Navigation & Audio Bluetooth compatibility list
Thanks for the suggestions so far. If anyone has anymore ideas, I'm willing to listen!
For the sake of full disclosure, it is on the 2011's (at least the ones with Connected, can't be sure about those with just standard Bluetooth)... Been using A2DP to stream Pandora from my Samsung Vibrant (T-Mobile Galaxy S).
Not quite as good as if they'd get Connected working for Android, but beats using a wire.
thanks!
The 'USB for developers' didn't work, and I can't see any autostart software that is obvious. It sure seems like something like that is the problem. I can't imagine why my Nexus can't be seen as a mass storage device if there isn't some sort of software in the way.
It worked successfully for others with large drive sizes. There's a few different options for FAT32. If I remember correctly there was a few PNY thumb drives that were pre-formatted as FAT32, but would only work after a re-format.
Officially from MINI USA A2DP is NOT supported although a few (Very Few) have been able to get it to work.
It comes down to there are so many different firm versions in phones that MINI is having trouble keeping up. Just like the changes that Apple made to iPod/iPhone charging just two years ago. With each change from a manufacturer companies like MINI have to shift gears to make things work again
Another Great example is LG. Back in 2008 they changed their bluetooth software during a firmware upgrade to the Env series phones and bluetooth for many people in many makes of cars stopped working for phone calls and contacts.
Hopefully MINI can work out the problems they are having and can get A2DP working for a lot more people on the "Connected Systems", but at this point I believe it will be years before they get it active for not Connected System cars.
Have you tried plugging into the USB port to see if you can see your music files ? My phone asks me if it should 'Turn on USB Storage' and therefore show up as a mass storage device. I enable it like I would on my PC, but the Mini never seems to see it. Plugging into USB worked fine with my son's iTouch, outside of the whole Mini connected part.
Yep, works with the usb.
For those of you waiting for iPhone 4 snap-ins, richardsperry just posted about a phone call he received from MINI USA. It sounds like they should be in the parts database and available for dealers to order sometime next week:
https://www.northamericanmotoring.co...ml#post3208238
The samsung solstice from AT&T doesn't work either. The phone recognizes Mini blue tooth but when you pair it the phone says connection failed.
I have been reading this thread and have found nothing on the New Palm phones.
(I have only gotten to page 6...) Does anyone know if the palm pre plus works?
I think you'll find the spreadsheet in my sig easier to search than the entire thread
There's mixed reports on the Pre, but most say that it works. Sorry about the Samsung phones, but thanks for the new info.
Thank you! The Eternity is now added.
And the Crux is in the list as well!
Also, I imagine anyone willing to experiment with Android ROMs has probably already thrown caution to the wind, but Cyanogenmod 7.0.0-rc1 pairs, dials and syncs the address book, with a MyTouch Slide 3G in particular.
Black Berry Bold Issue
Hi,
I have a 2009 Clubman. My previous BB Storm worked perfect. Sound in/out was great.
Now have a Bold. And the problem is people can barely hear me and saw there is static.
I have rebooted, upgraded, etc. No change. The phone sends/receives fine with other Bluetooth systems.
Any suggestions? I see it is listed as compatible in this thread.
Thanks.
Jeff
Thanks.
Jeff
So forgive if this has already been discussed, but could not find my wife's new work phone on the list made on the first post on this thread. She just got a new BlackBerry Bold model 9650. Her personal phone, iPhone 3gs, works just fine but the new phone just will not connect in her 09 MCS. Any suggestions?
One thing for you though is that the phone MUST NOT be in "Discoverable Mode". That will make it fail.
Hi,
Thanks.
Jeff
Thanks.
Jeff
And when you say it works fine with other Bluetooth Systems do you mean cars or headsets?
"RIM"?
The Samsung Transform SPH-M920 will now work with the MINI because they have released an update for it which includes "Improved Bluetooth device support".
Already tested and it works.
Phones started to get the update over the air yesterday and will get it till tomorrow... if you still don't have it by tomorrow you can update it manually.
you can read all the details here:
http://support.sprint.com/support/ar...NAV=SU:DP:HDIA
Thanks for the update VMCMDN!
AT&T Motorola Atrix 4G MG860
Pairs and makes calls with '09 Clubman S (no nav). However, phone sends out weird "attempting to access phone book" (or something similar) message every couple of minutes. Also has linked on its own to something else: was playing random music off my iPod--perhaps acting as Bluetooth speakers? I couldn't figure out how to turn this off! It has done this twice.
