Drivetrain Operation Hot Air Intake
Old May 12, 2006 | 12:26 PM
  #476
polizei's Avatar
polizei
Sorry, I cannot read through 19 pages right now...is there any video's or sound clips of the HAI installed? I'm thinking this will be a nice cheap mod I can do!
Thanks Thameth!
-Cody
Old May 12, 2006 | 12:30 PM
  #477
CooperT's Avatar
CooperT
I read through all 19...
and I don't remember seeing any vids or audio of the HAI in action. Mine seems only slightly louder than stock. I can hear a little growl every now and then if I get on it quickly from a stop and a slight whine of the SC...
Old May 12, 2006 | 01:21 PM
  #478
Thameth's Avatar
Thameth
Thanks Thameth!
-Cody
Its really a difficult one to get. Its so inexpernsive that most people just try it, if they don't like it then you just put it back to stock....
Old May 15, 2006 | 07:05 AM
  #479
racoman's Avatar
racoman
HAI Whistle?
Does anyone know if the HAI will exhibit the same "whistle" as the CAI?
Old May 15, 2006 | 08:02 AM
  #480
Dr Obnxs's Avatar
Dr Obnxs
You bet!
All the CAIs are a bit different, but they all remove those funky dead-end passages on the original intake tracts before the air-box. Those are to cancle sounds at specific frequencies, but also screw with the airflow.
The whistle is from air in a part-open TB.
Matt
Old May 15, 2006 | 05:19 PM
  #481
obehave's Avatar
obehave
Matt
Wow...an error....I'm stunned
Most of the intake kits leave the original ducting from the front to the lower half of the air box.
The exceptions I can think of are the Typhoon and the AGS.
Old May 15, 2006 | 05:39 PM
  #482
Dr Obnxs's Avatar
Dr Obnxs
Ha!
the dead end passages are on the ducting from the box to the front of the car. It's removed by all the kits.... At least I thought it was. It sure should be! But I'm running the HAI, so what do I know......
Matt
Old May 15, 2006 | 06:17 PM
  #483
CooperT's Avatar
CooperT
Mine whistles a little...
I just noticed that mine seems to whistle slightly, but it's not obnoxious... It's mostly the supercharger letting me know it's working!
Old May 15, 2006 | 09:07 PM
  #484
obehave's Avatar
obehave
Matt
I've had/have in order:
BMP/ProMINI
Alta
HDI
That duct is still there.
I don't think it should be removed but replaced with something more efficient. It does a decent job of ducting air and I did some measurements years ago that showed it had a mild ram air effect.
It's one saving grace may have been to save you from water induction with the stock kit as well as some noise reduction.
I've tried to source some large diameter tubing to replace it with. Preferably something flexible like silicone. Don't want to use brake or dryer ducting since it looks cheesy.
Any ideas or sources would be appreciated.
Old May 15, 2006 | 09:53 PM
  #485
Dr Obnxs's Avatar
Dr Obnxs
I thought about this some more...
and you're right, it is still on many of the intakes. I guess that the whistle shows up because more of the air is coming from the cowl, not through this duct. The piece on my MDX has even more sever whatevers..... I was thinking of just cutting them off, putting something stiff over it to make a wall, and using that aluminum tape to hold the stuff in place.... Should smooth air-flow....
Matt
Old May 16, 2006 | 07:12 AM
  #486
obehave's Avatar
obehave
Matt
Great idea. Why didn't I think of that
Even easier, as an experiment I'm going to put the aluminum tape inside the tube since it's rigid enough to bridge those gaps. That'll be a good first step anyway. If I like it I'll move forward with something.
Old May 16, 2006 | 08:18 AM
  #487
Dr Obnxs's Avatar
Dr Obnxs
Give it a shot!
And let us all know what you find.
Matt
Old May 16, 2006 | 08:26 AM
  #488
ZAKdog's Avatar
ZAKdog
the whistle or Buzz?
I've mentioned this before but haven't done anything about it since it doesn't bother me that bad
but I have more of a "buzz" than a whistle just as the engine goes to 3k rpm. I spoke with several people and the conclusion is that it may be the throttle body vibrating with all that air coming through.
I've had it for 20K miles and have no complaints. You have to clean it often since it is directly exposed and can't be rotated to a clean side with the angled boot.
Old May 16, 2006 | 01:10 PM
  #489
obehave's Avatar
obehave
Matt
Will do. Unfortunately I'm looking at days of rain and no garage
Old May 16, 2006 | 06:23 PM
  #490
etalj's Avatar
etalj
I've heard that big closed off pipe at the bottom of the "ram" air pipe from the grill to the intake is there to get rid of a certain resonation. I don't mind resonation. How about sealing it off with some duct tape? Possible?
Old May 16, 2006 | 06:24 PM
  #491
Dr Obnxs's Avatar
Dr Obnxs
The problem isn't the ressonance.
It's the disturbance to air flow by having the holes in the tubes. So when Obehave is done mucking about, uh testing, we should know something....
Matt
Old May 16, 2006 | 07:26 PM
  #492
etalj's Avatar
etalj
Matt
The hole is in the tube to drain the water right?
But i'm not saying the problem is resonance, i'm saying that BMW put the little pipe there to stop it, didn't they?
Old May 16, 2006 | 08:33 PM
  #493
obehave's Avatar
obehave
It's some kind of acoustic horn but there is also a small drain hole in the bottom of the long vertical horn. It sure wouldn't drain any quantity of water in a hurry so can't see it being much help in a potential hydro lock situation.
Since I run an intake with the rear wall removed I think I'll be safe. If I end up with any water lying in the bottom of the old intake half I'll make decision from that point.
Tomorrow is a gym night so unless my old knees are giving me fits I won't be home until almost dark. Even then I'll probably be too beat to do much.
Old May 16, 2006 | 08:53 PM
  #494
etalj's Avatar
etalj
yeh i run an intake as well, and my rear wall is gone too. The acoustic horn looks like it would disrupt the ram air effect, the only problem is, how would i go about getting my hand inside the pipe? looks too small
Old May 16, 2006 | 09:24 PM
  #495
Dr Obnxs's Avatar
Dr Obnxs
That's why..
I was thinking of cutting it off....
Matt
Old May 17, 2006 | 01:19 AM
  #496
etalj's Avatar
etalj
Matt
:D much better
lemme know how it fares. BTW, what are you gonna seal it with? aluminium tape?
Maybe it'd be better to get someone to custom make a bigger bore, straighter pipe for me
Old May 17, 2006 | 06:51 AM
  #497
Dr Obnxs's Avatar
Dr Obnxs
I"m not gonna do squat on the Mini...
I'm already running the HAI....
I was going to do this for my MDX!
Matt
Old May 17, 2006 | 08:46 AM
  #498
obehave's Avatar
obehave
I'm a wimp. I'm going the non destructive route for now.
Old May 17, 2006 | 08:51 AM
  #499
PSYCMINI's Avatar
PSYCMINI
dam i cant use this setup, i am running that zex filter with my zex kit. I am wonder if i can squeeze the cone filter on the the T-body. Whats the size of the T-body anyway...2.75"?
Old May 17, 2006 | 10:34 AM
  #500
Dr Obnxs's Avatar
Dr Obnxs
It's metric...
so whatever it is, it's not 2.75 inches...
But to be more helpfull, I just went and measured one... it's 2.600"
Matt
