Drivetrain Aquamist HFS Methanol Injection Systems
Old Aug 5, 2014 | 07:09 PM
  #251
Roxspin72's Avatar
Roxspin72
Originally Posted by nine5raptor
Just get a 1/8" NPT plug from the hardware store.
Which kit did you go with?
I am troubleshooting a devils own 2.5 bar universal now.
Sent from my Nexus using NAMotoring
I'm running a Snow Performance Stage II Kit, but it's just the Tank, Pump and Nozzle holder. All other hardware is from Devils Own. I would need the plug when I go to the Dealership for Service. Don't want to just throw it in their face that I'm running a Meth Kit...
Old Aug 5, 2014 | 08:44 PM
  #252
cerenkov's Avatar
cerenkov
I've been to the dealer twice. Haven't said anything.
Old Aug 5, 2014 | 10:22 PM
  #253
Roxspin72's Avatar
Roxspin72
That's good to know. Was it for warranty or service? But at least I know our dealership is a no hassle atmosphere👍
Old Aug 6, 2014 | 03:23 AM
  #254
cerenkov's Avatar
cerenkov
That's good to know. Was it for warranty or service? But at least I know our dealership is a no hassle atmosphere��
It was only for oil changes. I don't know what they would do if something was "wrong", but the Technicians have all been cool and I do tip them when I pickup the car.
Old Aug 8, 2014 | 12:02 PM
  #255
MarioKart's Avatar
MarioKart
Vendor
I'm considering putting my meth pump in a cool spot in the engine bay and leaving the tank in the back of the GP2. Any issues I should consider?
Old Aug 8, 2014 | 12:43 PM
  #256
cerenkov's Avatar
cerenkov
Ideally the pump should be located as close to and below the level of the tank. This will aid in the initial priming and also aid in maintaining the prime.
Most pumps are not weather proof (only resistant) so take that into consideration.
BTW, who did your ceramic coatings on your DP? I'm thinking about getting a high flow 100 cell cat and having it coated.
Old Aug 8, 2014 | 04:39 PM
  #257
wzabrouski's Avatar
wzabrouski
Originally Posted by CPap
Just installed this kit. Everything seems to be working properly. Right now, cleaning my windshield with only the purest water. I would like to set up fail safe being meth will be an integral component of the map (22.5 psi) I will be running. Anyone set this up yet? From what I see: 1. cut the wastegate wire from ecu and splice the brown and white wire from gray harness. 2. Calibrate flow bars on gauge 3. Calibrate wl and wh dials on gauge. 4. Set jumper in cel dr1 I think that's it. Sounds simple enough.. I guess. Any additional thoughts?
Can you post a pic of they the wastegate wire and brown wire splice looks like? I want to set up the failsafe but cannot picture this in my head.
Old Aug 8, 2014 | 05:07 PM
  #258
CPap's Avatar
CPap
I will take a pic tomorrow. Away from the mini tonight. Just make sure the brown wire goes to wastegate and the white goes to the ecu.
Old Aug 8, 2014 | 07:36 PM
  #259
wzabrouski's Avatar
wzabrouski
Just don't understand the "splicing". Your not tapping one to the other, correct?
Old Aug 9, 2014 | 05:34 AM
  #260
CPap's Avatar
CPap
You cut the wastegate wire in half. The portion of the wire going to the ecu gets the white wire from the aquamist gray plug and the the remaining going back to the wastegate gets hooked to the brown wire from the aquamist gray plug. So, now the aquamist controller completes the circuit.
Here's a pic before I wire tied and taped it. You can also use a posi tap to make the connection.
Attached Thumbnails Aquamist HFS Methanol Injection Systems-image-4242849368.jpg
Old Aug 9, 2014 | 05:55 AM
  #261
wzabrouski's Avatar
wzabrouski
Thanks. This helps a lot. So the white is the wastegate wire.
Old Aug 9, 2014 | 07:02 AM
  #262
CPap's Avatar
CPap
Yes it's the white wire. I would look at the diagram and count over to the correct pin-out.
