Drivetrain Burger Motorsports (BMS) Tune(s)
Old Dec 8, 2013 | 12:53 PM
  #1126
yesti's Avatar
yesti
Originally Posted by Eds not-so-red MINI
OK, then I'll be happy with just a little spinal indentation in the back of my seat. Just a little. And maybe an occasional chirp.
Hey anything helps . You got access to E85?
Old Dec 8, 2013 | 06:55 PM
  #1127
MarioKart's Avatar
MarioKart
Vendor
3 gallons of E85 and 10 gallons of 91 and I turn up the JB+ to 100%. Actually, it's always at 100% 😉😉
Sent from my iPhone Office
Old Dec 8, 2013 | 07:29 PM
  #1128
yesti's Avatar
yesti
Originally Posted by MarioKart
3 gallons of E85 and 10 gallons of 91 and I turn up the JB+ to 100%. Actually, it's always at 100% dde09dde09
Not you Mario, Ed :D.
Old Dec 9, 2013 | 05:42 AM
  #1129
Eds not-so-red MINI's Avatar
Eds not-so-red MINI
I don't think so..... but then I've never gone out of my way to look for it, either.
Old Dec 9, 2013 | 10:33 AM
  #1130
TeddyL's Avatar
TeddyL
I have the JB+ installed on my '13 JCW. I'm getting a CEL which I can clear with the CAN tool, but can't figure out how to actually read the code.
Any advice ?
Old Dec 10, 2013 | 09:13 AM
  #1131
Mcameron's Avatar
Mcameron
Any advice ?
you need an OBD2 code reader......you can buy them at any autoparts stores for ~$60-100......or you can use a scan gauge or a tablet running the Torq app.
or you can take it up to autozone and have them read the code for you ( i think they do this for free)
since you are running a JCW, did you turn the POT in the JB+ down a notch?
Old Dec 10, 2013 | 10:02 AM
  #1132
jomama's Avatar
jomama
Any advice ?
you can read it with the can tool, but you prob knew that already. check out this link:
http://www.n54tech.com/forums/showthread.php?t=20522
the same functions/readings apply to our N18s. the code reads out as hexidecimal: 0-9 and A-F.
Old Dec 10, 2013 | 12:23 PM
  #1133
TeddyL's Avatar
TeddyL
Thanks...yes I turned the pot down to 30% per Terry's recommendation. I tried to read the code with the CAN tool but was having difficulty...I was able to clear the code though.
Old Dec 10, 2013 | 11:36 PM
  #1134
KilmerPT's Avatar
KilmerPT
The JB+ has been good to me and my MINI a notch back, and today, I finally got my SG2 installed so I decided to try a new setting tonight and did a few pulls around the neighborhood.
JB+ @12 o'clock
Outside temp 35 deg F
3rd gear pull from 20-80mph
Boost max=16.0 per SG2
Per MINI Connected gauges
HP=211
Torque=199
I was losing traction each time I mashed the gas pedal and the steering wheel definitely likes to fight me a little from keeping straight.
I let off the gas after 5,500 rpms as I didn't want to go any faster on the street I was at and push my luck (Cops like to patrol here from time to time because people use this road to speed a lot of times at night lol).
I'm not really sure how accurate the gauges on MINI Connected are, but I was hoping I'd see higher numbers. My butt dyno tells me that there was a stronger pull at the new setting though. It was also kind of difficult watching the SG2 on the left of the tach, and the Nav screen on the right so I might have missed the peak numbers (kind of wishful thinking). I have seen up to 211 hp/206 tq even when I was @ 11 o'clock before I got my SG2, and on the way home from work saw 16.3 boost when the temperature was 56
Deg F.
The good news is no CEL lit up. I will probably keep it at this setting since I have not found any E85 gas stations unless I drive an hour away from home. I am considering getting a Cravenspeed flexpod and mounting the SG2 on the right of the tach so it's closer to the Nav screen and should be a little easier to keep track of all the gauges. And when I get the chance, I will mount my GoPro in the cabin and be able to watch all the gauges together working.
Old Dec 11, 2013 | 06:50 AM
  #1135
ChiliRedR56raleigh's Avatar
ChiliRedR56raleigh
Just ordered my JB+ for my 2011 MCS hatch. I'm hoping I love it as much as everyone else does!!
