R57 odd question, but I am lost
Old Feb 4, 2010 | 04:26 PM
LSK6453's Avatar
LSK6453
I have a R57 and for the life of me I cannot figure out how to open the trunk when the key is in the ignition. Is there something on the boot that lets me open it? Is there a setting inside?
Someone help please
thanks
Old Feb 4, 2010 | 04:43 PM
malteseracer's Avatar
malteseracer
Unlock both doors, the hatch opens when both doors are open. Also, the gas door opens with the driver side door if you ever need to know that
Old Feb 4, 2010 | 04:58 PM
LSK6453's Avatar
LSK6453
hmm, thanks.. I will try that tomorrow. I knew about the gas door, but the boot was driving me nuts.. Thank you
Old Feb 5, 2010 | 04:43 AM
AustinS's Avatar
AustinS
FYI - you can program your fob to unlock everything with one push. Mine does that, my wifes needs 2 pushes.
Old Feb 5, 2010 | 05:02 AM
malteseracer
How?
Old Feb 5, 2010 | 09:40 AM
AustinS's Avatar
AustinS
Originally Posted by malteseracer
How?
In the 2009 owner's manual, you'll find instructions on pgs. 19,20 under the topic "Opening and Closing: from outside"
Old Feb 5, 2010 | 10:06 AM
rkw's Avatar
rkw
Why not just flick the lock/unlock toggle switch in the center console?
Old Feb 5, 2010 | 04:49 PM
LSK6453's Avatar
LSK6453
with both doors unlocked, the boot still was not able to be opened...frustrating..
Old Feb 6, 2010 | 08:23 AM
zanary's Avatar
zanary
On my 2009 Convertible, when both doors are unlocked, I have to press and hold the switch on the boot unless it releases some times. So some times, it's just a quick press, other times it's a press and hold. It's intermittent, but I live with it.
Old Feb 7, 2010 | 07:16 AM
Derepente's Avatar
Derepente
If Key in ignition, boot opens after door locks toggled from center
Someone help please
thanks
This used to frustrate me as well. The soft button in the boot handle will work in this situation (key in ignition, regardless of motor running or not), the center console door lock has to be used to unlock all the doors. To avoid the "double tap", I have set the unlock in the remote settings to open all doors, not just the driver door. So you'll end up with doors and boot unlocked with a single press from the remote or a single unlock from the center console. I hope that's right... try it out and let us know.
Colt45Magnus
Aug 27, 2024 05:03 AM
Alkaidovich
Jan 30, 2021 01:35 AM
Manny_cooper
Sep 3, 2015 05:48 AM
broncobuddha
Sep 1, 2015 06:32 PM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
