Navigation & Audio Bluetooth compatibility list
Old Oct 6, 2010 | 01:54 PM
  #976
gregc's Avatar
gregc
iPHONE V1 & V4 pair up easily with my '10 Clubman.
Old Oct 6, 2010 | 02:28 PM
  #977
kellypgh's Avatar
kellypgh
Hi All,
I've reviewed the great spreadsheet by Nicknbecka which helped immensely with my last phone but am contemplating either the Verizon samsung fascinate (droid platform) or Droid x. It appears that the Droid x is the safer choice however I was wondering if anyone has even tried the fascinate yet.
I may stop by a Verizon store and see if they will let me try it out in my 09 MCS.
Old Oct 6, 2010 | 11:39 PM
  #978
nicknbecka's Avatar
nicknbecka
Originally Posted by kellypgh
Hi All,
So far, all the Android based phones have been pretty much identical in function- it's expected to run Android 2.1, so it should be a safe bet.
Old Oct 8, 2010 | 06:29 AM
  #979
kellypgh's Avatar
kellypgh
...and it is a safe bet! I ended up purchasing the Samsung Fascinate and it's a great phone AND paired nicely with the bluetooth. So far there appears to be no problems at all.
Thanks!
Old Oct 9, 2010 | 01:25 PM
  #980
nicknbecka's Avatar
nicknbecka
Thanks!
Great news! It's now in the list
Old Nov 7, 2010 | 10:22 PM
  #981
BRGeorge's Avatar
BRGeorge
I just got my Droid X today and can't seem to get the contacts list to sync (as shown in the spreadsheet). Is there something I'm doing wrong/not doing?
Old Nov 7, 2010 | 11:52 PM
  #982
nicknbecka's Avatar
nicknbecka
Have you been able to get it to pair at all? Can you dial or answer calls with it otherwise?
Old Nov 8, 2010 | 05:39 AM
  #983
schatzy62's Avatar
schatzy62
There are two paring modes on the Droid X. It has to be in the right mode to pair properly and then transfer.
Also of note is that on the Droid X only contacts in the "Phone Contacts List" will transfer. You will need to make sure that in the contact that one of the "Linked Contacts" is listed as "Phone Contacts". All other contacts that are listed as Facebook, Skype or some other Social Networking will not show up if they do not also have a "Phone Contacts" Linked Profile.
Old Nov 8, 2010 | 04:51 PM
  #984
BRGeorge's Avatar
BRGeorge
Strangely enough, I got back in my car today and the phone's contact list synced up fine without any further changes by me. Strange, but at least it is working now.
Old Nov 13, 2010 | 09:26 PM
  #985
minicooperwill's Avatar
minicooperwill
Has anyone heard if any of the new Windows Phones are bluetooth compatible with the MINI? I'm thinking about switching over/upgrading from my iPhone 3G to the new Samsung Focus, but if it isn't going to work in my car...
Old Nov 16, 2010 | 01:05 PM
  #986
mikemc's Avatar
mikemc
great write up.. been following it for a while to see all the updates, thanks everyone for there time...
My issue: ok I got my HTC Incredible to pair with the bluetooth no problem... I can not seem to sync the address book though.The spreadsheet indicates this is possible but the NAM member did not specify if they indeed sync'd the address book or not nor have i found any post saying this was done. I have the factory Nav installed and can not. can anyone confirm who has this phone if this can be done?
Old Nov 22, 2010 | 03:30 PM
  #987
snowie13's Avatar
snowie13
I have the new Windows Phone Samsung Focus. The address book sync'd up and loaded to Nav (displays name followed by number and if it's (h) or (m)). It sync'd up without any problems and I have made called and received calls using the bluetooth.
Old Nov 23, 2010 | 10:18 PM
  #988
nicknbecka's Avatar
nicknbecka
Thank you!
Old Dec 24, 2010 | 06:38 AM
  #989
Alexander!'s Avatar
Alexander!
Finally got my nexus one (froyo) working. Took me about an hour to figure out that it would only pair with when the mini sent the code 0000. But now it works great! Anyone else know if 0000 is the standard code for all android phones?
-Alex
Old Dec 24, 2010 | 10:13 AM
  #990
nicknbecka's Avatar
nicknbecka
My 3G Slide will pair with a random code. But if a device has a fixed code, in my experience 0000 is usually it. Thanks for the info!