Old Dec 11, 2013 | 06:51 AM
  #1136
ChiliRedR56raleigh
Originally Posted by KilmerPT
The JB+ has been good to me and my MINI a notch back, and today, I finally got my SG2 installed so I decided to try a new setting tonight and did a few pulls around the neighborhood. JB+ @12 o'clock Outside temp 35 deg F 3rd gear pull from 20-80mph Boost max=16.0 per SG2 Per MINI Connected gauges HP=211 Torque=199 I was losing traction each time I mashed the gas pedal and the steering wheel definitely likes to fight me a little from keeping straight. I let off the gas after 5,500 rpms as I didn't want to go any faster on the street I was at and push my luck (Cops like to patrol here from time to time because people use this road to speed a lot of times at night lol). I'm not really sure how accurate the gauges on MINI Connected are, but I was hoping I'd see higher numbers. My butt dyno tells me that there was a stronger pull at the new setting though. It was also kind of difficult watching the SG2 on the left of the tach, and the Nav screen on the right so I might have missed the peak numbers (kind of wishful thinking). I have seen up to 211 hp/206 tq even when I was @ 11 o'clock before I got my SG2, and on the way home from work saw 16.3 boost when the temperature was 56 Deg F. The good news is no CEL lit up. I will probably keep it at this setting since I have not found any E85 gas stations unless I drive an hour away from home. I am considering getting a Cravenspeed flexpod and mounting the SG2 on the right of the tach so it's closer to the Nav screen and should be a little easier to keep track of all the gauges. And when I get the chance, I will mount my GoPro in the cabin and be able to watch all the gauges together working. Sent from my iPhone using NAMotoring
I'm pretty sure the Connected Display won't display over 211ish. Sent from my iPhone using NAMotoring
Old Dec 11, 2013 | 10:47 AM
  #1137
Terry @ BMS's Avatar
Terry @ BMS
JB+ @12 o'clock
HP=211
Torque=199
Deg F.
Any factory dash gauges should report close to OEM power figures, with minimal change from the JB+, because the DME is not aware its making extra horsepower.
Old Dec 11, 2013 | 11:07 AM
  #1138
KilmerPT's Avatar
KilmerPT
So you're saying any factory gauge will be inaccurate, Terry? I suppose only a dyno will get the true readings then.
Old Dec 11, 2013 | 11:36 AM
  #1139
NewCooperFanatic's Avatar
NewCooperFanatic
There's a disclosure about the driving entertainment app through the phone.....along the lines of, if you add any aftermarket parts that add power, the program will not display the gains as it has preset parameters.
Old Dec 11, 2013 | 12:00 PM
  #1140
KilmerPT's Avatar
KilmerPT
Ah, thanks for that info NCF! I will say though that before the JB+, I was unable to get above 200 hp readings on MINI Connected. It was mostly 192hp and one time 198hp for the short time after break-in period. Maybe I wasn't activating overboost correctly? Or the gauges tend to read low?
Old Dec 11, 2013 | 12:13 PM
  #1141
ChiliRedR56raleigh
Ah, thanks for that info NCF! I will say though that before the JB+, I was unable to get above 200 hp readings on MINI Connected. It was mostly 192hp and one time 198hp for the short time after break-in period. Maybe I wasn't activating overboost correctly? Or the gauges tend to read low? Sent from my iPhone using NAMotoring
Do you have a JCW or Cooper S?
Old Dec 11, 2013 | 12:18 PM
  #1142
KilmerPT's Avatar
KilmerPT
Originally Posted by ChiliRedR56raleigh
Do you have a JCW or Cooper S? Sent from my iPhone using NAMotoring
I have a JCW
Old Dec 11, 2013 | 12:21 PM
  #1143
ChaiLatte's Avatar
ChaiLatte
Oh, you will.
On a side note, I finally located an E85 station near-ish to me. How much E85 should/could I mix into my 91 to safely turn up the JB+ on an MCS?
Old Dec 11, 2013 | 12:40 PM
  #1144
cerenkov's Avatar
cerenkov
Originally Posted by ChaiLatte
Oh, you will. On a side note, I finally located an E85 station near-ish to me. How much E85 should/could I mix into my 91 to safely turn up the JB+ on an MCS?
MarioKart (a few post previously) is doing 10 gal regular and 3 gal E85. You want less than 30% ethanol.
Old Dec 11, 2013 | 12:44 PM
  #1145
ChaiLatte's Avatar
ChaiLatte
I noticed, but I thought he could turn his up to max because he has a modded GP.
I have a lowly stock MCS. Could I still run 30% Ethanol and turn it up to max? Or is something like 3 or 4 o'clock a wiser choice?
Old Dec 11, 2013 | 12:47 PM
  #1146
ClubmanRob's Avatar
ClubmanRob
Stupid question alert! How do we adjust the jb+? I didn't fiddle with it when I got it. I just popped it in.
And so a 30%e85 mix with 91 octane will allow for a higher bump in the jb+?
Thanks for any info.
Old Dec 11, 2013 | 12:49 PM
  #1147
cerenkov's Avatar
cerenkov
Originally Posted by ClubmanRob
Stupid question alert! How do we adjust the jb+? I didn't fiddle with it when I got it. I just popped it in. And so a 30%e85 mix with 91 octane will allow for a higher bump in the jb+? Thanks for any info.
Open the box there is a dial:
I have it set at 1 o'clock or the 6 position. The default is noon or 5.
Old Dec 11, 2013 | 12:52 PM
  #1148
ChaiLatte's Avatar
ChaiLatte
I have is set at 1 o'clock or the 6 position. The default is noon or 5.
Just a note ClubmanRob! Do NOT try twisting the actual capacitor thing-y. It's only the dial inside that moves.
  #1149
ClubmanRob's Avatar
ClubmanRob
Ok cool. Just open the module and adjust. Got it. Much appreciated.
Old Dec 11, 2013 | 12:53 PM
  #1150
cerenkov's Avatar
cerenkov
Exactly, use a flat head screwdriver inside the little arrow.
