Navigation & Audio Bluetooth compatibility list
Old May 4, 2010 | 05:51 PM
  #901
DanH's Avatar
DanH
I successfully paired an HTC Hero although my primary phone is an HTC Mogul. Both pair with no known problems.
Old May 4, 2010 | 07:48 PM
  #902
packimocity's Avatar
packimocity
Nokia 6790
will not pair
thankful I have a HTC Droid Eris that does
pac
Old May 5, 2010 | 11:04 AM
  #903
ckakats's Avatar
ckakats
Blackberry 9700 Bold
works perfect, syncs phonebook, also voice dial
Now waiting for the snap-in adaptor...
Old May 5, 2010 | 12:58 PM
  #904
nicknbecka's Avatar
nicknbecka
Originally Posted by Nigel86
Quick question: has anyone tried to use a new HTC Incredible with their bluetooth system? I just got a new 2010 Cooper with comfort bluetooth and iPod connection and want to know which phone I should get to take full advantage of it. Thanks!
I don't know of any specific reports on the HTC Incredible, but it runs Android 2.1, just like the Hero/Droid Eris/G2 Touch, and those phones have been reported to work multiple times (along with being listed on the official MINI USA website), so the Incredible is very likely to work with the Bluetooth connection.
If the Incredible shows itself as a USB Mass Storage Device when it's connected to a USB connection, you should be able to play compatible music from it by connecting it to the USB port in the center console.
As for having full support through the armrest, that depends entirely on having a fully compatible armrest snap-in, which is only available for the iPhone that I know of.
Old May 5, 2010 | 01:04 PM
  #905
nicknbecka's Avatar
nicknbecka
Originally Posted by ckakats
Blackberry 9700 Bold...
Unfortunately with MINI's history, that may be quite the long wait... Unless RIM gets purchased by Apple, then there will probably be seven of them released in three months
Originally Posted by packimocity
Nokia 6790
will not pair
Dang- thanks for letting us know, I've added it to the list.
Old May 7, 2010 | 07:39 AM
  #906
Nigel86's Avatar
Nigel86
Just what I needed to hear. Thanks a lot, this thread has been a huge help for me!
Old May 7, 2010 | 08:10 AM
  #907
veilside.mustang's Avatar
veilside.mustang
Adapters and the "Comfort Bluetooth"..........
I am just voicing an opinion here but the promoting or the dealer-ordering of these "Comfort Bluetooth" armrest gizmos appear to be, well, inappropriate.
For one, it is now clear AFTER purchasing the car that only a handful of cell phone models will actually have the "infamous" adapter. If that is true, buyers paid several hundred dollars more for something they cannot ever use - unless they pay more money to prematurely switch their cell phone to the old RAZR or the new Apple phones.
Don't get me wrong... My wife loves her Mini. I just feel ripped off - especially since Mini does NOT state clearly that option will only work with XXX phones.
Old May 9, 2010 | 03:02 PM
  #908
Draikonius
Just received my Incredible and it works with no problems. Firmware V2.1 update 1
Old May 9, 2010 | 10:50 PM
  #909
nicknbecka's Avatar
nicknbecka
Great news, Thanks!
Old May 10, 2010 | 04:51 AM
  #910
ccsubruce's Avatar
ccsubruce
Blackberry Curve 8530
Has anyone successfully paired this phone? I'm trying to decide if buying a bluetooth package is worth it.
Old May 10, 2010 | 05:03 AM
  #911
schatzy62's Avatar
schatzy62
Not sure about the 8530, but i can tell you that ALL of the other blackberries in have tried have had zero problems. I.E. they all worked perfectly, so i suspect that the 8530 should have no problem.
Also having a car with bluetooth in it is worth while anyway even if you initial phone does not work with it, more and more phones are starting to work with these systems.
Old May 11, 2010 | 01:14 AM
  #912
ckakats's Avatar
ckakats
You 're right about the apple thing... Just saw a snap-in adaptor for the 9000 Bold in a Bmw X6.. Let's pray..
Old May 20, 2010 | 04:04 PM
  #913
jsp3's Avatar
jsp3
VZW HTC Touch Pro2 no phone book sync
Chances are the HTC Touch Pro2 is a good match, since it runs Windows Mobile 6.1. So far all the WM6 phones have had a great track record.
I have an '09 Clubman S that won't fully work fully with my HTC Touch Pro2. The TP2 has WM 6.5 on it with ROM version 3.04.605.3 from 11/17/09. I can make and receive calls, but the phone book is empty as are all the other logs (last call, missed calls, top 8, etc.) It does work fine with an 07 BMW 650. I have about 90 phone book entries. When first pairing it, I see that it tries to access the phone book, but it stops after a few seconds.
Old May 20, 2010 | 04:17 PM
  #914
LittleJoe's Avatar
LittleJoe
I wonder if there is a setting on the TP2 which stops it from sharing contacts with the Mini.
Old May 20, 2010 | 05:07 PM
  #915
jsp3's Avatar
jsp3
I wouldn't necessarily call it a setting, but clearly there's some sort of incompatibility. When I initially pair the HTC TP2, it set us the headset function quickly. Then it asks permission to access the phone book, which I grant. It starts to transfer data, but it quits after a several seconds with no entries. The phone book remains empty. As I mentioned, it works on an 07 BMW 650 and it also has worked on either an 09 or 10 BMW 328? service loaner.
