R56 Fuel tank level sensors
Old Aug 14, 2025 | 05:03 AM
Cassa's Avatar
Cassa
Dear all,
I had the left side fuel level sensor replaced. Now when I go to menu 6.0 I can se huge difference between the levels.
Is this normal?
I did a test..., filled up the tank (50lts) and I drove 372kms with an average consumption of 8lts/100kms . It seems even if there is only 7liter on the right side, it should be more less the 20lts indicate of remaining fuel.
I will monitor from here..., I suspect of having that left fuel sensor stuck for some reason.
Best regards
Old Aug 14, 2025 | 06:57 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Unfortunately, your observations suggest that the "new" left fuel sender was bad out of the box or was not installed correctly.
As an aside, how does one access the menu 6 fuel tank sender information shown in your tachometer? I have never seen that display.
Old Aug 14, 2025 | 07:01 AM
Cassa's Avatar
Cassa
It seems that is stuck for some reason.
you can check quickly on youtube how to go to this menus:
Old Aug 14, 2025 | 07:05 AM
Maybe, maybe not
Community Builder
Thank you and good luck with the fix!
Old Aug 14, 2025 | 07:12 AM
Cassa's Avatar
Cassa
If you test yours, please post the readings for comparison.
Old Aug 14, 2025 | 07:29 AM
Maybe, maybe not
Community Builder
When I looked at the video, simplecarguy's menu 6.0 also reports different fuel levels from the right and left fuel senders. See image below. Maybe this is normal?
What does your menu 6.2 show?
Old Aug 14, 2025 | 07:35 AM
Cassa's Avatar
Cassa
Both 1 and 2:
Old Aug 14, 2025 | 07:45 AM
Cassa's Avatar
Cassa
Got it from a youtube video. seems for now normal:
Old Aug 14, 2025 | 07:47 AM
Maybe, maybe not
Community Builder
Your menu 6.2 seems to report the electrical resistance readings from the two senders, which differs from simplecarguy'smenu 6.2 information.
Is your fuel gauge in the speedometer working as expected? If so, I wouldn't worry about the different menu 6.0 left and right readings because simplecarguy may have simply misinterpreted the true meaning, which is a mystery.
Old Aug 14, 2025 | 07:50 AM
Cassa's Avatar
Cassa
Nevertheless I will keep monitoring. Because one day it showed me 0lts on the right and 17lts on the left. When I filled up it took 43lts.
Well and the gauge was showing 4 bars on it . That's why I felt suspicious about it.
I will keep this updated.
TheSwordBearer
Jul 30, 2018 09:14 PM
XXLil MickXX
29
Nov 22, 2012 08:13 AM
chisss
Aug 25, 2010 08:19 AM
R53
Sep 27, 2009 02:18 AM
Aeromax
Jul 1, 2007 05:49 AM
