Interior/Exterior LEDs installed in our R56
Old Aug 5, 2007 | 10:22 PM
  #101
Robin Casady's Avatar
Robin Casady
Converting the back into a cargo only area. Putting in a floor over the seat area, sound insulation, replacing the 6x9 speakers with Infinity Kappa 693.7i and relocating them in a dedicated cabinet (they would be sealed off in the cargo area).
Old Aug 5, 2007 | 10:40 PM
  #102
MLPearson79's Avatar
MLPearson79
Man...I really want to Dynamat the whole car but having alllll that off at once is just scary.
Old Aug 14, 2007 | 09:48 AM
  #103
MLPearson79
Okay my set (for my R50) came today, and I have a question.
I have 2 sets of 2 bulbs and I can't figure out which goes where (I figured the others out based on how many there were).
I have 2 white-based 194s with panels around the sides and one on top. And then I have 2 clear-based 194s with the clear bulbs sticking out the sides and one on top. I know one set is for the footwells and one is for the puddles, but which goes where?
Old Aug 14, 2007 | 02:53 PM
  #104
Mach V Dan's Avatar
Mach V Dan
You can try yourself, but I think I liked the clear-base ones best in the footwells, and the cubish-shaped ones in the puddle lamps. I'm sure I figured out some logic behind this before, but I can't remember right now, to be honest.
But they're interchangeable, so if you like them the other way, that's fine.
--Dan
Mach V
FastMINI.net
Old Sep 3, 2007 | 04:55 PM
  #105
sirr6's Avatar
sirr6
what kit did most of you buy? the 69.00 or 96.00 kit? im thinking about the 69.99 but are those the same ones as pictured on the 1st post?
Old Sep 3, 2007 | 09:26 PM
  #106
Robin Casady
I went for the $96.00 kit.
Old Sep 3, 2007 | 09:31 PM
  #107
Robin Casady
--Dan
Mach V
FastMINI.net
It looked to me like some of them directed light out the end of the bulb (cubish-shaped, I think) and others were like a pinwheel of LEDs that shone out the sides. The pinwheel bulbs seemed best suited to puddle and footwells. I figured the end-lights would be best in the reading lamps, but I left those stock, so I didn't really check the bulb orientation.
Old Sep 4, 2007 | 10:10 AM
  #108
Birdman's Avatar
Birdman
Robyn,
Did you already fabricate some of the "new" floor just behind the front seats in that picture?? What are the two black circles in that angled floor, behind the front seats? Is that where you are mounting the subs or something, or is that already in the car standar.... and what are they? They look like cutouts covered in rubber...?? (in pic before you dynamat....).
Old Sep 4, 2007 | 11:14 AM
  #109
Robin Casady
Originally Posted by Birdman
Robyn,
Batman,*
You mean this picture?
Those black disks are stock. They are steel painted black. I assume the have to do with something under the car. Perhaps they are access ports of some kind. Although I covered them with Dynamat, I made it easy to remove them.
*no "y" in Robin.
Old Sep 4, 2007 | 01:13 PM
  #110
Birdman's Avatar
Birdman
Gotcha, I'm duckin back into the "Bird Cave"!!!
Ya shoulda took them off to see what's behind them, they look like perfect 8 or 10" subwoofer mounts!!! ;-)
Just installed my Blue LED's, can't wait for it to get dark to check em out!!
I did not install the MAP or Glovebox lights. I want them to be bright when needed (which is what they are for). Has anyone acyualy done the glovebox one? How dim does it make it? Can ya still see what's in there?
Old Sep 4, 2007 | 01:39 PM
  #111
a96bimmerm3's Avatar
a96bimmerm3
Believe they're for gas tank access for fuel pump(s) and stuff.
Old Sep 4, 2007 | 01:53 PM
  #112
Robin Casady
I took enough stuff apart. I doubt there is much room below them. I think they are access ports to something over the gas tank.
I'm not planning on adding subs. My home theather/audio system includes an SVS sub that is the size of a small water heater. However, I don't feel the need for it in the MINI -- not trying to rattle the car next to me.
