Drivetrain should i: mcs spark plugs in a cooper????
Old May 5, 2006 | 09:10 PM
GMINIO's Avatar
GMINIO
got these oe mini cooper s plugs from the jcw'd mc40 i just totalled. i'm due to pick up my spankin new cooper soon. are the mcs ngks a recommendable upgrade? how about the rear mcs sway to a non-plus'd cooper?
Old May 6, 2006 | 12:50 AM
XAlfa's Avatar
XAlfa
Sway bar: Yes.
Plugs: Why?
Old May 6, 2006 | 06:23 AM
namwob's Avatar
namwob
Are the plugs the same heat range as NGK BKR 6 EQUP?
Old May 6, 2006 | 07:16 AM
qwertmonkey's Avatar
qwertmonkey
DEFINITLY use the sway bay. If you have to pay for it, buy an even better one off of ebay or something. That will make a huge difference. (IMHO)
Old May 6, 2006 | 07:42 AM
dominicminicoopers's Avatar
dominicminicoopers
What did you do to the car to require a colder plug? Are you boosting the car? Did you change your compression ratio?
Old May 6, 2006 | 08:14 AM
GMINIO's Avatar
GMINIO
This car is off the lot, dominicminicoopers. The plugs from the totalled MCS's delivery day are in my kitchen. I'm moving. So things are being used or tossed out/packed away. Not sure there is even anything to gain by installing them in a NA motor, but by the sounds of your responses, it's unlikely.
Old May 6, 2006 | 03:25 PM
dominicminicoopers
The plugs you have in the cooper are optimized for the cooper engine. The MCS ones will be too cold of a range and probably will cause poorer performance since they won't ignite as much of the fuel, or even cause a misfire/stumble.
Old May 7, 2006 | 05:11 PM
GMINIO's Avatar
GMINIO
gotcha, ty.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
dscott90000
Aug 21, 2015 07:07 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
