Drivetrain My build. Teaser photos and updates
Old May 20, 2014 | 06:47 AM
  #301
thirdlobe's Avatar
thirdlobe
I do like the badge.
Old May 20, 2014 | 06:51 AM
  #302
daonlyillwiz's Avatar
daonlyillwiz
http://www.sector111.com/parts/perfo...n/racerack.cfm
Is that what you're referring to ?
Old May 20, 2014 | 07:51 AM
  #303
soccerbummer1104's Avatar
soccerbummer1104
that is the even faster than the already faster than stock rack.
haha
They have another that is 2.5 turns Lock to Lock that is ~$630 iirc.
Old May 20, 2014 | 11:21 AM
  #304
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Originally Posted by daonlyillwiz
That would be the one I would use.
It would add a little more stiffness to the steering, but probably still quite a bit less than a stock rack with no power.
Old May 20, 2014 | 01:13 PM
  #305
soccerbummer1104
on a side note, for anyone watching.
Anyone interested in buying a V-series Vipec PNP for the mini?
(looking to go to an i series if someone will buy the v series off of me)
i series comes with OBDII support, which while not required as my state has no emissions checks, would be nice should I be forced to move at some point.
looking to sell for $2000 shipped. (assuming I can still get the new one for the same price)
Have original box etc. Hole has been drilled in the side for the expansion cable. (which I will most likely be keeping)
PM me for more details!
Old May 20, 2014 | 04:09 PM
  #306
soccerbummer1104
so for today, no images of welds or anything else, but a good 'ole general update
Alternator pulley delayed. (parts from germany)
New ETA is the 30th (to ECS tuning before they ship to me)
But!
Shipped out turbo manifold, downpipe, turbine housing to Swaintech in Ithica, NY to be coated with white lightning!
(Wooohhooo!!)
CNC plates got put on a temporary hold while he does a rush job for a "better paying customer" (fine by me. cuts me a break)
Hopefully done by the end of the month.
aaaannnddd... I dropped a wad of cash off to the west coast and have an
OS geiken twin disk clutch and an os geiken LSD headed my way...
now to wait....
Old May 20, 2014 | 07:48 PM
  #307
BSTINS's Avatar
BSTINS
I'm envious of your os giken purchase.
Old May 20, 2014 | 08:39 PM
  #308
soccerbummer1104
not sure about the hardware itself, but if you are envious of the dent it caused in my bank account, I will gladly allow you to absorb it
Old May 22, 2014 | 06:06 AM
  #309
Herleman's Avatar
Herleman
...bank account? A Mini owner that has a bank account??? Never.
Old May 22, 2014 | 06:12 AM
  #310
Herleman's Avatar
Herleman
Dumb question. Does anyone out there have any idea how hard it might be to adapt one of the Lotus steering racks mentioned above to a Gen 1 Mini? I'm planning ahead. I have already replaced one power steering pump, anticipating another.
Old May 22, 2014 | 06:13 AM
  #311
daonlyillwiz
soccer, im actually looking for a vipec unit!
Shoot me a pm
Old May 23, 2014 | 06:57 AM
  #312
soccerbummer1104
May have gotten a little bit excited....
Clutch and LSD don't even arrive till next thursday...
Old May 23, 2014 | 06:58 AM
  #313
daonlyillwiz
Perfect time to replace the rear main seal
Old May 23, 2014 | 06:30 PM
  #314
DICKS GARAGE R53
Well the i-series ViPEC is under a GB right now over on the RMW site... $2300 Or something like that...
As for the Lotus rack, you would need to ask the guy who originally though of using one... Also on the other site...
Old May 24, 2014 | 11:07 AM
  #315
soccerbummer1104
well in preparation for the LSD I decided to clean some things up a little bit (outside of the transmission and the bell housing)
Things were quite filthy, but I got most of the gunk off.
However, to my surprise, the inside of the transmission was spotless!
only metal shavings were in fact on the magnet, and it wasnt that clogged up either!
not too bad for 135K miles!
(of beating the ever living crap out of it )
Old May 29, 2014 | 02:18 PM
  #316
soccerbummer1104
some rather heavy pieces of metal arrived today with "manufactured in japan" stickers on the side of them :3
Pictures later.
Old May 30, 2014 | 08:22 AM
  #317
soccerbummer1104
Old May 30, 2014 | 08:46 PM
  #318
DICKS GARAGE R53
Where are TF PIC's?
I want to see the new rims! :P
Old May 30, 2014 | 09:10 PM
  #319
soccerbummer1104
haha, no. the wheels are quite german. (BBS CV)
the OS geiken stuff is made in Japan :3
on a side note..
GOT DAMNIT WMW!
(replaced my clutch last)
looked at the pressure plate today and 2 of the pressure plate bolts already had their heads sheered off.
Just the splines though, so the shoulders were still holding the plate on.
Then two more broke when trying to remove them.
Only was able to get two out in tact.
Everything else I had to drill and use easy outs on... that took a while...
Old May 30, 2014 | 09:25 PM
  #320
cerenkov's Avatar
cerenkov
That sucks.
Old May 31, 2014 | 02:32 PM
  #321
soccerbummer1104
well after that fiasco last night, I got the twin disk clutch mounted this morning (fun fact, the OS geiken does not have the alignment mark on the flywheel so you just sort of put it up and rotate it around until you see all of the bolt holes line up.
Ended up torquing the flywheel bolts by locking the crank by putting a deep socket + breaker bar on the harmonic balancer and having it rest on the frame which kept the pulley from turning as I tightened the flywheel bolts)
Anywho.
Got the tranny on.
(what a mother FN BIT**!!!! wow. like really. no joke. ended up only being able to get the splines to engage just a little, but still had 3/4" left till the bell housing touched the engine block and I had to thread in bolts and tighten them one turn at a time going all the way around to pull the two together.)
after that was done I went through three cans of Gunk brand engine cleaner on the subframe and other parts that had been leaked on and accumulated dirt and grime, and now I have started work on a little something else.
if you know what this is, you should be able to guess what I am about to do.
(knowing the progression of this thread at least, I would hope you could put the two together)
Old Jun 2, 2014 | 08:21 AM
  #322
soccerbummer1104
thread started out so well.
haha
oh well, to pretty of a weekend here to do too much,
so here is my excuse (cruising on the lake with the pups)
(one of five guys, but this is the nose of our foster, Tyson)
anywho, on to what that scan was about!
Still no guesses
oh well.
Also got the ring gear on, tranny filled with some Motul, reassembled, and back on the car (what a mother fn PITA! had to use the bolts to slowly pull it on the last 0.4" )
but at least the clutch is pretty... who is all in favor of someone donating a saphire bell housing so that we can see our gears and clutch move/work?!
(aside from the stupid cost that would run and the weight it would add, it would be pretty cool i think...)
Old Jun 2, 2014 | 09:31 AM
  #323
Herleman's Avatar
Herleman
I know I've seen a piece like that one, but I can't bring it up from my muddled brain.
Are the central holes some sort of "venturi"? Perhaps something in the power steering pump?
Old Jun 2, 2014 | 09:41 AM
  #324
soccerbummer1104
nope, but it does deal with a petrolium based liquid
It is a adapter plate for the oil cooler. Instead of paying $500 for a front mount oil cooler setup, it will only cost me ~ $220-320 to make one myself.
Old Jun 3, 2014 | 03:42 PM
  #325
Herleman's Avatar
Herleman
Are you making the heat exchanger for the oil cooler too?
Why not do some more welding and make a full dry sump?
