Drivetrain Operation Hot Air Intake
Old Jun 24, 2006 | 04:37 PM
  #551
polizei's Avatar
polizei
I wouldn't think so. It's just easier to use a breather filter. Just put it over the line and clamp it down. With the angled "nipple" you will need to drill? into or place it at the buttom of the filter. Overall, I think it would look "cleaner," but I personally like the look of the big filter with the "baby" breather filter, which are both K&N btw.
Personal taste is all, I'm sure.
-Cody
Old Jun 24, 2006 | 07:24 PM
  #552
obehave's Avatar
obehave
Originally Posted by Hammer
Another question - is there any performance difference in routing the vent line back into the K&N or giving it it's own filter?
One way you perform as a better polluter than the other
Old Jun 25, 2006 | 07:58 PM
  #553
Hammer's Avatar
Hammer
I'm assuming routing it back into the jumbo K&N is "cleaner" for the environment?
Old Jun 25, 2006 | 09:00 PM
  #554
studog's Avatar
studog
What size?
Hey all awesome thread. Ok I've read all 23 pages and I still
have some questions if you guys can help.
1. I have '06 MCSa, I've seen 3 filter sizes named.
What should I go with 1520, 1540, 1550?
2. What's the con of going with the chrome vs. rubber?
Heat?
3. Breather filter size?
4. In the 23 pages I might have seen this but can't find it.
Any pro/con with a K&N Typhoon style.
5. Curious. What about just cutting a hole in the stock box?
Many Thanks
Studog
Old Jun 26, 2006 | 04:03 AM
  #555
polizei's Avatar
polizei
Heat?
Many Thanks
Studog
1. 1550.
2. Chrome vs. Rubber? On what?
5. You could do that, but why? This is $35.
-Cody
Old Jun 26, 2006 | 04:56 AM
  #556
ignote's Avatar
ignote
Hole in stock box = colder air.
  #557
obehave's Avatar
obehave
Yes
Old Jun 26, 2006 | 05:27 AM
  #558
Johan's Avatar
Johan
Heat?
2-- I think your refering to the hose between the TB and the Filter...If so that leads me to
4-- I've been told that the metal tube attracts heat from the engine and warms the air, that it's a poor design, uhh...not sure what else but basically gets a bad vibe here on NAM. I use one and think it's just fine. I have my reasons why I went with a metal tube. Plus it has a CARB# unlike any other system (I heard alta is working on getting a CARB#) There's a dyno sheet in my gallery with the K&N system as my intake. Hope this helps! -- Johan
Old Jun 26, 2006 | 07:39 AM
  #559
studog's Avatar
studog
Chorme vs. Rubber (not the hose)
On the 1550 etc filters, the end caps come either in rubber or chrome.
All the posted picts show the filters with rubber caps. So I was wondering
if it was a heat issue or not.
Old Jun 26, 2006 | 11:17 AM
  #560
studog's Avatar
studog
Chrome vs. rubber
Nevermind the 1550 only comes in rubber.
Old Jun 26, 2006 | 11:31 AM
  #561
studog's Avatar
studog
[QUOTE=polizei]but I personally like the look of the big filter with the "baby" breather filter, which are both K&N btw.
Polizei,
Do you know the part number for the breather filter?
Sdog
Old Jun 26, 2006 | 12:02 PM
  #562
obehave's Avatar
obehave
Chrome vs. rubber
Get the RC-1540 http://www.knfilters.com/search/prod...x?Prod=RC-1540
Compared to the 1550 it's only 1" shorter and I doubt that will make a performance difference. Besides it gets you the chrome and you can get a matching chrome filter for the vent or it will do a better job of holding an inlet bung for the vent line.
Now here's an option
Old Jun 26, 2006 | 01:21 PM
  #563
studog's Avatar
studog
Thank you Sir.
Old Jun 26, 2006 | 01:26 PM
  #564
obehave's Avatar
obehave
Thank you Sir.
