Going to replace valvew cover gasket. What else should I do?
Old Jul 4, 2018 | 04:12 PM
ijourneaux's Avatar
ijourneaux
I am going to help my son repalce the valve cover gasket on his 2011 Clubman on Friday. While we are in there is there anything else we should look at doing?
Apprecaite any comments.
Old Jul 5, 2018 | 06:15 AM
MiniToBe's Avatar
MiniToBe
why are you replacing the gasket?
you could check the chain guides for chips, cracks, or missing pieces.
Old Jul 5, 2018 | 07:02 AM
08miniS08's Avatar
08miniS08
Given the location, there isn't much else to do "while you are in there" except check the chain and guides, as MiniToBe mentioned. If you haven't done the spark plugs in a while, you could do those, check for oil on the plugs, and inspect the ignition coils.
Old Jul 5, 2018 | 09:28 AM
ijourneaux's Avatar
ijourneaux
This all started with a bad coil. Will be replacing the plugs. Is it worth changing the coils as a PM given that one of the original 4 has failed.
Will take a look at tht chain guide while in there. what are the of it being damaged? Should I have one on hand?
Old Jul 5, 2018 | 10:52 AM
08miniS08's Avatar
08miniS08
I never change coils unless one fails and I get misfires. If you had a bad coil, you likely know the symptoms. The coils are easy to swap on these cars, so I would wait. For the chain and guides, you really need to inspect before ordering anything. If the guides are broken or badly chewed up, you have a bigger job to tackle, so again, I would wait and inspect for wear.
Also, is your VCG leaking? One bad coil does not mean you have to replace the VCG.
Old Jul 5, 2018 | 04:00 PM
DneprDave's Avatar
DneprDave
Vcg?
Old Jul 5, 2018 | 05:10 PM
08miniS08's Avatar
08miniS08
Originally Posted by DneprDave
Vcg?
valve cover gasket, sorry to confuse anyone
Old Jul 6, 2018 | 01:47 PM
ijourneaux's Avatar
ijourneaux
DId the work this morning./ NO special issues. We decided to replace all of the coils because that is what my son wanted to do but but I agree with the comments above. Replacing a coil is easy so replace as needed.
Appreciate everyones comments.
2cati
Jun 21, 2018 08:40 AM
Snaps
May 14, 2017 01:10 PM
RexNTX
May 10, 2017 06:05 AM
Applesauce
Mar 16, 2012 09:32 AM
fixedcontext
Feb 6, 2011 09:39 AM
