumperMCS's Avatar
ThumperMCS
Thanks, love it...
Old Jun 8, 2011 | 05:43 AM
  #275
richardsperry's Avatar
richardsperry
Yes the Invedia sounded great at WFO, but the droan at anything less was horrible.
