Drivetrain Aquamist HFS Methanol Injection Systems
There was a research paper released by the navy where they compared anodized aluminum, aluminum, nickel plated steel and steel (let me search for the link to the article) and the outcome basically was that the deterioration rate of anodized aluminum was very minimal when left sitting in methanol for long periods of time. Aluminum that was not anodized deteriorated quicker but not too much. These tests were done by placing the materials in methanol and left sitting for long periods of time which is not happening when we inject methanol as a fine mist which evaporates.
You can buy Aquamists basic set up and I believe you can convert your wiper washer fluid reservoir into the meth tank so it's under the bonnet.
On my 2010, I have hit 14.1 psi on a hot day on the stock tune. 13.9 was pretty regular at moderate temps.
Sent from my Nexus using NAMotoring
I have seen 14 on an average, 12-14psi stock. I will keep monitoring. However, Cerenkov: you were on point. 90 deg today w/40% humidity. Saw timing up to 6 deg, w/IAT hitting as low as 13deg below ambient. And staying at ambient in regular traffic. Sweet👍
Just installed this kit. Everything seems to be working properly. Right now, cleaning my windshield with only the purest water. I would like to set up fail safe being meth will be an integral component of the map (22.5 psi) I will be running. Anyone set this up yet?
From what I see:
1. cut the wastegate wire from ecu and splice the brown and white wire from gray harness.
2. Calibrate flow bars on gauge
3. Calibrate wl and wh dials on gauge.
4. Set jumper in cel dr1
I think that's it. Sounds simple enough.. I guess. Any additional thoughts?
From what I see:
Ok. I'll Ping Jeff on this too. Hopefully have it going by tomorrow.
The failsafe is up and running. No cels and it cuts the boost like it should. Now I just need to fine tune. Jeff has been really helpful. Here's a link he sent me. http://howertonengineering.com/tech-...dds3-failsafe/
I think an issue people are having (throwing a cel) is they are using the wrong wire to the wastegate valve. The picture illustration of the wire from the gray connector appears to be orange where as it should be brown. The instructions state brown for our type wastegate and say orange for another application. So, I see where someone would get thrown. One of the threads I saw said they were using the orange wire which is wrong. Of course, they were throwing a cel.
ok. I installed the jet in the intake tube and have been testing. I am not seeing that much drop in IAT. Compared to most of you, I am way above in IAT's! Before the Meth kit I was seeing 30-40 deg. over ambient at the top of 4th gear and 19.5 PSI. Now, I am seeing 20-25 deg above ambient at the same. I expected to see at least ambient numbers at the IAT, but 20 deg above? The mini is running a hybrid turbo, so now I am thinking its running out of efficiency and blowing a lot of hot air the spray can't keep up with.
Here is what I am running:
.8 Jet measured 350cc
everything at 12 O'clock
SC set properly to 6 bars
System purged
No matter how much gain (full clockwise) I throw at it doesn't seem to make much difference.
When I was testing the system with the jet on the windshield, I didn't notice much progressive ramp up in spray when going through the boost/rpm. It was very subtle. I have it coming on at 10psi. It certainly comes on at 10psi as its dowses the window good.
Thoughts? Am I expecting too much with this? I am going to call Jeff tomorrow and see what his thoughts are.
System purged
What were the outside humidity levels like? (wet bulb temperature is actually what's important but dew-point will give you an idea). I find that is a huge factor in how much IATs drop.
Without the methanol I would see 20F above ambient. Then with methanol on a dry day I would see 25F below ambient, so that equates to a 45F swing. On a sticky day maybe only a 30F swing. But no matter, I'm always below ambient.
Your resulting temperatures will be different because of your higher boost pressures but you should see a 30F - 45F swing.
When you had the jet on the windshield, did you notice the progressive nature of the spray with more load? Have you adjusted gain and noticed any diference with that?
Temp Effects
]OK so I bought a GoPro and made this quick video of the temp effect of water/meth on the MINI Cooper (and Forced induction in general).
Please for give my video making skills (or lack there of) as this is my first time with the GoPro, YouTube and Video Editing.
But you can see that W/M DOES lower the intake temps quite a bit.
Can you hear the pump when it kicks on. I know I have a different system, but when I hit about 4psi I hear the solenoid click and then right around 7psi I hear a slow pulse. When I get up above 12psi that pulse narrows and its a very progressive pulse. That's how I know mine finally is tuned to the correct PSI. Just was curious as to where the your Aquamist pump is, and if you can hear it. I Keep mine in the Boot.
That is generally because the car has a modified exhaust on it, if the system engages while I am in a particle throttle (like an on ramp) I can hear that a little bit.
My system is mounted behind me in the boot also, pump and tank are in the Howerton Eng / AquaMist metal mount/housing. Solenoid in under the bonnet.
Thanks, I was just curious.
I talked with Jeff about my situation. He thinks its typical for (especially towards redline) for the IAT's to go up especially running more boost. My IAT's drop about 10 deg or so up to 14 psi +/- but once I get into RPM and more PSI, the IAT's start to climb. Jeff suggested putting the jet closer to the IC. Where I have it placed now (at the bend behind the headlight) air might not have time to cool down before it hits the IAT sensor. Thats my next step.
We also talked about placing a small .3 jet before the turbo. Hes seen plenty of success with that as well....just end up eating a lot of Meth.
I moved the jet further down the pipe line. It's now located at the bottom of the hardpipe where it meets the cyclone pipe. IAT's are down 15deg! So, at redline, I am 5-8 above ambient. I'm very happy.
Edit- ha! Silicone pipe NOT cyclone.
Great! Were you able to stick your hand in there with a drill or did you have to take the whole hard pipe off?
Not sure this will help everyone but has helped my situation being I am pushing more (potentially hotter) air.
Glad to hear that method worked out. BTW, what did you use to plug the original TAP point?
The kit comes with two plugs for the sleeve you thread into the pipe. I used one of those plugs.
Thanks...
