Drivetrain Burger Motorsports (BMS) Tune(s)
As title says. Stock run was done about a month ago. Juice Box (12 o'clock setting) run a week ago. These are just the best runs done w/ my friends very stock '13 MCS. Times are limited by the run flat tires (lots of tire spin w/ JB+). 91oct gas. These times are similar to times posted by Terry earlier in these threads. Best runs shown where duplicated on other runs and all runs where done in exactly the same place. Bigger tires will give better results I'm sure. I am definitely going to get a JB+ for my car somewhere in the near future. Please post your time/jpeg to compare. It sure would be nice to get a time for MarioKarts GP! (By the way, don't do time tests w/ a passenger, only driver weight for time tests. Extra weight is a killer to the clock.)
Stock 6.58 w/ Juice Box 6.27
Timing. E85 leaned it out.
Had been running at 10 o'clock per Terry's JCW recommendation. Will crank over time evaluating data logs.
This would be my route in the future. I think there are a couple three people on here misting, so: yes you can and it does work to let you up the boost. BMS sells a kit on their site so they'd be a good source of info too. Pros and cons versus E85 i'd have to read/research.
Edit: the most obvious thing is the tune should be adaptive to meth so if you run out your engine won't spontaneously combust. The JB+ is a 'hard coded' setting that isn't adjustable on the fly. The JB4 hopefully will solve that problem soon
Wait, aren't you using meth, NewCooperFanatic?!
Stock 6.58
w/ Juice Box 6.27
Stock 6.58
w/ Juice Box 6.27
This would be my route in the future. I think there are a couple three people on here misting, so: yes you can and it does work to let you up the boost. BMS sells a kit on their site so they'd be a good source of info too. Pros and cons versus E85 i'd have to read/research. Edit: the most obvious thing is the tune should be adaptive to meth so if you run out your engine won't spontaneously combust. The JB+ is a 'hard coded' setting that isn't adjustable on the fly. The JB4 hopefully will solve that problem soon
Wait, aren't you using meth, NewCooperFanatic?!Sent from my iPhone using NAMotoring
Yes I am, but here's the kicker,
It's not advancing timing, and this is with the JB+ at the 3 o'clock position.
With my current settings I should easily max it out, but can't.
The kit is working properly, merged on to the freeway with 102 degree intake temps, one 3rd gear pull later it was 52 degrees. Ambient was 80 today.
So I'm a bit lost with this.
I've looked at the data in ScanXL and there is a lot of variance in scan times. So during the 0-60 run, the DashCommand app might be a little late picking up the start of the 0-60 or it might be a little late in picking up when you actually achieve 60 mph so you'll could be a few tenths off, which is significant. So there can be a lot of timing errors because the times are so short. You can kind of eliminate this by doing many many runs.
Now if you do 1/4 mile times the times are much longer so it diminishes this effect. The problem with 1/4 mile runs is finding a place to do them safely and without getting a big fat ticket - the terminal speeds are quite illegal.
That being said, we're not trying to do scientific research so no matter what kind of times your doing just make sure you're having fun and definitely report them.
FWIW The best I've done is 6.5 with JB+ on default. I want to know if anyone can get sub 6.0's.
Did you put in a full 32oz can?
I think everyone should just take a chance and get the JB+ and then upgrade to hopefully a jB4 later. I drive my car to redline maybe 100 times a day, beat the snot out of it. You will be so happy. YOLO!!!!
Sent from my iPhone Office
That's the thing, with the JB at the 3oclock position, the car is showing 0 timing, as if it's too much boost, therefore pulling timing. I was expecting the methanol(higher octane) to allow for the extra boost, therefore allowing the car to increase timing through the rev, but it's not doing that.
It certainly should with the IAT's I'm reading.
Just trying to figure out why this is the case.
Timing was good with E85, but not methanol?
Don't have a way of getting EGTs, unless a scan gauge can do so, but AFR is close to 11(methanol=rich....while ethanol=lean).
Edit: after quick interwebbing, are you running 100% meth or a 50/50 mix? Since you're rich you should go more towards 50/50 and/or spray less.
The nozzle has been moved, so the car now picks up the cooler air charge.
These cars are highly effective at adjusting the fuel trims to meth, it's pretty awesome. You can throw as much as you want and it always adjusts. Tons of guys running 100% meth.
Methanol actually has a bigger kick than E85, more to be gained with it. But that's not to say E85 is no good, it's good as well. It'll come down to what you tune to run...which we don't have yet lol.
It's just weird that the timing is constantly at zero with the current JB plus settings.
I have emailed Terry in the past. Said my kit might not be spraying right...but it is lol.
Was hoping to see if any other member was just using methanol and the JB+. Looks like most guys are opting for the E85, more convenient I guess. Or those octane boosters.
I believe the recommendation is to leave it alone (at 12o'clock).
i got a r60s and always use 93 to fill up, what is the most i can go on the jb+ on the settings? only mod on my car is the VIP cai.
it was designed to run on its stock setting with 93......if you try ramping it up, you are going to likely damage your motor.