Old Aug 9, 2014 | 11:59 AM
  #263
johntotah94's Avatar
johntotah94
Going to move my jet further down the pipe (Closer to the intercooler) so it has more time to cool down the intake before it hits the sensor. I originally was going to put the blanking plug to where the original hole was but now I am thinking of just running a twin nozzle set up since I will have 2 holes. Do you guys see any problems running 2 nozzles on the same pipe? I am on the stock turbo running 18-19psi so temps are something i really need to combat. I will give it a go since i will have 2 holes anyway. What do you guys think? The more meth the better? Lol
Old Aug 9, 2014 | 02:16 PM
  #264
wzabrouski's Avatar
wzabrouski
I would ask Jeff about the dual jets. I think others have thought about it and he talked them out of it.
Old Aug 14, 2014 | 01:34 PM
  #265
mp5999's Avatar
mp5999
No more e85 then ?
Just finished up my aquamist install . Might sound like a stupid question , but now that I'm running this system ( 80/20 mix btw) do I need not bother using my usual 2.5 gallons of e85 per tankful anymore ??? Didn't know if there would no longer be a benefit or if I should still run that mix regardless .
Thanks in advance for your answers
Old Aug 14, 2014 | 03:35 PM
  #266
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by mp5999
Just finished up my aquamist install . Might sound like a stupid question , but now that I'm running this system ( 80/20 mix btw) do I need not bother using my usual 2.5 gallons of e85 per tankful anymore ??? Didn't know if there would no longer be a benefit or if I should still run that mix regardless . Thanks in advance for your answers
More octane is always better for insurance reasons, and to not rely on just one system. If E85 is not a pain to get and your car is logging well, then I would keep using the 2.5 gallons. Is your meth turning on around 6-8 psi?
Old Aug 14, 2014 | 05:13 PM
  #267
cerenkov's Avatar
cerenkov
Since the methanol is port injected and unmetered, spraying it on top of an E85 mix will help with fuel trims. Ignoring any compatibility issues of ethanol and the fuel system, I would definitely run a mix of E85 if it was available to me but I have to drive 20 miles one way to get it.
Old Aug 14, 2014 | 06:28 PM
  #268
mp5999's Avatar
mp5999
Thanks !
Excellent , glad I asked as I assumed I'd not be using the e85 anymore but will for sure now . Luckily I can get both just down the street . Was kinda surprised , both are under $3 a gallon .
Old Aug 14, 2014 | 06:55 PM
  #269
MarioKart's Avatar
MarioKart
Vendor
Race gas would be ideal, but not at $9-13 a gallon. E85 is great, but only can be used at 30% or less. You are one of the lucky ones, that can get E85 so easy. Can't wait to get my lazy butt to install my meth kit
Old Aug 20, 2014 | 08:54 PM
  #270
wzabrouski's Avatar
wzabrouski
I have been running 100% meth and just ordered a 1.0mm jet as my tune requires 500cc of flow. I have a stupid question?? For those of you that are running the 80/20 mix, how are you measuring and mixing the meth and water.
Old Aug 21, 2014 | 10:19 AM
  #271
johntotah94
Let us know how the 1.0mm jet works out. I was thinking of doing 1 big single jet or dual small jets. Not sure
Old Aug 21, 2014 | 04:06 PM
  #272
redparchel's Avatar
redparchel
I had been doing it by weight on a scale. It was suggested over on the aquamist forums
http://www.aquamist.co.uk/vbulletin/
Old Aug 21, 2014 | 04:42 PM
  #273
wzabrouski's Avatar
wzabrouski
Sounds easier to stick with 100% meth.
Old Aug 21, 2014 | 04:53 PM
  #274
cerenkov's Avatar
cerenkov
sounds easier to stick with 100% meth.
+1
Old Aug 21, 2014 | 06:27 PM
  #275
Indimanic's Avatar
Indimanic
Is there anyone in the SF bay Area that installs these units?