Old Jan 23, 2011 | 01:08 PM
  #991
DrJBear's Avatar
DrJBear
Anyone have an LG Optimus S or Optimus T (LS670)? I am about to call Credo and ask if I can dump the Samsung Transform for something different...
DrJBear
Old Jan 26, 2011 | 03:51 PM
  #992
azOrange's Avatar
azOrange
-Alex
Alex,
Are you able to stream music through bluetooth ? My phone claims that it is doing it, but nothing comes out of the audio system of the Mini.
I've also tried plugging my Nexus One into the USB port, but it doesn't even recognize it. Same with my wife's phone, which is a Nexus One as well.
thanks!
Old Jan 26, 2011 | 04:39 PM
  #993
Alexander!'s Avatar
Alexander!
azOrange - All I can really do is make phone calls. I couldn't even get my address book over, actually. The first time I used the GPS on my phone it started right up through the cars speakers (I was very excited) but then went back to the phone's sound after about a minute. So, I'm betting it should work with music too but I'm waiting until gingerbread comes out to really start fooling around with it.
Old Jan 26, 2011 | 04:50 PM
  #994
azOrange's Avatar
azOrange
My wife and I are both able to see our address book, which is convenient. I think there might be an 'office' setting that you have to enable on the Mini side.
Have you tried plugging into the USB port to see if you can see your music files ? My phone asks me if it should 'Turn on USB Storage' and therefore show up as a mass storage device. I enable it like I would on my PC, but the Mini never seems to see it. Plugging into USB worked fine with my son's iTouch, outside of the whole Mini connected part.
Old Jan 26, 2011 | 09:11 PM
  #995
nicknbecka's Avatar
nicknbecka
I'm not 100% certain about MINI Connect equipped cars, but for factory nav cars that are pre-connect there aren't any car-side adjustments to make once the pairing has been done. Most Android based phones sync the address book correctly.
@Alexander, which phone are you using that doesn't sync the address book?
Are you using the MINI provided cable with the Nexus? It has some Apple/iPod specific hardware built into it that probably cause problems for a standard USB connection. The MINI doesn't support A2DP Bluetooth connections, so you're limited to a wired connection for music.
On an unrelated note, the MyTouch 3G Slide running CyanogenMod 6.1.1 syncs the address book and works correctly for dialing.
Old Jan 27, 2011 | 06:00 AM
  #996
schatzy62's Avatar
schatzy62
Alex,
A2DP Bluetooth Streaming of music is not supported by the MINI
thanks!
There may be a number of reasons why this is not working.
1. SD card MUST be formatted as FAT If not it will not work with the MINI.
2. Make sure under "Settings > SD Card & Phone Storage" the SD card is "Mounted" while NOT connected to the MINI
3. USB Debugging may need to be turned on or off "Settings > Application Settings > Develpoment > USB Debugging"
Also of note is that if the phone is using the SC card for its contact list then when you connect it to a computer or the MIN the phone will no longer be able to see the contact list as only one device can use the SD card at a time, I.E. the phone is mounted to the car or the computer is mounted to the card.
Old Jan 27, 2011 | 08:58 AM
  #997
InvaderZim's Avatar
InvaderZim
I have an Acer Liquid E (running on Rogers in Canada) and it pairs perfectly with the MINI.
I have also installed a Parrot Minikit Smart which is BT enabled, but it is paired only with the phone as an audio-out device (like headphones), not with the MINI. Incoming calls are handled by the MINI, but turn-by-turn navigation is sent to the Parrot's speaker. Slick.
Old Jan 27, 2011 | 12:01 PM
  #998
azOrange's Avatar
azOrange
Thanks schatzy62. On #1, when mounted to my PC the properties say FAT32, so I assume I'm OK there. I'm OK on #2, and on #3 I'm currently set to USB Debugging disabled. I'll let you know how that goes.
Old Jan 27, 2011 | 12:23 PM
  #999
schatzy62's Avatar
schatzy62
Yes Fat 32 is okay.
Check the card to make sure there is no AutoStart Software for some reason.
I know on some USB sticks such as the Sandisc Cruizers there is some OEM software that make them not work with the MINI. Once that software is removed they work great.
Old Jan 27, 2011 | 07:16 PM
  #1000
grueinthebox's Avatar
grueinthebox
For the sake of full disclosure, it is on the 2011's (at least the ones with Connected, can't be sure about those with just standard Bluetooth)... Been using A2DP to stream Pandora from my Samsung Vibrant (T-Mobile Galaxy S).
Not quite as good as if they'd get Connected working for Android, but beats using a wire.
