Navigation & Audio [eas] Official DICE iPod integration kit Q/A thread
Old Jun 17, 2008 | 02:40 PM
  #701
tom @ eas's Avatar
tom @ eas
Originally Posted by Michal
Get a nano.
It will be a while before you fill it up with songs, and since it uses flash memory rather than a hard disk there is less chance for problems.
80GB iPod is not much more than a nano, get the extra space if you can afford it.
Old Jun 17, 2008 | 02:41 PM
  #702
tom @ eas's Avatar
tom @ eas
Originally Posted by haygood
Here's a NEWB question for you guys... I am planning to get an iPod and DICE or HD DICE. I know nothing about iPods. Where can I find info on which model iPod to get?
I don't have any imediate urge to put videos on it
I only own like 50 CD's
If they differ on this, I'd like the most durable iPod.
This will go in an '08 convertible. Where should I put the HD stealth antenna, if I go HD? I'd like for it to be invisible. Does the cloth roof give me more options?
Lastly, some HD questions... I live about 100 miles from Dallas. What is the range on the HD stuff compared to regular FM radio?
Thanks!
Brian
Check www.hdradio.com to find out what is available in your area.
Old Jun 18, 2008 | 06:38 AM
  #703
BSUCardinalfan's Avatar
BSUCardinalfan
Tom -
Didn't get an email (maybe you didn't get mine?) so I thought I'd post an update here.
Disconnected the DICE last night, left it disconnected all night. Reconnected this morning, plugged in the Ipod, and...it worked!.....sorta. I was careful not to push 'disc 5' because that seems to always lock it up. Anyway, I was navigating through playlists, and songs, trying to get to podcasts, which I never found. Finally, I just decided to listen to some music, and so I was searching by 'artist', but it would only go back and forth between two songs.
Okay, maybe some mode I have it in, I pressed 'disc 1' to try to get back to 'all', and then it stopped working again. CDC is not selectable with the 'mode' button.
Something else I noticed, I couldn't press the 'music' button to change the sound settings (balance/fade/bass/treble) because the text kept overriding the display. Is that normal?
Anyway, this was about 10 minutes of freeway driving before it died again. As of right now it is sitting in the parking lot dead.
Help!
Old Jun 18, 2008 | 04:28 PM
  #704
tom @ eas's Avatar
tom @ eas
Originally Posted by BSUCardinalfan
Tom -
Help!
Does the iPod still display the DICE logo when the kit is no longer active? Is the iPod still charging?
Old Jun 18, 2008 | 06:20 PM
  #705
BSUCardinalfan
when it first stops working, the ipod displays the dice logo.
if I disconnect the ipod and then reconnect it, it does not know that it is connected.
Old Jun 19, 2008 | 03:35 PM
  #706
BSUCardinalfan
Tom,
Still no email. I want to get this resolved quickly.
Old Jun 19, 2008 | 03:46 PM
  #707
tom @ eas's Avatar
tom @ eas
I have no emails concerning DICE for MINIs from anyone at this time. Are you sending to the correct address?
Please send a copy through our email system here: http://www.europeanautosource.com/contact_us.php
Old Jun 20, 2008 | 05:46 AM
  #708
BSUCardinalfan
Okay, I submitted it through the website. The original email was sent to the address in your signature (tom@european......) on Monday June 16th, if you are looking for it. Since that email, I've gotten the unit to work but only for short durations before it dies.
Old Jun 22, 2008 | 08:05 AM
  #709
bennettskis's Avatar
bennettskis
DICE, Alpine ex-10 or new head unit?
I would like Bluetooth, but not required, and would like to have an aux plug for my Nuvi 760 if possible.
I don't want to spend a ton, but don't want FM reception either.
An a scale of 1-10 my tech abilities are about 7, so I probably will need a trusted installer in the Chicago area as well.
Any recomendations?
Bennettskis
05 MCS (built 4-05)
Old Jun 23, 2008 | 11:16 AM
  #710
tom @ eas's Avatar
tom @ eas
Any recomendations?
Bennettskis
05 MCS (built 4-05)
I'm a big fan of OEM integration, but the Alpine unit might be a bit less costly. Try going to a local stereo shop and working with the Alpine in person before making a decision.
Old Jun 23, 2008 | 04:38 PM
  #711
bennettskis
thanks, I did that today, and it did add up!
Alpine unit 199 + 175 install, steering wheel adapter 75 +100 install, FM adapter 150 + 75 install. so 825 is a little much to listen to my ipod!
Bennett
Old Jun 27, 2008 | 08:25 AM
  #712
cheweez78's Avatar
cheweez78
does the dice work with aftermarket or just oem? which is better?
I have an '06 Mini S with a Kenwood HU and MFSW adaptor that doesn't work because of the stupid RF not reaching the receiver. If the OEM is better for the Dice interface I'll reinstall the OEM HU. I just want my MFSW working again, I have the controls and would like to have that convenience back. =)
Old Jun 27, 2008 | 03:55 PM
  #713
tom @ eas's Avatar
tom @ eas
DICE will only work with the stock MINI HU.
Old Jul 1, 2008 | 07:56 AM
  #714
cheweez78's Avatar
cheweez78
Thanks Tom, it looks like I'll be switching soon.