Old May 21, 2010 | 05:01 AM
  #916
schatzy62's Avatar
schatzy62
Are you sure it actually quits transferring contacts?
The reason I ask is that a fair number of people have had it take as much as three hours for the first sync of contacts in the MINI.
My Blackberry synced with my 2003 BMW 525 in a mater of seconds but when it came to the MINI it took going on a long 2-1/2 hour drive to transfer all the contacts.
Yes it seems weird but this may just be what it takes. If you read thru all the posts in this thread you will see how many people have this time issue the first time. but then after the first time it only takes seconds to make updates if you have made changes to your contact list.
Old May 21, 2010 | 08:37 AM
  #917
jsp3's Avatar
jsp3
I was hoping that it was just an issue of taking a long time, but I don't think that's the case. Once the HTC TP2 pairs, I can see what services it sets up. It sets up the headset and that stays. Then usually, it asks permission to also set up phone book access. I grant that. I can then look at a status screen on the phone book access. Bytes sent and received start to track up, but at 15 seconds with 30 or so KB sent and 154 bytes received, it stops accessing the phone book and disconnects that service. Going back to the main BT screen shows that the only service still active is the headset. I have driven for close to 2 hours with it paired and it never synced.
My theory is around the MINI's being able to handle the @ symbol, as that's mentioned as a possible issue in the PDF for this Sprint network device on the MINIUSA.com/bluetooth webpage. My phone is on Verizon though. When I have time, I'm going to back up and then delete all my phone contacts and put in only a few very simple ones with no email addresses to see if it can sync those.
Thanks for your troubleshooting ideas.
Old May 21, 2010 | 09:28 AM
  #918
schatzy62's Avatar
schatzy62
Sounds like you are correct. And a bummer at the same time.
The contacts transfer should not be looking at the e-mail address as the MINI should tell it what items it can handle. It is only supposed to look at name and telephone numbers. But anything is possible is guess.
I am sure you already know this but remember to back up your contact list so that you can restore it after on a small number.
BTW every contact in my phone, BB Curve, has an @ symbol in the e-mail address and I have no problems.
Just wondering if you have one contact that may have a special character in the name that is causing it to fail. That I could see happening.
Old May 21, 2010 | 12:08 PM
  #919
jsp3's Avatar
jsp3
Got TP2 address book to sync - wasn't obvious
It had nothing to do with how many contacts or any special characters. When I pair for the first time, the phone asks whether to accept phone book access attempts from the MINI. In the previous attempts, I would accept this as you might expect I should. To try something different, I told the phone to reject these attempts. It asked me 3 times in quick succession as it tried to attempt to access my phone book again. Each time I said reject. At the end of that, and after less than a minute, I had all my contacts in the MINI. So it's counter-intuitive and probably a bug somewhere, but I got around it and got it to work. Whew!
Old May 21, 2010 | 12:11 PM
  #920
schatzy62's Avatar
schatzy62
Well that's "Windows" for ya.
Glad to hear yo got it working though.
Old May 30, 2010 | 12:52 PM
  #921
MINILLA's Avatar
MINILLA
It's been a long time since I posted here but I just traded my 2003 Mini Cooper...MINILLA for a 2010 Mini Cooper Clubman.....I believe I got a good deal with the car since it was discounted a good bit.....now it came with BLUETOOTH which I wasn't fussed about but since it's there I may as well use it. I have AT&T as my carrier and I currently have a RAZRV3...I can't get it to pair with the car but that's probably by own 'technologically challenged brain" ...but (1) does anyone have this phone? (2) I am eligible for a free upgrade and would appreciate any suggetsions from fellow AT&T users.
And then there's the whole usage thing...do I just switch the phone on and set it down somewhere in the car (Center armrest) ...can someone explain the principle of how it works in layman's terms.
I'm also having trouble with my MP3 player which is a Sansa Fuze.....does anyone use a Sansa? (as oppose to IPOD) It will connect ok using an AUX lead that I have but if I connect the one that came with the car which also has the USB port I get nothing?
I'm going back to the car handbook now but in the meantime any help from a real person would be great.
Philip
Old May 30, 2010 | 02:21 PM
  #922
MINILLA's Avatar
MINILLA
OMG I just got my phone working...awesome!
Philip
Old May 30, 2010 | 04:20 PM
  #923
schatzy62's Avatar
schatzy62
Glad to hear you got the bluetooth working.
As for using it when you get in the car it should now automatically just connect for you. In fact when you get out of the car it may stay connected after you shut the doors if you do not lock them. This is because the computer that runs it stays on until you lock the doors or shut the car off with the stop start button twice.
As for your other questions about the Sansz you woulod be best served asking this question in a new thread in Nav and AUDIO seciton.
Old Jun 5, 2010 | 10:30 PM
  #924
RJKimbell's Avatar
RJKimbell
The HTC Evo paired with MS MOLY and ALL Contacts were recognized.
Old Jun 10, 2010 | 01:26 PM
  #925
Oski's Avatar
Oski
Now that the iPhone 4 will be coming out later this June, any speculations on whether it'll pair with an R55, R55, or R57?
