Drivetrain CAI for R56 (home made)
Old Jun 12, 2008 | 04:04 PM
  #601
ShaggyMike's Avatar
ShaggyMike
i just got done installing mine. it was easy, took about 45 minutes and it sounds great when you really get on it...
Old Jun 12, 2008 | 04:20 PM
  #602
pillar's Avatar
pillar
that was my identical setup... cept i changed my cuz it still bounces and i can hear it rattle against the airbox...
if that bothers you as much as it does me... and you decide to change it up... tel me! go trueflow!
Old Jun 12, 2008 | 04:31 PM
  #603
ShaggyMike's Avatar
ShaggyMike
mine is pretty solid, I dont hear it rattle at all.
Old Jun 12, 2008 | 08:16 PM
  #604
pillar's Avatar
pillar
then it must be my maf rubbing against my strut bar.... damn my strut bar
Old Jun 13, 2008 | 04:23 AM
  #605
tachicardia's Avatar
tachicardia
it could be the tube after the MAF (that heads to the turbo) knocking into that thin tube that lies on top of it... you can see it in the photo above. It is 'connected' to the air box intake tube and can knock into a few different things in the engine bay. You can zip tie it or something and see if that solves your problem.
Old Jun 13, 2008 | 07:25 AM
  #606
pillar's Avatar
pillar
as a matter of fact... my 90degree tube is zip tied onto the bottom part of the air box... there is a place where it is pretty stable.
i know for a fact that my maf is rubbing because i looked at the underside of my strut bar and it is all worn down from where it rubbed.
Old Jun 27, 2008 | 10:20 AM
  #607
a4autocrossr's Avatar
a4autocrossr
just got my AEM dryflow filter in the mail and will put it on tomorrow. pretty stoked
--E
Old Jun 30, 2008 | 02:04 PM
  #608
a4autocrossr
so after driving around for 2 days with it on i'm noticing a lot of lag low in the rpm range....is this a 'just deal with it' thing or is there something i should do,..aka open up more of the scoop holes or something else to reduce this. mpg went down .5mpg too, but thats cuz i was shifting later to hear the bov..lol..sounds a bit ricey but its ok for now.thanks
--E
Old Jun 30, 2008 | 04:58 PM
  #609
ThumperMCS's Avatar
ThumperMCS
--E
I never really noticed the lag too much, until I switched over to a DDM Street Intake. The car drives MUCH better with the DDM intake than it did with the DIY K&N. Seems to have really picked up in the low rpm range where you are talking about.
I'd definitely open your hood scoop though.
Old Jul 1, 2008 | 08:22 AM
  #610
tedbone72P's Avatar
tedbone72P
--E
I also noticed this with my initial setup using a less expensive filter from Spectre. I then changed to a K&N filter with a silicone 3" elbow and opened up the scoop (i.e. removing the OEM grill and bending and cutting the sheet metal wide open) and then I noticed an increase in the low rpms (improved from OEM intake setup)
Old Jul 12, 2008 | 05:01 PM
  #611
sir5150's Avatar
sir5150
Here is my attempt at a cai, k&n stlye filter 90 deg elbow and some billet work
Old Jul 12, 2008 | 05:13 PM
  #612
fongaroos's Avatar
fongaroos
that looks awesome!!!
Old Jul 21, 2008 | 08:46 AM
  #613
TBMINI's Avatar
TBMINI
Anybody know where I can find a 90 degree bend reducer from 3" to 2.75" in RED I've seen all the black and blue but can't seem to find any red in that sizing!!! Any help?
Old Jul 21, 2008 | 11:11 AM
  #614
sir5150's Avatar
sir5150
Try www.hosetechniques.com
Old Jul 21, 2008 | 01:22 PM
  #615
TBMINI's Avatar
TBMINI
Dang! they only have black and it cost like $65 buck thanks for the suggestion though! any others?
Old Jul 21, 2008 | 02:30 PM
  #616
pillar's Avatar
pillar
siliconeintakes.com
they have the cheapest ones i could ever find... 19.99 but only in blue and black
Old Jul 21, 2008 | 02:46 PM
  #617
TBMINI's Avatar
TBMINI
yep may just have to go with the blue... thanks
Old Jul 21, 2008 | 02:47 PM
  #618
tachicardia
samco hoses
http://www.samcosport.com/usa/rp_elbow_reducers.asp
Old Jul 21, 2008 | 02:57 PM
  #619
TBMINI's Avatar
TBMINI
well they have red hoses but unless i missed it i don't see 3" to 2 3/4"
Old Jul 21, 2008 | 03:05 PM
  #620
tachicardia
Honestly I didn't even look through the item list, I though SAMCO had every size and color. I would assume, though, that the 3 1/8 to 2 3/4 should work...
Old Jul 22, 2008 | 06:45 AM
  #621
TBMINI's Avatar
TBMINI
Yeah it might work. My only concern is that if i were to use a 3" joiner would I be able to tight tighten the 3 1/8" silicone down onto the joiner? It's only a 4mm difference from 3" but i don't know how giving silicone is...
Old Jul 22, 2008 | 06:51 AM
  #622
tachicardia
If you had to have red and you can't find it anywhere else, it will work just fine. If the samco hose is anywhere near as pliable as the one I got from siliconintakes, you shouldn't have a problem.
Does k&n make a 3 1/8" filter? Can you find a 3 1/8" OD joiner?
Old Jul 22, 2008 | 06:57 AM
  #623
TBMINI's Avatar
TBMINI
I'm actually going to go with the AEM Dryflow 3" and i can't find a 3 1/8" joiner but i'll keep searching. thanks for all the help...
Old Jul 22, 2008 | 10:37 AM
  #624
Mini'mon's Avatar
Mini'mon
Red 3" to 2.75" Reducer Elbows are available
Check out:
http://tinyurl.com/5zcjkw
and
http://www.fixthisride.com/showprodu...prod_id=155259
and
http://tinyurl.com/54snkq
Old Jul 22, 2008 | 01:21 PM
  #625
TBMINI's Avatar
TBMINI
wow great thanks... dang wish the where as cheap as siliconeintakes. Thanks