Old Jul 4, 2008 | 08:55 AM
  #715
gob15's Avatar
gob15
I own a MINI 2004 Cooper w/ the stock radio so the Dice HD would be no good for me. With the earlier DICE version work? I am trying to connect both my Iphone/ipod as well as my portable XM. If not, would you be able to point me in the right direction?
Old Jul 7, 2008 | 12:10 PM
  #716
tom @ eas's Avatar
tom @ eas
Non HD DICE kits will be fine.
Old Jul 8, 2008 | 11:16 AM
  #717
tom @ eas's Avatar
tom @ eas
Just released today!
For those wanting a bit of a simplified system, the DICE Universal Car kit for iPod allows you to connect the iPod to your factory BMW radio within minutes using the included installation harness. If your radio is capable of receiving RDS broadcasts (Radio Data System - most MINI applications are), you will see Song Title & Artist information on the radio screen. Charging is also provided - keeping your iPod ready to go at all times.
For 00-04 MINIs without CD text support - this is your answer!
This is especially a plus for vehicles that do did not have text display with our current SILVERLINE kits or simply do not want the Clickwheel to lock when attached to the Dock Connector. The DICE Universal RDS iPod integration kit is a wired FM modulated (not transmitted) connection to your factory radio. A wired connection provides a direct statis-free connection, eliminating unwanted radio interference.
All control is performed via your iPod's Clickwheel for easy access to your music library. A fixed 128kbps bitrate ensures superior audio quality to that of FM transmitters or other add-on kits.
The DICE Universal RDS iPod module transfers information between the iPod and radio through an included iPod-specific docking cable, as if it were an original BMW accessory.
New features of DICE SILVERLINE iPod Integration kit include:
- Direct integrated connection, without the need for FM transmitters or cassette adapters
- Easy installation, about 30 minutes.
- Full Artist/Song Text display (RDS-supported Head Units)
- Full control of your iPod via the Clickwheel while in play
- Full charging mode for iPods through included dock connector
- Allows CD Changer Retention
Contents:
- DICE Universal RDS BMW Integration Module
- Power Harness with BMW-Specific Antenna Adapter kit
- BlackOut Dock Connector
Models Supported:
2008+ 1-series
1992+ 3-series, including M3
1997+ 5-series, including M5
1995+ 7-series
2004+ X3
2000+ X5
1996-2002 Z3, including M-Roadster/Coupe
2003+ Z4, including M-Roadster/Coupe
2000-2003 Z8
2002+ MINI Cooper
DICE - Universal RDS iPod Integration kit for BMW/MINI
http://www.europeanautosource.com/pr...oducts_id=1909
Compatible for Business Cassette, CD and Navigation/iDrive. Installation is simple for the DIY type and should take no longer than 20-30 minutes.
Old Jul 9, 2008 | 08:20 AM
  #718
gob15's Avatar
gob15
Compatible for Business Cassette, CD and Navigation/iDrive. Installation is simple for the DIY type and should take no longer than 20-30 minutes.[/quote]
Does this version of DICE have an AUX input as well for satellite radio integration?
Old Jul 9, 2008 | 10:24 AM
  #719
tom @ eas's Avatar
tom @ eas
Does this version of DICE have an AUX input as well for satellite radio integration?[/quote]
The RDS kit does not have AUX input.
Old Jul 9, 2008 | 10:51 AM
  #720
gob15's Avatar
gob15
The RDS kit does not have AUX input.[/quote]
Ahh.. That's a shame. If it did I would say that it would be the "end all, be all" for ipod/iphone car integration. It seems like a step back by not including this feature, especially since it was included in the past two incarnations of the device. I would think the option to add an AUX would be primary to having text on the cd player. While I can't imagine how anyone would not buy the DICE w/ AUX due to lack of text display, I can see many people not buying this newer version, which would kill their AUX input abilities, just to have text display. I know this because that is why I couldn't and wouldn't buy this.
A great idea. Just not fully realized.
Old Jul 9, 2008 | 10:56 AM
  #721
tom @ eas's Avatar
tom @ eas
The DICE RDS kits has nothing to do with AUX, it's using a FM modulated signal to input audio to your MINI's radio. You can still use the AUX kit from MINI for other devices if desired.
Old Jul 9, 2008 | 09:05 PM
  #722
wojpgh's Avatar
wojpgh
What is your recommendtion for . . .
2002 MC, non-nav system, non-HK. I would like to run my iPod and a Sirius receiver directly through my radio. Guide me Tom.
Old Jul 10, 2008 | 05:59 AM
  #723
computerdoc's Avatar
computerdoc
iPod resetting to replay songs on its own
My Dice install went well and I'm really enjoying it, but twice the songs started replaying, and I found that the iPod setting to replay songs had been set. I changed it back to Off, and a few days later it happened again. Spooky? Anyone experience this or have any thoughts or solutions?
Old Jul 10, 2008 | 07:36 AM
  #724
gob15's Avatar
gob15
How does the DICE unit get power?
Old Jul 10, 2008 | 11:48 AM
  #725
computerdoc
Dice unit is connected at the radio with the included harness. Today the iPod is showing the Dice logo on the screen but the head unit shows it as detached. Rebooted the iPod but no change. Help, Tom!