Let us know how it goes.
Have fun
Old Jun 26, 2006 | 01:37 PM
  #565
studog's Avatar
studog
Have fun
One question, do you know a part number for a breather filter?
I'm hoping to order today so I can do it this weekend.
Thanks again
Old Jun 26, 2006 | 02:53 PM
  #566
obehave's Avatar
obehave
Thanks again
This one should work
I'm pretty sure the fitting that goes into the intake tube is .5" OD. This unit has a flange ID of .563. Should work fine.... and it's chrome
A heads up though. These vent filters will get dirty/oil saturated fast when being used like this.
Old Jun 26, 2006 | 05:01 PM
  #567
Hammer's Avatar
Hammer
I am pretty sure (which means you are NOT allowed to blast me if I'm wrong!!!) someone posted somewhere in these 23 pages that the hose was ID 1/2" and OD 3/4".
Old Jun 26, 2006 | 05:28 PM
  #568
obehave's Avatar
obehave
Why, whatever do you mean.
The 3/4" OD is dead on. I went out a put a caliper on it and got 20mm.
Wanted to make sure I wasn't talking poo. ID is 13mm.
Thanks for confirming. I'd hate to have studog order something and it not fit.
Old Jun 27, 2006 | 06:40 AM
  #569
Hammer's Avatar
Hammer
I'm going to do the elbow back into the bottom of the K&N - probably this weekend. I'll try to calibrate the butt dyno before then.
Old Jun 28, 2006 | 01:18 PM
  #570
theroyalwe's Avatar
theroyalwe
ok so here I am... finally got my 1550 today and planning on picking up some torx drivers this weekend. I went on the ross-tech site to see if I could find something out as far as install instructions and it turns out they are about 2000 feet from my old apartment and 13 minutes from my work. small world!
so Andy, have any interest in messing with a bone stock '06? lol
not that I don't think I can figure this one out, but if you ever need another car to test something with I'm sure I can accomodate considering I'm in montgomeryville.
Old Jun 29, 2006 | 02:19 PM
  #571
theroyalwe's Avatar
theroyalwe
ok... I put it on today during lunch in about 10 minutes. I didn't have the breather filter yet so I just twisted the stock hose up and laid it in the airbox. I then ran to pep boys and grabbed a breather that I'll put on tonight at my parents' garage where all my tools are. Unfortunately I work in a congested area so I could only give it a little bit of a test on the way to wawa and pep boys. I'm looking forward to my trip home in 20 minutes though!
Old Jun 29, 2006 | 03:06 PM
  #572
Hammer's Avatar
Hammer
It's been twenty minutes.
I will be installing mine this weekend - with a little surprise for you all.
Old Jul 1, 2006 | 11:18 AM
  #573
creeker's Avatar
creeker
Just installed my HAI. took about 30 minutes excluding a drive to the hardware store to buy a hose clamp. Driving results: Nice! Not overly loud in the cockpit, even with the windows down and the sun roof open but my family said they could hear the whine as I was driving up the hill to our house!!
I opted to have the breather hose enter the bottom of the filter. Buoght this PVC elbow at Pep Boys for $3. Installed it by cutting a hole in the bottom of the filer with an exacto knife. I'm very please how it turned out!
I'd give this mod an A+ due to its low cost and added driving fun!
Old Jul 3, 2006 | 11:06 AM
  #574
Hammer's Avatar
Hammer
OK, I installed mine. Now for the little treat. I took video of a rev from 3k to redline with both the stock (K&N drop in filter) set up and the HAI set up. I also did a butt dyno run through 1st and 2nd gears, both with the stock and HAI setups. If anyone wants to host it, shoot me a PM. It's about 4.5 MB.
Old Jul 3, 2006 | 11:15 AM
  #575
theroyalwe's Avatar
theroyalwe
see this thread:
Hosting for NAM users
