Interior/Exterior LEDs installed in our R56
Old Apr 13, 2010 | 12:07 PM
  #251
Robin Casady's Avatar
Robin Casady
I installed the red kit sometime ago. I'd like to change the dome light back to white. What is the difference between 06610, and 05665 in white?
Old Apr 15, 2010 | 08:07 PM
  #252
dj.papazian's Avatar
dj.papazian
anybody kno what size bulb the map lights are??
Old May 1, 2010 | 12:35 PM
  #253
gagamel's Avatar
gagamel
T10(W5W, 194....) bulb.
Check out my post
https://www.northamericanmotoring.co...ulb-types.html
Old May 10, 2010 | 03:06 AM
  #254
swooshmac's Avatar
swooshmac
help.. anyone know where the fuse is for the interior lights? inside near the passenger front or in the engine area? thanks. trying to hook up some LEDs under the car to come on when i open the car and when i start the car they can fade out like the interior lights do. thanks.
Old May 10, 2010 | 03:22 PM
  #255
Robin Casady
Check out this thread:
https://www.northamericanmotoring.co...not-fuses.html
Old May 11, 2010 | 02:24 AM
  #256
swooshmac's Avatar
swooshmac
Originally Posted by Robin Casady
thanks Robin
Old Jun 22, 2010 | 02:22 AM
  #257
swooshmac's Avatar
swooshmac
having trouble getting the cover off the dome light on the R57 cabrio.. anyone took their's off before? and if so, what kind of bulb inside? 194 or 6411? thanks
Old Jun 22, 2010 | 02:28 AM
  #258
swooshmac's Avatar
swooshmac
Originally Posted by zanary
So, here is our answer.
YES they work prefectly in the new R57. Go ahead and purchase the
"Budget LED Interior Lamp Kit (2007+ Cooper and Cooper S). Nine LED replacement bulbs, including a conventional (not a panel) LED for the dome lamp. $69.99"
That's what I purchased a week or so ago, and just finished installing them. The SuperWhites look awesome. Installing them in the overhead dome light, and the two map lights took some time to figure out, but it's so easy. Just grab the center unit as you were going to hold a large pie. Pull towards you bit, and then down. The entire center unit will slide right off. Disconnect the two cables, and then turn each bulb socket to remove the bulb, and replaced with the LED. The puddle lights and the rear boot light are just like the R56.
Now for the more important questions... How do you replace the footwell lights? I was able to remove the plastic cover, but the bulb isn't easily removed. Any ideas?
hey zanary,
i have a 2009 cabrio too. for the footwells, just pop off the light covers, then detach from the connector. then turn and the bulb slides out and you can change it. i was having trouble with the dome light cover, but i will try what you posted on removing it. thanks.
Old Jun 24, 2010 | 06:56 PM
  #259
BRGminime's Avatar
BRGminime
Pic of the super white LED inb a R57?
Zanary any pictures to share
Old Jun 25, 2010 | 01:43 AM
  #260
swooshmac's Avatar
swooshmac
nice ride, BRGmini
Old Aug 17, 2010 | 01:59 PM
  #261
CThoma031's Avatar
CThoma031
You can find the kits HERE.
--Dan
Mach V
FastMINI.net[/QUOTE]
Hey hopefully you still watch this thread in your picture of the blue lighting you have was that just the "Budget LED Interior Lamp Kit" or a combo of that with "LED Dome Lamp Panel - 2007+ MINI
Super-bright multi-LED panel"
Sorry I'm new to the lighting and electrical stuff with MINIs
basically I want my car to have as much blue as you can.....
Old Aug 18, 2010 | 11:28 AM
  #262
BEAVR's Avatar
BEAVR
too much blue and the police will stop you.
I had to swap mine to white when I got too extreme.
check your state laws to see which colors are legal to be exposed outside of the cabin (or brightly out the windows).
Old Aug 18, 2010 | 12:06 PM
  #263
CThoma031's Avatar
CThoma031
Oh I don't have any blue outside and won't have it on if I'm driving but you will see it when I open the doors which is stupid to get in trouble for but I understand.
Old Aug 16, 2011 | 07:58 AM
  #264
gothmdoc's Avatar
gothmdoc
Hey Mach V Dan,
I finally received my super white LED kit for my 2009 R56, but no instructions or sheet. Is there supposed to be one? Or is it pretty easy to figure out which one goes where once I open up all the lenses?
Thanks.
Old Aug 31, 2012 | 02:03 PM
  #265
pjdaustin's Avatar
pjdaustin
HOw do you remove the map light bulb lens on the R56 Mini ? Thanks.
Old Feb 27, 2013 | 12:54 AM
  #266
Danielng0811's Avatar
Danielng0811
How to change the front reading bulbs
Hi,
Does anyone can help me? Today, I changed almost all the dome bulbs to leds but I could not figure our how to remove the reading light of both the driver and front passenger. I mean the one at top with some switches.
Thx!
Old Feb 27, 2013 | 01:20 AM
  #267
swooshmac's Avatar
swooshmac
Originally Posted by Danielng0811
Hi,
Thx!
hey dude.. you mean you can't take the bulbs out or you can't get into the plastic housing to get to the bulbs?
Old Feb 27, 2013 | 02:03 AM
  #268
Danielng0811
Can't get into the plastic housing please
Old Feb 27, 2013 | 02:25 AM
  #269
swooshmac's Avatar
swooshmac
you need to grab the housing and pull to the inside of the car, it pops off. just don't pull too hard cause it is connected by wires inside. This is the housing above the rear view mirror where the switches are for reading lights, right? Cause I changed mine to LED green bulbs too and that's how I got into it. There is a thread here somewhere about changing interior lights. that's where I got the info from and tried it. good luck
Old Feb 27, 2013 | 11:27 AM
  #270
Danielng0811
Got it Thousands of thx!
Old Apr 28, 2016 | 10:14 AM
  #271
Doopie's Avatar
Doopie
Originally Posted by MotorMouth
No way I could do red.
It would remind me too much of my days on a submarine while at periscope depth!
The blue is pretty darn cool though!
Another bubblehead looking for a tight space.
SSBN 631 Scotland
SSN 695 Peaarl Harbor.....
MM2/SS
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