I installed red in the glovebox. It seems bright enough. I left the map lights stock for the same reason you did.
Old Sep 5, 2007 | 12:22 PM
  #113
Bucky1969's Avatar
Bucky1969
There is no way I would ever get the blue light package now, after scUM losing to App. St. Saturday, I would be embarrassed to have anything blue. So, I guess you can say it is NO Go Blue! anymore.
Old Sep 6, 2007 | 07:29 PM
  #114
Mach V Dan's Avatar
Mach V Dan
I...I hadn't thought of the idea of matching your interior lighting to (or against) your sports team...
--Dan
Mach V
FastMINI.net
Old Sep 8, 2007 | 03:33 PM
  #115
Birdman's Avatar
Birdman
I installed the blue LED a few days ago, takes 5 minutes to pop em in (minus the maps which I'm leaving white). Daytime, barely notice them (ya couldn't notice the white ones either). So I say, ok, big deal, got blue lights, anywhoozle.
Skip a few days, forgotten led lights. First time I get in MINBIRD at night sice the install, BINGO!!! COOL BLUE!!! WOW, REALLY cool looking. I took some shots last night. Will try and post a few. Really looks cool with the Nav screen on. I live on the water, so most of the map screen is blue (water) so it all comes together.
Old Sep 11, 2007 | 07:03 PM
  #116
Mach V Dan's Avatar
Mach V Dan
Just following up...got some pics to show us?
--Dan
Mach V
FastMINI.net
Old Oct 1, 2007 | 03:16 PM
  #117
buckoa's Avatar
buckoa
OrneryDSMini - you crack me up. I am in the same boat...hopefully taking delivery of my new mini in a week or so and the custom gear is building up.
Wheels
Replacement stubby aerial
Custom stripes
Debating the carbon air intake filter
On the fence with respect to this lighting. i guess i need to see the factory lighting or maybe Mach V Dan you can post a picture of the original to appreciate the different
Old Oct 1, 2007 | 06:17 PM
  #118
Mach V Dan's Avatar
Mach V Dan
This isn't the MINI, but this is a photo of my Subaru Legacy before and after replacing the stock interior lighting with LED units. Same camera, same exact exposure.
--Dan
Mach V
FastMINI.net
Old Oct 1, 2007 | 06:19 PM
  #119
Birdman's Avatar
Birdman
Pictures as primised. Blurry and bad pics, but you get the idea.
Sorry the first is so "jiggly", I was on final approach on runway 330L!!
More in my gallery
Old Oct 3, 2007 | 03:13 PM
  #120
Mach V Dan's Avatar
Mach V Dan
Pictures as promised...
Pic 3 shows rear shield collapsing! Warp factor 2!
--Dan
Mach V
FastMINI.net
Old Oct 4, 2007 | 04:43 PM
  #121
MWH's Avatar
MWH
Hey all, I bought a set of blue LEDs a while back (thanks Dan!) and they were a snap to install, except for the footwells. I can get the cover off on one but can't extract the bulb, and can't even get the cover off on the other. Can anyone give me some pointers? Thanks.
Old Oct 5, 2007 | 10:43 AM
  #122
Mach V Dan's Avatar
Mach V Dan
The cover can be stubborn. I just use a small flat-blade screwdriver and gently pry until it pops loose. It may take more force than you'd expect.
For the bulb, just push it gently sideways with a finger, or a non-conductive tool of some sort.
--Dan
Mach V
FastMINI.net
Old Oct 6, 2007 | 04:57 PM
  #123
Dave@ddmworks's Avatar
Dave@ddmworks
Manufacturer
Dan,
Those lights look great! Good job!!
Old Oct 7, 2007 | 10:32 AM
  #124
MWH's Avatar
MWH
Got them! Thanks. For the footwells and map lights, I had to make loops of electrical tape, thread them around the bulbs, and squeeze them to get the bulbs out.
Old Oct 8, 2007 | 09:05 AM
  #125
Mach V Dan's Avatar
Mach V Dan
Cool. Good tip.
--Dan
Mach V
FastMINI.net
