Drivetrain Aquamist HFS Methanol Injection Systems
Old Jun 4, 2014 | 02:59 PM
  #176
wzabrouski's Avatar
wzabrouski
I am thinking I might need more meth? PIR currently on 12.
Old Jun 4, 2014 | 03:11 PM
  #177
cerenkov's Avatar
cerenkov
If you're running 100% meth then I would have to agree that you probably need more flow with the JB+ at 70%
Old Jun 4, 2014 | 03:15 PM
  #178
wzabrouski's Avatar
wzabrouski
What are the dangers or running too much meth? I know I can adjust flow with the gain dial, I just hate the trial and error. I am sure I am better off running too much meth rather than not enough? I guess my question is where is the sweet spot?
Old Jun 4, 2014 | 03:16 PM
  #179
wzabrouski's Avatar
wzabrouski
Originally Posted by ra2fanatic
This was how I had mine set up for a while. I think I've adjusted the P/I-R since then.
I noticed you had P/IR adjusted for more flow here. Were, are you tuned?
Old Jun 4, 2014 | 06:01 PM
  #180
luigi90210's Avatar
luigi90210
Originally Posted by NewCooperFanatic
I ran it at 100% with meth, but honestly, the boost is just too high for the little turbo.
And quiet frankly, as weird as this sounds, the car just feels better at lower settings.
At 100%, it feels like an on/off switch. The transition into boost is not seamless....if that makes sense.
well the boost can be high but as long as we are within its compressor rating, the turbo will be fine
I dont know what the max boost this thing can push before its just blowing hot air so i cant comment on people running the boost too high
Old Jun 4, 2014 | 07:12 PM
  #181
cerenkov's Avatar
cerenkov
I believe you said that you running mostly off boost signal and not IDC. If this is true, this might be an issue. New Cooper Fanatic had issues running to much boost bias, IIRC.
Also at what psi do you start spraying?
Old Jun 4, 2014 | 07:37 PM
  #182
wzabrouski's Avatar
wzabrouski
Jeff had me switch from IDC mode to MPS due to getting a burst of meth upon startup while in vacuum which was causing the car to stall. I start spraying around 7-8 depending on how much gas is given.
Old Jun 5, 2014 | 09:20 PM
  #183
wzabrouski's Avatar
wzabrouski
Did some data logging tonight? No drop in intake temps??
Old Jun 6, 2014 | 09:25 PM
  #184
wzabrouski's Avatar
wzabrouski
Spoke with Jeff today. Made some adjustments, bumped the jet to a .7 and I think I am good to go.
Old Jun 7, 2014 | 04:56 AM
  #185
cerenkov's Avatar
cerenkov
Have you retried it with the JB+ turned up?
Old Jun 7, 2014 | 05:17 AM
  #186
wzabrouski's Avatar
wzabrouski
Not yet
Old Jun 7, 2014 | 06:29 AM
  #187
wzabrouski's Avatar
wzabrouski
I was thinking about it. I am also running an auto so my settings will probably have to be different than a manual. At least possibly thres, PI/R or gain.
Old Jun 7, 2014 | 07:15 AM
  #188
cerenkov's Avatar
cerenkov
Why's that?
(I also have an auto)
Old Jun 7, 2014 | 12:12 PM
  #189
wzabrouski's Avatar
wzabrouski
I figured the point of activation might be different.
Old Jun 7, 2014 | 03:51 PM
  #190
scubbysnacks's Avatar
scubbysnacks
If your running straight Meth and have a .8 jet throw that in then you'll see your iat's drop. I'm running 50/50 W/M using a .7
Old Jun 7, 2014 | 03:54 PM
  #191
johntotah94's Avatar
johntotah94
Anyone running a .8? Or will that be too much meth spraying to reduce power.
Old Jun 7, 2014 | 05:25 PM
  #192
Phipu91's Avatar
Phipu91
I'm running .8 without a restrictor and have no problems so far. I'm also Manic tuned.
Old Jun 7, 2014 | 06:20 PM
  #193
johntotah94
I might test the .8 out. Car produces a lot of heat on stock turbo at about 19psi.
Hope I can get my upgraded turbo soon. Just concerned if .8 was too much.
But if your running it I'll give it a shot.
Old Jun 7, 2014 | 06:30 PM
  #194
johntotah94
Anyone else run the .8?
Will try it when I get home from work. I'm at .7 right now. Just want to know your thoughts. Has it made your car bog or anything? I'm run 100% meth.
Old Jun 7, 2014 | 07:49 PM
  #195
wzabrouski's Avatar
wzabrouski
Did the kit come with a .8? I only had the .6 and .7.
Old Jun 7, 2014 | 08:07 PM
  #196
cerenkov's Avatar
cerenkov
I got 3 jets: 0.6, 0.7 and 0.8
and
3 restrictors: 0.5, 0.7 and 0.9
Old Jun 10, 2014 | 10:06 PM
  #197
wzabrouski's Avatar
wzabrouski
Changed to the .7 jet and I am seeing a huge difference in drop of AIT. Today it was high 80, and the temps would drop to the high 60s quickly.
Old Jun 11, 2014 | 10:15 AM
  #198
Go-Cart's Avatar
Go-Cart
Jet size
So is it safe to say that the .7mm jet is having the most success as far as cooling intake temps? Also a mixture of 80% methanol and 20% water?
Old Jun 11, 2014 | 11:33 AM
  #199
wzabrouski's Avatar
wzabrouski
I am running the .7 jet with 100% meth right now.
Old Jun 11, 2014 | 12:10 PM
  #200
cerenkov's Avatar
cerenkov
I'm going to switch to the 0.7mm (from 0.6mm) and see what happens.
